From 31fe13dc61a56e46e9e229eaa232dcab11acf1be Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Thu, 19 Jul 2018 15:44:08 +0200 Subject: [PATCH] Starting an introduction to Markdown --- module1/ressources/Makefile | 5 + .../ressources/introduction_to_markdown.html | 490 ++++++++++++++++++ .../ressources/introduction_to_markdown.org | 110 ++++ 3 files changed, 605 insertions(+) create mode 100644 module1/ressources/Makefile create mode 100644 module1/ressources/introduction_to_markdown.html create mode 100644 module1/ressources/introduction_to_markdown.org diff --git a/module1/ressources/Makefile b/module1/ressources/Makefile new file mode 100644 index 0000000..08aa5bd --- /dev/null +++ b/module1/ressources/Makefile @@ -0,0 +1,5 @@ +all: introduction_to_markdown.html + +%.html: %.org + emacs -batch $^ --funcall org-html-export-to-html + sed -i 's/
+Introduction à Markdown
+Voici un aperçu rapide de la syntaxe Markdown repris d'une +présentation de Github ainsi que de celles d'Archer Reilly et de James +H. Steiger. +
Syntaxe
Headers
+# This is an <h1> tag
+## This is an <h2> tag
+###### This is an <h6> tag
Emphasis
+*This text will be italic*
+_This will also be italic_
+**This text will be bold**
+__This will also be bold__
+_You **can** combine them_
Lists
Unordered
+* Item 1
+* Item 2
+  * Item 2a
+  * Item 2b
Ordered
+1. Item 1
+1. Item 2
+1. Item 3
+   1. Item 3a
+   1. Item 3b
Images
+![GitHub Logo](/images/logo.png)
+Format: ![Alt Text](url)
Links
+http://github.com - automatic!
+[GitHub](http://github.com)
Blockquotes
+As Kanye West said:
+> We're living the future so
+> the present is our past.
Inline code
+I think you should use an
+`<addr>` element here instead.
Écrire des Maths
+Equations can be formatted inline or as displayed formulas. In the +latter case, they are centered and set off from the main text. In the +former case, the mathematical material occurs smoothly in the line of +text. +
+In order to fit neatly in a line, summation expressions (and similar +constructs) are formatted slightly differently in their inline and +display versions. +
+Inline mathematical material is set off by the use of single +dollar-sign characters. Consequently, if you wish to use a dollar sign +(for example, to indicate currency), you need to preface it with a +back-slash. The following examples, followed by their typeset +versions, should make this clear +
+This summation expression $\sum_{i=1}^n X_i$ appears inline.
+This summation expression \(\sum_{i=1}^n X_i\) appears inline. +
+This summation expression is in display form.
+$$\sum_{i=1}^n X_i$$
+This summation expression is in display form. +
+\[\sum_{i=1}^n X_i\] +
Lettres grecques
SymboleCommande
\(\alpha\)$\alpha=
\(\beta\)$\beta$
\(\gamma\)$\gamma$
\(\Gamma\)$\Gamma$
\(\pi\)$\pi$
Operators
Date: June, 2018
Author: Arnaud Legrand
Created: 2018-07-19 jeu. 15:43
Validate
+ + diff --git a/module1/ressources/introduction_to_markdown.org b/module1/ressources/introduction_to_markdown.org new file mode 100644 index 0000000..3cbb121 --- /dev/null +++ b/module1/ressources/introduction_to_markdown.org @@ -0,0 +1,110 @@ +# -*- mode: org -*- +#+TITLE: Introduction à Markdown +#+AUTHOR: Arnaud Legrand +#+DATE: June, 2018 +#+LANG: fr +#+STARTUP: overview indent +#+OPTIONS: num:nil toc:t + + +Voici un aperçu rapide de la syntaxe Markdown repris d'une +[[https://guides.github.com/features/mastering-markdown/][présentation de Github]] ainsi que de celles d'[[http://csrgxtu.github.io/2015/03/20/Writing-Mathematic-Fomulars-in-Markdown/][Archer Reilly]] et de [[http://www.statpower.net/Content/310/R%2520Stuff/SampleMarkdown.html][James +H. Steiger]]. +* Syntaxe +** Headers +#+BEGIN_EXAMPLE + # This is an
tag + ## This is an
tag + ###### This is an
tag +#+END_EXAMPLE + +** Emphasis +#+BEGIN_EXAMPLE + *This text will be italic* + _This will also be italic_ + + **This text will be bold** + __This will also be bold__ + + _You **can** combine them_ +#+END_EXAMPLE + +** Lists +*** Unordered +#+BEGIN_EXAMPLE + * Item 1 + * Item 2 + * Item 2a + * Item 2b +#+END_EXAMPLE +*** Ordered +#+BEGIN_EXAMPLE + 1. Item 1 + 1. Item 2 + 1. Item 3 + 1. Item 3a + 1. Item 3b +#+END_EXAMPLE +** Images +#+BEGIN_EXAMPLE + ![GitHub Logo](/images/logo.png) + Format: ![Alt Text](url) +#+END_EXAMPLE +** Links +#+BEGIN_EXAMPLE + http://github.com - automatic! + [GitHub](http://github.com) +#+END_EXAMPLE +** Blockquotes +#+BEGIN_EXAMPLE + As Kanye West said: + + > We're living the future so + > the present is our past. +#+END_EXAMPLE +** Inline code +#+BEGIN_EXAMPLE + I think you should use an + `` element here instead. +#+END_EXAMPLE +* Écrire des Maths + +Equations can be formatted *inline* or as *displayed formulas*. In the +latter case, they are centered and set off from the main text. In the +former case, the mathematical material occurs smoothly in the line of +text. + +In order to fit neatly in a line, summation expressions (and similar +constructs) are formatted slightly differently in their inline and +display versions. + +Inline mathematical material is set off by the use of single +dollar-sign characters. Consequently, if you wish to use a dollar sign +(for example, to indicate currency), you need to preface it with a +back-slash. The following examples, followed by their typeset +versions, should make this clear + +#+BEGIN_EXAMPLE +This summation expression $\sum_{i=1}^n X_i$ appears inline. +#+END_EXAMPLE + +This summation expression $\sum_{i=1}^n X_i$ appears inline. + +#+BEGIN_EXAMPLE +This summation expression is in display form. + +$$\sum_{i=1}^n X_i$$ +#+END_EXAMPLE +This summation expression is in display form. + +$$\sum_{i=1}^n X_i$$ + +** Lettres grecques + | Symbole | Commande | + |---------+----------| + | $\alpha$ | =$\alpha== | + | $\beta$ | =$\beta$= | + | $\gamma$ | =$\gamma$= | + | $\Gamma$ | =$\Gamma$= | + | $\pi$ | =$\pi$= | +** Operators -- 2.18.1
