diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index 75676e49c9e18ed43db1bba6b61a8f5b59c192d7..e95840692cfdd667f43ea1c6c32d00f5e7e7f7ce 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -352,12 +352,35 @@ in the context of this MOOC in a [[https://www.fun-mooc.fr/courses/course-v1:inr It is very powerful and we use it on a daily basis but you should definitely understand what git does behind the scenes beforehand. If you feel this would be useful for you, you should follow [[https://magit.vc/screenshots/][this visual -walk-through]] or [[https://www.emacswiki.org/emacs/Magit][this really short "crash course"]]. If you installed the -previous "/reproducible research/" emacs configuration, you can easily -invoke magit by using ~C-x g~. +walk-through]] or [[https://www.emacswiki.org/emacs/Magit][this really short "crash course"]]. + +If you installed the previous "/reproducible research/" emacs +configuration, you can easily invoke magit by using ~C-x g~. Magit will +then prompt you for the path of your local clone of the git repository +(the path to mooc-rr in the context of this MOOC). +[[file:emacs_orgmode_images/git1.png]] + +If you do not rely on our "/reproducible research/" emacs configuration, +you should have a look at [[https://magit.vc/manual/magit/Installing-from-an-Elpa-Archive.html][how to install magit from an ELPA archive]]. + +The following method has been tested with Windows and worked like a charm: +- Add the following piece of text in your =.emacs.d/init.el= file: + #+begin_src emacs-lisp + (require 'package) + (add-to-list 'package-archives + '("melpa" . "http://melpa.org/packages/") t) + + #+end_src +- Launch Emacs and run the following commands: + #+BEGIN_EXAMPLE + M-x package-refresh-contents RET + M-x package-install RET magit RET + #+END_EXAMPLE + NB: =M-= corresponds to the == key and =RET= corresponds to the + == key. ** Other resources - [[https://orgmode.org/orgguide.pdf][The compact Org-mode Guide]] -- A huge ressource of emacs/org-mode magic is Bernt Hansen's «[[http://doc.norang.ca/org-mode.html][Organize +- A huge resource of emacs/org-mode magic is Bernt Hansen's «[[http://doc.norang.ca/org-mode.html][Organize your life in plain text]]», whose source is obviously itself an [[http://doc.norang.ca/org-mode.org][org-mode document]]. - [[https://github.com/dfeich/org-babel-examples][Many examples illustrating the use of different languages in diff --git a/module2/ressources/emacs_orgmode_images/git1.png b/module2/ressources/emacs_orgmode_images/git1.png new file mode 100755 index 0000000000000000000000000000000000000000..f6721fdac3580626d220049e5c1606403b49fa4f Binary files /dev/null and b/module2/ressources/emacs_orgmode_images/git1.png differ
