diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index 26f8213dfbdc21cf47fca886d079aa4894752c5b..f16baebcfef940b20cd7dc729bd35e18a92489b8 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -209,7 +209,7 @@ mkdir -p ~/org/ Then copy =rr_org/journal.org= file in your =~/org/= directory. This file will be your laboratory notebook and all the notes you will capture with =C-c c= will go automatically go in this file. The first -entry of this notebook is populated with [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][many Emacs shortcuts]] that you +entry of this notebook is populated with [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][many Emacs shortcuts]] that you should give a try. ** Step 2: Set up Emacs configuration Copy =rr_org/init.el= in your =~/.emacs.d/= directory. @@ -249,7 +249,7 @@ worked. In the video, we already have demonstrated the main features and shortcuts of emacs/org-mode that will help you maintain a document and benefit from literate programming. The list of features and shortcuts -is demonstrated in the [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][first entry of your labbook]]. +is demonstrated in the [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][first entry of your labbook]]. ** Step 5: Open and play with your journal: In step 1, you were told to create an journal in =~org/journal.org=. First you probably want to make sure this file is @@ -266,7 +266,7 @@ open a terminal and run the commands =R=, =pdflatex=, and =python=, you will not able to generate this document. When being compiled, the article downloads the corresponding LaTeX packages so you also need to have a working =wget= command (alternatively, it uses =curl=). Once downloaded, you may still read the -source ([[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org][article.org]]) and understand how it works though. +source ([[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org]]) and understand how it works though. #+begin_src shell :results output :exports none make -C replicable_article/ all ../replicable_article.tgz @@ -275,7 +275,7 @@ make -C replicable_article/ all ../replicable_article.tgz #+RESULTS: Download the following [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/replicable_article.tgz][archive]], uncompress it and simply =make= to generate the -article. You should then be able to open the [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.pdf][resulting article]]. This +article. You should then be able to open the [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.pdf][resulting article]]. This is summarized in the following command: #+begin_src sh :results output :exports both wget --no-check-certificate -O replicable_article.tgz https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/replicable_article.tgz @@ -296,7 +296,7 @@ tar zxf replicable_article.tgz; cd replicable_article; make ; evince article.pdf command line to load your personal emacs configuration. Finally, when you'll be tired of always re-executing all the source -code when exporting, just look for the following line in [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org][article.org]]: +code when exporting, just look for the following line in [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org][article.org]]: #+BEGIN_EXAMPLE # #+PROPERTY: header-args :eval never-export #+END_EXAMPLE @@ -310,12 +310,12 @@ Learning Emacs and Org-Mode can be difficult as there is an inordinate amount of shortcuts. Many people have thus come up with cheat-sheats. Here is a selection in case it helps: *** Emacs -- [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][Common and step-by-step Emacs shortcuts for our /reproducible research/ configuration]] +- [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][Common and step-by-step Emacs shortcuts for our /reproducible research/ configuration]] - [[https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf][The official GNU emacs refcard]] - Two graphical cheat-sheats by Sacha Chua on [[http://sachachua.com/blog/wp-content/uploads/2013/05/How-to-Learn-Emacs-v2-Large.png][how to learn Emacs]] and on [[http://sachachua.com/blog/wp-content/uploads/2013/08/20130830-Emacs-Newbie-How-to-Learn-Emacs-Keyboard-Shortcuts.png][how to learn Emacs shortcuts]]. *** Org-mode -- [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][Common and step-by-step org-mode shortcuts for our /reproducible research/ configuration]] +- [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][Common and step-by-step org-mode shortcuts for our /reproducible research/ configuration]] - [[https://orgmode.org/worg/orgcard.html][The official org-mode refcard]] - [[https://orgmode.org/worg/dev/org-syntax.html][The official description of the org-mode syntax]] and a [[https://gist.github.com/hoeltgman/3825415][relatively concise description of the org-mode syntax]]. ** Video tutorials
