From 3dfd08cb0e1759a82bed08cfb9577a3d3356c953 Mon Sep 17 00:00:00 2001 From: Laurence Farhi Date: Thu, 3 Oct 2019 11:59:27 +0200 Subject: [PATCH] =?UTF-8?q?suppression=20backquote=20pour=20que=20cela=20n?= =?UTF-8?q?e=20soit=20pas=20ex=C3=A9cut=C3=A9=20par=20Mathjax=20dans=20FUN?= MIME-Version: 1.0 Content-Type: text/plain; charset=UTF-8 Content-Transfer-Encoding: 8bit --- module1/ressources/sequence4.org | 6 +++--- module1/ressources/sequence4_fr.org | 4 ++-- 2 files changed, 5 insertions(+), 5 deletions(-) diff --git a/module1/ressources/sequence4.org b/module1/ressources/sequence4.org index b82266f..afae145 100644 --- a/module1/ressources/sequence4.org +++ b/module1/ressources/sequence4.org @@ -12,7 +12,7 @@ #+CREATOR: Emacs 26.1 (Org mode 9.1.9) #+STARTUP: indent -* Table of contents :TOC: +* Table of contents :TOC: - [[#version-control-with-gitlab-and-git-in-the-Reproducible-research-mooc][Version control with GitLab and Git]] - [[#version-control-with-libreoffice-or-dokuwiki][Version control with LibreOffice or DokuWiki]] @@ -43,8 +43,8 @@ This section describes the successive steps involved. The following [[https://ww [[file:gitlab_images/password_retrieval.png]] #+END_CENTER -- You can change this password in `Account / - Paramètres / Mot de passe`. We do not recommend doing it since that will block you from using the Jupyter notebooks of this MOOC. +- You can change this password in "Account / + Paramètres / Mot de passe". We do not recommend doing it since that will block you from using the Jupyter notebooks of this MOOC. #+BEGIN_CENTER [[file:gitlab_images/password.png]] #+END_CENTER diff --git a/module1/ressources/sequence4_fr.org b/module1/ressources/sequence4_fr.org index da52bda..a40ecaa 100644 --- a/module1/ressources/sequence4_fr.org +++ b/module1/ressources/sequence4_fr.org @@ -50,8 +50,8 @@ type d'environnement. [[file:gitlab_images/password_retrieval.png]] #+END_CENTER -- Il est possible de modifier ce mot de passe dans `Account / - Paramètres / Mot de passe`. Mais nous vous déconseillons de le faire +- Il est possible de modifier ce mot de passe dans "Account / + Paramètres / Mot de passe". Mais nous vous déconseillons de le faire car cela vous empêchera d'utiliser les notebook Jupyter du MOOC. #+BEGIN_CENTER [[file:gitlab_images/password.png]] -- 2.18.1
