diff --git a/documents/tuto_jupyter_windows/.gitkeep b/documents/tuto_jupyter_windows/.gitkeep deleted file mode 100755 index e69de29bb2d1d6434b8b29ae775ad8c2e48c5391..0000000000000000000000000000000000000000 diff --git a/documents/tuto_jupyter_windows/images/.gitkeep b/documents/tuto_jupyter_windows/images/.gitkeep deleted file mode 100755 index e69de29bb2d1d6434b8b29ae775ad8c2e48c5391..0000000000000000000000000000000000000000 diff --git a/documents/tuto_jupyter_windows/images/new_notebook.png b/documents/tuto_jupyter_windows/images/new_notebook.png deleted file mode 100755 index e8aa5d677a797aefdcb881a1327e5ae1c574fdb9..0000000000000000000000000000000000000000 Binary files a/documents/tuto_jupyter_windows/images/new_notebook.png and /dev/null differ diff --git a/documents/tuto_jupyter_windows/images/notebook_R.png b/documents/tuto_jupyter_windows/images/notebook_R.png deleted file mode 100755 index 09c36db62592613596deef66f849a96a2e42a363..0000000000000000000000000000000000000000 Binary files a/documents/tuto_jupyter_windows/images/notebook_R.png and /dev/null differ diff --git a/documents/tuto_jupyter_windows/tuto_jupyter_windows.md b/documents/tuto_jupyter_windows/tuto_jupyter_windows.md deleted file mode 100755 index 9daac155f4d69c99f6fcb6aec8e9e30808af3357..0000000000000000000000000000000000000000 --- a/documents/tuto_jupyter_windows/tuto_jupyter_windows.md +++ /dev/null @@ -1,198 +0,0 @@ -Table des matières -================= -- [1 Installer Python](#1-installer-python) -- [2 Installer le package Jupyter](#2-installer-le-package-jupyter) -- [3 Installer les modules complémentaires](#3-installer-les-modules-compl%C3%A9mentaires) -- [4 Lancer Jupyper](#4-lancer-jupyper) -- [5 Autres langages](#5-autres-langages) - - [5.1 Le package R IRKernel](#51-le-package-r-irkernel-permet-dex%C3%A9cuter-du-code-r-dans-un-notebook-r) - - [5.2 Le package Python rpy2](#52-le-package-python-rpy2-permet-dex%C3%A9cuter-du-code-r-dans-un-notebook-python) - - [5.3 Le package Python SASPy](#53-le-package-python-saspy-permet-dex%C3%A9cuter-du-code-sas-dans-un-notebook-python) - - [5.4 Le package Python SASKernel](#54-le-package-python-saskernel-permet-dex%C3%A9cuter-du-code-sas-dans-un-notebook-sas) - -# 1 Installer Python - -- Installer Python -- Ajouter les chemins de Python et Python\Scripts dans dans la variable PATH de Windows - -La façon de procéder est très bien expliquée [ici](http://sametmax.com/ajouter-un-chemin-a-la-variable-denvironnement-path-sous-windows/). - ---- - -# 2 Installer le package Jupyter - -- Méthode pour installer un package - - Ouvrir une invite de commande dos - - Exécuter la commande suivante - -``` -pip install jupyter -``` - -NB : Le raccourci `^v` ne fonctionne pas dans l'invite de commande dos. La fonction "coller" est disponible avec le bouton droit de la souris. - ---- - -# 3 Installer les modules complémentaires - -- Ouvrir une invite de commande dos -- Exécuter les commandes suivantes - -## **jupyter_contrib_nbextensions** pour replier le code à l'affichage - -``` -pip install jupyter_contrib_nbextensions -``` - -## **hide_code** pour choisir ce qui est exporté - -``` -pip install hide_code -jupyter-nbextension install --py hide_code -jupyter-nbextension enable --py hide_code -jupyter-serverextension enable --py hide_code -``` - -Choisir `Hide_code` dans le menu - -![menu_hide_code](documents/tuto_jupyter_windows/images/menu_hide_code.png) - -On obtient ceci - -![hide_code](documents/tuto_jupyter_windows/images/hide_code.png) - -Utiliser les icônes ci-dessous pour l'export - -![export_hide_code](documents/tuto_jupyter_windows/images/export_hide_code.png) - -NB : Certains ont rencontrés des problèmes lors de l'export sous Windows lors de la 1ère session du Mooc. - -# 4 Lancer Jupyper - -- Ouvrir une invite de commande dos -- Exécuter la commande suivante - -``` -jupyter notebook -``` - ---- - -# 5 Autres langages - -Jupyper permet par défaut d'exécuter du code Python. Des packages permettent d'exécuter d'autres langages. - -## 5.1 Le package R [IRKernel](https://cran.r-project.org/web/packages/IRkernel/IRkernel.pdf) permet d'exécuter du code R dans un notebook R - -- Lancer R ou RStudio - -- Installer le package `IRkernel` - -``` -install.packages('IRkernel',dep=TRUE) -IRkernel::installspec() # to register the kernel in the current R installation -``` - -- On peut alors créer un notebook R - -![new_notebook](documents/tuto_jupyter_windows/images/new_notebook.png) - -![notebook_R](documents/tuto_jupyter_windows/images/notebook_R.png) - -On remarque l'icône du logiciel R en haut à droite. - -- [Exemple de notebook R](https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/documents/notebooks/notebook_Jupyter_R.ipynb) - -- Lien utile : https://irkernel.github.io/installation/ - ---- - -## 5.2 Le package Python **rpy2** permet d'exécuter du code R dans un notebook Python - -- Le package `rpy2` s'installe difficilement par méthode standard. - -- Télécharger le fichier binaire qui correspond au système d'exploitation [ici](https://www.lfd.uci.edu/~gohlke/pythonlibs/#rpy2) - -- Ouvrir une invite de commande dos - -- Se placer dans le dossier de téléchargement - -- Exécuter la commande suivante - -``` -python -m pip install rpy2‑2.9.4‑cp37‑cp37m‑win_amd64.whl # adapter le nom du fichier -``` - -- Lancer Jupiter et créer un notebook Python - -- Exécuter la commande suivante - -``` -%load_ext rpy2.ipython -``` - -- Installer le package `tzlocal` à l'aide de la commande `pip` - -- [Exemple de notebook Python/R](https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/documents/notebooks/notebook_Jupyter_Python_R.ipynb) - -- Lien utile : https://stackoverflow.com/questions/14882477/rpy2-install-on-windows-7 - -NB : Je n'ai pas eu besoin de définir les variables d'environnement R_HOME et R_USER. - ---- - -## 5.3 Le package Python [SASPy](https://sassoftware.github.io/saspy/) permet d'exécuter du code SAS dans un notebook Python - -- Installer le package `saspy` à l'aide de la commande `pip` - -- Modifier le fichier C:\Program Files\Python\Python37\Lib\site-packages\saspy\sascfg_sav.py pour l'adapter à votre système - -Dans les deux images ci-dessous, la fenêtre de gauche correspond au fichier initial et celle de droite au fichier modifié. - -![sascfg1](documents/tuto_jupyter_windows/images/sascfg1.png) - -![sascfg2](documents/tuto_jupyter_windows/images/sascfg2.png) - -- [Exemple de notebook Python/SAS](https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/documents/notebooks/notebook_Jupyter_Python_SAS.ipynb) - -- NB : L'export Jupyter vers pdf ne fonctionne pas pour les sorties HTML et donc SAS. Il est possible de faire l'export depuis pandoc. - - - Exporter le document au format HTML - - Exécuter la commande suivante - -``` -pandoc --variable=geometry:a4paper --variable=geometry:margin=1in notebook_sas.html -o notebook_sas.pdf -``` - -mais ça ne marche pas pour tous les tableaux et on perd la coloration syntaxique. - ---- - -## 5.4 Le package Python [SASKernel](https://sassoftware.github.io/sas_kernel/) permet d'exécuter du code SAS dans un notebook SAS - -- Le package `sas_kernel` est basé sur le package `saspy`. Installer `saspy` en suivant les instructions de la section 4.3 si ce n'est déjà fait. - -- Installer le package `sas_kernel` à l'aide de la commande `pip` - -- On peut alors créer un notebook SAS - -![new_notebook](documents/tuto_jupyter_windows/images/new_notebook.png) - -![notebook_SAS](documents/tuto_jupyter_windows/images/notebook_SAS.png) - -On remarque l'icône du logiciel SAS en haut à droite. - -- [Exemple de notebook SAS](https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/documents/notebooks/notebook_Jupyter_SAS.ipynb) - -- NB : L'export Jupyter vers pdf ne fonctionne pas pour les sorties HTML et donc SAS. Il est possible de faire l'export depuis pandoc. - - - Exporter le document au format HTML - - Exécuter la commande suivante - -``` -pandoc --variable=geometry:a4paper --variable=geometry:margin=1in notebook_sas.html -o notebook_sas.pdf -``` - -mais ça ne marche pas pour tous les tableaux et on perd la coloration syntaxique. - -- Lien utile : https://sassoftware.github.io/sas_kernel/install.html diff --git a/module2/ressources/jupyter.org b/module2/ressources/jupyter.org index 743c899723369594cb6e772cd441e27ada8135fd..d9f0da101556a5f514cbb9a89d7c20e9a27d6357 100644 --- a/module2/ressources/jupyter.org +++ b/module2/ressources/jupyter.org @@ -6,14 +6,22 @@ #+OPTIONS: num:nil toc:t #+PROPERTY: header-args :eval never-export +Once you will have followed all these installation instructions, you +will be able to run jupyter notebooks by simply typing in a shell/DOS +command: +#+begin_src shell :results output :exports both +jupyter notebook +#+end_src + * Table of Contents :TOC: - [[#jupyter-tips-and-tricks][Jupyter tips and tricks]] - [[#creating-or-importing-a-notebook][Creating or importing a notebook]] - [[#running-r-and-python-in-the-same-notebook][Running R and Python in the same notebook]] - [[#other-languages][Other languages]] - [[#installing-and-configuring-jupyter-on-your-computer][Installing and configuring Jupyter on your computer]] - - [[#installing-jupyter][Installing Jupyter]] + - [[#installing-jupyter-and-python-r-][Installing Jupyter (and Python, R, ...)]] - [[#making-sure-jupyter-allows-you-to-use-r][Making sure Jupyter allows you to use R]] + - [[#latex-for-pdf-export][LaTeX for PDF export]] - [[#additional-tips][Additional tips]] * Jupyter tips and tricks @@ -54,6 +62,10 @@ situations however where you may want to play with other notebooks. notebook and confirm the upload. 4. Open the freshly uploaded notebook through the Jupyter file manager. + +You will find [[file:../../documents/notebooks/][here]] a list of jupyter notebooks that illustrate how +different languages (python, R, SAS) can be used in Jupyter. + ** Running R and Python in the same notebook It used to be impossible with earlier versions of Jupyter but it is now very easy thanks to the the =rpy2= package (see the details of the @@ -90,15 +102,63 @@ None of these other languages have been deployed in the context of our MOOC but you may want to read the next sections to learn how to set up your own Jupyter on your computer and benefit from these extensions. -Since the question was asked several times, if you really need to stay -with SAS, you should know that SAS can be used within Jupyter using -either the [[https://sassoftware.github.io/sas_kernel/][Python SASKernel]] or the [[https://sassoftware.github.io/saspy/][Python SASPy]] package (step by step -explanations about this are given [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/documents/tuto_jupyter_windows/tuto_jupyter_windows.md][here]]). +*** SAS +SAS is a proprietary statistical software which is very commonly used +in health research. Since the question was asked several times, if you +really need to stay with SAS, you should know that SAS can be used +within Jupyter using either the [[https://sassoftware.github.io/sas_kernel/][Python SASKernel]] (similar to the +=IRKernel=) or the [[https://sassoftware.github.io/saspy/][Python SASPy]] package (similar to the =rpy2= package). + +Since proprietary software such as SAS cannot easily be inspected, we +discourage its use as it hinders reproducibility by essence. But +perfection does not exist anyway and using Jupyter literate +programming approach allied with systematic control version and +environment control will certainly help anyway. + +*[[https://sassoftware.github.io/saspy/][SASPy]]* +- Install =saspy= with the =pip= command. E.g., + #+begin_src shell :results output :exports both + python -m pip install saspy + #+end_src +- On Windows, you will have to modify the file =C:\Program + Files\Python\Python37\Lib\site-packages\saspy\sascfg_sav.py= and to + adapt it to your own system. In both following screenshots, the left + window corresponds to the initial file and the right window + corresponds to the modified one: + #+BEGIN_CENTER + [[file:jupyter_images/sascfg1.png]] + #+END_CENTER + #+BEGIN_CENTER + [[file:jupyter_images/sascfg2.png]] + #+END_CENTER +- Here is a [[file:../../documents/notebooks/notebook_Jupyter_Python_SAS.ipynb][example of Python/SAS notebook]]. +- NB : Some people from the first edition of the MOOC reported us that + the pdf export did not not seem to work for SAS notebooks. However, + they could obtain pdf files through pandoc. E.g., export in HTML (or + markdown) in jupyter and then run: + #+begin_src shell :results output :exports both + pandoc --variable=geometry:a4paper --variable=geometry:margin=1in notebook_sas.html -o notebook_sas.pdf + #+end_src +- Useful link: https://sassoftware.github.io/saspy/ -Since proprietary software such as SAS cannot easily be inspected, we discourage its use as it hinders reproducibility by -essence. But perfection does not exist anyway and using Jupyter -literate programming approach allied with systematic control version -and environment control will certainly help anyway. +*[[https://sassoftware.github.io/sas_kernel/install.html][SASKernel]]* + +- The =sas_kernel= is based on the =saspy= so first instll =saspy= by + following the previous instructions. +- Install the =sas_kernel= package through =pip=. E.g., + #+begin_src shell :results output :exports both + python -m pip install sas_kernel + #+end_src +- You will then be able to create SAS notebooks + #+BEGIN_CENTER + [[file:jupyter_images/new_notebook.png]] + #+END_CENTER + #+BEGIN_CENTER + [[file:jupyter_images/notebook_SAS.png]] + #+END_CENTER + Please note the top right SAS icon. +- Here is a [[file:../../documents/notebooks/notebook_Jupyter_SAS.ipynb][example of SAS notebook]]. +- Useful link: https://sassoftware.github.io/sas_kernel/install.html * Installing and configuring Jupyter on your computer In this section, we explain how to set up a Jupyter environment on @@ -110,7 +170,7 @@ you to mix various components (including notebooks) in your browser. In the context of this MOOC, our time frame was too short to benefit from JupyterLab which was still under active development. You may, however, prefer JupyterLab when doing an installation on your own computer. -** Installing Jupyter +** Installing Jupyter (and Python, R, ...) Follow these instructions if you wish to have a Jupyter environment on your own computer similar to the one we set up for this MOOC. @@ -268,6 +328,21 @@ Here are a few extensions that can ease your life: jupyter-serverextension enable --py hide_code #+end_src + Then in jupyter, choose =Hide_code= in the menu + #+BEGIN_CENTER + [[file:jupyter_images/menu_hide_code.png]] + #+END_CENTER + You should then obtain this: + #+BEGIN_CENTER + [[file:jupyter_images/hide_code.png]] + #+END_CENTER + You should then use the icons to export rather than going through + the menu: + #+BEGIN_CENTER + [[file:jupyter_images/export_hide_code.png]] + #+END_CENTER + NB: In the first edition of the MOOC some people had issues making + it work under Windows. *** • Interacting with GitLab and GitHub To ease your experience, we added pull/push buttons that allow you to commit and sync with GitLab. This development was specific to diff --git a/module2/ressources/jupyter_fr.org b/module2/ressources/jupyter_fr.org index d9fef69c06417fbeb22d2b575c59512550b539f1..6a27566474838e53f5d2732461f0dc8cc66b957a 100644 --- a/module2/ressources/jupyter_fr.org +++ b/module2/ressources/jupyter_fr.org @@ -12,8 +12,9 @@ - [[#exécuter-du-code-r-et-du-code-python-dans-le-même-notebook][Exécuter du code R et du code Python dans le même notebook]] - [[#autres-langages-que-python-et-r][Autres langages que Python et R]] - [[#installation-et-configuration-de-jupyter-sur-votre-ordinateur][Installation et configuration de Jupyter sur votre ordinateur]] - - [[#installation-de-jupyter][Installation de Jupyter]] + - [[#installation-de-jupyter-et-de-python-r-][Installation de Jupyter (et de Python, R, ...)]] - [[#sassurer-que-jupyter-vous-permet-dutiliser-r][S'assurer que Jupyter vous permet d'utiliser R]] + - [[#latex-pour-la-génération-de-pdf][LaTeX pour la génération de PDF]] - [[#conseils-additionnels][Conseils additionnels]] * Jupyter: Trucs et astuces @@ -108,11 +109,17 @@ MOOC mais nous vous invitons à lire les sections suivantes pour apprendre à déployer votre propre instance de jupyter et activer certaines de ses extensions. -Puisque la question est posée de façon récurrente, si vous avez besoin -d'utiliser le langage SAS plutôt que le langage R, il y a deux façons -d'utiliser SAS avec Jupyter: soit avec le noyau [[https://sassoftware.github.io/sas_kernel/][Python SASKernel]], soit -avec la bibliothèque [[https://sassoftware.github.io/saspy/][Python SASPy]] (des explications détaillés sont -données [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/documents/tuto_jupyter_windows/tuto_jupyter_windows.md][ici]]). +Vous trouverez [[file:../../documents/notebooks/][ici]] une liste de notebooks jupyter illustrant comment +différents langages (python, R, SAS) peuvent être utilisés dans Jupyter. + +*** SAS +SAS est un logiciel de statistiques propriétaires qui est très +couramment utilisé dans le domaine de la santé. Puisque la question +est posée de façon récurrente, si vous avez besoin d'utiliser le +langage SAS plutôt que le langage R, il y a deux façons d'utiliser SAS +avec Jupyter: soit avec le noyau [[https://sassoftware.github.io/sas_kernel/][Python SASKernel]] (l'équivalent du +=IRKernel=), soit avec la bibliothèque [[https://sassoftware.github.io/saspy/][Python SASPy]] (l'équivalent de +=rpy2=). Malgré la qualité et la stabilité de ce langage, SAS n'en reste pas moins un langage propriétaire, ce qui rend l'inspection de ses @@ -123,6 +130,55 @@ objectif de recherche reproductible mais il faut aussi savoir ne pas SAS, l'utilisation de la programmation lettrée de Jupyter et d'un contrôle de version (avec gitlab) et d'environnement (avec docker par exemple) se révélera très certainement précieux. + +*[[https://sassoftware.github.io/saspy/][SASPy]]* +- Installer =saspy= via =pip=, par exemple comme ceci: + #+begin_src shell :results output :exports both + python -m pip install saspy + #+end_src +- Sous Windows, il vous faudra probablement modifier le fichier =C:\Program + Files\Python\Python37\Lib\site-packages\saspy\sascfg_sav.py= et + l'adapter à votre propre système. Dans les deux captures d'écran + suivantes, la fenêtre de gauche correspond à la version originale du + fichier et celle de droite à la version modifiée: + #+BEGIN_CENTER + [[file:jupyter_images/sascfg1.png]] + #+END_CENTER + #+BEGIN_CENTER + [[file:jupyter_images/sascfg2.png]] + #+END_CENTER +- Voici un [[file:../../documents/notebooks/notebook_Jupyter_Python_SAS.ipynb][exemple de notebook Python/SAS]]. +- NB : Lors de la première édition du MOOC, certains participants nous + on rapporté avoir rencontré des difficultés pour exporter leurs + notebooks SAS au format PDF. Ils sont néanmoins parvenus à leur fin + en passant par pandoc. Par exemple, exportez en HTML (ou en + markdown) dans jupyter puis exécutez la commande suivante: + #+begin_src shell :results output :exports both + pandoc --variable=geometry:a4paper --variable=geometry:margin=1in notebook_sas.html -o notebook_sas.pdf + #+end_src +- Une référence, plus complète, et bien utile en cas de difficulté:: + https://sassoftware.github.io/saspy/ + +*[[https://sassoftware.github.io/sas_kernel/install.html][SASKernel]]* + +- Le =sas_kernel= utilise =saspy= docn la première chose à faire est + d'installer =saspy= en suivant les instructions précédentes. +- Installez =sas_kernel= à l'aide de =pip=, par exemple comme ceci: + #+begin_src shell :results output :exports both + python -m pip install sas_kernel + #+end_src +- Yous pourrez alors créer des notebooks utilisant SAS nativement: + #+BEGIN_CENTER + [[file:jupyter_images/new_notebook.png]] + #+END_CENTER + #+BEGIN_CENTER + [[file:jupyter_images/notebook_SAS.png]] + #+END_CENTER + Vous pouvez remarquer la petite icône SAS en haut à droite. +- À toute fin utile, voici un [[file:../../documents/notebooks/notebook_Jupyter_SAS.ipynb][exemple de notebooks SAS]]. +- Une référence, plus complète, et bien utile en cas de difficulté: + https://sassoftware.github.io/sas_kernel/install.htmlxo + * Installation et configuration de Jupyter sur votre ordinateur Dans cette section, nous expliquons comment installer, sur votre ordinateur, un environnement Jupyter similaire à celui que nous avons @@ -136,7 +192,7 @@ avons manqué de temps pour bénéficier de tout JupyterLab qui était toujours en développement actif. À l'heure actuelle, vous pouvez cependant avoir intérêt à installer tout JupyterLab sur votre ordinateur. -** Installation de Jupyter +** Installation de Jupyter (et de Python, R, ...) Ces instructions permettent d'obtenir sur votre ordinateur un environnement Jupyter similaire à celui que nous avons déployé dans le cadre du MOOC. @@ -307,7 +363,23 @@ vie: jupyter-nbextension enable --py hide_code jupyter-serverextension enable --py hide_code #+end_src - + Vous pourrez alors choisir =Hide_code= dans le menu de Jupyter + #+BEGIN_CENTER + [[file:jupyter_images/menu_hide_code.png]] + #+END_CENTER + Cela devrait vous permettre d'obtenir ce genre de panneau de + configuration pour chaque cellule: + #+BEGIN_CENTER + [[file:jupyter_images/hide_code.png]] + #+END_CENTER + Il vous faudra utiliser les icônes pour faire l'export en pdf ou en + html plutôt que de passer par le menu. + #+BEGIN_CENTER + [[file:jupyter_images/export_hide_code.png]] + #+END_CENTER + NB: Dans la première édition de ce MOOC, certains participants nous + ont rapporté avoir eu des difficultés à faire fonctionner cette + extension sous Windows. *** • Interaction avec GitLab et GitHub Pour rendre vous simplifier la vie, nous avons rajouté des boutons =pull/push= dans Jupyter qui vous permettent de synchroniser vos diff --git a/documents/tuto_jupyter_windows/images/export_hide_code.png b/module2/ressources/jupyter_images/export_hide_code.png old mode 100755 new mode 100644 similarity index 100% rename from documents/tuto_jupyter_windows/images/export_hide_code.png rename to module2/ressources/jupyter_images/export_hide_code.png diff --git a/documents/tuto_jupyter_windows/images/hide_code.png b/module2/ressources/jupyter_images/hide_code.png old mode 100755 new mode 100644 similarity index 100% rename from documents/tuto_jupyter_windows/images/hide_code.png rename to module2/ressources/jupyter_images/hide_code.png diff --git a/documents/tuto_jupyter_windows/images/menu_hide_code.png b/module2/ressources/jupyter_images/menu_hide_code.png old mode 100755 new mode 100644 similarity index 100% rename from documents/tuto_jupyter_windows/images/menu_hide_code.png rename to module2/ressources/jupyter_images/menu_hide_code.png diff --git a/module2/ressources/jupyter_images/new_notebook.png b/module2/ressources/jupyter_images/new_notebook.png old mode 100755 new mode 100644 diff --git a/module2/ressources/jupyter_images/notebook_R.png b/module2/ressources/jupyter_images/notebook_R.png old mode 100755 new mode 100644 diff --git a/documents/tuto_jupyter_windows/images/notebook_SAS.png b/module2/ressources/jupyter_images/notebook_SAS.png old mode 100755 new mode 100644 similarity index 100% rename from documents/tuto_jupyter_windows/images/notebook_SAS.png rename to module2/ressources/jupyter_images/notebook_SAS.png diff --git a/documents/tuto_jupyter_windows/images/sascfg1.png b/module2/ressources/jupyter_images/sascfg1.png old mode 100755 new mode 100644 similarity index 100% rename from documents/tuto_jupyter_windows/images/sascfg1.png rename to module2/ressources/jupyter_images/sascfg1.png diff --git a/documents/tuto_jupyter_windows/images/sascfg2.png b/module2/ressources/jupyter_images/sascfg2.png old mode 100755 new mode 100644 similarity index 100% rename from documents/tuto_jupyter_windows/images/sascfg2.png rename to module2/ressources/jupyter_images/sascfg2.png
