diff --git a/module2/ressources/gitlab.org b/module2/ressources/gitlab.org index 9936655685a07702d3eeb2710280b8bba601ff7f..178c76dac683ea02b2150d9828d69aa77f9faff1 100644 --- a/module2/ressources/gitlab.org +++ b/module2/ressources/gitlab.org @@ -81,41 +81,28 @@ git config --global http.proxy http://proxyUsername:proxyPassword@proxy.server.c The proxyPassword will be stored unencrypted in your ~.gitconfig~ file, which you may not want. In that case, remove it from the URL and you will be prompted for it every time it is needed. -** Configuring your password on GitLab -1. Access [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/xblock/block-v1:inria+41016+session01bis+type@lti+block@05a0ce425f1741e5bee5049040f70529/handler/preview_handler][GitLab]]. /Note: You have to access Gitlab from the FUN +** Changing the default password on GitLab + +*Warning (Jupyter users) :* changing your default Gitlab password will prevent you from commiting in Jupyter. You will have to do the extra step of changing your Jupyter =~/.git-credentials= + +1. Get your default password using the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/7508aece244548349424dfd61ee3ba85][Gitlab credentials retrieval tool] +2. Access [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/xblock/block-v1:inria+41016+session01bis+type@lti+block@05a0ce425f1741e5bee5049040f70529/handler/preview_handler][GitLab]]. /Note: You have to access Gitlab from the FUN platform otherwise you may get a 405 error/ /when trying to direcly open https://app-learninglab.inria.fr/gitlab/users/sign_in/. #+BEGIN_CENTER [[file:gitlab_images/erreur405.png]] #+END_CENTER -2. Click on =Sign in:= +3. Click on =Sign in:= or using your default credentials #+BEGIN_CENTER - [[file:gitlab_images/projects.png]] + [[file:gitlab_images/signin.png]] #+END_CENTER The long and uggly character sequence, which is here replaced by =xxx= is your GitLab login/id. You'll need to use it when trying to propagate some modifications from your computer to GitLab. -3. To defind your password, you should go in =settings=: +4. Go to =Account > Settings > Password= and define your password using your default password : #+BEGIN_CENTER - [[file:gitlab_images/settings.png]] - #+END_CENTER -4. Then, go to the =profile= tab to define a valid email address: - #+BEGIN_CENTER - [[file:gitlab_images/profile.png]] - #+END_CENTER - You will then receive a email with a link to open to confirm your - email address is correct. Just open it. -5. Once your email address is validated, it will appear as =verified= and - as your =main address= in the =Emails= tab: - #+BEGIN_CENTER - [[file:gitlab_images/mail.png]] - #+END_CENTER -6. You will then finally be able to click on the =I forgot my password= - button from the =password= tab: [[file:gitlab_images/password.png]] - - You will then receive an email allowing you to reset your GitLab - password. + #+END_CENTER ** Remembering your password locally If you clone your repos by simply pasting the GitLab URL, you will be prompted for your login and your password every time you want to diff --git a/module2/ressources/gitlab_images/adresse_depot.png b/module2/ressources/gitlab_images/adresse_depot.png deleted file mode 100644 index 684b44f96d93fa06e11b78c5d76463ff8a655c2d..0000000000000000000000000000000000000000 Binary files a/module2/ressources/gitlab_images/adresse_depot.png and /dev/null differ diff --git a/module2/ressources/gitlab_images/mail.png b/module2/ressources/gitlab_images/mail.png deleted file mode 100644 index 69238ec3925f613167b4bdaff868940182e94a6f..0000000000000000000000000000000000000000 Binary files a/module2/ressources/gitlab_images/mail.png and /dev/null differ diff --git a/module2/ressources/gitlab_images/password.png b/module2/ressources/gitlab_images/password.png index ac5e65c48dd6d75a4923269596fc7ac0fb6431fe..989e3e2dc68a785590cecd745799bb777b2f75f5 100644 Binary files a/module2/ressources/gitlab_images/password.png and b/module2/ressources/gitlab_images/password.png differ diff --git a/module2/ressources/gitlab_images/projects.png b/module2/ressources/gitlab_images/projects.png deleted file mode 100644 index b80f45b6db11a383f0f0f26849e99f539354465f..0000000000000000000000000000000000000000 Binary files a/module2/ressources/gitlab_images/projects.png and /dev/null differ diff --git a/module2/ressources/gitlab_images/signin.png b/module2/ressources/gitlab_images/signin.png new file mode 100644 index 0000000000000000000000000000000000000000..1a14b4d148f811fe91f364179450f768ccca6866 Binary files /dev/null and b/module2/ressources/gitlab_images/signin.png differ
