From 2bab262840aa07da87ed111ccec285462f5e04bb Mon Sep 17 00:00:00 2001 From: Konrad Hinsen Date: Thu, 28 Mar 2019 11:25:08 +0100 Subject: [PATCH] =?UTF-8?q?Copie=20des=20mod=C3=A8les=20qu'on=20fournit=20?= =?UTF-8?q?pour=20module2/exo1?= MIME-Version: 1.0 Content-Type: text/plain; charset=UTF-8 Content-Transfer-Encoding: 8bit --- module2/exo1/toy_document_en.html | 188 +++++++++ module2/exo1/toy_document_fr.html | 188 +++++++++ module2/exo1/toy_document_orgmode_R_en.html | 369 +++++++++++++++++ module2/exo1/toy_document_orgmode_R_fr.html | 381 +++++++++++++++++ .../exo1/toy_document_orgmode_python_en.html | 383 +++++++++++++++++ .../exo1/toy_document_orgmode_python_fr.html | 387 ++++++++++++++++++ module2/exo1/toy_notebook_en.pdf | Bin 0 -> 59730 bytes module2/exo1/toy_notebook_fr.pdf | Bin 0 -> 59871 bytes 8 files changed, 1896 insertions(+) create mode 100644 module2/exo1/toy_document_en.html create mode 100644 module2/exo1/toy_document_fr.html create mode 100644 module2/exo1/toy_document_orgmode_R_en.html create mode 100644 module2/exo1/toy_document_orgmode_R_fr.html create mode 100644 module2/exo1/toy_document_orgmode_python_en.html create mode 100644 module2/exo1/toy_document_orgmode_python_fr.html create mode 100644 module2/exo1/toy_notebook_en.pdf create mode 100644 module2/exo1/toy_notebook_fr.pdf diff --git a/module2/exo1/toy_document_en.html b/module2/exo1/toy_document_en.html new file mode 100644 index 0000000..8c2f192 --- /dev/null +++ b/module2/exo1/toy_document_en.html @@ -0,0 +1,188 @@ + + + + + + + + + + + + + + +On the computation of pi + + + + + + + + + + + + + + + + + + + + + + + + + + + + +
Asking the maths library
My computer tells me that \(\pi\) is approximatively
pi
## [1] 3.141593
Buffon’s needle
Applying the method of Buffon’s needle, we get the approximation
set.seed(42)
+N = 100000
+x = runif(N)
+theta = pi/2*runif(N)
+2/(mean(x+sin(theta)>1))
## [1] 3.14327
Using a surface fraction argument
A method that is easier to understand and does not make use of the \(\sin\) function is based on the fact that if \(X\sim U(0,1)\) and \(Y\sim U(0,1)\), then \(P[X^2+Y^2\leq 1] = \pi/4\) (see “Monte Carlo method” on Wikipedia). The following code uses this approach:
set.seed(42)
+N = 1000
+df = data.frame(X = runif(N), Y = runif(N))
+df$Accept = (df$X**2 + df$Y**2 <=1)
+library(ggplot2)
+ggplot(df, aes(x=X,y=Y,color=Accept)) + geom_point(alpha=.2) + coord_fixed() + theme_bw()
It is therefore straightforward to obtain a (not really good) approximation to \(\pi\) by counting how many times, on average, \(X^2 + Y^2\) is smaller than 1 :
4*mean(df$Accept)
## [1] 3.156
+ + + + + + + + diff --git a/module2/exo1/toy_document_fr.html b/module2/exo1/toy_document_fr.html new file mode 100644 index 0000000..0924a68 --- /dev/null +++ b/module2/exo1/toy_document_fr.html @@ -0,0 +1,188 @@ + + + + + + + + + + + + + + +À propos du calcul de pi + + + + + + + + + + + + + + + + + + + + + + + + + + + + +
En demandant à la lib maths
Mon ordinateur m’indique que \(\pi\) vaut approximativement
pi
## [1] 3.141593
En utilisant la méthode des aiguilles de Buffon
Mais calculé avec la méthode des aiguilles de Buffon, on obtiendrait comme approximation :
set.seed(42)
+N = 100000
+x = runif(N)
## [1] 3.14327
Avec un argument “fréquentiel” de surface
Sinon, une méthode plus simple à comprendre et ne faisant pas intervenir d’appel à la fonction sinus se base sur le fait que si \(X\sim U(0,1)\) et \(Y\sim U(0,1)\) alors \(P[X^2+Y^2\leq 1] = \pi/4\) (voir méthode de Monte Carlo sur Wikipedia). Le code suivant illustre ce fait:
set.seed(42)
+N = 1000
+library(ggplot2)
Il est alors aisé d’obtenir une approximation (pas terrible) de \(\pi\) en comptant combien de fois, en moyenne, \(X^2 + Y^2\) est inférieur à 1:
4*mean(df$Accept)
## [1] 3.156
+ + + + + + + + diff --git a/module2/exo1/toy_document_orgmode_R_en.html b/module2/exo1/toy_document_orgmode_R_en.html new file mode 100644 index 0000000..6ad7f63 --- /dev/null +++ b/module2/exo1/toy_document_orgmode_R_en.html @@ -0,0 +1,369 @@ + + + + + + + +On the computation of pi + + + + + + + + + + + + + + +
1 Asking the maths library
+My computer tells me that \(\pi\) is approximatively +
pi
+[1] 3.141593
2 Buffon's needle
+Applying the method of Buffon's needle, we get the approximation +
set.seed(42)
+N = 100000
+x = runif(N)
+[1] 3.14327
3 Using a surface fraction argument
+A method that is easier to understand and does not make use of the \(\sin\) function is based on the fact that if \(X\sim U(0,1)\) and \(Y\sim U(0,1)\), then \(P[X^2+Y^2\leq 1] = \pi/4\) (see "Monte Carlo method" on Wikipedia). The following code uses this approach: +
set.seed(42)
+N = 1000
+library(ggplot2)
figure_pi_mc1.png +
+It is then straightforward to obtain a (not really good) approximation to \(\pi\) by counting how many times, on average, \(X^2 + Y^2\) is smaller than 1: +
4*mean(df$Accept)
+[1] 3.156
Author: Konrad Hinsen
Created: 2019-03-28 Thu 11:13
Validate
+ + diff --git a/module2/exo1/toy_document_orgmode_R_fr.html b/module2/exo1/toy_document_orgmode_R_fr.html new file mode 100644 index 0000000..5b2a25b --- /dev/null +++ b/module2/exo1/toy_document_orgmode_R_fr.html @@ -0,0 +1,381 @@ + + + + + + + +À propos du calcul de \(\pi\) + + + + + + + + + + + + + + + +
1 En demandant à la lib maths
+Mon ordinateur m'indique que \(\pi\) vaut approximativement +
pi
+[1] 3.141593
2 En utilisant la méthode des aiguilles de Buffon
+Mais calculé avec la méthode des aiguilles de Buffon, on obtiendrait +comme approximation : +
set.seed(42)
+N = 100000
+x = runif(N)
+[1] 3.14327
3 Avec un argument "fréquentiel" de surface
+Sinon, une méthode plus simple à comprendre et ne faisant pas +intervenir d'appel à la fonction sinus se base sur le fait que si \(X\sim +U(0,1)\) et \(Y\sim U(0,1)\) alors \(P[X^2+Y^2\leq 1] = \pi/4\) (voir méthode de +Monte Carlo sur Wikipedia). Le code suivant illustre ce fait : +
set.seed(42)
+N = 1000
+library(ggplot2)
figure_pi_mc1.png +
+Il est alors aisé d'obtenir une approximation (pas terrible) de \(\pi\) en +comptant combien de fois, en moyenne, \(X^2 + Y^2\) est inférieur à 1 : +
4*mean(df$Accept)
+[1] 3.156
Auteur: Arnaud Legrand
Created: 2018-09-19 mer. 21:51
Validate
+ + diff --git a/module2/exo1/toy_document_orgmode_python_en.html b/module2/exo1/toy_document_orgmode_python_en.html new file mode 100644 index 0000000..4eb6e9b --- /dev/null +++ b/module2/exo1/toy_document_orgmode_python_en.html @@ -0,0 +1,383 @@ + + + + + + + +On the computation of pi + + + + + + + + + + + + + + +
1 Asking the math library
from math import *
+pi
+3.141592653589793
2 * Buffon's needle
import numpy as np
+np.random.seed(seed=42)
+N = 10000
+x = np.random.uniform(size=N, low=0, high=1)
+theta = np.random.uniform(size=N, low=0, high=pi/2)
+2/(sum((x+np.sin(theta))>1)/N)
+3.12891113892
import matplotlib.pyplot as plt
+N = 1000
+y = np.random.uniform(size=N, low=0, high=1)
+accept = (x*x+y*y) <= 1
+reject = np.logical_not(accept)
+fig, ax = plt.subplots(1)
+ax.scatter(x[accept], y[accept], c='b', alpha=0.2, edgecolor=None)
+ax.scatter(x[reject], y[reject], c='r', alpha=0.2, edgecolor=None)
+ax.set_aspect('equal')
+plt.savefig(matplot_lib_filename)
+print(matplot_lib_filename)
figure_pi_mc2.png +
4*np.mean(accept)
+3.1120000000000001
Validate
+ + diff --git a/module2/exo1/toy_document_orgmode_python_fr.html b/module2/exo1/toy_document_orgmode_python_fr.html new file mode 100644 index 0000000..a6c3ff6 --- /dev/null +++ b/module2/exo1/toy_document_orgmode_python_fr.html @@ -0,0 +1,387 @@ + + + + + + + +À propos du calcul de \(\pi\) + + + + + + + + + + + + + + +
+Mon ordinateur m'indique que \(\pi\) vaut approximativement: +
from math import *
+pi
+3.141592653589793
import numpy as np
+N = 10000
+3.12891113892
+N = 1000
figure_pi_mc2.png +
4*np.mean(accept)
+3.1120000000000001
Auteur: Konrad Hinsen
Created: 2019-03-28 Thu 11:06
Validate
+ + diff --git a/module2/exo1/toy_notebook_en.pdf b/module2/exo1/toy_notebook_en.pdf new file mode 100644 index 0000000000000000000000000000000000000000..f84d42739e9c324fa861fc7a19631734566ec6f0 GIT binary patch literal 59730 zcmb4q19TWC!oL-mGO8zcGULk!$b;l7?=n{l2FcQYNU_G8nsV z3mc~?%nb7GM+Z4WVw41D``gQ8ROe!Xv@FH&Ko9@7O)qzI_lLE$jI|kduA-~>Da43R z*N3_sKM!G_cfl-HaUK>@w`J*Ig-w^+5`sw?C00lvake-c3ObQgxFjvj| z^$N(a=K{0J8qrF+v7Nw+gF895UY*ZGBmN08l5mF=SM`DAHj-)B$ic37;)F;=H#y+h;`(k$hROfs11VLURWJbP=q4WQQdn#gRgW;pXr#^^5%Ba< zRl0J?YAF-a@oQAUt%PiGjcVQ7z?T2Yun}@kiyM0g`>_+sp*$n)|`;DX-V{im5@aAscXPLJaAh_E9 ztxy$#QP|#Nrsz-5^FjtUTJj+7R=QFs|JrwZ4?ma{Cbl@uiVbH7tFK^qc-s=>D?ewm zm6lW1sh{B!pF{++$rGZLT};z0colx5?qXvz1#q1jA9P-0EyO{CENXi&6l?>_~5r`_O^Dwk3+-*(+5>&)`7KSC$dD+pJxb!N|!Vl&oD);@aMVC4H=rnKp)w z6<&P@mR?oF&t=p<+H+XtHSS=Ad@}jJ_YbGWj3Sf#Af`p7{RMGXwNs}-UXR-NN67yRs{cEkcjkw@*~y(Nl4BWDxWTKZiw zhJ70E%;=hD&0~N z(oc8XNE~!?z>%Z<6nL*a92p+4D+_!NXhH+tcU;1-;RI^L4&Juv&y-F2(FLs;Jf9}; zC!jJ#oxz>8PjO8K_{JoEHsK(6qbCtrn@H-125-klbdct$1|W~V^LfD@RNo7E@w7rE zz3(|?9h${|BZ1ZQs5#TpP}@~hTq}6VqKY_E?eK8b$6oRn_5FE)LTM_zbo64RRvck% zsSlZLcSDQxJ>p8K3Sv{mg7>?KD=ZGegQ2&@7En4L(PVj4fDd5x!OB}KTKhyd?MaPE zUixz*SiE~$N|G5@aAsML2ny<&!dPcl*eLW`mX;%XpW6I7NFPb_yD0xFdV;`9DYmf|TQ(Xacb}kI6icue+dvbt?`&}Jo?iPZ7Q9YPm|0}}pc3Sih92GP-lpW> z=PTZzm*8&U!As`BVa0(n*+e~#-=9@y5?ZgclVEhD>+iAe(ks6BOG!WvF;p`>dQV(W z;B(;JFbudCbBr@S+EVn_D&fl$(OSMOL>%j7eMW)gFPR-_?3~z`ZL=&K3rWsv?O%)( zui8j+5O!9+bbZ#fVTgq>v~JzGNFcbBAHhJ6;g;2QLihbNkP1~WV@%Xu+;Njx(0RcV z^Wp*d)sfVQ{>AC>cLPN-3v2#xptZuIE?jwaF`8Zp) zW`$s}F;-?Q1-gn**lr2~l|NZpe9)L-ac#3wI^~uBV!U6&Lc)@9AOq0Ui|?*OX~PUr z_t&O`A92is*PyqXg)uFpc#@M$0Z(wE`;30;oL*VFtI3$t-y48CWh3QXMOME1a!Nvv zCT6)8A*`hIj~LP-xju3IYN#F!BEKFEd=c`Am{I?y4bHbgyL9;_zi2x`#NW`I1xI5Vg1k?1$C?E@-#7A`EX&wRMvkxC`RUH;I_lC27xbO!7^~0VVo2S6=f;my2)U` zPsp!@W-k9;4IL;G&s5U9_>OV%Y|aIU+fhX}hoImBBOq=1VjDPAY8+yenY{)Wm!E_l z#6F&cma+fN)mA*?$t6-2vikS+Z|G!gtwu00q9JIR3te)5ulxJxA-_*K@$Yukb_#bh z%>FRco07`#X7;B4P7MB*{-F}Ay#K)|RJ|O{m^BrRt<6kanN{43UH^IhYG-6&#;jpw z`VY0>D}#2EKJeMsu9Y!R9qZX*2^|8XFBpMBg`; zdoat15D`sE)L=C=>Z+R;FA7c`NXe^f(v_9ci+)II!kBBi@>SHUk$f}cnM!KNrevVD z647e;eEf74f4*j6fmjvGfN%)RFr) zyS0(KX$)O+&md1;Z^hbMM5t`IcS^%7ajvAO_SC*7-H^b_9H2B0KTY*NO}uzF z=Z-T+^;Y+v3ux0_7y$DtK^OgD6%)%=k`IucXF(_=LcUM`Cgr~_+$K4=t@>=3tf*0^ zt?GoAT%Q-T+Q%=wRjJNA)$i_*S-r6-mb|Do(=G{ml}&bj#Si$^tl1o&U7B*h+|D@i(=Eq;?1|!z4;x|UOHhpX@!G?O?+KZux z9%WuPKV5v@@tOC*68)nGWN7zmMFuY2m5!d8MEWH{GCEtowYAHbWYqo z5*91b20u4zbNBzdT;}M2%Tj+W7QsA+bb}Kh@!8Tq_NQ?Wk|OiZ(UAU#&zXu#FYj^z z;+VoDx^wt8-qZ%DbwXKQ@S*IA8;ROwb0XWNamt5OBb5pVpH;Npb-vBS4tm~`h1$R@ z6Iz}8srnRhk(lx&ixweG>}fvDf7`h#wzp?}gutz1cXu9_{a*%<9HXi?*vE+V`~Nf^ zEZBa2v))RM_}!Hi(@q8??DcU~(sPkN7*Xs6w~wRkhT=0}IDkbpIr-Pl%5$qbAeY5a zgKWI^J5Njb6d~pI&&0ZlsZU{?9nqXeBh7%m6|B(qn!9GvsTx0Iy=jdxd(HT_Bl5;T74U-P=)z!z(8ODsG}FgYT9vs4wRdXX zF#PXFW@-Sq400!CoVp)LbBEd_lwAY2i!<9lO_{P0v={v8R=2wsT{J~ry7)hx{eQ=r zp%)CS?tP~JjOc7E|AFZL38BABi!rOn8@bq!{tNiOGyi{JKKwtJ|6hRj|0}w)|JUgL z*R1_N!8<8C8w(59|Ag;3Hg$SxIiOZn$b$^zvaV2(kR2>y_)rVfl6tEY|Cl(tjT9Ai zd5xL7yU}O9rT6Au_chK1HSwQ+Ej1Osg~)Yy8i{QRRERNh3Xy!TNC62iI`CVa=kvG5 zhKIc~my7mx?(4G-x6@6RM}42_&zIhn&+A+dpkHgIUgK%&jW!!Z|5>Kd=UJv6`&ph| zqfPjGqmBDiU4Z*k4c@~{%^K(6#~Np+`KoZI`3mBz#md>bNo~n3_gz5*afkE4Z@fs0 z6>$B>O&3K)jzIxq;j)0oEsq&4Lw82deePqIMd|b8f9~U7{rnF?Pg{3S?j9qGns^v! z2+JCW#@3o~jQ^^1ct0<@l*+g?!K^Wnra_&pRISMhF>Vad`*pZ5vk2VsS1X#HKWy0V zyr`(@WO_fm_4J7G_iVi+VSiq#tq@24+I!@tKD_P$L38*K2UZ;A)#m!Oyc7v%rb4C*Jw$Nuyc`!%6M)rqy}RE( z?Jd#Qs=^Sb_mQbQbI^91Wa`;pjYnzJ88}%kp0p zqr{cdJmh|dTZ#gSEfL)rfM@^biIa63j3TJ}0+WZ!MU{ml5e9XB5{-Iy*mQ(cxCcU4 zrTZ)(g|X1XDg~-0`IrW1_U|B2*Q?KBc>`xJeGD>Z7+X~}bQAL-eFJr3Mxfd>!98vu zh(#tR?Y<4T{2|19)Abdq?h3bAD5XFYzALzM=>vm<1CvEQX+_cP*`He3d2vKCY}k)o zG4KI8quwV| zMPa3PZJ*Nvn1gB#^uy3p5?Q56oq2r*(TY-A9b}ckD-!`031#<(q{G$=ORNaUqpn`1!t8MqE^;DyW?eh~JGqLO4 zjl1fE0b*$bMt<7H$fFXjNCfe!L!H-Bg*#_phG^B9;Bnl~@J*w^bi$^gz&aWRu6hIT zz|+PgrvtZ0T1)g}-2gxQp#Cq_RDxHcP-snu1~ht+bN8nU+yc|SqyQxtcLXXh74vOL z0fq>KPAH`^HdYMPwE<$9ZJvZWuetM9YW+Ss+&o4lyut1FU7UrqIOsPcx2pFfS?itg zB)kCc0hcd+Lh|*r`$5oEFj_DJBDb~}pk1yr(1L<2KWx5wt-jOQ(TeSh)qTB5CC)|l zgCDmj;!~hMOttRy*v#^oi%4^6wDKV{G_xp`JI+n;lAgO3I;#lY2!!*M0L{jtrQ|nU zEX0`BZC@8MdG}~hP!)^zq2IwzxQNw?9pC!#Lo5{#$vny2&?#v(|K;W|YZ3zG++2a- z>Xid30uMOn5dI@OEII((aQ}7&cyKO&(D8XJZFQcXAEO?Y@Z1NhX_bsNL;%4+K8y*3 z$nO1o<)D(n;YR|3uSe3FPc&NODwX9pMK&XUU7pMxyNBrrqvP0&x77#pzk5U=Yg`wu|iiL9If2bNXAz>Z91hzC>#ni zWIjB5=y798gLJYtokbYl1X%{f7(`uLJ?hM?-w=esU>UfkgU*JC$0l{|BMb_0H*g{k zx~L(59jv}4V3S==08S3jQ5+wm21QJ~&|@=k8R}GQsGkkhY0LxDz;aOD%D!LUas6ks zd~GQ{UbZ$&U>Cun130e0k5#5q0+Mg&qu1PXM~&pR4EQ;tDpnJNUXNk}D~>bG{v837HJh z0z>@~u8>T+172-*g1Q7KAG**Mz;>PIacID`HOodwA2>Szh7J;P647W!rKl&s z-0OZUr8IC`dJB_0$5Xb4`U;>N;$eX_0^oEZinPc3{%C@9MTO3sxRMF;uWojoCT`hH zkQ^&@$ICYz{FekTTLo>9?rii6JxzXl)WO1;YUOv%uLE zYXrvkSV9x=q+69EH&TB%Mc0L=$0-B%2T1WIQ?kphXwzkWw!a9C|9 zA*#CO(KTQVn_f@xnS@Ve7Fqj};$Pa2-SGWz#6mwd*kkuc^H=Wf=SM5RAbM(w--o)Aca_Ge@Y?6z7kX@WwEb+3qXS zYp_h^&Q<@EX4q_0S51I$m%t~F`A*!+q{ z%07e-Fn6FpM@^+LBFH(nDsqQ4PIoX$JU7@ga69-a+|x;+_z1&z`0C=6*DkmBmm#(_ zH#I3kQi5Xel3uB8^~bN_qr7IC3;Y>J-c|rf4Qm@(T@WJT%c4nEaqxKgRRp z2D3kk*b{eB#Jr!Wh5;g%dnAhZaropk{X#-7mPC`_n<*WJPyxZspszDtW-B`oI;d}P zqFnZye@q=%-*6Lgu2A&hI(NbJM<_%rBbhAcGTh7Huq`O+a#PMWZM1TVOIy6$UC z?E4d>xw~Ut>)Nx#scU7wls{*Vg!6_ zMTtr2Q%O`jl*(rpkdzFV=_rOOl*){q%LLy>veo>Kg0ICHl?0;qCG}226WTER0V`?y z;caLp>f(g*@)6Den=zheg?;Jicl|{m^md+$rP3}&o(wLW_1_Rr8iib+P$)s6c?h~C z87O95;?v8lavlLEb-wEk!~aBOD;eTvf3G;Q*ZZ|a-pfJI>&J`6rNK)U4)Bwoz~6sB z+HHLQ1wwOddEnK^tvZpt&eW0!Q3(vxI+Vt5iU;-*&Ur)q=)#T(Gd)i^N;Y&|-V` zB)M0wUipNE%*gxANk=36L{cyDK?e3D!?=qLkP1N5tudNI+@_32@=U@q&EJP@emUw(Cbtp zM4*|$n-U?Ip(o!ngvA|=GuUJe!3nU)gQyXB)sW7+dg!-ue(mlInTMWF-a8(iNjve5 zI>W2~_4S%O=fXueG9xD9V6Tm^C>^92zI$NaXUbaagZglE0&rxJ6J88bUqAj)al+R} z*J;xaL=0HB4oO?942O=f_V1F{@`PS8=c@9HMHa*CUDO+52gQo zA&=@T!l9ld=*c_?Hd%)*vkI8$VNU z8bjdwg+lxqz90lwnDBVv+-y*q!FC!3|4{guagj6YNNAH`KFNpU zx~Qg4P4Kp#$F79_1#?ve%ZxT>N{#P9fi)Jh&;8O}(XYH`+RIQ(29hus(Toj5`QcL9 zKn^&$fl!LS_SFj{5~_zhjR7$?w`8>sKmvDvPTIz55HuqURIrsKq=`=#>q{|Y@xD&C zZXA(Y3~c-SNWpPG_&E;M<>4t1^u~W#+(rcp=mti*=1)10LKv<&r6N9%1o#q}Qr=C{ z?<*41+RA`=9_9Q<4VLUMJ2?Q{W>}!F3aW!2fG!L(X@|48sqsF5pFVu5Qt=1Gi?*;y z<>6k?Z#wU8de6T@(1p{vRajq=zSaR2BbP zp_vlC+g_C2Mh;hkCg9TP5pL3f3ic7MIV*K?xqOG|nUCqHzcgAsnJLgXNuT^rmrpJ~ zYF^GPUg0s$oqp-n#hAp)lX8Aedt&=7Gd$M~&ZAI(rHH6ZaO4E|i#79Klo5$e>8Sg4`M5qJECmLJgBcARC z`M8Kdp%I|KXde}-gG0PJbkOe9ph*B=6F5U^5F!BV5ms7YeN*OC0`snRU_$nWm8isEZn%v~-*pEkZ;7<(lev z{w#vgM=IjK2Ee+LqXuP^JPgug8+f{*K=Ckrn+n)87b}=KR7GIKL~2Q^I65fCIozkM zap}sE_()@k6r*GrDINaS{2`KHl^p~kSn|HN)dB}*9gp=U*jEcx%`QGqx_T*nwRlru z=y4MZ(}R-eTPgiw#6oL3IO_|7k_E)eOITw`LyO`rV;{AB>B)S^?$I03;5J0?lEpMz zL-736vY-rwHijk-3}X=zx~1$3{RLocL1EbMb?C`ZuYQ~Pxeapt>#AuKYpexi&T*8U zec>ae2EfAOsZVwSgj_&ei^NR&qmK>l&>V9p4=B@DQ{&XXP)J28cjkW93XFk~{|Ph_ z7<2`C?)@}i+;~{^cMy8t(_{>iW}ypUX*i( z8?x)LS)*QT?9(pljHWYe=R#TdZewl!&V9~1sNtF5(+8LZ7aeLkIvder=pvCRym{Xt zp^}JT9ds3b|D*aHsb%=vj-Mf2f`*^Pk~hAy>2F>l4>1`>K8*eL{yJGXgbdmQNRkBT zw<`l;usXxu;1p5BpN*-h{;+$NZ#V|t;uq>cBO-ODHL^O0DpLFh?7aoqV;aQgfpZ!r zxuXOQZ)fA&J)fY6fQFCzyqCV6W_w8nF<>W0Wk#>?7BbJBPl-`Exh0nm(MNGan z5%9A3i)xNLlZo64cNGJ+sc-$*^N{@r$b{5_pzU z&}N%gV=7J@VzZx(EMshGoYY`Iiawc$W{BY!+jLm+$6wVfUUaES1lj-+?WWLf13eUv z5L1ji82lMv*6;(nTI@!oFs4>#*hMV?-ZumhF(RDc=6T&_A$yHVaGgAkK|HzVv_@k) z;5c5N=Rj~G)!#60C6{-9F^wc-uGZ6ZEwfSIhieM==0MsZutOiJ5V6j-mhmEK%+vuaAAfa~Z^Q~(4xz9PVL`1emWU9-~zoDb@#N=vL=vk5XY@k!nOBeX^bT6^& zWb-ySC|g>`D!TCZO^}Ap_wNe|2VB5SnvqQEGS_x*zCn8RD$kcO&RRXC?l*NJ7(;kZ zx*AI7z8|8eG}*8UI0|KDKLEK#Qqp#X)^F(~Qsz@{u-|&e>+@*)*}WAwI=-c0F{#q; zk9#UTW(iG|Lklr5opGZObg?#I@#MQj>XVz8zKD;J*|YVU=I0ABd`Fa>bjwrF!L%CG z=@UDIp1L}CxreL0qha&nAhVG(0uwVmzD0s2F<6=jNb2k@al$pO!D{h3zkE z_>#IFNjY}-bjc?$rstNL3yMzxEByCQg4@dfO`$f&oRa>aO z*>-O`;@vi4Z9|>VL`4-UBG4n)QAC7pg*n3}gx-aq6T+EUCsoP71C{@22&4H6%$)xb z|5w*Q6FFkr=Q9hBuS!;K_jeI=8O(j@XF?bd_sTnBtpSfa2QU|}FUllqz2<*)(rinu z0(bm;=P!{kwZn$-ueQ+FPwoAA8eNsRCm=vmc7N7h;ZA3M_P7^MeFg)^(0Q|{GEU0X zjM)O&mdLU|9ylEK-e0^q=K&;|DdJ>{tJd1hAJ-LixPW z@a}qS858MUhuip9crkX+6gTxU0@*bz$KcRvgQIPq;Bz=X=R>{@v_#8k;|aQSb-}k` zRRkU0p<(`|sMZ9RC3UPnno;aBVHx6#FYT%P{{^b5~mNgQBPdq8oon1WGBpPC*7lBrIi(i zia2jmKE^j%e(>-ES`5K2ih|azEAC@{pcu9l%gj(Qlm#^U1n5ar+r!v&qg9{fgaa2` zI9tLtum_)dC%&(vYT*bg)xEK1*h(@KvYgJ{epgW*GupTN(Mw-#@OR_OuUIC(YuI3Z z+$X3tL?_V+TIhrE+-E#Gd$maX*tU& zF6>PQ!hDPW0X+L~;3Bt`2Y7;MB|>TTOUIapY%j3ozt;S*eM);!hBEtZIKg+KG;>8sE&x^-+>@%} z+qv7y5}4*PlYTcJQJhGWd1e2qrf^<{Fn|AhnUti#=<|Z_VJ)K-4m(%mJfE3};`DIp zt(hZgWrNge9?26DAcPs4@YgJ>2q`KA02?0N6xtIH!>TB|6`rl{sN}Ls#pBL-I#)8V z*-;bv?e16d?(e#@(jW^creW#~gZ#5&``Yvgh!E zfmf?0jO0e@z@w|p5dC9bSI>(IYaECgLw|te+KTs;#}wzEl9#H*fC|O56#{Fz! zM{&JxH_Y1stAk7aFx{^XFdDs{@A-qo{xjF~!q;mYc|qN3yT<5pk$8FT+Am#RF5Z5` z>ElX$TO!Djp+Cq7U1oB2%1)OlR}YGTSIP17TuNYi06SfJFq? zvwAl)%s}6d=X<*|oYea5$VBBIQv*K@11hmKnwt|OUfoPnL$t$|=2Uzd$2D?au1{YH zy&dm&LJXwiz4w|=&iyb-a#$+hJd^3f(C+rJScfP89o4ZSHf|~*^#!)Xn17h#`(`M6@!elRrFGa=WPdpPd#hdA|JVEQ54n0S7KI zA&TJD-j^^h9bB&E7w$S#!cJi^;_{|oY$-Ye!i8*E*cC->6Zx^>qQYPrm)yvuB!8VS zG1iD^0dGfaE_n|YB^dQm)#HD~JoabgdX+LM z{LW*zCnqTvFRD7VSxq)0QO2&9%`BPBV2USzM8K+7n~i_|790~$FoWrii@}Z>CT$3? zh1(U=qkrL>W}LPA+S{#D_e{8TG~b{RxUmxPGgzk};<#*FkF{?h2KfoL3t9kBK^KZE z^Vh=;f?(zzuEje)?W}vBEf^NK8V@O6_B0`?J;Q-~9#<@Nuw`Rq#13?C&KfaVz>fS$xe*lq{4f?5^_CSe z>0*NkXFQuRM;IsbZLawJ67UXpGn&)9ThqGI)$v(_zn*$PUX@A)AIZt$koBQW1Y5QA zX&uZg12-aG9!clQX}=dS6ApRv4R)l|4;R{(R!&|vFm6hAUlOe2irMmEy0Uz=WWAzLJoqZJ&&uiXN!ES%PEr=f zXC!SZQMpvezKVZJO4EWI8oh7)bxdm&E-RE4x|VHy4GlNe2S7g%L<@cmLtM5OcPDjQ zMZ1K3$ZdX=1+1#}abKLLs^hSQsGMd8qZ)LOqAz-T*q4C;vj?!8a`r&9c~KbLsqAq( zO7W!A#RkzIU=F`!#^{dYeaZIy8-OF1ocTjVLe%PSX9JmNzh>>jYL1KdI#H?f)xPSf z%js3d6tZ!*?{?+QdLmW&!tekW%PjwyQi4kauuB|GfWF@00!!Ecjw1d`P zCcOZd6;W49;#oXm#J{mx=*pukctbUZ+1D)ALA^Oh+fYCFH6fIbThwV{AwKo)sTx?a z{hxRFMbP+x@7yyh;X_AL%1j3ZqDyNw+n&|lxM5zB1lRrXqJ9s95C*}>$SasIv2Z6)V{A>q({uzea%Pk z9LL+SvTl7xWtNzV`5Pn&B65x_ZCmNH(Ci*}$Fbh(4J<8xh|XE4PQL>cQszKbEXu(v z`?QRQ^(zkVM0oM#m~2fe9dp2d${1>nq?r64MB+ds=-CmkVBT-ZX6Ve?+Xm+{Ch@M- zAMktqxo4|uSnRqf#Cu$>3XDvE3FMD^gVv@Q>w_Zsse*~$gaa{&&YKI~JzUr)MPot! z1Y8v1miay+`P3I~h>}e9&4d7KEFSoe{%j>yRtOPYNRCWJT#K;n@RJ#2zsJrWQld_0 zd%2LhG)OJ`P&uTOi2~m?#Lg5d2d<1k?_ou#?NRAamLeM+SZ}x%B=vIJG3mpOw)Y-b zMlRgj>ETetzB9`AlB`BGY#xKLGn>zvA!`aLfPZ0ufAdp3)bKB;KH{ms!p7iK!# z+^F_V6)0?p`$_P3m6gK*LnS@e82TU+ zS>_7oS088sIluwn@H8)z1k*#QKDM@?nirIpU5(yM_~HA@e&VQiUT>|vi4 zP;<8?-|Ul*`cKXlea`B?Vv5Wv|H_g!Gz_m3mz+fpp8V~C5j{Oz`WU~Mm1Qun>J5+J zNfZ7P?ieu^mW2F@ajr&MTA4KJL)1Ga1w__^3Mi!QbBaeANdnwFFg?$TvY`|gX8f)@ePMGTIBBvs4Fiy?v4C) z%|#T&E2u&~_>hGUMRx5kr}PS`x4K2y4@DjI?H#oa;MgYbIo%%?5fW9@>CntRNO zIXShC$^;Ewf7A&n z;S&LtO&W2kJD!PMO~pn|*W3@@Za049Vx3rPwp6+AKX&0qZaT~AY2RIsp3ZhX+gO_Zn#@O3J<%mTk_Fs21`VgAtm#cwDt4r5u>;_5k3}T%`QfZ!G#|s< zZz5kJVN+(t2BTUL>q|SDiay-og`g}<@y~D$vtf{zKOC0yGk-^7A(1yv#rfgrslv=~ zL&PE`*17ziRqxUZ4?xD(gnfG|h_JrJG)5IQlANkw!*+z;HDs(a*G{GTsD}V zXOjAw096EPnJ}mGOlV@7!p*m%P`nFiN zTrWteMZ4SZ>IUya7;akTMquXbZtnP2`IAQEUPN5=5j~sct9!cO%Gf9m9tCNgu$r@k zL)y4QKQ&7CwqGw~KRA?xlh#-V{jWlbHM0gGDbu4M7m%Kn_E9qGtQ#%v$JOhBQGzDT zh!Esct70v+`g(cVZSmDk^yDfVFCh#!>1N6uiky~LxoH(xIu{kGZ=i!mA}^UHSy_TW zksav0R8Iqyb5Z5?my_bj>u>BRYwWNqA^Hx1X-7Xrej;9g1vobr94UdYG*mxtnEx1z zJok0v%k}k#@ZI0sNF;|pF;hImR|y&CB~E2wfM=+~YYIKKLrxxNTueElY9{?4)zlg# z&QdzxPu^hE%L`63l1Uea3TWR?;=^)>wQ)Gl9oueh0Z*bI{q}h_Beh6nQ`*96Zo`{j z;}y3u!@MWR3WAB#{ixK?{~T9*;I{^sGRy_zK2TX9d7Nbbk>9`Q;74!fZrm>Q z%}0ZBmP{&*(MXsq2NT>xWle8;EbSp#EEDJ82Nlw_K}TSjaKlTapVTB(vmLe^(a4uf zY&{4gR2C|Gz;qyy$QRzVW*UQx+eiWjxm@XwrtatNN2=Sisz&W0fBFZGPU;4zuIUEL zDRq%B$J6*3#_t;`SdvPvy|9@)Qk>9lOLNp`kI9`Ci+@admqxqwHJ;g=8Y@oHFW-X8 zAw*XJ-Ut%G*B$nHzi(l%zcWsjE*Yg&>Yvf`j|O-V@|+Ae9waM!oRu^;B@}oy770!t zErb}=dx-$*ilhn)>l{I!pb)rvq1%icB)@JgN-&0?>%l-7dr#)dHG46Gb}yo7tP(?3kDJZ>OW#K>w4L59rrncm4ew)9 z#qpGtX$2_iWRde#sQqB+mqC?+w*FC4VF;VBf94ssA9S(A1PswL^8hB*(EFTTWhJ_0 zfw$K_oFm?EOC>qM{2!)APAz%k{r6dLi$2R%8Z)%tFCqYe=G|awp!n$@<5_8s*XAJ& zZ$>!J;oXt>ftLXR7S8IBKl>`W&LRwF5Quol$w{51QC-JAPPUfG2S};%k|DEjCL+C zzg@xhA^TVE^i`};w~Tge9J>WOnfZ|AQ$(=Q0FIqd3=Ut1r_Q)}s2fAMKn&KDPhKF%)qCS0yzPBK!RRru6)14qx_{H7ix-|b;Cw04?D`yuvm(VL3G5Ia@YRlZQ;0{&;p{d2zX9&TQW08F_+F6Yy)Fo z!6o*`nPPT^8*BIke#&N+)uVXzvT%Jw(WBddN!ilvJ<5y>S3N#bbA)AhPB6lKJ5B)6 zw4lyR?N z>vqYv8-tkZ_dY+ULV^%-J$FuK=ycA>LVnCuVJ_CPD8DN`a*OMKH0rH9Jo#d_CJ6(R z7A4Byi-v4lptt$3xllvQqVHt}4+TNJO7{Rk!SlRtst!iUQ+VzPfio-{@UgF$6g42V zo{-JoFNsm*!WY!oSI21SbvI|F!+5dfTHM5^>C6;;*T-Z*II)rcp68+<$V!2dg*&{e zX})a=8w{x>-zrTmQbB%zh+&@gJmuY)`5V($g`4yV$@x}>NkfO|0$TtFG#gWktvfmE zt#V#6Kg#z=OnioQZqIP6=IUrzQ~D;=NW{N#0ksN*mrD4MHK^!$XzuW>5Sk_XY&?lX zghF_JUYnWM*L>4cqxglq0z&g+-8hJ&^J+G7W14& z!egSXBWXimP+?5dXZhYBsjwx^3Jq;ScjzQ#2CV5M0RhX#MN<{d=Ocrg6TM}SI%LSR zb!u|pA{!=DD-8_i6WqkS?0fA8uS{Bw=6MmC?guQPA+S`jBk>K72h7xCO;X`x*dl%$ zge-_Mh1W%~fk3Zdwa*Wy*&FgVYoKJ$7gnma1=IF5aRhSv{w^+`+{!W*L#N2aW_RrI zzInX%gTxtg67-s_8#*hS;-^i=17aebYE?rBxF9Kjj}T@yK!VtC&t6K*Vy}(HbdtO>c%pZ6!kyd zg7HrM8oK{v*bq%k(ZT~VKm^CT5@ds1B`Y7&$y)w{zpPdDGDVT`)yC4}s;a~9Ex&3< zpXuq`fm#tN2^qIOK#HejWD1#~rGAVvPs|*=iT^@|u<5uz+vGteEip%6ZKc({sr~2u zz<6Is*I>Opq3oTO4N(%rS)nJrY6ez}O7qdjD~17LG(yY{Bk=^stswn_1U?ra35s#l{Qaj_bKiR&)?i$Eu3!3 z0M}&-ImX=JQo~xfh)DTS__20BmI-0xB)?^ z*R1yvEgZJi<9>k}G&2$_Ox+Qf>NSU}{9jz8xPyY3F)WxZq%t*EqE=#>IIx5bo`P9W zhe52HAw&!&`15SdKrJ#GmPwU}Bt5||a0HrlG~0i1k&o^gL1#5YU^Cn^u|;s|@6Yu1 zLA!EUKpfo!iT=YWD@gl3AyG7As|V?YApN1G14j@ROc0WDKuN#-_{Rw*jEw#xIhpzs$EhqQ zM_TrRXHg)91G)*w89_Qb_59ZLIEjM9xh(y_?Aa<=Ad_HD#z7o$MBNdC*EicH8~e^O zZn&YgtMAG9*a z!^lueq(pa;%P((1{jrh+ie|leQZLAgCKJaL(4G%68Gr`oX2KAI0bn2l#E>ryR5|rCe9456Q0v#%J;jjG?ylC4&RsUiTF?^_z$6_@`~Nk^7^5oIjdqT*Fm*L!R(O=mG`8*Cep>Q&dr(3G+HXtXE=Uh0pv-CWu?8oBTFIM0cP8!bM!A&y1ZN^+V3LldbLm?# zkRFDc^+gDlsGt|`Ti;3z#&5oPblIG60jYoL8#PWLZ}Eas#AY)q_@7aC?4V}_ZU?%A zz45A1v0;YCF%GO(TLRsKZ_wIp7z}>}0+y`eo9OKT>O*5_L3P$uRWslo=V{?A2BgLm zG5H9`XdWxY&yFh3HNM`TLe{Dl7@CfCaS{#WxkAX9c!ihxBr%WZ4fB` z#RfNL!XJYmc%Lq+Dy!TwX?dT?JC^#d`6GbIOlS3eP-NY@1R?_*B8_gO4hCRBNB)G> zA&nV_0l_vq7pa^5^)UU!B9%uJO-I3NQx%JlCZuGn#y5+qW zUbu@4vD`y09-&p+M1Yj7&eI6*S-UpLE*^mkhZ$X@O|k^2F;ZvwK}LDX0c-&U?6{@7 zd#fVb#2miK>%A}v!UYLsWBZu;b=M`5V6F_PO#^#iJ9*G#j`1qDOk3~ok^lpHHqMjj zY?1e?uTCEtj5HksG zYZ3|6$(@Fw^I1X!tgr+YVAb!Q61ls_>Mc5!4(!=Dl^D1H_>DKFh)z4=u)Cnhs#OUy z;^Z~2d(~q?pwPpEksBI?{0UcTb}outW{;2qrqRG1kr-@B9CG!9a4Q*9Kg4oY$9wG_ z4QI7c4f=)_b|m$i(;O2pA*;u_Xqq4P`xt3QSsF1?XR96Un7}=ARFEX25zp8J`|Ntm zX0V=HXvtf?htsgI+i%~Q$0-kG9{hpI26>v+{}{%N7@j8%6EJrB^G58*2 zU>tD9-l;($=37BsO&QV?WixIVPEYS)iP_u(X4Tr=y=9#@+>k`7p-ULAXasBz%fmv_ zA;oZtKj=7WJBHBUPHT7ZP52*r3L8xk`{%V|>11IMO(us{Qi3 zh9Q8WS-EEHM z97BnQ`+VlLV`(#3YGis^j|&BRE`mM9cm(vwG`eqmBbf)^{N~QLhtmR!5VP;T`_jh2 z)QzCb@62(<_99>SLLxBe#I)lf*>)n+=RTJ#QJ&R@W49g?j=8~UTk7x3Gm|=3r1FhS zK^~)c|3vpUH?*t_$v}|udFR!=Ym6eQs=EBi=FJJ|ZS28k}l>gcj$fEw^EqF)I|I zTW;A!gPkDa!?_>LI8>=PW1o!7GAN}0uS1|dY-@J6d6I-5pBhS)F|3(u#9v&$gQ9cOxCd zJ%u9Y*g~&hWM&{?ou6^^ONTvq*E{dq|L02%sXq8t-3PL8vho_9!H|9Ep@i9h@AT7a z|8eU)*e%|K02y7ManWOcZjBZBCF8dBv|Iovh@JzBiTa+cnEiUKTF09+8gAnll9U|6HKxCF$VJE?krt-O$yx$?2r-_ z(HammH6Vu#U{j4o^jO#9q1;r>Ya>U@aBOokSSYfzT2q{w1}itLU7HZPSzs%#T4mCp zm{e8uBqKO)x*lz-nD8!${H?c=bNTmwKTYgA-$`HE4uTJ8EEWoBRi|6)1=*3w6*0nz zCng5LLLg(bowp8L@zSAdUfQzd)Hhx{=;-BjO^be&eWad~2Y5^@1Q!qXSCf{gP;)i% z-f$Fo+sc*czj~ANdQ!5|BHrubi(4F*d9YAX4`+yfusDj!Q75Wac~XIh5Wk(I9_`kw z$hlme0~$Opf7!S(Eu7Cb_w}R|rLkEXri%-6Kdc8y8!O^*Rt@~2v1Q9@dfs>Siq{TW z^N=|MkX?Vbl_rH*3b)X6rkd7REqM0|^VWeE>M|er0c%G(bE7q&74NF;$r8XFyk}F{ z2G2~OC9SULApOWAbwL|2n=K4qN2~rh&<)bRBRT3=wJN%2V|CaFiy^heRi4*b7uZv(lN)>oyE-UY^Kt-?(z^c@EnlEn&BW`nhF!0 zD4@C@{2;OLs8a;!@@(=b<7MiP)lfEXuIsq)JqCjb!I2%GGo3+xt7bDCG+KaSpa|x}{Wv#Do8;d*d zOiq1$9lGR;8YJ`Q*ew+Lh;iWe<(DU7h%V*MXJj+UA>Agc9c9Dq3C#_luLrD~HYGbX zY9w3DE;=57$~jn!Ifx@?$kl=oh!Ftz^o>#3Ts#hJ`SKH=sAtk*FZIjTLO7uI3@%hWpM(-XDaD*nzOQAITHt z2$*oIK0L*^WzPW>6ecd~*Jl+L4Y5F7QKGa^{fi^#r=Cj001V+imdBI*^8??RM1d>} zFFxlrdy87C({uSRaQ6z^i<>CK9+<8$GK??eJ^~%M!Bdss>=`&=PnW=wa5g|@mtLB{ z3&VrbKmst5jRfY#DZp_?hGz~`Ihs2QmLR~H4B`$=%yI+}s;xMS;Kh-xla`NJJ}}_m z;hHU|(f)ZIrYcB(-F3+~x^d&q4C7*5d44c6hlWo%CGFZh_tc?H9%oJ7N+K_yhk$Mk zG@VNT>LNVt0{a0O8pt{4BpN8{D0Ok!oTFnhas!XZt{4O|2vjJT1-lLkq61jl8FLNg z6@-9?72$3}UOiT@Noaa`IRbr;TcvVY*f zQ{1LERpI zt!57!+!~CP%YAt2GtZ>J9uF`17xWMup@~MJ<6`!~u?($?Qzuo39@j#v%3-_gXwAYT zn;m%zO)tt3v}P%}%ZzE<8)KTPAJ9O0tX-RExGO|}JM#{zyc&9g*z!0_=||TmOb4d$ z*kg$jphmu7VwQ-_L19-50m!Vr@r}CXp#mJLQ0fl#&Ge8+mz}WJR5C1<)2vHns9DoN znR9fI2?LJL#z&la<}S6pn#{ube!&HoF5PJaN1ApIgKuh{U|8htaY3aw-k7Q|F!_Ar zr9(Bnf#nG7L?+#`cBW@h9Ug&JZ@#%bG|kDwn0YYopvnUEtwl1s-6jDbbPMWZ5`)6Kca&rHxuO`ehT8!Vhao;qEL%+{uTC3y1OipVy!nuJz zE5Zyjy1NMq_>pDeP1w5p^7Na}dA0p600v3F@2M^OE`58+A?hYuceHPSrBguA+_-PL&aD=~ta?h10%nK>6@{<)(R^xx!ZPtuY#51D zbWQI9V912`zVh;KmLK}Q-@N(CYwxcm6p|fF;3;Wfg_!bI>#a?w)^}X*U6&Aw4 zI0J*N^=E6A9H%9u+{?j#BM$V>@f)vj_duPHIKgRjxg-i-i6vW9g;r+!;Ap{$XZaYf}h;DBkn zcI{5?V2CJRe(YnlPw9pmS~3boUb#-lRN>j+Zqz~?GEUCjVOVyE3JRAWwbt3MN&0~m zM;^Q8lzq3n=gocYd+$jnU3tRq{O*d~kA4em_4e4WDkKj-T$lOwG670^PMnr$Aq2P? z^}twmYt2$jBhmx+YXHtITnYr*Z_HE920)< z!MbHwez5KIf}~IT_=@+Qx8~QEeCjtJTl2^ZD;5O(7LmWdRTs}&nWMJ=%2Q5B%%NEwCy3uC6$`s}I5(rgk8$_72;FO}&6s7M^^ii?Kpn*{+(U<^gR~)Tba|4do(op3_Cpj z_yp)rd?H~6`-*MAe+?sTVgs9D<1IdbTf8pUL;7hocAd9CZ@PN;&BP+btZB>?S5HNj zW|Lsnh{k1!Sr~*xUBlVRH_%d#g{_gp3>lLTa1+1+aYm`ea8eB~dD8Uopkd|*+me%A z#<+Rfv1)q}_UizF|FNmS@%!ITsipr)AiSDGXR2z-X`Fil_J8-g3EZ#^>nwoK8#mUS{MZQ@#@T1rN)9}p+hDXF4uB0{ zeDt3h!eDq8Z;_RPLxvo0*pNgD*wAWC=2`(836@~kF(0;;XYDd1nocDa%bw(`R@F7l zVaB`#rHkLvzySv&JsWnw?_-Whs0L(MI4@-t&BpG0W6AYj{xT5{-&}fWoeAV@Sw5rX zB~O}_xkjq5aj=azW%7oi7!6?w^{J+(?-ke&V!<`pT7D4Curan1=44=Pkr>VQr=3>U z=dozBS;C0vYCtkwQEGwzf@i!PF31i=C|H3##o++=Lom8`5E`2{C4}R@C~0$OCAiB4 zj%t)k3D5xeWX}um3Du6*ty@=Dy4M8XygA83W(d#(xJAx`TrKm!<{44&gI7zvHR zYnrF*!;cz0*hUzB?Q3cNFs8f`<2>b&?qNQk+{V4`x>QrioL!K~ejxzb(jz+ibA=lf z+4?+|5YtXzKXeQBM?*w}1xRm62(~j~9-n%ucEIzYaDx=Nb;iN_Cv#?xdCLVCq&Lnf z*gd;c=WMjd>#VP+*UKsxb}2pm^rT&w7jMid29jnp(h1`sTrPkDz=F^a?WaFoM|Kn% z9c)`0!{AMB_MUOm8%&E~ZW?U=^iS1Szgm`|UchU@o{iP?de`OL6qXa-ZUj2tz@NVS z<()B-IWNb&1CHP>JFQ$nOJ3=^B6Kw9%M z&W{N&83mw?gEVFgl|ye4Vk{p;5uoj}PkIo9^ZUF?WV3u=Ar+Y_@)KPjg~#;Ta28LH z-oS(Z@-Hc#9NU_i@KUyeZDgFKwQq$0)i-RSlUyIr1N1-q!(EDw z>VWG;R-ST7LUF_$Krk0dLl%-d;)sM#Kt>8g$%aS_-2p!6 zA&ka<`(p&{O?J^m3H2lRuNu{evg-`eLw0f1A zO#<%1%;5JJTPXV2ZL+A=H3mDkdN9;t6GEGNtGma^rRM_$yJ}4k&4Zu8tuxMOi9;?# z(C__Ta+vrhI0tru5R3`Gw?LXzJ6R*xKh{ZVZeXBItzMnTfZr?)nq=f+R!oCABf+>0 z#sL9?^za4Nr84PZwsvqa4ZX~EKIJ!`TRR-vW7tww)`Nf!^W*a_F^l>HSXf0>)u)g; zokj?d+#Ccslx2@Uo;aml7byZ-uw^ng-JPO*O4X$hxWz2JHEU|$5*`bmZYQbIv28bBW}b_9DT4*tRV#p{2ap0Ff95hQ~&1eb3>j zGmi{1o%bP{coq_Ub4N+>VuaQ(yC&rAG0X-b7}*+Dq=;zlOCe?fg*D4O2V{>JB#so@ zozaCk2nb+BPd=IG2JXmCFKqXU!16hEEOpzEhO7uxK^u$h=|PmdZny#+Mr&bOXhucc zvU~7gb{){`)Ngi1nTwgO{tD@;c}M1e3=bt68elT_-kW4X96<~`*UWV@Gth^0ZEMyQ z6$L#6jP~yN2+Vf<`t%AO0ZQm3T@7BI6?%~ypjK&4_f95j@ zhl51hPrI6#AGh6>pa~6tABeW$rS2!j{wAl-5q&Nykgk25608LXg17(_-~vRzp)K2w z8CDnvrWT`&Q%3XdEG7=X1b@LkS@Y1IFUS($?F9&2%@$8|G5xqgmL>=ensi%_q z%57-v(&tF;MQ&i&waw$${(Q(T6&xtF`gx?}^Utr1a;TJVQ0_4pnv(?VhU>*SfR)Dc zeQ7PXlb7nrHB5+si+yYXMebY!luR1Q&Noc)zCeC9(6ySeX@t$X4`?i4-l|neHHx!g z6pSI>i$XUWtF_j^7VUCaZn*sNq|LjcE3QcFBU~)-DRxTVyd`H?luCaTacI@M`o-)B zM^52fgVg@yPio_xDe@z8pyZtwna9d1fcLiUaIs@wuwn=>zBrjv7Lrun$1G%PMl&muI7`Tv<1>-~ArX zsa%GwTblq#8Kh}QbB?lnBV^G^0j|a+_Me3}fZb1iQilx|TRU#WyROKsE)L2KpZsK! zz3ORvubJCaT8yc*FQtxuR_(MQfU$&9t01bXcKxA=)_NFQE2iZ|cHu893Ook8m|>o` zP*p8;fqc95adkR>?|aGIiuCAihf00E#)V4HupjzRhZbbt5hhoZ^WQ_U-zGu;*Q{{V z;uB9yLe{npdEGT3Yc4N}HM_ztqVud@Uwg8#J3so-+O^lCG>?l_IR|YmZp>crAR;Je zwN(oh3!zvG{^+%2=Ex0%##lnBRS;EGyL1Y)e*E!dbBorkmPP<7N{O*G*eBo{1dtzK zx5^MZK(av(J(TF&xUCvy){D}0U^+(VLtqDng*J!PHm>g;E`Kg zN|<>|gq4=9IHGY_Bh7*6eU&kL>1yf|BpVX zR!`0xt#FYBJXVJR8q5a`8~KSLbjvNtmI}Qd{V*3ZD%+3qrrxf8!Lh$;i`i_p z@`lH2>mPGW630khyN((bVY(2|m45-e$9fW3BU;MTM&NipRWQXuPsp!U$vl$OhnOX{m)p8EaaJ=J z%_m0N2H~ul$WI=50Rfv3>=9Mro9g!yjMO+R7iq*Y!@45C`0TT3*9xB`W-eC2TxSNRtLnpV_V1JL@*~)%eiwInQeO(+Jd>Si~zBnG%H5q;0TidJXu~mqJ`fxAq z9N24m++g)41PmFn>NR{Fj()@uX?jQls|k5r71iE{_@*YX&B70fKE{6m7Z_}qgH59P zfzNG7urGX}{cv;lT#Ewxd&<27Uw%M7_Rj{fvY#d^g<-q>8#W{+hpdMKjVvY72THXZ_Ky7nXJQX2q^ia)t?tRV2v{+S871RR~GkOSx#O;y1t&Iq*t>2JO{ z$$IdBU4&fGZhH#zkLA8|VoyJvsM`K3=s6~5>5xU&hxNVe(=ZnFH%{>}Y3NtK49hd9Y z)rDC4PX+-Fi1on_ChdYr8d7TGv-8hS6Gld%uz~vgKn&mhcCtaIngmf=^%CW z*gyjyF=kRTUCY^m^el(pfBeTg)8YmNu1>pEb+t%37r{79fU=I&Ip@@kJiuuei%|t+ zt+CNU!Ala-13Rz^f?+?PnF*Ysq5a!L!{Szq1Jf-eZD9^F+dLS%|D{bA6FA+^$QU1L zRIjVH_oa+#?4lIH3glbAJ`Ibp4tao2{A*nMXDk;*USbsjU~UFS=$vR(V_J(|P2pT- z&*lAAmIUokBmf^8i)3I(%!3c6tcI;y(@ML#l}Hkna{?x8KX*pV_cx z>474U9oCy;fAghzMFO`REty4OtC+~v&&W)TEh<;%uZY}es}x%1zgdiEx-JS{%6=hp z)DI)4c^Zv$yZ1(kdB+`z?3OIq|6%57^F81$2yF2Q|uN@^NGyHZQBy0Y%%n{tcMM# zcHxC-Qy+gk-H-NCqO+;zo;$)HJhB1IWL^#s2-x=2uIWF_ z%AFGt%vbHGK+2*Xc%YVbEY0Y>ku(Xo&(ycaenDbbtFlD+t3_RSfxM;-D!$q zw^_RelpUx<70wC$SNTF9X)O~5M+L%W9XaPbHP!}Uh4TY`58iLyoQ!Dz#h6+nQP^}` z-$~bP!`sF7zo@G^TV6Dv==(AVCl){N*PjD=*%cWiV4bjk!`E6ldTSBpoV9SnaJ(NW zk@+u@2kbGjAKdD3;rBZy82|R$cX4c6fs~n}&hZU&1sAj7p$+8nW^(x?oi<|g$RpEH zQ6z}jih_AUR165-z(F9D@WA8>g46Ttj7Q);%w$N5zGm$71WuYFVy~HX;8X2=U#1=I zwlKWk9=EI$ysx%LdZ_p3_Sr}tGmwWhdCZVP#Ccr?^cLjp@C^QDtHO_ z&#!+y{VqN`Nm(GDL4B|mTiGJJyi3!V@bzqw#{s+9TOeW%f!2;`6Y$w4 zr?x8$OE97nX&**W?43_BEAxRY1XeF$xZGLH*e@qTx_LOyZ1o;jR+ zaw09;y{ucelRWat>rse^gE*QkAePs5pUjEbghQ;wWIb5BWwY|V^C|nj_+#<|CTX*u3OA?9m^O27v_g~?~8_A)EAZV+62(r<4Y%$P&kAABYv#TaglS6S~z5T;K zBr}eE&EJ*NuoVl9zt2C1t;}!c47sBAeBc9h!YqR}#%bjVb(`<+Z+ zr1AI7>V!1!z-;AW4p@Bp-D2(ZJIE9*!@ zJ2V!xU7HhYRut}Uzut6xDC-SIfT|Je{GbW&CzuUIF+;R=P@gGrC-=Z0d3NK*gzjJX zLaoqyme>9!3iko^?R*hXjfCdl^iZ#fysc+~&G(v`XDImC zj2m!_+fQ%Np7nNBLiWD^2!6>jL5qhTs!zU#c-E|o6a}!(KR*o)(9S$F5y=rp)Nw>? zIUMNw-!BUmw2Ja(MPa679j?60NssG8S?>{zJzZ>SZDa@d%EVx?AP2m5)22k3djIhLDB4nowuJesze-%((&|jfZVt?x3B&2dvmgve#gP3RT?(gP;RPxF8{9hjo?LzP zplpOzuUFI0CTD@CV1jaCY&82-7QJ@jq@r+A_nqbAT`=tLIn)3O zHep6Y+TaOQcx0{PI6N{mE%&LZK*Lcqwj{H>!Y2E1@4d=ekIOjgfv~xr}RsTz=sfQu%yt?}7 zOR4J-@t>@YdGy$^B$FPD5U>2#vu==;f3acxMN5minN_umPmQ;LY91Z|F)RV@ z7iprxCL4?mdhN9dsvx%w2Dt&P=87xQHbiX|iGeMFa#|~0YWAVLDdi24%Ug|vZp|_w zZ*v3q@bjOiJJsWP5qQj$l=F}Q^EBtP^+2P`B2x1ldhLu<}H=NW_8lFiSt;l~{%;@RWcbKqaX*K7rbuIyn zH&4$)4OR|ZP&t4L_SWzqu%^7u*}U!LF1u`(BSP;4(L?xv-^_#$>>n?+&m0DcSvA&H zK}SMUG8&m@?U)O?6kVuf$sn1PZJH7ME?+|yPS4!VI3vAIJcurI%!J1Q1t<$-njJkx z9(cPOJMN4Mn>rA+fWZ$YV~CZ-$ruOqy|vOM51N9L*CA7R8yUgh!?}aO*|No8kY-1Z zktKH=r|^?9+hz*H1f8hE;Rf-qU!T0RNHAL&M8VU%+98Za%^oF?jc&dR`3%q6x;4=W zdLVc5J+gX?1Ga_rc#hk%F}9gi2%ReHpN@JxLFq1V7gS>#fF0U=?n^CRT~ycv`$c7B z5zoRP<3 zb2)*@$aK2c-_^rwte%azq6x0Vxrq>Drzcocv#T7YDxU!{^jK_XGc)GOE9>sR(GEI# zrh9IH*xAh5g-nCL6V+)a)Nua#(`)7^wpHWQMM#kE%Kh}aPdu>(srVcf!Rf| z`J5$L0v~#7k;#KWSIwrVI*YM}jVpl$0IX{SIK>47uzY}DIZiBsd_%TVMRZi-O_q_#qDSwoU>?L46*Ielj+$i3m7SBD%8b5LfP)Ht z6bhk}1gbF2q#5#F$&j!B>XGLLP zc)bBj>~@`>-qF&kmL}*{`%@GUr8JS_F&O69%1vu z)aF^ezSK)DNic;}G|0dPcBq-Bg2uUS-7blOMJ7~CQrEs6hwRWMr9}mbNL1I4(G!7# zOt;y%5i2~71gP3lb`0y!ztM*2hg&`l`~nO^cLH1j4P>?ckFI@GiyLmJ18hJ?^gv_p zBKD~%QX-H9Qkft_sM%DU7lHcvVfn9mmlu?f*NC59>y|~(y+T=u4h86&H3N(K%%}k{ zLQg=g{{yP!HJ@`$l-sO-k-PA6DdFI)W?AbbQD*dq@a2wjWRsjzx0ZH>V77v(TyQeIjWAC5D~dtUWGV&` zr+ZFVZ1=#|MkRHEkqc7amDA1)dF8;zQx+9H^FbSxUjh>#nio`wZe?$ zH`ojS!S}`k19bEsSPsZ)vzFF#Q!^oZcm~6&a|2?-f$~Bi6Ueb>05kD9%a1b_z1=R+Qy!Ogq{ZRhBtlZ%Wmc?8xAB}5cjupz*x8p-2VT~)hi zI~&e*A3ikCfTdy6(}IJ{;Usqt!G2NPbWIkVx5YJI8@xa9#5zU84_ZA%(!Qs*_k#p?y+5@{KEU)(PrA$kfN6TaXa}4tS%C8N#>(&#{sR1OpsB zHsbRi|M4z+Ba^eZ5(L2B^!swd>zaGb^YbZC|JGaU6YHY8^}yq&p17T21V;7@h;@N{ zdLoC9^b?z-e@4UrZj)BA6ENK?7YCX5bArYp^r(Ew{8cXD?iemiy&JVn6ir zz3){w-nh#n_B%o8U%fj0=5uQ|&wS2U9n8W0NPOlSb}mW=nQ@^zpE;md+ey0`TzRgi zT3ImyBb)ffe1sA(G!YCwZDGSavcJEX4Gf5d+;mf20;s5}3&!g%b7D{tsLx`DbWzb$ zbnm@oN>{9u?*Y3;2upwt!3QKZe2~do{7c@qm+<~3Gl1wJ@zx46>>@k>I#E9Xk3rUv zcI0)}B?N^Rf}>CrkF#ypU!RI51U?P#<{5KFA7JxL6R|IOaq`N$V7gJXIU)syEA(9! zUYB9R#T?Mrflsx)EF_!)Z01iR`s z)A9UlKUSb;2e*Iz=juQGr|I_uSg=alv;0`m zgl))8sIj_vI_C%k7+4n$EAT%=AEFPv!bMdpCQs z=kBs*rLbZq+`ucW!rLrKmV1f-8f13NF}nowX)N*TNXO$gWEVujXv`U@g-wVFciClo zh33;d(L{&tDOF%sB8=T!K8!p__RJiStGeL}3 z2pMD@N((S#fk+rn;_{i;Wf1Ywn$)k(g92lw9yjn)RGQ#fMqr#s$Ky-nHX1)LR}OHG z-ivCgwG7|;H-Gat^MvC6_>cei7k}{=t^cy3pqx^sYbXngk@Q)A)HPsJw{1(Dz#{!@ z6*r^u-gjRLV+L_mMT(1Wjyy8)6682y7x1BwfEj?5&xVyV2fozHfjMEXQZDYvCy>vX zxf$iguuP2m&px|8ZRImhfib+7&z{0Ut_;pw^pV4lAwPE7?2Xo$=UI_X(#gaKyc#(M z5Q0JQuai$s3K%ak6%c6|eSAIWZ9Wy32VvIJmKiZOil66ydH zA#0Jnu7qxjPJ`S`6`8KN38E{q;7MKCSUPY`0B=2@9eIq^f9O-F(M|K9M^5IBCJ>rw z%Y(LVtz!^O(d2u0Fd9f<1LS8l{6w}xtIkukh4&ic5Eq8iH@}&lGMb1@x#EiSJz}=2 zR=}R*@hoB-qM&wvFcGSNBWDh==b_hJk`9#zwi%JdtH~N9L z&N<)p=D}9Ke%~zgz}%pmvCpkQRv16AV4YNvSj?w)hVac@wR*9X;%?5sFRDe^@od~JUsVY z!W#f;a1|&O2b|3lrAS@@`FJYY%0>YdxxT0mzhQ9f#UTe<%}lhB4trQ5bO=vH`k!$| zn)%wby9hDOiGlsXnkrKS?WtHZjXVRhp8&#L7G?k#{P4qRr3Uk`@FF+g<47jSgb@o& z{=^gOlEa>RM39vkjIbdtR3kW!XT7Z_#O&-v7uAPf2F#k_E|VJA?QgMTfAF~|KGhm# zTh+s(U3Qz-lQF7UYL)c*?92y|R?!vu9{boPV{M9$ykaRHa z|MjoaI2T@6t7@@-J%NpUsqtVm5fl5?w~~m@l^mvLzcBMZ_!C9hFt3s4hRnxvhNatg z73%^NfwUr2c%YJyGiJB|M!fMLc`Ry9HUL>S7ldueTQ;%C)MGnXuQ1_)JlG>XGji(* zao&g1lVHm5`z}P>qpnD-MSTIJaeSAR_KmZoPRFnfkA8fYk0l-2W zgQNU36AnWc&-;PeG_rZAbfOsW3Z`l}fYpBT{p%`yE)&g91{lGt?TEo<+MoPnBF-WG z!tDAA!K3G}x=ouBs$u?`*M_BNV8Rd$s+mk2;)~H31pa~=*;*b3j081RcuYu-lBtoY z$0{r?EzjmQK*9YZYn{hQu$6C2IRIP+;mxsu%K~HnSOwklo^AS}!BiduKxh#PYiY&< zPHTl*4~s2t3>Sh7G7&f=ny0j6+5$j@}mMb(j zYW3=L!yR`d1BQ{2QOI}rBHz1^uC&^~dnkX&l623Hew3D`OX@=(N{k=z2uN8}fAnQe zLTrae?}qN!7yk|?{Zy?9!%?V$-$_y5uKnlSrzy>f$H#s9)I0!hf5Ga}P zxgm;zHN|O>JQRIp7^J5$LhB~Ni6o)uHN;Lu{UUQ7!noptGIJzune!cmVW zJFNl0v)5eHa-IU)cGyTqbc1_NUh;z^UX4}*T0{k6=EFB&2JbbFl?k_&8Ek?Abhk?61aYAu0|*^wu}EaTR}hP#|w$1S>!DU)$S& z4Xakwtt#SA;kwK<>FyOw4vH}X-PaE9^AO0`_yCA~|m?Vn@??D>o3{iFAicpOMY)f8; zz!|r3WiT?p0s%7z1OoDe>1lL98%7*KmYDKA=sU&Mk&9RJ8F{|b>WI)<0(Rg!c)*5% zG`hFt4W1-0i0Z!aTb#X9kfu?$rCVv+wryA1wr$(CZL8A8m$q%Y(ze;veJ=KYqW3w` z(Kqk)iZ^D=SZmHP#zQS9c6*}B4;@eO@~}>wGd)QDEORl(NQ+QLf>37W0#q1}Dc9!d*^1NQir3CP)j|Z*a5SFYwXiy!l}1EQV8Svaz^;3a-`uRpLGW zerAA{#$AagMQ9z~tCcR83KC?~(nw3*M~xV-aR>_>1nvu8;lFk?JoAwPG?IuHo0X~W zIlUJ-sYNe#89$SJS5rVo2b?yw3UAa;|ZMFCyq1*^cx<|hc$y)$M_b(78 z8FpFd*MaOWO5VJ492pR8Eb4olk*yZGyP7e8`MnLbJ?rg5ns$;Lm@6BZhP;PRfw~@h z^B%k+EA>qpL;;~REx}r$t(U9=5G3p{TsC_N7V#;44=0rnU#@B~15l7k%YrL3dm2Wk zblzjQ;!i_J3qjD+4G2flY0HZN|C0;iOR=-|!yS{2^XlX z^Rqaq5{kW$MW#tk5Fb9G-)+uuLdXUUa_A{4Sd~~rP>T=@(fcIJ zbo~D03d>$)W>TtX@mG{6l2h&)8lQ?4u6`G^)xvg&`6pSerK&ws;j)xX%uD+Tyh z#&WsYlyW=z$bqGoh>7___AGZ()^9UYchzMrhD{LY3HPrNG53+h#%Ko^ivWhi3`QY* zgm_Y|={{5xh1=Uf6!N=4Telix^*<1do$EY^e}6Z68}^=_(6QgKkymf%QUBYJ>a^b( zP?+d@bi(wSEPYMls2oSr-3P;sjceoF6~GYepAnq4T))-9MH7CU{;GPk#?OGw88;gB z8^^{6*=O2)Rn65+-ok@2T zoNtF6iH|z1P+m?mj#~m8QfeDW0;Mquo=tr>f0-SqTs%j>PGznGn}c>r(v3XJI2<#w zO`HFtY=qH(BW5s!tHoBr=`rKGF=n5?@n&&P*>ARRYvQOvKpJfto)F!U$SJ3Wnalrf zpHW$;jR00{7vj1%a)^d$P`xGHj6|P@s1b&XoMCVY&>=Wz0y7o;O*oy@FE=*MX{fx~ zStRPA)49bDBqYIji5>$nSRRGzoD1P;O|nwehI4&(qwj%AYfV>Y6iq4-G^@aKAMS5S zDerd7sJ_F$%ZGCybQri^@7xl21;jE$7sKu>(C_yXP4D=RD+kqQf6))I2=|S_1Rr7l zFR2AE(XbY#+pk_%`~4_i#sASX^vVPm{^v06P*oO>@R7+3zUf4M9G3RY{fEASn|4A< zPq&W#opL1K2AgtBCaJBEEF#NnvG9yqFaZb?C)p~Ws@wRq1#KL2tj6c`qde)a- zQPh#XxN{K`BF~hvn@PC71uY+x`{Qw#VWk^I+^%oz@~Jco@jWBeR)aGIydvMjC^x5; z!zQRZzCb0IbC1wM5Fg`^>zE5Ro0Rpoi;_v2L8+1;glSw+=c z@uGdxiSKD5J65^4E9%GhvO!DjK_3!Oac~7xrhDK z4QpLyxA@M}(u6L)!yc~tA<6JhWK@B(!mlWFaE8X0od-5Ux%yC>zv zF0%PQB*A$-{)_K=I(|Q?i1-MS2usAA%fDdx)J00cHkawt$AsS++V1U5ezD0Z8tHW} zc-kKd*kxani+!1OpB?#!yheZiKV)M+XIbO3;M}yI?d9j%`=Rg(5dR-u5$-GIuZsBS)$Q$Gy{vZs|HX&@2lm@~w)dN#c?Uu6zrnsU{TKFK z%+kii)QLgN#?Zy||Dm%p$e7xhyI2r1F){z+KtVgZIGGySLVIigG^Cw3*%5nQ)Nj=) zB3C^4nXgI~OOx>zB*nwsXywDwEG6+GQ>Z#3e|#}OsX*9CqFJpqkqvMB)`qYB`iR@5 zErf1GQKoOxNhfvhA9&k6>X4=SkfoE~Y>7z`t&^}&2qPtrInt9|+NYkEAFaN1@Ku>&P}}3(HH)L^GZ=DXrWWfHtqPz!B{RL zN+-`WlL|(*>t?Ghs421MsA^rz{9}~_U&|*Qpe5r?7HIUI-|m;9;4lKJ^0J#Jv!{EJRB#7oRbSvcUpxO^pSCK=QnfiN_F`!+%n47ar+lf593 zdPawK*rA5FWRSV0vU;fdV8MJtHCYB>UPC@jn9fuuP>nbX5bVJ^im>6c)HbiLWg$gu z(=Wh#cly!4*02r?lavkl?nT=~22pZk*~BB0gw7chW@US3|8n8t5JJ0e`K=W49_U0Y zFqBBtr{|W$0-e)9PtlaE+CtkR%C)3u$LTPm=YaY|=EvQ4e1~HIUfqbaHcC7@v-V91 zCV8-Ar5Qv6W|xkiN=lnYkude1C{lo$5VBiFAW4iHFNoYNs(U zLW)!#D}`J}!Wu&gJmp7vw>5qzvHz#oSCaVGg(Py|@sAX8%ARA!Z5}O>6<*`Hv)394 zK?p>h;J82Ua_B1w+Ev3iOhZ%WhYOF=zh!z&@`$^uGHyuZGJfY6j}KF1ZZhk4UXWpS z1Rcl<0$BzEc5y!IeJd)sS0$vA`PJ(T{=hzE5&Zn^;DD#+W&l`vbbqZoO1@K5cE z=5;>2YNnmq#d!;5@1G;o$Zzl;!K**iT>_4}CD~$}Px{eNEezicD`N{+&;8alQTyOu z_X{7sUpM;~X6b6##QeZKtqeO4u#(tYTyoivhEAyabgDksqg@-0$qvGivY6DcXZ(A$-QJ%=fxtN9=0y z9_e8rGbnMPa#0NuquhBNL!`m985ea=U!Tb>_VCzE8&HnMhOgWPNRkleJq952n$J4a4=^u!&imM0Nq# zXwmxJ-dAZ$JF+g=OsFc{I|)puST9m^Y~fae_LLi)!H8F|MeZp^BGoOE3!mf5BDM*r zjdD>NIc~Spm-V%p&+9LvzOHgcpx7s*VuatkOmZRra_t2g>VpZer=<^sX_Ml4h^b<6 z0+w4PxU9dv$z57oBRqd+g^t|(P>%04N(@jD+ z5>EjN95^)Y8+{QM`=Ha>*6slY=J`gQBImzZ1pB-X!EaE8a(My#94iTG%@>!dRiAXX z1)+0sv);Q2y-OJ3s4stzPo?}?_M-Ahx-$^39$pRkms3ap5^Oz)Ca5z=AA>>TaR>L( z=(@}E!8Wy!=`ZxpFM!S6{n4c94pSoqNu#S%>Hxn8JB)v13IvsK@Db5DSYwS-y9^#- z`WscyA+xr5dM}bS=eSCt69JeWY5a3y_&vyjY2p2?L8w${?<6X9rhl7ygw{2UGL2~z zVtxUn{tlntO&P4>q|jih2QOy4fik^Rs@4%oEu`vXy?DB-n=w-*NY_%Aekw4+WQw0h zY25-v(CqPg#)dRfQBuXxywy&8tIlziLMXWButD#dibb0dYY1d2@z4*#&4cM*C;vK! zUBY&&CHnXYg17O!$qgD-R!TFM8Yh<(mLF(<6#ilB9s>NgfAt>Gx^nwij!BoE(D!E? zA*iw$V$o8Yz;+^P#@4&2xvuOM{ zt`!_0^!>YJo55A)Hpjug=;lvJ@{Ft=_glyj=;Te=kQ^7=vite!B5#?ihHWD@;%FD| z-I0}anh6@E>@7}J0nR*p4g9UR61rhjOiV;niyTFE8=g?}M{1d|mLwN`bVN*?7qeL; zcGzk*Xm8`k>EbFp0xJR;D)V>bcov=`gjzYSo3BRBltxh@i!k~rYHMywH_8f%8^?Y0 zVci~1TdF(YQ)s$o!$KL52frPQ^qJBAhxn*gDlU_IM-A ztAtC!YW#a34fduuSCnMQ9}a3Zf>u*jWwO3aRDmOc8k|mH{MIW=+hS1m??Opmw+d6$ zaQE;R$`Mz=Tvy#34J8H@p8wHK!U*UbLj2Ux0%z#wcBsAgPYml=@6`&(r9g270vp^c zqh{frV1r@6Rq=yJ#J5V-au7P{dIxH%3uzc=>mO3}X*D<$nJC>kU_OE0s6u3{=1Ti5 zK~w0bV}H&iIlkC^oqj(`u63Gp^(!{edngu!xEpTR8{KTx3%%S#!I7!DVA>C1;aGxo zb)o%As3I>0zAu2(o?cXSGI_t2v0D^8jL^vp?_KhTU8NGK?V5UZAKS>vEytR*sm`mOA|kW!SBxwxxSv~|k;r$-yV#oNH%I5oEeadc7sj0uHkR_sI zVP060>2G*O1$wrxz z>aM6-OgfGq3Iow&j{fmC`Gx+$)~2zt{%}>dr9HM?G`yJ{cj{D#i}Ct6yKQQ}!R3fjLR7F4YOZ|wb+>;eBI}k~ zi&Q?k{XLn+>Fq##<|h$Ah-b>x#d5xMdsrMaF^WET1G_-wneB5~q!t+Be4y8Fv=y0? z0I6BD9Pjshm%728u(4CUQWPycZ4I+JfUJRTc{3S#nQQ)wBX>V&j%SND#ljb+HeJ_l z`0MK00>=}qnDs5N4GydU!?Mki(e2FpQHHNw4F$-q9z{h<8xOove6fV-&%Ho7b(2r2_58D;7p(7G)|=*th2Zr{8P4C*p?mjEQ004N3Uu8|41^)M!9ojUICh9d zUU+ITx~ZFm<#?^z*F!KETDNC+VY~EiN`eJynH@hFf<94+phZ38gC`B*tvEH>8Vl)J{k05oP}a)8=sZWElVS`n*3H(b(cWXjvj$!|P=0 z!(`&nQ(U5BaR8I3bLh&6EJs85_Pb{9`1h=aeYL2+v3AB~ zW7n3HE=l|ztSqyfUymNLOpCP^>)Y9e29$+Ba>d__M2|4-5iil4c}(SOvcRG-*$=*L z2mj0oT_dxm+N_`{pRr^CQ$4#HyA=2tsbp}y4FuP-A~atP$Vc$GG2sP?XzE7>*kCKK`>Eq-i7 zu&C><9QuT!({f{Q3}NYjrp8oo4!ACEvKf0i4%Kmx$KnEey*1fEHsV z3l_jqx;lox&ZFvY@-B`$QkpixHqHq6?G^!h1n)(v5x$R?k_}R+l>7u!F3J7{B!6Uf z)3DMS2Cly5)|PMp`AhI2dzyXb63L=x=t}7;C&@~1%D481--?Vrpc2R^(Zwp zCG#RK#qAf{TCd6yuw2b7!OKrS>fbd;^w(CCE+fPTmOoM z`P)06-^E|usO)cp-(LR=%C+eyXzHxY{ES(1hh!hOP9e%Y`@}Mp zx8Ocxt?LBJysYJMj64;qvjUP-+$n|=GeW?O2>oWGH(vxK21K*uAFD4U4KK2cS;8GEfoX22JIQegZH2uqSUHfS|r1lDE zs}co^sk(|O_EQ&4P0!5rOfgRIuOmFyT-nsCIRtW9Lo2XhuKdz}X`Q;~r$_CY)Zg;n zvpqN*8{D(fo#Hx{q`XCLKC@;AuoW4)`#$&5R4ywn&FN{F(;bs-;td?0jGD*Q%dNqb zrV2V4EWGL8BCKj+!~cpBSJZZtOt+>bj{kUB(Ds#vYMLqoM2eV}@e zwEz%)h5dXtoJ@O(h9{QuA4FO?JDEl;x47$)47KC{VAnX^+?%2{<-?3f7m-$`&tm*EV zL>?RdjEh^4tU&T7omX_}JET>ec%`>(xRd8?!t*XVzl;|MYm!^uPvgBGuzP~UC#G1- zTm=ZWbuv$hN3un|#V?qgvV`G*O%LT~ke|b~wxg;{0*SkeSwcjJ!lN8AIMJ}rfrXBi zxO=^V>wL$I@z_@V7L5+Lu1Oyrht`C+AbB4YHflB5<=*9#FN_XsI)*rI6o0{tBCPIZ zuXC112gM+@Wb+Mgd5u+JQ6EV{RiX*enjCb$ica(h`D2RtM~vV+R56>omVZ25i=N>I{M|Aqx*=}IyUNJ!#q$dmHEW^04lsJaz$ z@6VvVTgQuJM1*?fvXrSo7XxSjGk*(j4`~fhoN{@%k7ExU)J0S9!~jh&!f5XC>}u|u zo{Bb~LtJ3OltwHBSss4?OlbyzSAzlVy0axY(B{O(g4qHW2{{Y85s}zMb#aP`xR_)q z6WA>h8#^5<)7phBITNWOmHvpV2;Nj6u`H24-{dsaeBK^1)~}kjcmSZ-sD722s+af2v|w#JNC|slTEZdnnAlC>&E$1kw`?p`)37X$tx$@>C9-;^O1Z^xIpqkVTB2f_CRRQMgJ5zSpiRA6T3V7b0XFHYP`D_^M^{Zy zGqU{;_vq^p$uU!_N;VNH#nA{(a;#;Fhbuwtx6YKV5`G*&K6rO2`R}`kZ4pz22D6t8 z7Gl8;5%<1>lIm1s>{u9=f>(XUk3QwDMhV~4$@?>k*{_{rXS&Jq5%PzI=y-{f9U&7|Kw@%jfrpNsmqmuzd|HgRS%U>;aZP|4e{d_Q$pxyo0l0 zt(w8@lv05nP=8GS;L4QJ7RwAilP5lbMt}ai-bgY4WH58qj94*Y->W5)!J8VR$z{df z(|;f|$nZ!1n^_&#|HZ71g@fh)J*!iP(oi=4H>(@q(u&oK%gkHcAU#J-=Z;g=9<33r z*Pwy6Tca)km5?AL4Gf`+xFkB19zbSaA0W?$6f7tTrBdSoxNa=Cl>*${E9F}=ufGuR zPj)^CTvE=uSzdno&LlsOzRmvl@4oomeE3C1+&+ROOG}*YY$IImIuq(tEK(gb zht2JRV!1dD?1NwH1!)uRUuVlYG-Bm!g=gPP*6q#e@%#7|zy1!&V0t7N;Pb6@P@fre zH{$AfgLp&P#|nu+jGhp+kNAz|`?5Eoia<9^l*V`47iAF4#3G7Q$3%m#)9cqwOs?!` zE!v=Jx-fEq2J|YMC1uV?Uh#OG8r4mmI#8`hwWO6Rg@lX#z4WZRi7MTCwNbZLx=^K* z!Y%4y6(fgJ1-U#@`AELZ9J-NEG`Ia(5W#kO&}>#CXs=bVW~4-kMqW&<7R^z?Y@{k? zXc#(BE+x5;CG*-XWUVw*M)_o>nloUdVDZ$@vBXKl`>kg?myI@p3Zf@JK=WGe5Ik-Z zB|DEj4UNm>V?8#FJB?kU8DYJ!ZyG8Xn;*k6R0_SkrN=@8@Jb%2o?wJ=G*XG;tQjv? zHrsD|r8JImqYhO`RwMAIc!w5^qSnhqE>q4dok3G*SI#%mT9ztSOy>fuGCnO`y=pZ{ zmMGVCEe7kapmqIuh0sMUgbrl*`9u?pFry<A|VQfhCh=C+(L5fG&jHHNAFrsLPh9nt?+#b?1BG@4ic2YKlx(J- z`*4`!Cs}a#xTOGfo~d(!M1<6;>h-;NH`}Q{S!=4IDSv`bJpsqgTfXkX8l8B!2k|*y zS0V+_s<>Q*h4cOh4_g9haDp;#@&w@fqsC%(U|k*4OXR{+aQ4}{qYELslEi@eiltSO zu8owB!^FYFi4~ll+KIC)?N$9VK`V7bVI9Foo zIYm$$xS0t{S&FGLlMOv;@NV4^e9ljD+GuvlN`)5-q`#&RT#2GV zVh#2tXzz;&p3bZPoPMF`nDlCXq4Ue5!z-ro&1ZgkjaXazY;W@|_(89!hv%=8hxfIK zbJ!nq+~Z*4PCCUsd@d7ohxn`%dOnK4Xpz;#IAvOKz?(m##{!406udDyYt&Az+?_piz0LCas!2cQ~UjH32y`Ecepw8^;CyTOkfDzzz^v7&Bt~|rmDOP_Z z4Z5nVYkVD;mhWz6t-o(t{u(C9T0lE{%gAoVP7bexG+9X(4D4W>r&q(YXi@1N)+>o)sg?XSjV&yoGD z%eF2PYx>@=5tJCRnWRLmB+?v*sd;ES2vG<(?yLf2ec3rGmx_fQSUjQhJSR?5F zF|S&O&S;WMduL^=S9ez%6S1ZQuI_kOXGN#xn_6+tgTGvDPpIu|G(lIRdfQ zGrBbTazn7{3l$M!zqyNp#l>~&vq(e8x^xfp5~m*GGba@H8a#W*ZKnY3@0c2&;-wpt ze)wh6o&aX8bII!RN{oz-A30|Q`#yGgg$S(pG_rGe@MgZJ4b3%nwn@hRi>~LgZ`Mt5 z5h+jb-kpdT5v-^?UsrI`6nL}_6e=p~t@ej7so-Ny*M-vSo2|mtTr)63@2;__pXipV z5&Zm$A=Ln!v|UNMM)jG+hQ*TK?q-Pl+5y)cmeYz!o4QtUn*=!%v9Yt> zbV_wza~|l@+JScm;3rEy_(35)+&_qVwZ@406;}<0EmgI(WNy*IN}`#Y2&!TvwkgRK z!|uIfgI&?jEt0k>%m;@5_)>M6==USN;thmWzivPd<^HM=iG>{T$hz0A1g)=}2vYE%A#tW%UAzjqYc z$T@dn1=|VF4B?~g<&6^-(BZ;u6PeROAGd)Y5-nxJ2yXxZ-P#rT{cP4Tx*N@Bh~|!f zot&mmdr`xysxdi-BEMReIuZ;G8(Mk^!foa%vaej9w!f;Q7mYqS(x>fN+Wp3wtY0!M z2RIMZZMk4Bs>{XfrX&dLcS&z2wyE4f=yW}9C8fab!g+H5{!d=6*MMH zUB8hHmPo zypRt};lZB?o&*!CnFwy?o%0)3ZEs*#J3MWCCb;$7$bQmUMo!nnNy(449%9eHe4L@9*!Q34-aN z01rhVcO__$+L0(NcirMnG;dK~MRzk_um?2D{$~$N!IdsO)kJW-b;! z4x(u0#PrD_A0DWW>d^C~4CH>k!9>u`G6NV>aj=&zeTP}fvU$UbdetVfR5#vc%B8sD z#AOEb&iwk4HRFI(hXbEQOt1H*RXLK$jGuf@?QBHl!_2GUXsY zXy#@9VnzL-XWG69Jh`lcnkjsPs8K*(=UDPSUzVE&$GQf>^TO|x;T!2z@B50fp%MnNNN)~Gp>mA zEHx@g1q3eZS(KHUj^mV?M>=<967tXq%84v&!K;wQ%1NkDdjkfADdb?`$Z{eQjhO@H>HNV0L0msRWoY~igyT&`m@o7*7XpY#Act^n?OS^Eq z_{6iV#CdPeg?WD^UzvBcHNia)-?R99o@R6dhe`R3K#@lC7blPjSS5-Y1i$&%XhW)f z)Wq8-iylP-!is#^pW(w7`C6$iU)@!|_$@jWM+iPln|-tYV8~3`Zr$Uy?s3f%Y6YZN z1R`J$Egh{^YYx`^Rrjk$-;Q6=>kh*gqgnAEV@N&0P3mzqqUjAu$Aq_mQTu`V!k#|+ z%|qmnRQFtTx;h`O&SA**>hEhUq6ry-S>ozJZ-akobq@X7P1`HdglY zwlTU9yCIoZ3EJJmk0HFG%Qf2&f?4yYnA36q>QEn}ox!?lP8;Mx$0I!(^$zorpV%m5 zIw`NHiJ}r-=vp9|u`z&4NGy)>JVtx~ql&qpijen<_6zp$ne#82RN_b)VmqB62{^ie z+vpX6-~33m*Z3`IEO)}LAs{R|LUENUDkP*^w94H-^oDj1Gg}sq8UvDcIf}A7{+AB$ zA~^dlMqbNYh3{3~k8)*h8tgzln5qZJ?yqe2iJ(J~zF&}D2r7N-;?+j4PYk~hKcf5* zU-%N=sgw95hB~O-nP|AACTAB;e=rHV2p|DjC}(u?Zsttw(x5)J9$VI1M$<%SR##Dj zF|%oZFBdSC3b>WtIv|8KhHTyAt9Wwv$nuW}RfSWX`;|+Eiuc4{#^na+x*t_SVcg^S z!Mar?-F9K*CO4AT+D&J6d0a70%YQM&!E$iBNpGa*Jg%+k{L+Wz0slTgid<6i1Fw_d zFg-q#(zs%4wElz5vpU?%=yJXKX~u;2N}s0sP_PZB8&vI5`$#_hwrugQOWt3c)lt82 zYurF5QM?{O{APzUX(?T8%KD_!JQs53RX#57!#xchxip?tP$qe4gxnVB^iiN_)#Dbp zkGX>U9`0Hjt{m%0;`WwR%Z(DPvZrOcVY`{P0Q8XyYXROg?3j|me_Dz@o0>}$5PpGPI3Rr`6$^-c6WFDa?+%v9;a&nzcroW{sR$SGoaRw z&bm&`v;kO7b%mEoy3X9XT)(`RO&A#mx;p-eEhhrKG8$cb(0PJx=@Q`!Jss ztbO}|%U3Zu`QP8UtpA~$`#;vCuye5frzFK!Nm~L{5i?H{AVa~@Iu@&gz(-}<8I765 zfSyTQQmso#8s&I=d70>V%z9$u9cV`mim!W@gmYM_IdLp4GB2DULaKYq))?*uTXeG4 z;9Jh3y`s%P!2k2|v-^@iNC7=O97Gw_Ig@k6HScSsFCmwe%N%=oQ_vWP8gA841?nA7 zy2e&?<+=_K-Km4&Crj7W^Nfzw`4pGQsZT&J+~XJSk}nVSDn_j&v?`wiW(5}X zUbUQqhqD;x-aR`S4L*7bGm4TKgkWrbMfJ8 za#ScISSgrLjV)n}i@8>*02ACmzF+{>adKsa$OqBx?p}EeEHGt^@@N?bFd9!wPG-_UI3k}pCeGu-?+Sea5<9F?=@yc}>6w}PY z&ec=|;kMJBFNXq8AEDs{yN5mu&NcWiTD8`U>+88U2BW;*1iG5{^i7vn?hJNQD#<2R zLj{t@T<%;SEos{Xnz)m4{(0Z5Zzg%u2(x9(m)A8s#wFL6OIxR7Q{7508wS`2IlVih zy#K^PMA44WuqOy|ItJmG*DTo5G{{&V$djSw>_<(PT-tSA*%!vy-KL_-bPH*Y6*d~w z`E=TJ`O`6S5)0=lS{qr?SFd20b7au}P1UpfUrcwHIaxXXv+Q%#EFDlzu=Li`x|V9gS-OUm}s_yno6!%zAcza({wMK*VE#>X%JxI;P?c@ z!eu}a;Swn%rTmi2R?sqAFw1I|3~!WXXE~cl2x(d5-zM0-y#Ba;;k|kIz57!0OHxV* z6d0(-?5L8Xv2|+uPED;trX&fCnk_qT*C3%{zaQ-~8S*0~AU89rJ_%GUYs^S8iNV`X zLUvE@V8-|4-LAxeJc#ttpZ7O6L2UfQ=qpm@Fha$s8Q}n^NB|@lQNMT)1E@RtjQ;IC zF8*nIyYorSiUl3FsbgfIMw`t#b5WlVZv>(>s+Va)R>t&h1}b%Ii%cQ=6h#XaYDl4o zAS#tAw9(VbV-B453X=1R?YdyKayc4zW|Ra6dU=YIQL<94!Uftak|;J_VaJca7~8o} ziC~4|#R&?{Q%KC5HJTIIPhyc!?c4~+17wYmdg;=|o3~H}MU*QuKu}QvlQl$%P8|#8 z;P&%_ICew8!WH|s-iY{X#R8jGuwJdQ6&z@MMvvK*Z(JC1CQ)3K`n{o$@{l>Y)!~Q- z8~-pYbBUHbCMsGOr(9qVrOG*gIx}?isBGapMHw~5tEA)A{LwQ+PLXyItrGRU!taeAb)I#IocJ2MEA{%u3Bh?7$R=Fl1o#-$Zk4Ao>Ghd{Ne>5Nb~3!@1;0DWXZ7HnMnPz zj#B^<9>E|3@SjmL+=H3xchgU>`jZtdMEC6`(3?AzKTA}FL6?Nxk4w98qHZ{dzOf8J zNn(baVL7F&^lG+fX~#V-DG`J6&f+`J?0toHV!}J`4a#>=B`-St66TSnQddvy38V=} zKKAlA`}5E7q3;eFXIsEy$Er_$;MEi*&Fl)*lqft{LA1M!4{4~HzjXZzyLMbfmsZ`n zHOLmcS^kLn`Jlw~W*)wMFbuV$Ljrc|+4N1Bv0bt_gzD)fO?D>fIA;ud-sSIIj{2V~ zn3?UTBfzHO{Ck1)S|)9lb0V}rnR{P!^a_GUaJM!HcrOX)H0O{{|K1!OdqAkzKw;vq zEVsG{ABEVlk)CG#YDuIT&a?d6SRm?iPH2>!Wc+3h(G!LOt3kGH&KGXyKq~Vf2n10f zKGdBHjOS8^@jqx*d!o>*e{k<%J+gEShWn45G-9?Ub=aR-n-=Gft%AUDv$BLCz6SlO zIZRty`?Qa1fV+?92jZ2+NBgiyh;I}lz&q-DFdMp`a(B6Ey##(Rq zs7fDo6DiTaK0#rx@Q;!@Rtf%^-J1m5pjqyl@!qb@w2jI=;A=Y$tR7iM(%hp_T}qaE zIaAf_B7y%C7SzpSTpH^26Pwes#Or)awp$xR%yNYJMb}i0rPO%1O(qSvW~I_(Jn-1} z?l~u8N+#hi7&~WFQde7GXWJFiv3B|_h|EIjpc!7;sFAgZKWl{)^#o~{3cz49b~XdD zRlO%&+TR!|+f+QzrsJtL$#NMNxSTv}4#$RgIF@oCoz=Z)yVyj?MkH)y7Ql-6^8FQ7 z1D87`;x~0GYur>o&dcL3lZ6l|2|~p(tc^%0%Ey$=@hL+b2r3~)?3O|+fWU<_-L4lc5fgP~u?5>bf0`H97 zG<}n5vOFjfhK&Q$`ed>Y+QgG(Lq?&LpD!qhoZK1k<*xdeKmDHK;MVoi+=vPmn(}+vRTM@M|utpjZmp zt8wI2X}NTw#;rv7fF9yt5Lo8TC&brNWX>ztaa+RVT{GDO;j(gyMmH~!1E-DEWo1a4 zgUozSXm)6A_~Af?*(ca9)7h=!j|7q5jlvEx)s*V=#B6iML=Ck7OA1PFGB646057*^ zGuH;%es1zek`BSNhaBqSWsWn;TBf?Fa|WsuE>UQayjKnrGxQB`^8H=Ii})_j6ltI9 zW0YZ+266DzeYGwa+424Uqn#PI7+?ou8tV&T-fOd{AM&QXzE})eE`Hs3cJDiCy;Y5t zk--Js@b7yZBOWf~K0!lW1WzW#HFIwpl!bhGejqu?hIu-T$_4p^o3R{j&x%m8Hgm{9}(-2J7jv}_tjd$a%&G@EX zRQrRlE>}GS%i#;QJgfR0`&~lVh5Q}@>jAB-D_c)$z`D&zJY{%Qp(Hfl$L|Z{JjEsnOQVjgJjVm-MK?*- z{w*Vax;QlvA*3h@|AJw{ljF}Q?M6yZR==uo5WKI>0CAYNi8+TXf zq{fU3Za$Ag4aw^7{Fl7TUSM%WMJ48w;?ZOP16Q70M~ZcN7I!n~Bi9{N9f_KF_R;nOQ?Nqqc}G%MuQs2UNJGdusJYc67SQ$uZ7B zmfPF&M^*!7^4ZNxya2;*#Z|R&8fE2H=bJ`bjU}gZg8(bo(6?O}AAR9rJ*wSEuezor zXJfr~g_Y7B2COjtt&SN;=l0bGo9oydRr_CBMSP57`8++~`a}4A3sbDxQY@WkCgUWL z^X7gMx$O62Ws3-4Z#1Y9vZmz}-(cjVs|EkfrJL>l;?m8|$j0@bmu`Tjr;CbemOs($ z4w%qfN=g3_pH~XLrT8DD1YhMe!f1&#P!oMpZ>7yDJ^*ROdu7s6kG-S>Fw|I50I@cN z#4sf&2Ivsw^IA=C9LdHE-AwW9R80V1nfaOX@l@u6(+)x1PUr4d%kIs~wuwS8gfbQu z7DBa7gTr*v@NBhCLjKR@oias9zN`$NSP4EsiWf1<)0lx_)9uMo*MPD5;VpyrbguG@D&TJznm7hHWAS|6txX z`QC)1#t{X11pIV1V+DKwtuY@UaYMuwON&z_Pg0SUEd^T)uB@>fX-VQ7=vS9g60}#5|Y_{tc2csLqOeLFoaG8vT0xwS*2TAg=&b;>;APBtc zxlR&u4CH!Gr-VHbu26a@e?K|w47TEHzK=n)M=GA+r}BD{cxPV9Y2c@yG`k-ic(&g0 z&W~1z-_W8@T2DbITSY0ncPTsuDJYdNmD6FXOy3fjhSZecT*kGr+(YPmf~ENcPM&wm z^-hOdVJV8MpdD(?f1uZE&;^8iA=I%-9S>SHcUW4@c6!(S#G$$7(B0^dME$M}#I}Yb z-11r_>-ky8`e4YF>~;Kc|0`ovk9l4VPzcuo9wngzz*K5da@ZuQ6TwUef0vUv+9NT5 zOz#*g@-)sf>GvcBGhdPK1XVX9KZ;u+Q+iii%Bkc9n!lKq;#2&#qQ%bLp@j7{Y`7(b zEKW>vgf#w*j6b}-$ZIB_3ZXD|1LK6K*a4_5`>hj50RBm6Fb~EHZLW96-AxZ!kg!rk zstrh({vPh@>5-8^0?~?Agy2rNT!aApuwFDX!iFFb7Qg|2ecFUNm0^<>++75%klgkk zf!q{4tiJd|>;jvm?@@pr(*V@5RQedC4~QC?LyL|}@!%Vui8{>)LU z4s8o}SRCp7kIv32sIFj3!?*@_g1hU%-5r9vyL)i=a3Ht@cXxM!I|L36!QI_qn3;!> zduyiZzUrFftQ+gXVo9flNrSL=Uwq3((-$~>4$CZiDC&{| zTQyW3x@c^=PL=dVjW?yV?Yo^G>{;Av7!@W1s8Ov*BGr%VpGL&6{#yed@fHLZO}z~- zPjea*>JAP~EkA&96v>&ZX2Ze%S>rg_m`mFN(t_RDwrZ)ds?nrHMYpINoTn7xIF17X z>Akk4!F4GZfV@E)Mv*nmuuieyf0=6Tr5CdTeeNJN$LE4rzc5Q{Ul zu}+b9%j&Klt+A)EDDX}0B66y@IMFRt4M$M-UB}vgd8|J9YqtN{QH&CObBe=)U30Ok zm5A&%jBN=9r&I_%<^}Nk5O2-4Gx64y=A~;lm0>~4=+Q%H?@#foII3I|3CjyE<>qec zy`#D@SH=6S5WoDE+B?N!E!-+^^)y&fy!1=TfW16rCt%03Ciur0nnFBgLB(0;^51fsxD+X1AGWBaBee#F`x21h#QB(=H zzX;#;#uO8scz;Kkgx3NYVWS&Wiq`ZyZFP&fC2eaeXVul?_k}rts{3WJU@o(;Co5tK zF_0FOqd<_=Y;l3lKyd6iPdfj)UvbIFnon%TNdM+%u^FuTC2JO2)2B*0`z8cXDFvOQ z4RGMA7TjUhW{{PtD~K3{llK>xeplU<7jia%z{{Sxg!$l}g!xJHu1({$Y+U}VxI)^X z;h#DuKSYnXsEqz1gygoQ$!huS_J^x>Gex=zN1vQSSYMovg4Twr8(iPeZo->|q(RYU zUptv3M>~XJ{3V^C?b7?;{<&u~)<E&`K z9VuKTI}PgLmei^RdpwWVJSr%}o7yI%rmW=i$6kLcVq7h)e~Vazq7FRCoW*WzL`{<==kpz*cY?v?|-3N|7ol30Wko zKbBN1OJ4%VlJ^BNXL@ODDH-j^xykc{Ki7?EW8p<5=4>wOg|X!|rlsQ=t11^<{!NIM zRSECB_@5eTG)a^_?_PHb{BS7k;l!N+2Ykld9Z1bb9`xV5rKEf=L1shgw%n2ku23SV zQqf(@b8FYm7gAi{Z9jFrkbxHLhss{^%e7od(t2KH=IJc{jVvObiX+xo8at`1cXz}r zu09JW5GFUqMP@JGchPa38E<|kn|7U2JMq>ypp~2L*JSgBWWle#00d|zwDhsLM)jIC zQ;rp3WH^f-qL_9jKr*bzvoKkonhgdFVgU}~obZU4_fRzjT)IOeOb0zO>#nJu=V*i{ z+E${npkbgI;}08t1dYcyY{G;f0WIXxiCo5m1(w-BQha#6Uoz(RMm{M10_m=&v&Vu2 z9gWWkhf!<4(>I0ob6W@;sQy>~4Rw4zO!v z+nV?=h*q&v6D9*b&-1={{pcHuGlNm4h)&3%bHKN)GJ)0tzMU`2%S{uQ5f4$xriRp! z>=1D_etv)%c~&cs5AiqV}iPJKfGJaBAuuiq8wOA8L9f4)x9h<{g?ddNU<2!HYX1 zHp_56V1hG3qXQ5(Ud(A3wGU-{MeHnNsbgCRZ5?7xqnjnYf9}GpJEO=LOUuRSAhpY8 zIghoM*%nt%uKudvIR26gfkmpYGg#I3X8W?}+dXA@s}3{wgG`tkKy_2PE*HDYB-Hpi zLm$z^RHeH^f!Ra)fvQj|?#sI2L;@D4tk~bQs~&T^PPyxYTEt;6S&er!#>= z`{Rjn)pZ_5n{p&ddM0#<_PH6E|JGj^@4q$E4tMfPCU z3q+BpgQQG&?P)$U(;>js#@^Q86R~l~1tkxOTP{fa+2pFR4M-U z`P6=Liu%8M1hPnKT`*h57&ZO^Q;a0DOhWsI+&axqms=u zswX4IXZ3NUL(OZ+bMx8wj!hoZEp582E5L}j4*!7a?MNa7Fvh$+x)6D677A_%by_91 zf({(6gi=g&R$(GwRx z%TiZuK!nczL5Jbg;lkxCv#hGtfv)L8=-8K=BYnv`7NhZ@i`vVoI?~$S7F4DeB*WUk z3n^g_(rL*V(Tnd<-cqa0*HG~kXCpI4sDiE~>&B$MA)_e`Y-`o$#cerA}iQmjCG0mS_90{IBDHX)4wF17tO#XN>sUmkUM=uvh3*=d;*2#Pw(`R(O)W}$4q-M4lFr$4P03Pry# ze=-zOGP)!?AUv58gx(s55yHPUJ{d5ZYf@g_nMrCAr^LU?E0{+W+@}e^l%7EPlTpv~ z<+G9c^l4_)I1xI5o-78m55Du{61|oStDElm+p?1gt#2ZSwdo8k<+j`e?l#s>NXpNz z9*^7xr?NTODn4+-u1M5mSs3V{t8xIu3y=sv=!aDjo>7;&SK=1$m~#t+%u-YJoG?>< zSQk#s^DXnu@h)5soAd%{G8Svc{mtX)Ewh6}#$%@Hc~q9%W8Ue_!Tqx>GMzIDnL$TF zjJ-gX1oEOH8X93wq&c#hz2(uu#9Q8PWP-Ur>&ry??CZS#9`mq+GcNgdr9#$B%Izk4 zkaTxlWFL2X`Sw9zmq$8%qNYWO<1b%zZCcYv*p!>4(bWO9tdY+r_tb(dD z9|3Rx^l)ENGozHVV8p0q48_?1R8gdQUL;*8k{Y!uXh*B>zY%LUO~(&Pv)h($ju<(? zV^E1dYr#b^Q%Cjlz`i)y=NwYJr?)c5TOee33^d2#`&xy^(SCWFcQP9{O817@t zJOX(SBWpppA|@l+0EC&67-^<Cx=B^x z--WpZFW!Sf-ooE}RU4=u0t*z;W+aT&FvUf2i>`b*`o{B`Ly11R8H z#$n`LpM=&?clE*hN}XCL5()T(3m_4$5>~_odD*WXbDZidc@MmH1QF<+|8`>=j>yqY zyVt*67al%ZV9OV}!Y5>=-cBPYw+faHiX0ktwY`#mmOU8e(n9eY+FgR-i_i6sk?E10 zP2RkOYG<9KdN5!t+KSveOL)Vo>hR?=X6$5I?fSZP_o1KommW4Vm59UHJm>JMUb@ME zXbnp+YL>_pTBT~q+&dBB!!wz3l~Uh2^&G8P;N3V&^C!HCH|K*F-IY+qR8Jj1fpLF?hT2fFOGp;5 z=rX{&bBvmhFT20+;eX8=-f*52_q_Yz`2Prr{3NLs!LZwp@j}dESQq8DXFgaL5D>i> zHqZDwA`aQS?tmkB$Z}Jo`2?i2fJ z`c)b?Jl01RSMWKU1|7=kHf_J{` ztgD2e7eQ!T@)zot{MasQ#;K^+hZj=_BAJJr-gNHh3DVvAl_HVupjt`5tdm8$4@wJx zMYnP%XV%A_C%EJzUY|BGRhG&lYj0QDM*6(oy7x|Vd5bU&^@#~SaeTmFY|=d1q)gU9CkOE}ZZ^S$AY zzVl?mkO6U`OlaDW5#jhtw3HIahK;H9S!n9(WuFgc>OxjME>r=eAt49v6PyPBo|SwV z-ohogX=)*f5B4b4SyDRkTv|p|^}$@TZDsb;+lQc*ReS!i%wvs9ukOX+eBM}_43n;2 zzEjlEeB2B^JKJ%(C&(S*1UY90msF=3RbG}vKL;zcY^-hLsiPe|Wg=ui+x+Kps>3eiK9a6qlljN^k=XP%o9jJ-k4XKo3QhDg(^sPgdiZB0nwMiv8{%08G+ zss^i_fza1-?~ii0hHC+p7IMK~u!aE&R!saKz%X@L497jqo$57LsQ%aZ(AiN}Q)^{@ zzsJM{hGSVgYTgWN8WF_!QSp9Vdn!w1ePzG+07awf07btbv3n{&$TSi6sl)gk5t19o z{k>=?O3L07tL!peV4L|0G60nbH@~=u!Xwk_p_d?q2wU&Sc#DqK@}MiRlq!dLg`r|c zrta&-@3NqUkfQFfGOGzjUOmsk!`h-|slnwg*=&+0pvUO7pKJY5zK8Y1u;kDe z2zTXmo^pOQs+!)Xe)}sNLEdDq=Ps%(H}q5@-F~jrs*;r=erAXNwyfb@IYT+qYAcPH zC*t926zK0w(gaB)+sK;`)_`U9#rW$X4U~p=G_pKDcbT6_RoP!KNwrB(DG;GSwoSRt zigk^;>I+cX#|Tm2`>E>AQ0%;wnq;Z4OKN-61ce(wWuwn;gu=}LuL43{9qFeAJlg)t zMZoLl12QNO^4GTsX<5U^l$25+%Bwm|;KuiT?ku;Ey<1{)hZ;YG!0?Y-DD( z>w1NVbO*Qi{T?Y6004_x+I>TOy4yOiTOh9gBD9MeFv9-!&FGzUitJ$~dQS)?kpU8t zyn`gtY#TP=O8}H`A-?oxGb-d)a`Mz%aoy?DOwjf=sBd;4b9-WKB6ENY64F%Q^N)kq z;IaIPTOc}gjF|$on4Fv|Av8H8q#X3{8Yq8acYq&yV;}(tS{pzop_U@$7UE%VDpV2a zrz$8c?3Fd_>Fm^FW^K`8?x9&%RF%r(Z=et(rD@`BDrMl1_{}I(BmSG2l}jCb`>O!l zUS^K&H=P8X!p)4F1f3*Umo~T%s5l$TQzIh_Gc#Jjhk}rcgSCzNjGhz5$2teWoi5^y z^nhOaW{eY^1Mb3DZyN@c0GCk{4_7q1Nu5Aspv`>`qK`{%_`jO@Arr*8scCX#ZF z9)?`QjkK!8qaI4uIa(Y~)2|o$=t5NQv^ZJpEk5tB_2>9cLMO{MW9{SP2j8dTVRat# zuP;5i`+*Sw$7~<+FYnTB#wQ?)T*^sCeXO&UY|`p=!Sz3@`OOliUp9{ZPF`iOZgM4x z+yl?Et^ICZc3*nf^;iA#U(_DXLj~YpOdf`_FZLg&JWu)N*uA>92ZhdX>fchbhnR*3 zO$2iyT+vZ9QBWQ%swdYnEN?EsST7zT$iNEchcy1lg!)%<^f=l7hlxueR$p4x7r~z~eKzfSo0YLC>g>?`NP!?Y z_%MGugT%1_@g_fdtle+w{zqe!3YXBMP(U_u01$v5%F5Z&^uk0SpuBhI4)R8b2nWM* z9X*ZISdK_~)2b`O?9f@Rsv`}pFM_VtMSRsz*$m=Wdl-*{F%{eBO&eCdxc5Bn{FD8z zRmwNgFeMDFy9xpwnw;=wQ#CVA42psWgx)K3lJUJzv0bxW5Hl}$qLijgaON%8@ zp<0C2PGX1Jb?NmgQMW_vU>C;+9h~(~>#Ra8m0tP@I+~WdBpd;2bHlEz3pi)nCTO9x z3sDu{5Zi&(yO!9b0bX~)! z@j#S`ITe}?@B=tC466W`Go!FssRpym$ndhHv__P~l^sj#C(3gCe4ANm9gET@q_s0aqcTesfCDw22#rDP6*8o{iue0_6lRQZ|w`2`x#BO%4Gf3x;440ulT&5^ZS;lNUg(W1bC)yUwZB_|DAB)%r ztIwx!V)j9I3Yz9%cD!;M`P*3$BNMy%u?89QLLAkY%z}V)4T{8N2M|EEm`rQ+4rgG6 zEb1R;G{?W<#$^Ni(MR@gACbYJ)DKER#U!exm&Z)FO~3 zLznGIqzj_~@L+QFkA)}kzQ_ZC^5DK3LMeV5+Dx|sFWqz2Td*5G0c?>e9v}_3R985| z!@FOb^B42F3n^{YK7Jl2`+un(6I|tkUf!<^NUxv>~EnCM`N$j`o9+PeclYSN+ z6yyk1OmH(khqa}s9jUV+4hTv7)ivotS(VlA0e;hj3H9PKw)VAy)$sBCUTZ$*=`Xk| zY*V2oWGV9E^6(*4(c5VfC;#9vjO=`ma_D^L!frBbD0*pF@tebR9y-sHW@{O zBs+Avo^COT!3@QCCAf5fN%NX%r;RHyI*!QIQG~&BWxxSkm9ZNNF>N&1ng> z(lhwdsW4X1jo=ZIJqx|m+Ga+9R8@gAGmaQ=d-8~J#dS%iukSCH$3M#uVZ97MTYIN+ z3XUb(?;QLzWAXGC+}{H?A|kAWPyM)i6UHx}w?qB;l-vcXx)H@vVSCIC8_K?#TYpRX zN!k?#+Yk{!_R#^DKUiz~v*eeZGMHMIaoX)qXwYixM_ma=c3A{O3T0ht=k8T38-UWQ zcv-CZxL+jWr@vnD6OX5KyWnZP358i~Mo__b z(wB2fZ^Dt)iGYH6hh)8bsdGQb_^CFok)Ug?k)UMfgi8TPVuHK6mkauDlAxnxgyB^~w=kfu6swo)YS12_66>2%_RLm8-u2+zsRJgJ~5V8QTjN8PkeXa)ZXT$ zOpi#Ku{fV~nf-mkEc{3L7{N#b3vCMqmBc}neqY|QdbD2nMZL27VlZdSUv^na*ue`y z@WDuCQ*-*wS~qL`B)*cP3jo=rqYf<5Vu3uYTNUcEn_(sHUQH1~ig7XU;zmJ!!MLY`O0VP8>U@ z^rI5jtCd*mEUum#nA#3UwY;-b%{gBk7A&H2O;RdANPT-h*l_pwSyt{M_~HIgEzx6f ze`8L2iEvkKQ_Gw!P=5cd+-}+M z%Yx$+(0~s_d>P_t3_i+@-)Q7qH^l!?y70B%z~4`mH25{?Gy4<({btyRfBMxl*sS}& zO0`NM0Ze)K!k&4D*gJ(cvX6WBj}? z?X^9r#3L0kHaT5=J1r8d^)v%}Qf6*r;z;L*DTt4tRg0bRH`r-Vw0 zQq;lhN{|n|kOr=2BMB7+5oYmDx~ zz8&Xht-7Ug{@m?)=1bCWtXsw~GIMhG3)r6xbz(#g(;kPpP@h%)h*pq5lzzvjDWI;e z1UUx&dKy08fKv1z30+m#AN!yy=wr9~6kgJK-g7WFL(-;~AI8ZB+fz)gEu)cDtzMcm@mH28f-DVr;MoC{O*$PjN(nK zEKo%C_+jgrmJ1oJMW)1<*fJV>b{PHq#~S-6(e=5Ogm_n-Ga%>2^XV!gV~+TN>1Rzf zREu|*U;~GrsQc~KW`}T&Ud|H05F;}|Dwj#pi7uu;ZCeg>WPa>D(_&g_h_D;nKWg>6 z=dYn*PuDUZf5)r#C6-3QnQMwSE9O<$ctJ{XWX%l?!RUj%{0Ccq-dtKy64u@98~WuL z_tC+lRS-r+HV+;_rhbnX;vXDanz{{P8M^{YDKt;*1DZPh9U8PE>a(A3DR`fktz8t| za6a^+fDbMSl(W==Je?kchg$9km!8}; zK-Cntw|g(tvC8j6{}`A#|JyF-KLWFsin#@|ild_&$-jS5VU}^Qa3o>-&sT9>epX`> z9&S@p0Gp{Xhba#`JEu9T84o)fE5Mw`#EgyGT=4&Iq0g*p?QM?0$;Pay%lg?hoBsb5 z_c_`ByXA~=q6Iz}95sB4&-Hzh=U|N|&}Rugb_)s{c?%}Ei`=Rta;Yuwt%mvYxY9SA z71>%XMV1i4P?(FXU?qn0O!BPrV9`tt+kpVdWWb5PVX6)kT>0)kyz`?`L0YIRnlu(jH_&3}|ldk{( literal 0 HcmV?d00001 diff --git a/module2/exo1/toy_notebook_fr.pdf b/module2/exo1/toy_notebook_fr.pdf new file mode 100644 index 0000000000000000000000000000000000000000..52e1666fa1abb3eab1c1e68df71d60e2fc96cae8 GIT binary patch literal 59871 zcmb4pb97}-)9#6_iJggU+vdc!IkByYHL)|XZF^!n=fs)V#+~2$ee3eQT5JDNdv))w z>gw)iKUG~6%Hom?EQ}oR6#G}_Pw*`4B+Mj^CN}W={7jP8cCO~mOp zv{)fbz*_xSrw~nKm$2Xcc-j7HS@u;yj(pgpdpRM~=WyFAyFFgtPb(2KoVei|#>dXm zMcd2A_xqDaGYO1B@vEghuuMpmdT&$$88VId*Va?o&nMGV&FfeG&p)GL?Ou;hrIJx3 zWRT6@Qoe>ipNM=J`cYAAAaxL4c7Ne@E8MQF`i{g7X`m`Ek90j~%Eqsc7Kf9@fodRt zI-byv1iQwM8guPE!R+7!@7c(BODe?S^y+fk9zDOs<92CMN`_GILv2hMLQHGFuy$}5 zr!s_7`rGnxU>BB<8PO+>`73p0<|xBnn{{#GtNb=stf`tn9wT~qKeN~-4hH2q(lzf4 z-l=msTl+SZw%YJfgO|q}>-fWXgv+Mzx}@zER01r#{aSqu7bQDXQO&5FYmFWintLI^ z_wyHV36)yo4>|B~a;9sRX<8vicRDc8$z_05)`2QpR)Zr=awOb0(+@OyOryPx={FB@ zYKh>i8l3ideX>IH*4Iu)CL5ji-0bkxa$PQ%r2}x|qE4#_Rv~0izl`%pvN8QI>QYy< zxyO*+7Hs%lafj!4{n*3_y7N+(*hm@8QGa)+p}qezk_;*IyK^f~U8_PONs_5mGl91-^r)O&&)(|Kyvi6i zb!sgA)ys>Xfl$%R$HUA8G)dVI*gx8TE(yRtP`RsSjqcl&S2pI| zl3-=sD_2k5)AgYqvByl0c-X;yTqc!#_hR+WM+(+X*D~1lLxPX;SW#OZARXGQGMP@G zXuC@)!Oab9DdV#vzb=_rLW=VZI9d@&i>ZD)7myuWKl77cllV7DU1958MjUNoQdczZ zF14~E+GuyqUW~6|Zmy*++(+2`16Ip7^k3$V9*JlgHeqdl&KZ^5&M_d>GzCW0T_25q z%}QL=<4*@-+n8zE36ee0(Tn4|-O@nz>bLXJ^p9$(s)NB8NN@er4gEsh_B$nVoKE~} z+3plidXk#EYr!hHv}YDH4!8s#bpFe z4Yv4}5KVL?eeg{~5k{zI6PfjSM&;OIY~S&q(`YOPb>tr$NjS|55nfJOtgCe~BJEd< z5d|q(oxwz4oq36+$kq6vJS2hBk2k&~XyE<=f(fw07a&*B#NF;@oWWn!s#w#eN%mPj z4xJgj2azL@8Qb!ohZpIRa-rpa3X@m_vmWmU-0~dtPQev7UNKb7Os|yB6w1Qu)+k%w zHzH;zbhxkDoZNzXvn$bfQk6}_<0#HPtm6*gry!jXeRb?%zsloZNkFY=vLz8@6IS`< z1hvQPJ95oeWkHf~IW2Xj7(KhzpkLiDU`NbbybEUUD10e3bZvAjb@7UHzdlFY7fPa^ z0cn`V3<#4u@`e=4`33HK$5P1;iP9 zZHS}Bj48D-)0n=ercB*_Oq5aYHlcMRn%vfNNavofn-N`jRyw8FNvh3}uGqZK6KyH)F&({mNX0pE!>uiUNP(VH`QSj%aLsMHPCAhJqCmXc=~cS@emB zr+Pe)NAdLMXY#x!>$FRdXKqq_i{Qb3~FE&n%(#cyNbSk=Z>UJ zV}{}GtxN(Q9)pNe!38V+b>8B)Z)q*e5jLYHrOyOL+^>Y8!-YgO54aR0)^$Z)`DY`{ zM2O*M0hTuKooSy|FOV$nXNzV7WM)gx(9b9etv-SI$^vB6v(}~GBKH0Fr43tJOkUr% zRX+e7L8izm4aY0`HYE>due>m_wwb-rzu6sm+O6Mg$yRxvX=rx+zHHURtxja?Y6=i| zcZ#GUU%$-M*GA~I33*vpYRSNF>T~R$(JItz6fhJ|mU~BbNIRBj2#B({ze*x^qNoX2 zghPEjsXbbz_2otlCM>FuzWuH7DfLu19f1UvM6b}`Y2!4zUW@^$WKmF|82R8eD7j?f zyGs@-ew(02OD;|;sIz6UlHCq^A?>K~B-)Qj1l=6K1t%t5~qe%2E2m z`$?GvL$~e_V}Mc91zv?}DOK5g3>q5$NcZ7pf1|9{yd`=+hZw77Wj*6MHB-KdX;(d&NUUimb4V~dt zO82fVq1 z*?$s`ztTTcg@yaSaTYZ%Cvzq(B@-KSQ&%QcHxt)?-ev5KEzOxUt2#q**m!WOOvv*xtX=8tD`dstDxZjo>0NFuyV5f_k`+v zOT|i6lVJ2ZS)w&4j;4uKMbFT;Zpe6!V>#HOrYMbifKzj$!I<#d=5h~4IUypVX|X!2 zmS$ab^WsIp$pZ;lbxpd8a(dAZ2`v~4Emz)(dUax1BkrlBhHMIYDr;fwme0peXR+t| zro6*hAD%a*xNjH|Du17pyQmK#?S-(y=YFKCoxunc;vOr1;6ojmf3sT~nVaU&HP;OC zmpgJp#3_CC|i)ODv6%o4{+ids+Yd(sUttn>j&^YGJD|I@^acXRGIQ&ewt|2e-7 z?S&yQzY=uOA67B3Y%TEs>3J4}LM-U}^dDOOy>Of4=(g&!VY;GDmA0xIUVMFC(CQGs z^j4)d^HjgPLu&oTs#N@<)=aY`;8ix+DT5bK+N|jZvQxHs9-EiI6tRALq&0n;mn_b- z+ipOQqmtDy&B}d4UuNKFXQ4maGDP*hZLMF2E1u4|Fx)dl`{};tLR|mY>`(O6^7OQ8 zbqgCW@P9JzU;gnIyg`q(ulSALtwR@Ei@%|fxAtPBt%Ya!_&|Vs51;+kQGae%wt2xr z{F(G?nsICO&_}KLrf{!daUAH@ZuqP_5_;`snx)>@Y2>>V(}ZtWSU+{xOw^jYTMzT^ zz49-$|7tp-G4yaR&oS&}yxBmS*Nq4~J>s1MR zkAt1h-sqTAjsE;o09Ol*`n)#dKOQhy@;ZuslGv9@rMdSXOa&e&enc^~h7P|Ut;E_> z0JVByyRIqlHW;gNzV%*!{$FM(G`Ds?(D#y|&-Lrt&2nY5_Po+x*THhdBbOL!lO_g! z?{vB*uWI9@!$k+@uSXQrMxKhV_hA3dHDh+XmakJ#yR-HshxR*HkGSPZwBgUq+T8vB zs+TD`;IhPDn^_>wG2QS4NOZO|ko{>Agrvmub2Ows;&Z0r(#yM?pD3mpym`s@?5b9|3Ud*xjAmWxv!Al6_R|2J0BHe*d4&g9Y2qZ#G-W5x={# zV%kZ81ie14%K9z}2O~C>X41se&=Z^pTZe(c417DDNnt{ZSbJPBdDr_&+u-&w#YA8x z1XZWby*I5f=C2w5aYWweDFa?Gom}Y65t?{Pl4kmtOR6%rp!QBJ8ixP#$V?3YmqG4C z3{&?bY3@*)1afQO_HpL>rzumm0uBN{-RgGtqKl@;N*4czv;Uu1GxUOv*}c#BZxEg5 zzajeng3#ZjM440-j9qL={ssKsnEpR7AO0WA|2N?M|BCKx{~q1pSvdYr@J_Aktv zeT`#5UF_!p_m(Q}LgYF;wfHtUD#REWxp2N$B)_;9E%>eO^Z8q2!^7U0%SC%T*Y#P4 z+v%puqk&KL=S%O(=XI_J(62R9zwxy7Mu!!m|18t^^DI-J?JQ5f(Kh_O(bj#cF2H@N z2KQm6W{qR;V~wNJVpXWqVg>Qla^-B@w6^$`>#iVzsKfc-H*Tcm3b?`Jri+pi`yjuG zP+7p^md6aIkvjwEKKHT9vgCR4e;wmrV6TFFjnCSp;tRs~1hrA2#fFUR2a{GQJ<)dV0k8 zd$wK@vpp}>R)`_X^d7ls46l1YP#=Co`G!gn+h=@s1v&iL{pFt8{`p}&UfY{1SgWnN z&=mt}4)FOC8PIuph5jJ)RM*1SK}0mB-$rS{SsfGQn2sW(_i>1C!2t|>?MDH9TiS`x zluOfS-PY0fb90+ySz5EyB!1O8DjYFyLKp7zMBBVQ5>iSw3(fmr-+7l3(jj!$5?J>E z>V{lk_m+K}11pa5YIFTsUW$Y=Qz6p@A0pVfUyh5Y@WJZ3-ret?_Lk^s)nJIy`$$_L z%TNN`CbHxnKgUg9iQhQ^o1gbbmG605&O^l2GR(NxOHuEgJK-lwnw72FvO=$Cs`eWi z@7tG1VQ%P{f;WjLVc1`=h`h)_WypfuTP;BUrD&#UgbnIt#;mtKmxX{I|84 z3P-=njz1+Qd&ITVyp?(@kY)V1#;>FgIH13adq2$wH^z^w<$vTc?-n+`P3CvFrNp1u z649Ljc=msuI9azvFM_%+FnzdOR9#3Crq|#j)~t7jO-D$DdmwOCzRv=Zn+QIvlA~&o zjcI~r|4ssRz4|PcCvf)C$1rn-p;b*&FEJm|H&8cb1gcF7+~Wplv+D~evv{?y9OixZMj!+z|Fp%2g*^*&LmLW!vD zZP2mX|7z!T<;-tV&%tqOV zRt z{m`|Pg;yz4XI`Jd^ojks&+#Tr)+(t8UK=|NJj;3Sj^BmfxePq*P2EnC#J)KBKlh^( zt$D6U3F;8~uKL6IR+pvr;uwH8dL0+snQX(4yyFgP?FM_8A9_hnnf%^k9s;7$52Ve z0QT?HQsxd2=fXqGUxfwJ6<8v6Vda=FyvcK}3dSKIDSo2f<*yXPldCL-6n8+Ww{L&TB>^!&7q zkw;}5;RvEt$2za23U`jc43Vlcf#bNJ;hV;T=>$zffpygMob`s_fv1g0-w)g(X{^2+ z>jn7X1@(WerWCjmfkJCKG^Ey#oV!0=;NqY5B>^bIxFb-4sakAH@Y6>ibV4bYv9h46 ztql-SZ*wQqdCi@-QW^Bo;^Z+X;|^}W?_w{c#X-LryH&j>$=U3TC*cNo54e2w6I7_D z*$;xQg3*Q<5WclT2kmm6fff|y_+axjY7M@h9j(~CSl`#1R$^aNKlpKpAU*~9!&K{C zkIgKfxd=CxM5`P!K{JU^x?|r2FX_8$e_;{E9f5GZ;-}tNw33j;!9U9Qqyngo{|M*zv6&Kg3i85ziCP4V{uy^IdKZvm_x<%*_=TtzJ2zB5;Fq4B{TE}7FAxhV4Ic^GJL)K?2lNDkT8y02zw`pKoc>Q zWYn>@z>fS6l7%u)7WwO&30uy=VPPW%&lp5-{GmY6BBWpYy&%Y1&D^ULwgtcbF=jhP zEY6|pb@mV(tQI6m(r-AZdSDzGS{FFh`c%#`Nzl}9!UYtA+lN3+Iyb}gMqZa@}W`FQA&S*d>KPLge4 z4d-1LLSd7eBlF@qK#!YH7^aiH z=`O|pja0h{b| z0N?1PL}hOm!;#=JrhXCc_~YD|C{w*27TXM`5`KFhqL@HAgd%}_Da(fQ4aQm% zvIrNp{8FhI|3GwDft*Ab#nctiLGVviRn?90HDtRLu1_}F&C{oBOrE#ye5?tZWF;_E#HwG zCh}X}5TB^40wLF_kU&)RdG>+Jg~5@saXBjfhFYbj3=GN#7N^BM?xrbfsTS>Gwb~u2 z!I$^!98qQ8Ug*OR_5^%U`g8T%{HuZ$?hd{#iug)W{+xHmL|i&Uq`=5vgfk?Q_JBu+ z4Zkh{%7-?z1+ZP`c^n#WZNt0~(g)54fT4wioJ2I<(QT!)+fzCmBmoh4qrpxoWm~Wl zmK^1FE=1v2uaE2zDPF^C`BZksWRQ&lC>qd0_LnplU=E>&p8AHPJ@>jFODGK8mfpf7 z&T&;7pkx3PL)^@e#sKUtMB(;$-ycnouBgzN6Iaq<{?*N{(?l)1iCin$&6mhg`yAh> zr2nvRv=yI?6k6pvh0P)61X4u$DE}5QIx&JK2CYp3reNqHe-=2qVvc}$sL1uvCg5`% zcHPb+DIkVecp{(!P%AYk_@Q}WrTTt>A%W7FQ6xcP@vq;|=p9!ZiV3T(x%CWL!lu_# zd?w*jnS|HArudiiV>Ns`9I-Tr4ffdm(JaH&oxCN0`HH{}H4;G)2v5F7D1I!&L&`C=< zj1Y3pt%}TXjl&&`0@n@p4BQ^R3g>iEFh0U49=`fl%4?U~`^ymPnj6Y_6NgGqbRWH8 z$s9etr0#42XdqH00DzAZl{i=a1cn*&Q~4psU8mZ(2zx6aAPG=6pS_zUOHR`E@xo3l z30lg>CQrkknvxoU4~`tokURx*iYb~2l=w=G8V^nQ6(&EZ){o)*xWW9764u0>BoWVN zs!@ROGGb(GXp7!~}>7B zU>1OfN|Afzu2nb{uU!Q1YlGYzkWmBGa=uhZ)ORgdUi=rFJw5j|Mz;M4lHA=fuXUYS zqSUprQkBn{BcZ&ZlE`T1AmqtBk}prOK`?Eo$hn0>UKAMfnAFp$VKZ!kp)e?B5ci2x zJ7f&4eMN=Iin8(VCz_5`+;8O&O1{1mwZwild4}}bJ<x>RCS59RXN z1teudCR*~L3gt2r=Q4q}k!*Fpqu^^X24()}eF^>3(1bR0f51xGes~+2sfHMVfVx_!`o+ph1XLIvTkwz}xCm4!fXc6+oiWC&HF8=9dUOA6| zojTujhwgu(x|Iy^v%gmi+3Wq!hwtw{Amui`{{o>kwmk4^ z>{gw~R%d2Kh^Pz(Y8^`BGs6XY3Fo+>dURpKfO3|*hFIZY<}|MI%wVkqv%9*++gj z!T=t)UW!g7uJSWZ#Sp+OMg(S!xK1YcXn}+?8mUY^r9DJN@bx>D2@t4faHoXvXXwcG zj9_s_;|w=hLa+lY^B`*YUp1xjt{(cWonN~<>ORxX}u%Q9(-_VgUDC^HBQV7xF02A{^_fOCuOScLulyO;+D<~t&zc%$~x_81~nElD^ z@4h}Kbf1x)=AI>6O!~zy_(eTv69rD?kzA`P73YYdFQ6~=vJbJa+8q3zzK!te!P?#{ z4?&m&^)h-&em$_Tphad5C6IW-x`F;b>n9SPHhByzfg=XrCl?P zKaVRU&*@JxZ3oXH+T?+jZo$I-j^bLzlI-_bt-7B+*~hIMZsM`#cINgpB>37S#4S{; zjg|X2QPJ~p&l`l`3KJeLl$#AoGu%!?=Nk$?GbwUr83}DN$|wGCS{KpssR`cp^Vk(P zxL~TPV4l(8NU8BXD6qj~^0{BSD=N)6wq|sHK{%o=oIu93)Tvr^_doA2ly$map*W=if{9 z>tamf6-YQfr#-R!mg%4C2Io=8!BT`(C)jfW{6(AjF3Jc+rt<0gCQ!1#;aD(UFmdcg zNUzLbw&)GuWqe;Z;Br9_U6{Oj&9oVDS9nBf1lN+Vl1Hxv5hXEn%#GHbt_O4|tSY}0 zw}0yyPi{`tgbm6cSCW@DNXTgM3^>q0sPAV04ZO zHNYWW9Xn`tYS6?1un8O?H3$&^wg_u&u)Zk^O8$9QdoV!6tVRQx^AEZLJ@o1p1ux#W%KZ1$Un&_h((i5Gppy}wRQ9wCD!0g^ZY`t8b)2&~SiH#kKE z@n>Udsz2u|X^osNqN*g{0b6fD_LwHodElI;Y3?Y#pV7l`!|9!hzTRC|PN~D?OL67C;F{88PeBm|pbrDslO$59wmQv1fWipca zY4D_zj+b~cfd(hT)(|{wh3g7=I=^ElZqKYUb<*$HUX*ecMFP)K3fk=QYRtrlLTvZ5 zk)=(nOp+Q5Nxn=bq8Xt(#Wo!l|M6Edj~7|05{5Q}M7t@p-}n-WOMoFt77YFjFmL#Q zRV{iWTo_ZUJM5yK0Ph=uh!_!$fAhRl!M=zG#b6TUh9dI0PzcrwxOn&t#$GPIB*C2B4~PGzwNTkW=8+tQB=sB1IPvoyX)?&X_+$m+mwa zdP%qny!)ZPK}H8wazD39FNP1LiFUL4GkFS0V|l0dSg`>mTH*aQATJXB%nZBFtxo!A zv^b5DTj)+151!tV8cyswdIXGg%g3<-g_LVi4vj*k5Qi=$aQuW*gy)TDh~2|#UP-U9 z_+@J1)$b}W4Oz%-9E@)JQ}UbB1CMWK%A)nKx4a*_L^pSyseL{fs`yEH7@1PDP9}xj zD+;XF+)8h*hIuuGV8C^BCn^8}98U@0IsE&ly2`K{y{7PKM*gOX|DaV}84rvgJ@1(% zS3m!(oF!M;prddBYxTOS_}{Ce^2Fq77U)^w_iW(zpqDQ2<>_7`xyj~ja8S0Cu61AxY$O}gbN>S9h_5qLQh>Cyxhap z-chr9v6I@$8}WwtB#ERvTQi)^qE`$(<#VyqoXB}L`%f#B^}_a-HT*tKyubl!z3I$P zUdB{Sz4g@|p~fW^<;FK~RMiA|u3f?h3Xn9X&xa%Zxc#c`=BguD-)y(H9r11#v9_T> zV5+JH6%ptW>?ABqyTX)V8$#!T-wEN&q?@X2=z+@jG=$##6=u%=h)>2f&{Uqt?)l8p zLq^%!?fx!;HiM}z{Y(%Y;$CG(v^C&y=K$v7^+knvt=HnOOTsem$^;>YnVO;3bp+<@>icD=e^AV+f=voO^!@Y0s z$;E^&C@JaU!qF;_RnzHnme@!`Ed)|VCtN}(3GC$fTzDT}ocxME_qYx%oBA1H=(#VRvY6lDR8E&+NH)$TAh-FVe!IpM$s2hNV54eY_E{yVSC zsCqcUN_B6nIhL|Cxg3Xcx8GHi$BfSHe)N)zE#7W?`4#izH%(iNkNX7mhUg?(0ZRig zKAbvE7#+eds9JYTJox{Z2q34-#5qA?uWHPI@w$9#*9y<~Us}%k9vAke3t_Rv_W+)K zIPet2RgfX>`_(C~g^Q>&7%AYZiQ#bXi!}0GT>iN1u-UeQ>3B zd#%T)_0PKt`46HsoX>BpmHzwL6D?du{I7)&>j_kEao>DA$<-n7XXUgNIwo?Cy@8@4y@(- z-rgu*;x_FS*1)g9b@Y7_i#FJ#sK!NQog-d+#1(mR4khcT$E2TC^eC?P?S^SPV0CcG zAEx`&5k|Au^F4o%$baUVPUw1#Juj$Reb?lRd?aq3yUt6Omy5R_QTn)Y-0<*w+cCM$p>2c*J!H?nXkW(yY zC?*EYn8R*&`QB6J@&KxtHlr@}W_sh@U8b+Y+$Me1Y z8Fp&@c4VT;kEwy5Mgf&rn$67#;;(LIsUbRHOLM9|jpLfRFW0B91l~^fJ0XTr@!osQ zC+B|X#W~CsaGuGuqG)&fm@Gr&fR5@|VOuxVkop2UB8)%L-wu~8E$l5Uu6W+k{SGG{ zV54no703pc5=0TlHX>S?(#akkE4f_M{LfB{mONknbe2JWX9fo@F(L}%*4`I0Egf90 zDqUGT`u}pl>NT1HuLEnAwy>>=OB~;G)7{8kgM2Bqd5u7#V6#BE{pPat=A; zRD5nj(YM<^Y9PKepSAwI!vfxp*k1A+EQ&Mer)tEP#ys|CeIdOPBYBf z%k*~Z);$w!9nCjr25ziG{0!DDh&V1A*JtTlh(UgW?Ske9RM3XvNdL{SgCLl=hHG)p zPdn@0XA6e;uf{`uEqj_0)}CQQK94JvI6CwSe04A|uY$d??{HXjW&wCQy}zW8puCzc z#7@&1tmFO2p0V#*&)TrOec^lUdBkSwX|w~bDCyt+7Nq-9?AG4h!EX*gCKyhDd2Roj zj6cNZ1ep@cg^?vnB{ZAf;NvNCz>l~e<@{0N9D#LvZbh=vMmc623rxJO58IQj3@I0L zLj}~%W`6EsqbDC%mGM$+1IYu+pLksYL*jH>m%}cFKCZt}z_J0B^L--lmBrnjGh%Zz z-|S^YDX5s)Szwook_|u}grWy}H)oCLEnr9fBwPqee}0&ViFnHin|86ngfpDYSRjm( z`ZibmehGMoyBW=C-mPg}>FW5b!COx~Agf9xg^%Q5cFg+FA%v}3`m_mVl7<@*E03gg z<#5=GmH5r%9x%+th1Ks#f|tawBVI*s1B3lUP$U7Fx;QG`)&2Hgd5{jlj*Miw<^(DC zmT!nXg63lN1|R}fT`^id%vP4KmTXoOe+|A$@3U}te3Et_z7vkIXqkR(ii8>$jBeM0IOPfv1Kp(ZmQedDm7IVY0Gulu;Ml7TQ5;scA0&W<|u+if9&> z2=VV-Ep+8k7QB(VHg2V{32+)z;~{h zmGGgXDHX`PzS1Wg{P~C`DCYm|_$bahc}mgu zjD)Bym}mSPD7{#Vr;b9pw2*GRp#9q3K$VMCC*si8F5DyP?7rqBaE|TmR9UyaqdH4O z$s`L&jEI~gN7GjFEI7Nz)p4x9dIL+t7ovL>s@v~KiIh2z6^nB4$~GJRw6{@k9wd9F5{_lqcKFE*vfpFp4@r^lXM4GjdelfQ`%pO~ z6p8$@8=_~5l>=8Mp!cvM)b^-!C@bNO4$Lvy?tyy&ifWJ z7bQb3^i9_K79+pXksr-Qees%ksjQK`8XXB~^2<(xH=~dMNNH(Wj2eB!GJb47_2Hn>y#z+d1S;wUIW9rj zlq7x`Uc=%$z&)JRTIKTQp9moz2 z0Eef3nZ%zSO7*d`1J%5syzFZBX2K8OU-lD4z4Lf$?;Y<(FI24kIrL_r2Y3g~z8$gw zG1jXM)NGCVm1mQJs%co0v~T6B4SR{p**zp^PAv{h@Nj~ppZ*r0yn3Ei!*Q$`ws7Qq zN;72~Om>k5kmQ+h>+t(eCH}fksL8381w2<@pdQCHI;QpKI%U? zTl6`rm%$L8RVmGqGBOIU6O)+z5--436PnJh)^%D$enn$l%~W= z!0<8zO{j|aJ%8j+jDyrfU~p9x7&W%X1Gy|VNwo0a70^&wa@rgDo0^L#idR&FeDEO+ zABybSUry;2Kzr?+t$e0%S5qx;XCb^zh_+FMLpy2siF8#niu|Ki}#J}Tq4oF|iG zhL>mVOBPubydBn=0+zKJ`4^%o=kwWsBWC_Q@kA7uk~y(jGx(?zRK_C&ESolBS9d%U zxtfWNoUXYayxng6$i+Od(Q2u3-+%1Fi`;aU)7QDX9zCT^jkz4h)1e36Zj;5!$G0&z z{SBFqD0`xdeIyFFunikdNm$aGtX1tv)ME$0-yVyI74pMbz^Fflx!#1oM#84dj15M$ zBG#95G!=cg!wW)Ln&F*cA7;ZKFMl{L8D##B#6%)%o{ICs)>ng>;ev=oOssSHJ*&~B zA0B{=rv>}=R1jfvi(!H)Vk|LL!HVSsy=%l!XQ7iy`^UTa>+G_rxcJTAiZ$zIX$Xx0 z?k)tz;PQ71VcJFLq9c3_O@Ry zeraV5LQ_fkC#RnJ9K z+Fwq7OsIKV-t0@iPFsIY_8HR5g zDVP$#v7Z%cDjXOGF96^nmNdzVJL4K$xwzc*H#q+h-TmqUoG0=yB#gReUr z^nc&NV0~klELk#6t28*H;~Nd|BH%t5Zahd<@i;4PZb~TdYAh0%K3WJduJ;lK)D=k< z7S=g|K0zUH^@6t#*0L0ySxzk|6elmy7>WB7g*hjJ&m24w1 zh!E@>2DYBem20+N^g6wWX0gijSv_vH^DliLxzP6dw;1+Mb~QYYO%=ye)@Bu;sFOvG zSHbp!rBcHxMID2qq{0wZA^*%XEI;U9;uA20&rAatltb@x`jwSmtO~rn_Tijxe_JWb z3*`SWJNn*|H{O4r1-Iz4Y^^y%^X(!65NOd2rVfgq{xP1F_IPa(((q=C{T$vMnICu= z5Mb%70r|79qU$WeXa<3hn~aRaSqjy4?Bir>nQVZBG9M`|h*uM2ZUxEfHM=IPy>E~< z@oUr=!rx&t9U4vjY4gC1zT_)XrI`tUKVUP{gYjLh(Cze5HnTc5DPe4qD2D%}Ec9JI z%t!f&G;u&S|N8-Q=Pos)kp59F+f3CK1|l*|rAKU>md@rXFvNK00z>u+wh!6Aa;L9i zjjCm|Yvb50_`A6eX+C)bD>dNwJBs1q>+sYW7dKU7C?}{vL`960#AG6YlRwx!>SM5~ z4L2ps1dR#!G;*At;#mg@>J`|4sbgVgdnXzeM;v7#jq0aDq&A?p#LQIFXdA;^D00dALU z-21yp07^KNWpfnCH#Is~WTePG|GyzK-4X$v!1&@I^5|! zTfAIeddeXF7GOCgG6j`xD{(94GK{BxUJFrnMvJUE*O7mL<`=gNVQkBP2z*Tc0+1%Aytmb{{GzK}9!x*5UBqHqPM z3U2!Q=+6+U1#;XVWy6^OrtRV<3#pwD5SekD&7~2m!ZrhBA-hGekzwAEu!C zd%__%!Pd;ZY71`_=bYzNJbEQzu^6&quN>}1YgKP}wR$afvv^d~w7+SWeETtoxqk2S zgDNBlLDzHVWcp6$oGj$WTveuD+Lq;aB}Z;?{g1}Im4_!^&DSJgVA7&Q=zY+CuWDIro52P{YAdu# zkqK9j9U!7xq&-i0cV_;^@Kxm^c|vl&m1fk`CA`4m#|F*D)MDvP&U&k!7tfFKJ`xd~ zVV*nCAFI1M8P$}$Nj4Jltz1B@0^ubSKI9B5dLEiPd@BTJNk1D;A`zhwo}brd<_)yo z^wr5r(Yw*?+zB8&%8~qM0yVx~v6mQSoZ;b^DyOR37^UQ6NMpH2N)=CXW+K*ap#p&1 zV5xTRp{*?*XWsWq?08WGPe%4-!GniTtZjL4b!KDb%$gt1dFX&=re3$UfX7a^#n$rZ zNNvgG#K1cJ)|v~`sXHCnVkP&Bt$-0@NP76fR58^FXJ-_CodUx5H z&JqtYq`BkN+YBjdijUFYF$(9}ft(T4+Wz-m5vmbwfp^z#1pP#&<^E<8!F6nxR7B;? zHE>%$6W-I&g@=TkMo1rt-_>@2&2=+s%P=%LxRcwAaR|C5N{nCJr;+d&XzNHi5a^WX z({x$BH%O|iiL-)3o6sG)Ntpp_x=BF5vPscYh4cBy;O0bc8Kf>L@@$>DJhJY7Kx*r!CxDp)jS_nJhf8b1bhMB^lQm5Zd4lZ0>b<0xTz8K zDUQuWAFxX0G`QA49rYR~#hX`bIp|*z$nE>PIK1*J%b4_?!WWy}vB&!s@j4IUXG}@Z zYj$p5SXh-lZ95(i6KS0mHvpM>sOtSU1Z7Ad528o>eT-ttbG@yqqI3u#-cJo4m>v2E zt36LsbeB=z{GjiG79%<+JM(fIM}~Ex+`M~@y>DqVw9cSzOd|;q|I;lP?^K!4{U@V_ zXe#m+Zjd1&IPR4IE95F^`H*hb@*liq?W&h4@(dYUE03$H4!^hjsvQHyr*lUtC8#81 zocaJs?v{}$Wcrr+F^)V@3-Bhs3u%I;Z2kErL9R9VHR`;g%pZ5dfeIZ?g^$rAb zciOguNf2j+o^)y%m@%r&M<1`~hKSJ!F*^)I6YRG}iAZJEM9!aV|Vftje}54HaY}*%y`0}kitKIYkRe^yD17tx4(RMt5!dd z75J>fjPGhctn%}4ts=(I%(3padWPk`V7Cuksnye7AOId2oCL)U2td7Ny%%d^v$h`h z^Vgu66I)~Gjlfi|IbP+La+2T-3S`DGW3-S+*IbEMi)vxR5;S-UWI-JUv22DA(wpMV zvo-^@No|=YRU?x01-`=JYt>P2|HVaK+G_;e)e!#8aL>dRfvLdKe21W2`79u|UV?c4 z;gmI`L!Y1snu+y;)IyNK(9(eu2$MRm^Z42EZbZHHMU0^?DiZ9qdds@r{lhk!WVP>Y z+J6DKKu5n-M2WG}>@J!E{1Tgwt@^?jI-!)OSZI=3NfMl} zU_A&C*lC>=Uc?RN=AvcYd1s2lg<>ItI7}F_Q~k~oS%ZhK+IXj*UMo~i6&?@504^*6 zs2A)9WtkEmR;}7ukq&K#KOq>_f>H!V{rJZTCX9^!BRQG+6UV76Cr4WLf@e`6g#)?? z$QeO8JN5k5^*D)w#JMc}!0g#7Ss;^OPR2nTaYWq_gV#6PCL8*7dZK1eXO?Z9~L_TmxVQQrKrGqkPGPkWlN_ z*FD9M(eAF+kIr2-$y(485x^uJOZ)#d$K&2{v&akZ+Q~F3A`a`*>KipqA#d@5Qp9F6EBK#LckG~N1#SnrguU^qQL$l$$1x79 zS6c$zgKyBRaGd~FaY|HTG3XTl$YAb6iH zsw%78GHH3A$vc+%ulXZ@$xLVUeo$oHx&$Hv93qWwqz(pPK}Y_C)gg@;hXKJhI~S>& z{q{mWn=r8`gPYOl3=b3s7(WVU^{uxWRCGFw@h2_?~(umdp6FK>1>hrtFKNUEJ0x5 z+q~{o7XdI7D)qK)X@ehrIEi?yF93VT9d#=)x5nTLEiv|vFB$)tXVL_C9a||U>Q~`Z zl7SqX?tz2I^!)RQT-Cnp9tjrmO`dvhWrw`r1qv`0P9Bk(3mH3XpLSZ^GQxNsPab%- za0IJ*F(8Z}QfC?5#+ar_a6gZ?ba!v^EmS4Q3yzW-B|#?u8W1xHZfg<=)XANOq4QZn z1gx+G7GTxyo)Wpc$LcLQmJaOMIF%T<0QikJrie~E;;_4*$f{KdGveemuY1*FLZHyY zgOM8=h5QLuYIZJ)U1pDv1E$fy9g!GpN*r?agm5bvR6oRWR>yno9t~%;Q4RWr7Iq}{ zo6{T$1gRbv^c*0`2Ynh< zqwZDz>6@%n)w$IoEI1U@!raW01V`DIB2A}9WbrzXNi0Vx2Ql~_WMCX{#@?wxA?8~_ zT}>I%6J;}Q7*0>`VTsw?17_9Q-MwX|SRLl(!iFJ$qT|>|2l2Qb z=%rlcZSETZdOhF!_c>hHAH#fAb z49P%{@_Fagy=#mjs;avD$>z-o>22)6XXC$%d6>?toite}(FDAI{yLUc<0nP*@FdFx z6naiq8eKF&0ZmO90N_!6C-|{dQowBXh#RacScDemrY*N&m@z99p<8a*MT4Cn;={OT zrwY1c*wN|8t50!P= zh!Z>5T0my&HO(e8AG3b8ZL77eW?a;sb=Es>Qbdmn<>HHzu0KT2iRQ4tP?=nm-w92f z8+Zj6k8t(`I+An? zVV$3G^h<|5dDlDd+yCcF4yiu)R^11(aI*3mp23iP=%Iw!fbaCvYyWZUJlHMXga8>` zpK;M+e{PKx`6c7F^|V|7D2Sc|i;4Q4t(znOJ!6uo>uQ9pI4h50>Q%NFQB-kID`rw1fA!c+_^xGLi(s>Y~2PSzm zq8Jt@Bz6;um|=rz!BlI(t48L*LXkiRia?*--`XWIc7$QElC9~`TAe)4JqPo+ll$Rx z8XinFpFqynCR4*jcB53ZmJeB z!`#EOyqf!YV_xmqa1xJJxcS*<)7JJJS}C+Ix+uA}jnQgWC(mnkSmqYSABKl|NE}KO zd~Gfn9RTWI|24tclRI9GQU`)Yj6N@7ZY;sW;8xk&s;Z=uUci&pqNxu^&}%WZ@M0B ztC;XEi2SX$l5_d@e?Lv^JKsrP+75ybXe<^AX;r6N>jl}7$rUlei6A!lD z^LkRU(jwmL;)`1xmwB*IQ4eQ`f3P@;%26k(R(Vo^h!DS>q#o_otjM`so&y>@FMrv% zF)f_WHuv?U6{WFR8>Wj3b3d#HNgFHTaaIldp|NGlYI@#x^@`UHTJw-O1CU*Rx0NP^ zSqit%bEcZsSS@(>3iH;17wR$}_yKE2I&-5npcU_`?a30r9lU2#*#^%{pe3!Y=pg;b zBXvO=Fq;i9b&gKjhOlQ!6b5qZG{`tfdWpa5E z&EApO7_o$yr_Vf-{sitv9hESt-}6&tcwAo6F zV>hZ+oqcwi40C4wVA3(i)Sbo5?QEvfw(jx}H1Hgd#hT$DUYZIMohYEXAN(M(@TgM+ z=<;mxDC1@7kJV5%Z?5aO@I3~D3Bi#apEI37eye6P95h;hV&lO`qM1tFxFL}ayXUkE zXxN$wo@dL6A$|BPcXQlvb%9GAGFY7Uc}FOJ?sEyP(Pgc#ZySp{?@Ug8eI2^wiy9>J z=h!V2`iODh_vM!-Vu&u~&SzvZ$sye)s~u&-?Fr2dpsxq4n>HmoHEJYV%`Q3~fXX>o zj5&xSXUNrp5r`20_~esG8Zf5aLm&qBC74dF#Ewi^D!|0+O?N12rWZAE=G?S>fls>- zZv2Mjn~G|xXVE~eN87e!gK_q7IPieakb(MlQD*?KLj&PZ?rIo1PmWz1kuYZ#8;5#b zF6@y9I|EOC;v5j(4`2Te{~>XNTW(3H3|;{)Ya}0WMEV^uT*Yy6apa83Wb}(^%$77ejLT~VU6Q2mP|=ck@Z!~hK8K9i{QnPt&^6ISw1k};NhArsL}p;9i}Qs zf8BM-H@b1-&J5#XU3q>mGlzyxIVJ7dJ@?e1O&(`W-bx}bpof5N4K$rg0O}$L_(_*_@+eGI9ft$gUU!G6+;Cm<78I3Zes8+Zl5WNC%zz#b1T`4{vM9HEIuq2prq!Lbaji&H06h#uEMtIA=!>}buxB%2+13r#P|5wvD0 zxyy`c+#6$>svpomdaPZWXt*mxfIIUJs=OL{gV^#oOX)|~Crk&X@YrLC5}-!DVPcku z%|T&T3jxTizVVH^=Ai-{s!-|<_09B2h&&Efb zdFC#)y_(Fz`hLL$moD9D1V@^74}))No?uwy?r}k-H{O`4FfjRi_jHr zvUa9tQ5_zER&Tz!Jv7b9!Il&O=!eQ@bZ2i|n;wzroaefpsXzV&9JHXC!#$C=9_w0fIHB%c9jGUL0QWs+l~Q_jrU0o_~HFTxqzQL-pH~?6K_}?P>_W6kXz=MtvhTK1^^%zU;Ep zRT7TQ+xur;WO8!D_!AwqTHp01qKP$ovGrGG83iy#_ z;!W7P{POgh&v~`|E&v8ezwfCn`!0QZ$sx;s`m-H{*;E#H@3p|ZKj&~ovk*4Jih1xz z9h4YY;OKCRD&jy3(b|*iq(8LlXfjw=-pChy3VZ@!K`{pkK~!0Fal#_`O$o8g2FQKQEV8ARCG=60$|95_rCJ- zZ)g zq}&8hS9oC--t-eHz6c z?ftsi9vc5+uR_BuC6X?cI#*}ShvcP-ZWe+nWrJZn+%1dN3=4gbqJ$$ zW>>AGCc`ry68!$qhmzi6aKFb`x@*?0OMg0e*P*PDm~lnrIpBb4yLRnP?qG;0Uw-Uk zwNL4W8(K07Mqas2$W-Ck;BM4H95PPM-CN`V+fE#M z`}m6Yp10=Lmwf6sA6xUt3o8}`{T7kGzf~8{TbZM`0LoKNNzA6&(fF2K2N%ItKnzBL z=tmt@SD|7@Q9@wkIw=0~FWXrfyAA@OtS?_)#|uT(u>K=RUKG0ye)A3Xs7M)w{|jTL z)%xtI$kJ>Q49W&Qxzqp>zf4uOkfI(Z}HIL{BHP3ZSxGoaf*ZO$k?8T z^z=Oz`&*gQ)mPVTIuWVS%KYS$6EeZhjf)1Lwvb>KQF}Br`3yTe{`dswPkbU_2K$O_ zz<&)RZDIqPVdE`6fLpvS*F*YgHFll1KySKw_|3#3#jI(}6jx70mS&S+)`-SsiCGwg zMP0+$$~VwbkA2rf!Qf%fY#|#1h>b7jPJqh?HWm2tW1_kyZ`cp53`Xrm<-xQV zaI0B*W8|*Gm3h|iX$#&XK*D*|l@^>6Kr4D#atlN^Dgo7;Kfm*xy0IVh0HAo0iqrMi zr&R+esn_mf=bl?Oc2{O{C(~wzSREc|g>+&qW0gEJ__o&4Ad8OGUX*GdjNp4(uw9u9yFV0`qS8p2?B7jKc3 zf1seS zT~TU*|AJ?{9WKZYMJQN-J;mVw_d_tccMuwzHYJ4PzbI*QXeGGI1&(TzO9{{b_+-xu z@Cnt9*R5MuSGv~(-@G}=LuLrj3OB12#UW1XFF*qrpbVblE*J@o!E2hQ?8A>5J=jJV ze(h^%{xGJz65~AOk?vtWpWMd1?z&V{$(&t~$$lXK+R`IB`*VdG71{bcmJriUU_W#V z_D4fRgat@%NeH$xVjiD*s&>Hhp>Tr~xpl_D`zLc|k9o@l7o<1NDcC)`ROf88$m^`H zsMpIX7FaM5bdWwT}O5l8Xas~8^hpDZuXvW z(;G~SVQw01|MXAQSHD`8pOP$*!8E7HkR~F^`&S&F&S=^y|0^4-6BVpg>ylGR}_)Fc}4)je|61 z43$G~5n?PKMG>Iwvrl>ug!B8nN@TNqU?CNmD)JLuABD&C+He+6klw(9|MD*>o*dhn znebA!gKwCgezs{8W1cqe@9EiCO|@@@0M$2aqLW-7&;#^8{KH*}j^w1bIGS6{_6r1InW8cGXlI zSP@^52rq!1Z@e+_ZxeT*c1RArCAg;8&m%ULLl-*fr1Xu*>f{k_cHy?|X)%pvm|d%C zZja#zJW&m6T2qCXwPK_Js=OV5SpA`^dR(7+Fs0h%lk5Ew!?b#pnoR=k!pz|J7+Wa% z*ln_?)-?t@w|X$tViQ7}d#k(0$))E51-oiZ5Y2<1!L2jSXo*8EM9}a3UUHcDCpZUo zf)I=ezqde|RXbTD*gw`uYHnblO|4#?$bjE04Vq-+VpdFpIU~Wi4aNZhgY@tP)}=D( zVYYT~F%7-Uc0T1dpIbW|+hf>LR@Q@n4)f#lE-{Px1Xx%_Rn@1EI-N!cklY*uIh19O zKb|*-AsE>jR-}k%?n@zN0fjZoJO^Zt7$lAq+nv#cIS2?~MNdAN z=mze{PA_ctioo(Yb}V((p;{ zMwyG5uKo(?s(DA|fD8{M8ya9T_uiXiLL5O1JlD*1Gc(YKbZu+a6%_?N1dR6X`3TH* z{rdC@9sx?|BwY<&)lpfOrC-!D^Qv#HAq;1qo$le)jEu$w_J8Ix35SD3+fTcinIE^^ zmY@j@fFFpq;ic{;#{MR!&k=ntDv+*yof51C2!gl(6yO3xz@aVMj~P}N2c{OIj8jJQ z?kpw_RRCYu-n2?&=4QI5p^z@ZDmalmlF91@G6L|C9x2A>?)G$LxcJ4@#`GJLZ-+gtkmo=Eo z#hfR-e`L?bIeIyN@Pl+VBq+gDRs{NP+?aR++AY}3XMo#<8PLXt4JibLO$ByWUA0Tz zmSJrm97C~@{IJ26ikZ8yq$vqzGs&l)u3N?AMG?J0%0wOK=c%WX`pRu+?b7E+??rB4 z*tN~$*#3OTE)^UowfcFa_X} zz!vRtSZ=ud@}$kXqARXQ>?2$(@F{jm-@GMfSd>bC6me+PyZXiK2uDugT!Ym9-iIw)GdW|KBy1pDp|E)!K zpLu2{xQYYpX7RbI+UW!63XU2=pRf-=y2~nZ*_UUdtz20*v)}z5F7ty`M_NExJQ zNOO*|d?RGhN&&9MCH9|%H-Ozweo}`G7F#=R#k;P^tu7AA4WImElD+C_e6N|?R9cLw zv@fNOe^%|ZA%L-jQmY`Us&@UMiPm};TPvpJMRwsYEDAgZyO?2~w@_6rb%A`l^>KAN zfA4$A+=}$*Zih;JzQ%=0&#)i*P=^*|-w`HPl=I(1vEL>_0N1Q=)Z!CQOhVSS4td=* zA!{x#iZ#2!E~4|SUtfE&u{%Hd(b~1wqco3;RXGQ3EpE(S@E{^6Xth-f6$_zQ3;yV} zWah{XgvMAxsZ|hFRl9Tww0`{YWOIwwt(HarDoTm5HP|QM8w8LaV7JN;J3z8Q4?UFV z+`2;&Onws5ggGF6;DPjZZocD=1V&8l_S4^3xoR=*>#+zIKlX1w3rnwn7|2n7;HTW@Xyp>bujZ-h{gtzlg|pMQX!nTRLF(z*W06-hw|#F76bqg00mG6+t>`mB}i$nk%?`` z9@v^%1;(SUfI9NRX#W^xtxzpsmi7s5^4Dg+b>ncxop90LTSo|#4;Bsc4F=9@Y4f*h+n9`-oK`4lBp^h6cnLjR9Gs8&zT9IbGX20T`W z0UFE)4IBB1A#}?v$(RP)e)z)_;q#||y34asu|gpLnzmM~Xr19mjUzJS9(*u?g%`c^ zPPz@8hQgODX*uNKH(VcrwCW7I$^9@FGb-DU^QPXee!;Q7YKz%yw(^F@YwI6#OcKXP zUb~JO7Gb&&(3lG^2pWsyVSxPAuhxCuTidJjMESQ$=DF0J53>ZGYPt`DKxrsEC=961 zyd8vQSYQHA{h$A{`uNA|$O|nE(?sp22zItstZ1F#NR1Jkr?bF$`8^T;Pa(gRttQlUABKwVE+)i6J`U_2lB~&{^*Z(cH_#!2PW&7 zAZ)L>rcRUPS#;KjNk-s!K2?e))Q6ZQwwK$wHE~um7|ka}+XmsRn#fNc zc>w{N5bP0E;hXCB6O7b2EEj3SGQ+we!1(O5Y1ay$BxW)HRSN0iGwRa_R=Asq1Vbmc z*I<8--Py{1T8ju=e|=pX9DEuplD;?|)-@S@-do$N=&@CZgZgkU?i|=_dfZ_3CIk!_ zvg$Q_9gcp)5ovlz1FH#nTou*chxn!@u+72`i9W`E0T&o-n1fBC`hm}FNU$$_q5W`k z_gsqt`+Lg017ChXKK9QBv9g~gD}`aZ{TntUCWowt1C1;t(&Te+P@ZKOBoY8# zfc^vMT1zLLd~$M;u|eu!NT)mmevm0U)mGJu1^ZbGIOoZcUO8AeE4|@{odE?%c{Uyb zXu9?z=u#U1i;6$FbF3in(EgbTx&$1Zr;r2a7)@2dD9#AA0O@bOImvqPfL(-K(QbPR z^N;1eb7D_Fov7OWE9f~UXX%hd*N6K;8$iI?&aNV+Jr}K^=h-~Y9LhJPff>RV%zr2z z1U}}+@SwSAHo_Qc%FaWE*P^KD07w7Ux6*RJZ!k&kvcZPPbbABB(%`|ZSY^}@xPH$) z>BnMBs4Hy$xK$|`1X47B93aD}bm}$VnCFYZhRr=1QVKIHMID#x*42er`cDP{4v6)^ z4<_w`Ng7gWO@OkF)j8+XjXc0<7mHB^WUaB$LcvQC(gQoN z3W8xjpqUArp`rcTM8o1%j04jxByC|1GTS^DyZ@z47ZW($&&U`bYE-YQw)drsYV4vE z!V2VDzdj9%u?~5FPyB0K`)4c{MP6bR0$^?iN9derRbyIAvDxcY~X6b<l({|g{4q~@V9}AW_N!S8 z=CaF@2pU6;ne1E!wHTx~4aYi+b5raVO!JA%#% zk9E}wQ{yPZW&%Y0HIoN=IU+c@Rnith+}gTD+;3zf6i%KW{V3Tac6iqR&9kV&J^K#0 z;IHrn%N(s;TRK0m!hsb?Z`XU+q5-q5(r=*eWUScfu1fS1IBD9S>IyrV!#Tjxg+hG` zbEBfb%x<|Qachu0~n z{a5)yAZaZV21fND2qzXl@7JFLdf62jBw(Gef5X>WIeKdm=A5-~!*IMGDUtavk_YTDvLD>) zapCtnCm8?s+jntnTY;3Bqt5XSbOjf);h_!W@@8`RB%L;5^T;F9QBfp_*@}XBLR1V0 z-oQa1mGHpi3WC$~?2Jd?KFnlDi@s*;^aM_tB4V$Zb>LI&eP5;>?zS+z-yXND6TGjs zM|!CD=l0o19y5@KHF?aCLd1Dp2J{x>?eGl#X06X=1=9G233&Wz#m}#QJ^d~|J4sm} zpFw@F7F*dOySz)&!YL`00_FH%Il1mba z^Yf99B==w8#T&_?hahOHd^P#ukVOt7IZK?!Uh#k9_h5ep(-{c{JPV&hO{5 zUC?O40c*s?MzWp@%=gZxjyo=Sw@~L$4z1E&FJY?1oEI{?<+Gnnjpe%Z@2)1&t*)M~ z#O42aG*kfPos%q(R(i7k{#Ffz+gognK5u(vDnsmrivHP7&V5IT)&FY1A>#(E^ zKa2p1SoKKLg2k$ugH^l&8Z!W-=>g+id9GQ0G+RK-=;$FXny$RI)=D#xtY@fCp}H5g-W)0>E?6t&8D-h^tm5nbTU^wU}EN%HV4x zfDZ}M%!BZB)|vl$>#Zre32v?Kd*_|$1||SUFkpuLMaAc{3ANhFaC9pmq-38^HK%A>d|@vG4%2X9%#vl`HE=LpwAUwOyMNYgQEQ zZ@=DjeJJY-?Yz@F$oJMKMFPc2J)waVPh{AbED<#)R%)_(HAFdzRPCYqQ^k zmA$#mB=`P!n^wsd2nzQB_3eBSP>qD<;PgyLs{<;jXhm#YHef(_{zj!u^68@vjXVQn)SvX#zo>^0luect+Qj*7Gl> zBt!g%f7m6#qXuPHKfOH*`=b)Fa*UtI#}f)R>xDN&`Q9#%TWe@q?o+cA85j@Znzv;w zc`gLP>eb2n1Uf?>W=}3N~RzMB3m9Rd{5r z<2XDrG%fe3sX)U~G`1wOyuv2?aqqp!?gZRmKd8)@0G2@G?NCM%g=(l$hG6^Vf@fpS_aU268ByeZ`klFM6-gl^3;A#Za7`0(?er#sc- zc@cQbl$7(30rNEHv-Lou%jF`M36uhuED#3FH?4hK3bnhiCtK?YNOI5>;Ic%izNXxL zXSGA%h6rL6{DzfSG&h{oQ5v2}8m-8GTg>R`)pwY%V`(+#u5~T}j5kluLk(6ATu?cH z3-;FVAh4#q&e^=}|AQ3Y$6* zwSd77CS!<|#mN{4^}V&yB@dc{lh+|rc^etQ-^00s!P&CKV31}p8AQR;yxJj*M$H~2kd1D>3;7Js+PXE-33?!R@;$P8j03iX z^>~ikvoW@rRS2Cb>z|H#JwfR%a2Hf#8-N|!eC|svUR_k!1p7s0WD(E8AmiDhBa6zY z8iJc=DL>>jbb|Oo*Mf~zSp+|W7e%Z_rm9Ag!w$YPNvDFQC$u#MA|~U>AQ%kgk4#C4 zTu>A|#`klcc@otQO_k<0D1?#O9ro9Qd^8+{5?KA2UE)o6>fokAc}mvH6@OSppw@!-hYy z+mLMfAOGo}()5@cw=w2vr|mp$3(Pi+%R0XNNSp=SnvK^7ny{^S9IXb#Ek4~O24CJ+_L%Dgn zZCmobqj#NtdV28DN0W&E^FOaOz#Ox|o||v3eN7Sr2sBdiPoNvO8bUqEg9UXJjj|
!8D@ zkmItn$KEYGp3UyObLrRHlwcmj78NtQfR37E%9Wjyo63y7RDgpDe&mr!q13t7l#~5x zWIjm=i7f>6wPpDRaj%ny&*uKJ3X6Pz++DqF*ylAHcSz2H0f?wN_^-I;jP970Oi*yslvhDWVTeA<)KPMfy7JEej(+ z^=G!B=2dxt_`_B_^5&Ye_MJjW=Se!2PRr-hRBAmq?BO&59T+|LTpjm@nC4$iWd=mN z>87;V>@=TEfKml7wzFT2%qOX9A9S}(GK2~xfW$g^a?b|83ui@PV0iE}k|P+_k5ZI> zBdq!*f6?d#*&>q`Xi%NS#G}7rs227hVhLT%T8d6;&If(T6TqIDU->+nCB1md#*N9_ z200-m_$HjlEd}D=n2yVTA?x|{XOQF&zyA8_D_=<*0`_3hG9F>`#MI_ly}r~-E=e$j zR5ZxI26m{Kr-H`0Zrv`4f<-1&Oj6gr9f$1DCZ$CMibzz~kI@r>gG{&CxDhKnjs&RM zQg#gM&%e=z>4#fB4*UWPLw5pP0u5xf{*SJGREryKr~_<3NAy5r?;`f8DN-Vk1X7tG zL#WwQoEL%m`eFI6dY2cJkk^QxUh9@c(7i%gi4Fzmn>7QA`pl>SFhWm2t^Wh6CR&ji0uWWc zJ<&9fAwOQt?K~A8zESVg*VarQV{aJ8FwE9Ws3K9TCoFz=bxx&IYcy}sh8|pO#UV>v z!4z7J^&Io~%w$}q&5OJuIz!b09s&JJ58TF!awSmk>XC$O%$m2pDnE=lBtxhW=}k*1 z;y4WR)C+g%r8`elrrNq?59waPmSDDmsa$X}y^SzV_$!J*(PSzH5vO}jf`C415C1jj zpL^g&LmVSr-$w(O@NM_F3tNXOYNN*pt#|f&ehf}EdbNzMZ6;KL+XJ#_{Rr} zz%^|oUl$%pHU*vySK>qA=p3k)bXiKl#q0>^4$e>Omc`V)qP4<|+;mMAoVUd_UmLtX@x(e*5K#z*HG5bzJq&D~r9$;8wjEp~)fp0E ze9X9Kp4pi;H14ror2NAB-O*;+*N~!?{c$__2&^s=aO0Hf*=JL70)Kwt3p-1`af1yK zLD10aaup8Mg3&yzU}6TM0h!NyW~W0Frjx6Y1`cVbjXZ2_J$wjD$sluV8{ls|+{%@m z;i7v9_7^9bpg6cvRG3kbh5bDDT+*kj?X_$Te(E`LSI@DM2LuBgJvQR=AOG<#dn1#x zxDo`w-t_x&!|R%R&GYjqQ2*9j>l5puyY;~1r=GZ-VgyF^42X4se0&Bhzz}@p&TFqt zaAS25!fj-KytmLLiYgDF^_geZ=k9(fl&T#SH1tmPA2#@IeDz6=vWKHfyjm^DVcuH)k(gikAE3MPfhn^S$p?H{Q6*BlbH% z>0iA%{pNFPH_v>|SRKs4{z!c08+I;A2AOf8JD)kASldav8eDm_}6std;JE^}f~5vb2%hjdZVQ*`gWWlC49lVRj(}~t*kfYAcHmkHPm#(@(Rwf}3e)lYY(G|@X9u@` z{^#mH{io^o1X!>twgvdCYSb$6(FH+wlnwP0m^9xEu_XYvr?dQ6(S&WtO{lTDc{=9^ zABv-f;^Z~_CwT|HYCs_V1V`hJVCxFYLYmI6uFUj6Vo&AzJ9{^KvghuyW~H!VCfvX) ztiszYNtSzx02*X=%rUzJ^Jy&c>PW}qHe?q>!f4DHsfA6533u6LdxhrHJkdml?kQDZ zS0aqvTt19ENcPMek*&@O9;{kb_j1dd2t`7$q4{0eLe5$Kq&pS<#Fj8JI)inX`3&~+ zQj<~gY^;F?+d0cDQkS|$$jd_VM!18T4;Tg-VaEeoD7>ecO*27^R|pwo9ZCx@WPwN+ zPvY{K*kus$(wfw-&VvGDrXDx&Q&gJZSw>)-NXO$#`=xsg~mj_|i)0P=AH;a@2c|KTVfJF%+=qhHyH=wCDfFtld({L5$DDnue z0M5XF<;wJdy<>seFfbH;fGYdTu&Ack0Jq(iNQ?2247MR;A?Kdk37oF$Z~yjhdoX-q zG@oXS!w-MhS&gvh^NQSrLk#hsfO-G*zwS&$w~GX?XgVLb#}euQ6d`Moy{?3Ai%x^w zOcj}~xe1~xvfxQw*;qPoO#p8_pdERP)qm(ysL@UHphr&TjwTSAY0HDQZmnYwOwr_f zcrY4BVFTo6HT*=jL#xhHwT1T@;}92y(>K4Fo-&$t5(3C*QX^&Uyp-!`iV$kCPL5@hEx_>pHdXk5G+e(#|T>Q;U_mIqml zw1SYICQ<0d1t35v;<9A?(A6oY)bX}^?8PAmTg^ypEsdqj|x z8H}(YE>t5pj%U5CC&cXRMHkhFUk1#Y;VzRJ*zIqzV}J0uC_dF1W?bwsKmmKW#}g%i z1!URg(1>72>mrI?*H|#(>NDiSgUHW ze?5VXe5vtZG!YZ~*0+*~&y^geXTLD>Kll?x*)Xq>=Z4J3bB3kccNOab6oIrNRCu70 zkTYhu07ks=AbBimPBs8pHy4C$$y+wD$kbyySg$bQf;`wGJ~MLb331+s)01G!G%>yb zq1FmuZgXi2yujE$u%LS(E?6)|s(pMx6hHtL!c>$4LLY3l>jA(*9D}3$G!qU(7ti~F z+BC9xsdS7eJ&HtPX-vltnG-wX4;?pWFpQX{le_}3c;i2u)0l~ z5~^YTn%9P#H){3jbi*BYBm;(# zkx|HZ_#)rCkgl}azkA9Svrc3HWA4-fL@d!v+RDbkkPC{&lNAHI2*cbuz zEaY3yCN|6R<(YbDQ*2Wx`pVdz>dPTQfBfUL#d;SM-Ryga?g3>(7BTkcdP39~>_;Pe zwy9QvE-)Cg9N|EqmukIdQXbjxJzEIKKsX~5xW4+;U5dv;7~r3_??@GS;!|xMAWQ&N zmAScu_3IN7KyM(&=FJITyUGj}pg;=2DZmCWNjEtoTQ~?fun;Jj@wp+2f;GiykvtTA zWf-KVF+%Gm!iglI=rzPnMg1ak9>TcdgEDg@ZsabkyolIT0{xd%3w^oByrWy|5k{a9 z*lcXGrzdQ=!6CpM^wP^=qYBVVri)^VLTn5p5Cm7)o@=k&*}_qeCp)bHz_Zs}({i2y z+jiJUM|6XGPG0hZBwmeH16o7{V&=m)U*p5 zr2%*b+wO0?6+=bgSO_o5Ar9#a7@K(6WvM(hgw1FsOZ@Nuy|Ygl6JyEz=6gf*)Hz3r z&7yTAgPeQrw3^l}0_?BGX(1{OLG;!)wQ&`HdQc#5U<4~a^IzNBfDNlw)vYV|F-Hte zAMs~=_E?ea2l*gE8%z|FL8@Sbad<2klS)t+n{*g^Z=dsgWzezksvn$n8(lxF8dMk(LmNxx}kj-tqvyijD3IrOklu( z_d#bC&H`AX*a9hO_dKUu!z=NTY7ZD5J&WgIbDDszdz|ilA^yxAt^Z(hi0Q-5d+xL- zWkqjKbod}+$zC4TDYK>rNuQ-J=IE*6N{QeK&${e5`JsfVH#+(#v?ifhUHH({71~EH&na3hmWQ z6-WjOux@FfChenyk5xZ{1`Gi8fi3r2`!_uEkpwUjj}x7duIDkm7e1*;D|#6_lXzLi zAz4C~fx8ieya{pc1e95^QZ{Y5_#m#-08G3`djQUz2SW2}2$KlCEcoY8<_|e{&N-Ge zkQN5zJ=Vxp3(Z~iShLx^HKiT%?L&%If-Hy&3yHd%yI`K0E^E^stO7ITO$t~Zz7#dy zTE2~^j6DE2^e{{&YcU4lDQyosg& z_@!p|_E_AF51oTj3D_~uo$vs?5p4xdHxNd@Ze*Q77_i9cLoObdV1Br6JCq`-?Vqsi zduK3qfOvc)E=!c3yf0Ieypr}Xxpj;p27~Z3TWDtn#KH&}MUwLrKWvDGQ zqVc%(mAv7dgBRF6`;p}=$j-G#oDa~EhloIBd;wk!Tp(EQlMKW0`;!YaYo)1iiGumQ z2thcz>@_4V1v54%@E^LmM1P_m$0wjhVQChp`&LK;GeYRGSexgcGQtW3r}HV zvxm%C&c+O0Qxi9pWlg$GAjk=~uMttVk;R5cdnoh2bn$8Qg1B(8#G2E6$Vl?Hw}VKe zcY`*r)kbPXVDz2qT=4t64PFMlrzbS5cPyk;8@iOg6H@K=JAE=^J@-ziUgM>&Ni5~# zNSgaVn6Ys!th+oYyn{2m)0XSET9`=ukJCSuk5;&8&{^Y#qrT&qxInuN$#@GZ6EYrl z@*JqG=@oz>4nSGzlhkxaq*40MAu1T62d^dYz$?$jasSYW9;gfR9mc`)*+det<~F$E z@Q(lHhadD;iJE$|v8}yZ%0BsnCC~uG17UQY3g}N)Ac@SRIta|SLyyEpoR%vsrx?X7 zH6M{{=}Q2l&K+IH&A3TR1haRKUOuHw{h*?ucZSl0(eoc-v=`7iz))RoVqP?hWlD zq3Ts`i8sSh=fSFlV8UnUod0U$9X5iPi16Z1C-lpXjk6mlt#%fOxNCQA@c{^m(_f-S zfen^LU^``lc~}vxRJLJVpWW!WBU4+^)EY(-iwDfgbKQsfS&+-Q9@DGs@a^(o9SR=# zuh%)X_+J4q4beogI`Q}W{zTF`{Bq?W`s^OkhBz1LaY2V35a;-7R#{|=W zdf9BHr%=A=WnBx)Tofcg5IY_h1Oy%T1|mnwMLbZxCqqwPsir?_a}ensYTmj!zs`G0 zEB#mdF7iXq`y|r*Md0TI3|y>MR~&9@c7x2_7fSiEov&woXca^pXbU?R(ZO;|$h#SY z>RM28fjK`Ohv`qLg3%il5N!4lR(RJ-3_y|YS^p;x?}T{1KIcR%>{7L zjyR4vpfib?Z;QX6>{w-kd4dsV{a|bu|3=`^^r>#>Qh$FJ^iE>aakNT62cKduC=sg_ z6PhDe;jGWwNvSMmn|!+m?>PeZ#wckO=LzZ6?R4Z z_*~X&sy^s}HAco_mdtHJcG*M_$cShUlKCN|71d2mD(=8Sb(0i0VQ1j{;@aUxFhh6GDE(nb{V`6EsP&^9I47GUB@JvJ06Ax?6vm>0?%#&-XYOiFv&F8iXl>8kY2 z{|0P7{x7O_*Z;(9cfV}NG;bX@vrpjOEgbYJd0Wh4eULSp^|wGdJ9!)?Y)8E>d!veJ z9MNURF2?4lO@S5D;9I{~Pn)qJi($Mj5HO|RBwx3%y?=R6nX%C|{^&5I*UOvNpMH6D z-{~9$U(dXFUVRVGxc?Z6jqc)FuVp)>#U9;sV|<`Ra9n*4zHN8yY}bZd2@H6j6%5?G zwamK0oxf=LKjZ^G4Z7x#+X(1#>iljByfgwt7B+d3xt>S~k?l;=>5#9<#_ymW6}PWt zr7$pYU1aO@cCTJmx&8m*!~X;OZ8h8b&BwR{C;NY5-x=xuH}+lB!rIxykxtawz}e*g zp|jITo7kE;o8vPu&@=ugOTAfL%I=UAzUM{lw8fPz=k`mzDYanR(966&7>?#ZpMXoU zVju-s1C;frhe*M3OxQ{*0&^6ye99Xe){NH?okx_J@HIc)^i`^0n)clSL&r}UfkZ#N zc>bOj5iyKqJ^&(aNO-a{Q=@C0ScIil=Nt8_AqqU~@MTsn(DrQ($Q)igXfX-3j~*pLCCSB*>OV+|`C!-5ftW?C5bnIUC<~v@IUZdefpfJ;z- znV5jsnLV1V&N0O9+kYswHlpU(Q+kLyXJ(>CTz39v86i z*to<^ECPwi>(NYo-#o~5e}vQ+TKwFCgaP^|{1;p;D_=QFc}+YhCm3;d3}x!{<;oO$KcJlQyU$y+s}EVvl3pT2qm&fjv^ik_(%FMn`d4gc`p4I7?=5e_B@(5h}zDxjy8lN9jgPMoa@>R;(_wU4*iFQG6Xc&mdV@%YN?uyd=vOrz^JCH zIX|4}MST{BVe(_DSoUKdq5(~WNEBH6;5(&2{%+gI!nu#0c=;Upm6%7jS#fn}#1GG+ zJ|)aFzBnyy2~!JKy;}2h($Ix&4F>`3$PPZd9HEu?EThhn^-K+5pbA&H?Mfg@rzG#i z{l`nnsym-NQrR%9Jkj8TR=k}KD3?`)ZqX=^WEPb%_{V_CqL^r(=DSqHZ5RJoSAf=4 zYD3|&7O8{FVH;tiIOGP1h>@(Chw0Ng7oSVQyI3I?34M3WRNxS@Z%%qy>h97}e?`$Q zJj^JmK_@B@)!c|A(HXXpNui{l&uu?v-uuP>GbS;y{_mKimO2;jkoVpuC}Y}}??cFr5tiSYXdwelU^y(%f^0`)%QvPJ6_K`yP3 zAXFJ+k~8WJovwvyo>DLMtZ8(K!W@K@-WW_6`8;L&iS9sg(=JqlhS>%A)xjG;)PP?= zrBZ2=Jwzvbb>gezD^YqR*Qq}dNa5r`Kqiti z-WqHi+occ5Qs2k{j~KN|r#mmPS0{J0Z%(PT=+q{JxB-nbg?NCFbs52eQ?<)eX5-(= z1dRcV_>6Tai(3T?kuo@K(PxAMl zDp1@tO78o)x>a=ZyV!cGEx3^-o27|j=Wac@|1sJHbCUNFAzlm@1PCG*k_J_vNbc@7 z&n5?Mkp z9vF2Jc^~TpOpwOtwZ(1N^G0Ym&W`1evyZID$lnkQg>T zgltG@AQA?i0gqIRxEPi`gf*l!v^nGrm`kRLz#2qTAEGW*MYMv11E0E#_8b$CU=?d38Kst~*;Od7ISZ1GR4_tRtgH{aAQSy(g8wL<1Ld08Z@#pzk&Mpheo9U-%H8!4hy+PuRET zG&7hC5xt>PlYeD*#AN&kdnl#Lt+nG^@;Y`PD)=K4lA!<;(qGAWZLc^~Kqm zQ7roL$?|I;M^*#f2&0SMwfU?=t&f)>4MrkTavdh2fnnHdV(S37sBovphr?^tLD3@3 z1UZLnED8o%4hVFi{1jc%Ap}FI^mi%YE1m{tM~(|ZtjrHqBMVitVdFN%Kp`^E7hVN6 zBY$DPnYpzuBXg=)!XHbIqjI=;_z7v*j6c6!FRwR`yQsl$qMJ1Ou@Db0eX!Ub^34ls z=l&DGBHnKEN=)5fbraqgJIA0&&_A%CD$<%Sn@;$VqFWcv6W+{>xV)Gsp16&enBA(? zBAs8c31gb=4>CW3vOr@DVl&FQW}c83OB`*;Rmc$FDO%&p_!_m>a7Lfo=WrLKQBwTZ zc?pWAyIzutrVQAFU{+n6YTu|9z#k5)MJfWki29|^D9RY=&B8-g9RBCAbdOJ?!BP7_ z!K3@iEOA4qn*Ey2g0?g1?z*zdM`f#N5qLPC%Pw`uN^Vsr)Ggt2wbHqdleOiw+7bZ; z9!o*jM@qyjL_?iLw&;#}fbe<{uzHZ+f(>d&^RnMIu#zAjTsG1!E?2O4rl`0k!4`}V zUsTQ_*pe6pP&1VwX&E7RxC-__Q>+V;8FkD(=J+#s4DZXhf3(yi&9=p|t>Xh!vc2gc z<&?@eI%h5iK>;G)z|o_Pt4-c+OE;X_-Z|_?REhZ3E!QZkE*Ek8^SyDT&^`lG)9KvB zcAy}ciMXyu*4K_ISVX?_w6S8aW>4B@Pyc2A;Hnf)d{5J7^-0#d>HuqFKhBTqQ31`9 zvsU+F-G<1&nqcP{mm7XxG|3IrXOWm5Hou|MbT?#itg5;6U3m3y6ORCK?pHkjy&sD` z*v;+6`a&tT^SW1Fgb{EQ$D)ICP{0l#CHmk(p@UQM9-R zu(9C}Bm>zM(svGQn%wH1poiIFshAdRKguh4myj+Q8^yh<@yoH=NjfF@yl6pb`7!#V z(hIgHyW{}Pp6y}*4ulxveIDS+TvKCB!|E!BJyMb6oNQ!|4PNLu$r-~Op;3tq>X zp6k&|CgO%~$p7*357E+S*9pM|TIAm_7wQLb_1Cn^^!GoXceQ9t@W{)OsFRi2Dct5s z>B=>2I{jccYkbdFd9ipWKY2l4aNJKxiv^1rVL}o3X@SIsGEp>lcI0P{83qx8T@u7i z5=4O&R;`7Fa3-y?cOuF)S%l#jWyE^GQ~Dlw)#0qB6)8n3rBoVFTD;w93lgE&0=^wq z2QyPj>8*-nBISKpuZsNoj2|;#2bU@8f9H?b1Q;$8dgx%p6vc7;I06Y(zx>#3xbJ`# z^LS7*q!lq>1)yfKCm{lYRvUq(#v(~`w?^f1$#SEFNQpgY;ij>Ob-hW;xUsJ%AGE}l zyj{tC)vQldO9b;nYP>EIkHr+b)<6&DAXzV7Cn*+#l;IdQ$FUkmUPV()Wjj=^g5=}< zoKWcR7jU+ni`pJhU8Ij&&+;?WDD?Vv&1>VpzGHofK-P}*z6i_!>L|b)-Ig|&C|h0% zL7^0orO`IwQ)+-t!IQWU?-_fAdWwgKDX$~rVP5|FHRx_rN~>iZJ12Woqi`N&DYyK} z;ErH_K%8lC)#nF8FyijQ2=28HF;JYxlc_aKD-qy)MqCSpP^esMP`c>=`0!cAhTr>wmc=Q-D z8x+-$Pw7|$tRXO_6ZjMHTO?UigR_W|@R`VejE6z4|pb7U(4 zr^2eU#1_o)L*vNH)LXEKq!E6YISfO&8yXA1+;+%8-@&l_^4C5^DU2r0_{Z><$rsO^ zWQ>LD6T_>4wfI!t#LZV0Eevk}0dJ7YPLy%$F|OLSE)4N3)va?kAxS8mfGlz#^=Yzc zVNu{3CMi{KlYycMLkpAAQj(YUyWme~2i-T3s=cng0X$BZRmcwJb5Ww>i|CbHOAJ~i zFTtb}B49C553%(ENO2X7jLC-9W}p@l7{52Lr4yx8&rcS|&YB}ujY62F%ZE!iR+}g& znBDFOdxnsMuZKl@`M0n zYHgq|NKPGAiwOJp>h+Tb)Q!Scli0&tWrA;;LcE^h`WSJ_YtRST+X1DCDN|5d?uYDd zDsE`b?R^}!80cz{9zxEt&9WmJ4i<89{Y{3IMmseV~KQC(?ddl+p zlP3#R=iy8sLIqPJWBfXh=uuqDpV30LLS;Sh_Scx&q2PW3F|#8+%rPENkq}m}nTU0S zdyp()6C$SReqJ61*+NGr7<-^|o=`4xK*TI|H$6}EjYG|)*mt zzs;S3qyOxZtP-C6*Ko5gRJsvlC`ulckTXcSphuxop&p0dxygrghR?CG+K0fNhdnA% zJFa$tnfmjG+GTfo4h{QY%mZ7tV(vQvCJLskEukVxbQYF5_11v;Jx{1lXR0VGs=0lu zYQQq`SZlb;Ed62@>iloeMlGK}D*d1j6u<1(0%0ek*@pc2UPXdKtm}=EJ`T6~WA5=+ zLDYj1QkiJlR1vY8D1N8yMlSDOQ#+VFJQe-FQp#tKEP1L7!DDFqTI{+uA;N|+XGKM@ ze-vPYkc|#qplvHc88JY?TTwu~Fg>rJXg9&x z^*QG@-;!$fLCZQ^wPadcjNuFx4sFC06NO%eXzdJyw5%K}V1Q+AJ&yc@%xE(1LDYP^ z+pVetG>9E#P!~n=Nm}w+$=S*A@#*QclPmuQ7|_d3%WkYIEJFe4Eh7`CC}z%xeafvi z4ZYyp#L7?cu(m$zcC0VB$*yo6O5%qRqQ5>?u*}3oE(uFxYoziUTME0Ym{*e=FzmJM z?(`d`Fe<$Q$t~oSlbETANqA4T{e-4tFT3Wv zjt}m1sED<(cDzRN@TyOd53BeIjAzJ%0QxuL9fA`P|&eI+6z z00RSolAHUVo?M!rO7IgQ$)5SU7yv38JvqrYw7tl-BOX0zpQwp z5q9=5_A|fj2DBPR2Qt@8WCBLO%3l02ER9i^*{oKu+AiF`D%-K*-cr9@_bneBm4%b7OKbyr>){M_uUMg()52i6 z;+y!rqwdfP8%$Q*ZO#^TW_*LikjCF?JnuIQB7j6$_0637yuE(Q2k1FUFM!QViOznx zwxR9mwl|~qZc^q`HpYP?NyJV4yMBk8&(#;byUne^4N_yp!^oWGpB*Y*F zv?1|k@Nb;^jX%KTnk}7s46IVinH~BFldV8*xpwYPSDR$UT zzD@*E$rag?mvauFYd7}Zb~h9k3y7W;ylYCE5f@CN@!dNmT1ppvCw=Gb&&4?IV#`@? z1I1`I`s5?Ks!? ztFgWP%D(p+8=O2r)7l#1*3z25;l0GLyo$?!yQPn__jIM2*`)^*gsiUHUjapNkkHZM z%)yt$`0<-lw6Dz&LOOeH4rkk-b&Gt){}f_ zL@4yNG_*8@J4?nci5#NxDBdIql#j(cD(cuG?zM1ml92!M3|&ZdF=`X&_DS<#Nt@NR zhI(}#93`K+F`~k=0&__aUhP_UlKHl>bQ5xtHQ@s&=ovQ)&;$vu7i3f&dQ;F{g}3A0ab`l}#5lM6=jZ49=I6T`WaxH3h#y~HNVOVbv%zKKING4! zv0Ale?sS#ASGiW@Ht@k)4xtAEaCfl~BG))g?)(IcFDr8<``vZ5_2Da*G|XVsw|`e@ z^xo}_-J7iBVAI{>&puxiJp6Y6VgC&X9z>6~!N?R^sXo%IOeQOjxShDn(omU91KROS zHdUl#G7ow@jS?mc1E&VQ?^^lNIn148wnd0_q9O%Tc`{?NXk`*eHQY{z<+kK{Qt}1s zq$;J$gmAkmY8G z6v#z1sgZNRh<<`WWdEe<*2{cRN~U|KC=71OnaZnFFfV6#?D2k@M9n;g38_g$cq>wI z5(TqpplVLU)j=_Icm@GlLKLRX6w$?^N%#c1M}c4^Gi>!_;XOI;x{<;p45-cdoc7n8 z8r+qYv}my^%b^17cXQPq!MdCCZ}0NX`|Vo~m;jw6JWZgB-a1^LgP^pDNGU9F2<8Au z8iCJ{8i9Xq$lVZ;Asw7J1yNv#(U7A)KwY9svWifbXa(^i>`9ou-hWNpnouxoT9_O` z)S84d4B&u}A-;5l-jF4qcn5_VO&dMs{N>=5VX*TP?Trmw4KglSmiC01JcV z{-!V`_T9M2;BnNbC6iP}Qp+fi_g&srPf-K><{kAZZz2+5yFrf zF)Z(sVc1Tf%ioyjNRZRfnggsOnX!OrY@mGP@!{b`BkydS*^N7Kw+wv68c|dGx3Gm5 z>mSJ~XL3vurMb~O3Ste%j%(pQMlm$m#!P%f^I4pFnqmh39V?G%tliHlz$uOO%Ca@W zV!wI);!jxIGhyTK1~7{Jv|wQOz`Wv~VH+D`wQUnJO~)TNdx2AJo7Z+%UqF!+Q>eKmTqEnS*1IAkH^Fk;KF9sVatw8 zX|M*{d2T-*c{{viuo^fB&59MMCDar%FUZRrn174GewKP|?gnTGq>3%)l!=+s&KEBd z-^u5@gGbTAQbF94X9!WzvP9nDA?j6AOB5J!r?rvMw z1tWQ_2vp^jB5Cn7-*0SMwrDX^7KDKsj!`WAfXAH4b2zoRQ`4^JL!&_6{%ZagO%LaJ z11x!=<^goOCX5_ZV$Yl*St}Cgh87mxg3`h)4u;cZtGCz3+MTikXofpwdJ`O%H@@3U zMMj&<5TAoWj((1UY8^OD^ zB)<-!vvk!g#;!TQGro=73UMYBcD{Qzb#%K*Cg~TFLT|jLj;guWk~wx$koA+J=bn=e)dUa2EIHV4@3mT|$uoar>oPr&`D=w3+=zxaL?k4fQ=UBXVK|_1-0ge$vi+Fvo9lZ^zbLhf<8}|M zkVqisOe&r(S{Mulu{JiXJpXohI)61Pa{4(ARTQ(AwP6aOiBhk5L-_botRw9WyYMZ( z5TB!=!L)5i#T=>9Kki*Db3qyLL%eGnd8VbLqhPk89LsNAS~<-bOYpf%#jvd6nKVeT zoJqWK>gQ^?!OXY9J;I24<#VlDQ0np_-(-8J^Z3X?-`?R4AXW+ycFdf-&%1LVq+hP2 zVniVNM+51!^kXB>SSw?)4n!iey~Q%kgG&%88>RJj^dHeZm#W>4!*HLJHKzJwS=x9L z)RK>&=**%yRta5jk(3?b}S#F-!jhP@UXwx$w?<}_gnG&-aD&x2y~e zT2y;PuNWbF3c7=OM#`!wYD;If@uz`-e$aYlWjpxpEcu|$@GCVLL9&kD%M8Dan*o>u zgAPSHdV>wm{i~v>u~%E}z^cbpK4~siMPtg1H>LLP#D|sEm}n!hO23+KFR%L>L5!rB z$YiugPUJEDZT7lhPyDJ49^^Jhb1Iwk4^41rf_u8rf3x zaIB#bGrhX?iA5Vrp#JS7KqFT zrzX`W_#CUawKKU^uf4V_99@p3-Fe92L>!(gG1{hz6A63RQx>zj31y?LO^+?UCT>}Q zrkJ40bsdOm2pR>IO?=!a4~x!|T9Y{y#UNYFuG7sK(ODQ~mOUZnWTQGSy+U`rEO!q@ z?UZ`{oLNo$-4v@r+=qlkzH5@_yPm*HBiMIf;w!D_`=R)H2S<<2WBFNsAReB2u!15X zRv$eV$R1%rK4d=Np&vrNb3fYyEyc&HGy?ZPZlSfA-k(CN3~!_%z5^N@-XIGZBJ7sz z69yLc18fjDdYhZGQ{K%AZSsB80}c=l2i2=D4m|@+HY0bdj9*_Bb>FxMu|<2z0ltyR zm#58${L%M7W_*b$hIC@og!?IPKxwmrOw~O=uUpUHDXNUB`IBJvHL)g%XKv%@uhN2d z4C!>b{pU|B>2|>dB;1FqqPI4?0S5uLjK4?b0eI&l*88TjIn&d}rd@nsJb}ks9nrdi zizm7#CE`pik#ueR{ae#TVi{ zL%cF6>kTBS(@k%Dx_BLUa|M9de|;?sJksYk9;9B$ePy1D)wDA9{x~n`a;qq-A337v zp5Az)*(x~i?drC(zA5B-<`$`JCC0K*^(aZ;xmJAe?g-q#fy-{$5&H73qcE6#pIkC0 z%&DyDejm?B{!TTOQ8n;15a6mXkvosYrq)q=K}zJeh9(;kNG$w4)jTMkC_K+bF@KqB zkGP1?`;Q~A=?;Ui;-z7yXf4H zR~RD_nk?7ET=2|!NzOuuC}xfpV4zXK9$ctX)G=yukWQ9J%uF;E{=)34Y?Fzs`w?yT z9tL@Qn@O;rS<{`#(U}w|{dSubvkab**CeXR)I{FN;(>y{wK+H@D?jBM;4&hmCSHXz z>}U?CA`S>Xk(F#HLL7qa26Bhrdi#AoIcshh$%8S?n-!ghel8EyXB#3?$c7F3R(N;AR+PgsT zTs+efLKYG*%`zj;2un3u)*1!==_ebfHZQ0qK&?|7t1mpbRv(rytV^tOO;@aw`;S}F zmL2H0p{cBUVY?HOwOocUgF7FjPp@EF1-G*%d|exd1|#Ab4a7@M!5kWok1SDFCogZ2 zzC5R>q^?4Lf(e;@2Wy?m(fOiPO8B%+!+3eH%yTAQESZ_+pG}#Gx79W_jaiv>FG|Gh zm4s~5yB4#Osx_Wpl2}w|yFni|pc&0H3)#Hq;QXkLQZ)^gqUNGH8Zr+zkrht?SM^)7 ziW8JGcTa1ZJ7_{x?`~cf+RqN+{6vUxefQnCe&+w6aeaU0HXoLjGdG=_4BhJkO@s>W zzWQwhFC4bLjYV|}$#tE$Hm@eD3Ic5=XeQz_2wIj<_#={dUDG~V--446eNE)N-OLlc zix$)uzHbfJ3^WM7oX(q9RWAL*seUYnEq4F;-jb~ zj;w&5qtPr)#?(3%tqsRRVbd9joRj~jT(;cAU{K9%ycGC4Z?^Y!!cb#fan=unRzap1qQ=(DZU zEhgx=aG7FpWKNdsQpBztsY9|BO59(AU{gC;Lv!z|^G(ryd48bu2F3?#t3z3i0IasC z3x@T=j$U;{&dm8Ql`?;boKKl4lYiuNdc@gNFu%THCW@aTpNP z3<~&xzT?eDJ&#o^3n& z{wgU3LAEU(q=zwAe_3R&ehEwj9{a0bhEEG{2swnD9s;Lt4nrvD4g(L6LGqh8umCV3 z^Hd1h&VCpy=KawkJptnwEEXiqH$#CkfRu&`+Sm|4KbvWi_BX@~;tTx4G)1PO6b>uc z(>twzfdMR!UK%6E2TVz*o{F@UDrEqLA{&NiZ2q(5(-)9oUCv1iqI06wmJ*R=25+YD z^FY8j;#p8qd7gtCDnlDNP`8%IRD3*@mW*uZ1x_`-}U-;(Z)Z3sXnZWbNRp z6RG(6a%$jpZL3@H<=7q*PN$8bk9$?L3L(+~GU_;1PRE!G9hV+ciV6|qgK;wW#Pz80 zlH>QOn}Vs!-f1XEN3~cjQf8%0o=vq$nl&3KCAKgkrMa3Ze*OZqw_X{B-2~h&7_-WOACvd)lVKiucxmSaAlCZ{qU%3hzW6I z`^jj(LdAz)i%5SM{D3@s$bhiIW?oCHYM#m#H=9{3Gtbrb=aO!Rt+gv@yFy)?o9o(5 zKHtX9-CbY4+?$h+w`;k-Ma2Yw{(p8mTt6a~JsMkjRN|bBJ1S;FPmwMal_V@!zIg>K zAevyND~hGSbD{`P{Dbt7K+N&et57@#Zx$UMrFsL;rBo|kw)lrBSxw|Vw8f^neNsl1 zdX~_p83Bh>q3CNCE?Fa|`rsr@R+ywID5iRmz&=c@AZW1+nI1m+PpO<`i3ie?rkL6* zj5l*G&V*4WJYZ>OGE@1VfzJ?KMN0WHFetk&_>Gs5p_>j^o6wO7a1p*_95ejEkPn!%Ts{RFOn8A_IwVU+I zpqrGi9v`=s*Qm--occhBP|wnVeD&``$|}>E%#_7p=40h(kDvmU!W;lOu%WzNpQY#s zQrS))p9^mlTq~v_2XHUJo*6pCW_0&Y>AXdx+veAekie@QS^nN!%8Wq*s*~B&^L}*l z?F$wCP?@MgJbBfrlDfsU(xTh#_r)#ejKn!~vd3euAPqOJ%Gq)E0yhZKkIY$N8@Eu8 zlpbCKn|JLFSZMj9{#7rFw4YN^Q%wg`0qFC{eh{r2~QU6-qU_ZjC^e_I2}=rTf!(rAD%WQb5h8Q_v!MuFjbJf;T`->M%%R*DV+b9q7tmc-F|1iO#hE5lqpxSTNnXP5Fz=}~Z zAI@!{a_{k64!<+Hc1CU|Uu*VR(QatKcMCq<36*k9H46mnavzZ-+oJ(^yri`dG z(MwoOaGhfuSZIXomwl)ws0PPAt^((ygqr%XuT9k$SuwbBnt^8m!sriPMK_5mUL0pW zA9NGyiKBX)Und&ows2wJiTue8+TSkJ)||~C+Jer3zU?l6(S8Psy^{94WWK34NzAd8 z^HPkrGdHm7sI?1~yJ`;p+fQ(6aR=qebVL#Voqm6zQsA9kOA`l#x8vOixN$?>y0G{81ZGH#8L_XbsbAgBbB1 zS;*qcQr34W&t@&(rBlAH@R$%V8KgE}K)y_I77$+(FJwd{M!M6Uenx=r;lHE zjH9M&HoI#u$I9;JJn!5Fkhx!Jy&$B>zfMTzig!k-e3WTJFl*_8zXnnm{rSM8uoz&6 zp`AWE@Ow1VE1(q2oGvr(&Dun!YV1q$(UwFm*$KMnF@7K6%|MkE3aS^>tbJISnwmv( z2QXjjUv%>otvJZ`M7}#;jIFss+FcO%Ai~1NZkhm9TY8^n8brg5Xz8zjlh0 z2Ccr4Rbh;nE7N>q2Wh?ASi!1Iiz}LR41X-tb7~n4d&}q%8&)I?v=~~O)4WE^`gtQ< zeRc;+uKE0q0eM}$5BTx&2zs;8^0jA+(VVEPR`mfUlg&S6KTbkxV&(SDcDOj0!Ofle zRH;B{bZY(DU45oWsZ5kOD*0nAaV3XeULU_Wy?klzYsrJC*LvjL>Lz!`O-Jc)dhcg) zYxT1JFe5hIc}X|*>nijm8?`8w#<&$6_hQ~bodM>Ajs6g9#sHK};>Z*npIDB5=)XhQsiU{yRVoFe_Ck)%x$6-@k_YV^20&`tPR;8Y% z%7V~FeSaL%(vzI&3*HH@k31P&cYcNa^88pIPEb_*-02?>QA{g#?;zhbE@PznGhImf zO%9^!9^~VEZmw0tHReT6CE)Z0eUU+JgvfEyfW%Z2;kX8!%PtKilKZ?-=nT9A!g`o! zbQ9a-7AE6=acZ*djv>d}TcNM!&|Y6b-5Q!5^Je(sWfl7=X7|BK=udyM6IZPZ>6$uk zGJW_Rqrs*!%QDlLYM5W*9tHsodK-&W8`il-c3s!|hB&vQ`ejQ&o$R#upvOi@bsixA zkRh+)<;ZFS?G>6$DqchaY`80~U+1xeXzz*r2^-vEo!J3QwQkM2l)@Hk_ zxA1Ml&2ik*@RNvrQ_;nvU7zJuP>c`>y5Y0!&q}v4Y3k~|?&JAM?Q8Ds*9BEDcM!Jp zp!AN0MWl}>_o>>Ij^)bMq0@w6r`Uep=e-LiL_g&H?AwH5W!LD6OqnEFn9O%+9doQo z@p%2!mFv@TMd(V#cbE966Heba`HHCT2QZ*)T!oZ;ogT9MDIX)y< z5;NZ8kbL#Z&)mNw{i%yx4huHOoAdeYnw>TIhSO^P4LiI>Lb1hrzuan#dLvL+?XP<0 zr<|^K#^gmmUna`$|B6WF%WyLpz znjN!?7&yN?r@YVDY2jwHv~z789B5zUr+*L11ru3iskNrV2Ml3rcqoH z!-s#7mp?qQ#z_;3^Hp+FmtQ_E_0b9D9-X(0Tef*ITEI3dB7wD$u%#d5>zuaN#dBwIkaHC#dFd`8EbB-D5C|Ss|D#T=%L2AcdD=VvL9a z-I*zo%AJ7e@mxA(K@{uF`lbK3H{g3pdgW!P_YZ7I(ZhdH^D+N7(qC437WV&4f15Qt zoRw8F{0MG$Km_NKiu?cZcqZXmh!r8k`6#8}M@p^zlktsnTsfNJoLXfAHh-JuiA}3@;xoTRIF>lrt{D#h|uE{r-H73wGnh zz6TaD$pahDj)<1torWvAkxSe>tUZ=b$G`|&Hye%h`W{XwP%JkVdpj*A*>p=ni=8=< zavPi6#h3eDq%&@>Vpv)X95tCnPZFbET^^vW=Zh; z>lrtZFT5m_l;)Y{88lHWst~Ifs~{&&J*?21pHn!Z#8jrSgl&oYMEHcrlB>y2Q-rGE zv1E8|VoA{)r77Dj*e%&DTAg=ap1ee93DcaSDOO!d3RA#XCb0B^G0F4{#|Z67r<**}VFJ>x-4mbOU8`5?a|^f5#iA;**Ta$7By!h0`ZYq-=dMiRR-rc2t1lrs8{ z<4WhveaD7d?$P0Vo-1JtFX z&!0qZufel+(e5E%Q*;SI1;j)3u?K`&6$;wT0!HgdWlZoP zkIzzKOKWJ7zwt$VDaP7)Dz)|~Pr5U_6`!ga_$xjGctV%56DiqjZ`~)od^9{3Gg7pa z4N^!?othhBz`V#9dmt?~NX+4xId)y?9{}?GM*y~Pl5O=xIh@`w9FQ-3-65rklo*rpQ7(n%K84!;6^I71AUxte&I_Lm6{2ZviuWyTByAllI z+^dVg1;Xpzy}#Ss+r>w3pdCP?)GZR=L-Ix?H054u@g2N|C9Z~6`qYqQ79!dRWI?b( zw$jN8prUy)<-s+9PLt#R=R_0 zJQ9i~Pi!C)Tt`Tfova>ecnv@8=5u|l<3^S|#YC2b(-}fl!~0efJQqBk$4$tDMiA!e zqw$r50NiDD8}fk;LiKqhMB7ZO=eVZU5r6n48DpQpMf5^ZTv%hHy03>ebD>OYIDxHi zb3ZJK=WHRg_XQZ*kAHzcPjDmC(-IhrPrnrfks?)PY5?Sn5rq%eWU>5)`AZY;3x z4=-5|X}_@PpPwGf9Giz=vC7G>n4Cg-_N<-5wth^F>+Wj_LurIx(EP_2cI;q$pPzGZ z?h-#yOe1LiIyiZzAD+K06c*9;9{(%qTcZLaYFztEfc{gf8ubb|6r>|O0?>hGy+T*~ z|DdgkIJ7?|y?k><6;(A}UyYSoxXB(l(|;!i(54mcmN61^K|gltTvD|c4@SRE~(5V5aECN)c6{af9wSg(Vw2Wd;GYQJl2eU6VxZ@|4zZo(>hW3)ZKpS}o;F z(`2RLF2llexIpCx6Od17nM+p;Z$=_O=^q3VuRA##wCZfDEB*DS ztS%(6y2WbRJ-&y zKe7I9m;?D+6!NC{!g)y3zApoYRZ}J!|JPlDgO?@M5ipWGXxn2#Q){Z=l~!+CSaH;7=Yp}H?f$C zKs6IPZ{pcc7492@&VG->PVLJzypNtxF0B?T+l}^dxh0 zCZ)&rE7!mo+CeOv-hD7?{#7&Z|I1Pw}WC=U@Bhc5#RSVzJ>i@ zKb0&vYoYldB!BTjYo0?o0XRVAH8TpTt*N=a_9Q%@1DETrKFl)hIAF*-G8=yPP zu3-A3@$altdX5rY-$2GQDzBsd&Y%tY&8_vGTYtST3PfM=jB%DTwxhNk1~Uz49t$cH z*Jzr>Jy#^viKp=jwL_}Zt+MMpj*iOgE*tl3V+G+$fzom_UM_ZyubD4%xz*PseyQE{ z1t>UJv44eaZ}B}^jEx*wg;{8P=|or3(Wd@?Zwwp6wNYKE@p!2CP(IqWqzh zQs&{z)ij<*hh7Ns~+Fb=93NVu>iMS zWdPO6rl>!UN}w8Mo2C2V56bVtSo`E6<>KyxV>ZJzI@{N;U7Dyga|eXkr3s<54h`%o%Lv%Xnq($VTU zF#T0x@+=VfbBMymOzIL@hi3)rzP7TMN7k}>?m`+$1`JMDuN-~Ph}Sxa}9{IO86CoK1iGTH=AAi108_r)(g(pBh<&^N>N znfJs-ci?*nX`78hO5e`4kFCOS)4O~~eP~eZJZ8AkkzPf)c8}e8Iq0hBFyUGCnkq#k zweNC#9>U_{l3PmnF){iqrh6s>Sh=iXUNy8{>dd68#>^;8O_InFHXl51Iz3P9icDKb z0^y^6p3Kd)h^FS{BvL7sZY8IUr&Zh3^}}bdRr*lWa#O9yI8&VBDHHuFEc1Qb+7?59 zl5z?fUCQ{yepQ7mN8+*D$t|gJ=O2{`dA`v0cR%0CY{E#^&Ww}~@^R`$S~-nH zE;hlupL`6B2lg#YJBrnnqGgGulZcwX@P|EdVo5yI^u&ew|MRU*ud7J9`^xpR0((Tx zzqq)rPt9kP0)F-yPAn1M8myL)AhKC8rt=3&;K-MI>z7+AnJTuwR$h6nYi9#VLaw88 zM2{h>nf>IlH_%mI&yuG2$idzGYqtW)AKnt5Z1~fH1x0Rlwx}`ypkN9K%N7+jPu(VU zSLsE~9T07E9G6aGrAG?C-x2L8uza*^yDZn7<#V1&F-ptrcnx0O9W^*Kjpx{{EmuwE zCbMW)H0TB&F4Gzv(2sY)a*0f2i2o)|s}m4Vwq@ERE?l0NPs@KL|AhN-Qg&&UaHalKVHu3g_YM(5hvr50c{i$ zV3Anr***4P7}m0TLRt^hQT7EO08k}6aJV=|Ji5cAmQfiF#ZdB*^nQf1zE998zYFH) zY2857J+Iw$)0|j2xrY&D11oW{3FwX;gvWy($_K(Q}8537HzmVT$rd z4iSVu9kp-}bFYvHOnYs-BiWKVLd)$4IxYDrt`Y5T2CI z6{R>ckzPMR+}5V<*s66#w-RhvtA$VNT9Mcd24E(jTcAf@dA&4W?O*I&U0-I;UtNkm z>922I6$H!XVCkTgsiDk3f7#Z#-+>KUbAA18KgxFG5*t;74DBy97!auTEVW|h=! zA1N%8ERn;YZUVG;Y1jS2<9eN`hR|Nh&SI_ZA;?|L?;4v5oTV_PzwY8h$5pYJ-ZTW!TPdR^x| zYQVy4c!RO!6XRTB@I0K(F?&LU{zUSp58OB({IOz<8{x?5`jovc{Vj$j+x?L zG?XHV+Dzpm-no3ko3*bN=%=@hlNTdIFW&-ja!d%28U#-((CkI3HS*vI4=Vb+xsS>xBzA^5w>-TV7bhV~ z;`pX0tK#|+)nc>Lk&l0yMD;A@_Y*u$;x87q3TIFlEx{FYj17$=zya6F(xt8qMx~0p zsug_P{-FMO3umU#uo*)|)Sa>f=JUg=_OCq&x!I2=NOnITRaA2L z-F8E53<*VMnh)`32-OoUY_Hw_hsmi zta2l&1>)gFxNcJ>;d;)-piuC^pOVncpH3)}&P2CZZOe06DB z2H33jSPWZIe!v}zaT+$W2V_8Ame1?LZ0NLt1K!q#hWCwbnrfR^=kUv0*xX7h<)XH0 zL{cUnK!nd2$UoUuGL+Mb=+MYqo97%Dfdgy}Ehr02*M^b8}}{XtQcC!BCA92+%1qo=*HHM6G? zz`NcIdQYcsN=vfuKNB&CuX&HTIg1JjQ)W*`##DpGzgOuz$_V_}^7Z-Dzo6)biM*{) zof)h&8m?6Lqnc@5c-&MZXH*KWVGRB%H8XNB%y^2GDMCG;E45}x>qC0UBj^4+kh#O1 z8FRV|Sldo(SnK)7*y|#IH0XQEDp$BcUQTqQAxPoD*EdUn*o1Xk6hC6PArddmuOz_#Lkg7gQ#rvzqk%Yd0>x%55e836hu`? zt{!VbQMQ-&1!HxBIRvd26xjf45#6JT?C61&g5EIMXe#@sd{ zl9lb-`P*Ip%xj4a*&bCSXw5> zE8Y&^mgzIFt7s;A>Vt0i4hljx62HR6TC+SGp|uOMS|#xo73Fs2yG6~@cqGkU@>NT^ zX7g}Nd31e$FLm7$9$idwTy_8AO+_*&6VZ}t)`V6hmxbJFvJRBkJ{=9`1^)M{b-n8x-YrJkgDnu?R(@^(@O8Qk0OTxn^C7P?XqD ztz}Zxnme~H!U1=@z6?5byo%zW2;`ym#}vZCoNS_ob$co;X?JF%y5@$12an+RhpS-4 zd(9VQ?5soN7(y&FLPB<>+;-nt?e01;gm|<4+~dt#3%>SrionkDL16{|m+}Aq1YyL> z@%cYb|IN%zz+e+|^BuRFn`pH28IK#xI3AvNQHwjz==ax~`}Xr6>oCN2hy#YWpH)p> zsK%*pC%^5AVJEY|!_%}}Mvh1W53hhYxH4NXy3;3&xZal(GrQ7< zN68>dB_Q^hyP;5ByqErGVPV%7vvcxm!EKR>pzLPn8mQ_g=@)KfRQX<98gvg@ z9L36Q5ODG=B55k4;N)q{KUmMGQT*3a#U@vm_kQB(41^~}|HAm;2X~Xt%TpZ`a4&Ye zWINn4GP3V6k%+8+3%We_?C6b&2sq+;ReXGrgMg1`E%WHcSV4rR|8l6RRz+8*mJ1rC zPcYUG*TycgI5+r{#cyJuIW~S*k2{Z@+@NLuf=A6;Xs8J4qv`En&e`7GxYvo$47Yd3 zR=?Qkhq~vqoB_7MepAuh2sb=z9c=7d%c`-JEUT;YcbsRp5!CPEr3MuKFA4QOvEA`; z|CfYPiUY}MfQbj!JwIBxL3`t6q#cC#yJtU_P+OKJe(N!@0QljE+vTj3I&j7Ruwl~x zXc!3>7xC4Sx3jcINvh(2VBYvU4iK;rL`|=0V#z3xPwi+A`E`HdYCAqrCWK?47`@{r zE>1zq$k?i~#Mv4}l{0-b&NdZZ?sFtz)|c9f)OG-=#3uv&jqsu_CptumVM+H+3>%L5 zTkJR=;cLhEl5x^g^2o5S!NSKFnl%kdO0jH>3pP_Syq5{xr1=t5{Ko<5cOG)ip_lrfhbDv$)fsT9jAz+CiVj_`36_rr!FMT zxUd{tP9Ixnk(RlpdMazHC&nuY(@5T`-_9j<+~1uLuTNt4?1o^~TXjvJ+k_q@muXIm z4-9!(ZZutyS2Co~zz*EMW~WWo3H6$1#~danmoYwK+`rtzr*tCCk(K_Z@+K_h$Ymiu;V`A>!Wl|nC6gL~MP)(ckQ44Nr!Y$PG#+P&~h z`n$u~c9O-7l~k(%4lW&)6LI=wtTnZ}HmF35;$LBTzQ}`V0oaUa`M#hAVy_8 zC0O23^};06?jr<7&O+A%EOb``j7(E4OiT`N5fXnqQPyd_ld=trjF7+>jfr7#Z9)1v zFn-^RSVUJQjn;9`_{Nk)qe?|A+m+4$;_{Fn<$;cXV1`oY zo-BDuh)8>!=@|O1n+>aDz(y>)*w^#>z)h)s$KWfks=6S^%8Q*~1FP%b@Pz`7I@P$0TV&j=7aVKPpEY?%xOG@{OU2 z;rLc(A`OtI#$YK6LVwX9P5~C2C)F^)Hx%kD1@@dHZhlfV$lD&o>yL`0rR$Q*pf$++(ew=A&%XO*`s~WC?Jb3El$WG?Se`Ue?>^#AB6u-6}Ki&jl=O5HBg;M zQ!~a|hSB>~wC!cE0$pXAhqHoOwqfbJ z4GuvQq>U}XcN39A2%1rY+uLH#wb7t9(nwE+M&I#bqvmfctRN?x{i~CS65g?0c6mU$ zd>Zwj@XMuwu;({2p);gjPh8Ny;2_fip!kzB>w6ML6nxU5e{obOgV=)ENh8iEj%5Ix z1}*sajkea#znq96Wlr8!66o5b`%62+so0x$5Mra&^;T^^`TC#n$=Q~oD3&M zx#iE{Vx-DlsOZZRe+_nMjFCyzGZCw3AA6OTKwiX(f`~~(jZSShcJsm}kjxbuS=sBn z{v7(k4X2t~7^F=L8r_d4Pcr99@MVrtpwMkkEyTdKmVCdf3{oTdF4+ba-Ai(Xu1&1i z%am!R*vc}NoTr|f1fXG83_R)wU2bor3~#9A4sVVx z;#9DBiK+f*Qu@^F+W|U@D?{fI&=f(qnuF`EE~hgHi~PpuJ*7BZWtfbNzYMC zXdZ|37W%?6je$1kPH49-YU9ZS7#A7DDw0F z*(nRg5H44G6aHdn&S8)Z06sQs0f#MxWXAS(6rP>g3L*{XG6{8dqjr@;3Bl_KsVC(P z$InD>^Ou=QGlNOJpKbk0Leqz51y8q@ZjeitAOZp2R5m@bV!m?G7Po4c4#Rc zeZSxDAQuBEH_nmGY4F0ALM8d6%`>CD&!1D^RONDqaG1-eS;y*^Oa>u&^!jl;oA+0? zs77I7MtUz(4#Vx(?j|4AxL#b%A#>Lx(J}J;O|3&C(L}lMUhgMOoKuUN3$IBt{cQ|5 z-WanW{P-LJ#XYQYTR->^IF>0PhXdG!hf4?3pfK7y@;7Q4Oe5Gg#;Ofdc1ngt#Yt;t@w zTO&vIjV#8IG+m8Lt>I_U=v%_oCXmX*Y=;O~k3CVm}Ro!(3}6*H#BE2+5-T@mAobH=#grk6|s%b*|5=LXUSMBUW^QrtqMxA3hY10 z{oR*kkoY%n7(giBBu%j5;X?!^bT*q&m03_vJ1KnR?Z53U%-Xg<$7k05zG4(JuH@#ab@^ZRm414rg`tLOX-~U+? z=&D;-va35eK`1%j)M@JM@{X2Hl>gz=czcvG5H{!Mu&{jVz%2O8z&!kXT%7#8+`Jq- z{9OFt&-|Y)xJ3W|Z-Ce}Y`$8c@o}>27;wJ*nhW&*DmnQ63sjtLbP)AD91d_QgSQ0a zHvV~yrJtH*;2W|~4SaVNaxI#;s%rO7@&o_9%ezqw8tTqm8kfJ4Skse%M36jWcpSf9 zQl+?xKrP{{&j~>pGVCw4tyfF-_N0NILMbtDQ6w-7<;2PG5<*$LR3{ylUkKd;>X;5U z?X>2%m&*(G)3vm!RVp&q(zM;%Wq%P(hVnu3u_cLn3HBcJzCFP$(G$P>?*Vp$fL$S8 Vt`?SPyq|eK^P$nvNvp`9{V&YZl6C+9 literal 0 HcmV?d00001 -- 2.18.1
