diff --git a/module2/ressources/replicable_article/article.org b/module2/ressources/replicable_article/article.org index 2d9cfcc24db73b1432f4ddaf4c890894df147935..caed127462ff1d761937b6a8ca17e4e04acecb74 100644 --- a/module2/ressources/replicable_article/article.org +++ b/module2/ressources/replicable_article/article.org @@ -218,7 +218,7 @@ our own experimental testbed with support of our university. #+LaTeX: \def\raggedright{} #+LaTeX: \bibliographystyle{IEEEtran} #+LaTeX: \bibliography{biblio} -* Emacs Setup :noexport: +* Emacs Setup :noexport: This document has local variables in its postembule, which should allow Org-mode to work seamlessly without any setup. If you're uncomfortable using such variables, you can safely ignore them at @@ -227,14 +227,15 @@ our own experimental testbed with support of our university. # Local Variables: # eval: (add-to-list 'load-path ".") # eval: (require 'org-install) -# eval: (org-babel-do-load-languages 'org-babel-load-languages '((shell . t) (R . t) (python . t) )) +# eval: (org-babel-do-load-languages 'org-babel-load-languages '((R . t) (python . t) )) +# eval: (setq org-babel-python-command (if (memq system-type '(windows-nt ms-dos)) "Python" "python3")) +# eval: (require 'ess-site) # eval: (setq org-confirm-babel-evaluate nil) # eval: (unless (boundp 'org-latex-classes) (setq org-latex-classes nil)) # eval: (add-to-list 'org-latex-classes '("IEEEtran" -# "\\documentclass[conference, 10pt, compsocconf]{IEEEtran}\n \[NO-DEFAULT-PACKAGES]\n \[EXTRA]\n \\usepackage{graphicx}\n \\usepackage{hyperref}" ("\\section{%s}" . "\\section*{%s}") ("\\subsection{%s}" . "\\subsection*{%s}") ("\\subsubsection{%s}" . "\\subsubsection*{%s}") ("\\paragraph{%s}" . "\\paragraph*{%s}") ("\\subparagraph{%s}" . "\\subparagraph*{%s}"))) +# "\\documentclass[conference, 10pt]{IEEEtran}\n \[NO-DEFAULT-PACKAGES]\n \[EXTRA]\n \\usepackage{graphicx}\n \\usepackage{hyperref}" ("\\section{%s}" . "\\section*{%s}") ("\\subsection{%s}" . "\\subsection*{%s}") ("\\subsubsection{%s}" . "\\subsubsection*{%s}") ("\\paragraph{%s}" . "\\paragraph*{%s}") ("\\subparagraph{%s}" . "\\subparagraph*{%s}"))) # eval: (setq org-alphabetical-lists t) # eval: (setq org-src-fontify-natively t) # eval: (setq ess-ask-for-ess-directory nil) +# eval: (setq org-latex-pdf-process '("%latex -interaction nonstopmode -output-directory %o %f" "bibtex %b" "%latex -interaction nonstopmode -output-directory %o %f" "%latex -interaction nonstopmode -output-directory %o %f")) # End: - -
