diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index 08f61bb2ae2dd87290dc0847f4daa65df8c314d1..53c4b2d132440a6f5e6b9e7368a3930185f13ed3 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -98,7 +98,7 @@ For advanced uses of Emacs, such as calling Emacs from a Makefile to automate do Be aware that running Emacs the Unix way implies some subtle differences compared to running Emacs the macOS way. In particular, Emacs will inherit the shell's environment variables when run the Unix way, but the user session's environment variables when run the macOS way. ** Windows -Download the recompiled Emacs 26 ([[https://ftp.gnu.org/gnu/emacs/windows/emacs-26/emacs-26.1-i686.zip][for 32 bits architectures]] or [[https://ftp.gnu.org/gnu/emacs/windows/emacs-26/emacs-26.1-x86_64.zip][for 64 bits architectures]] depending on your machine) and unzip the zip file preserving the directory structure. If this approach does not work, follow the instructions from the [[https://www.gnu.org/software/emacs/download.html#windows][official emacs website]]. If this still fails, do not hesitate to ask questions on the forum. +Download the precompiled Emacs 26, which is available [[https://ftp.gnu.org/gnu/emacs/windows/emacs-26/emacs-26.1-i686.zip][for 32 bits architectures]] or [[https://ftp.gnu.org/gnu/emacs/windows/emacs-26/emacs-26.1-x86_64.zip][for 64 bits architectures]]. The choice depends on your machine; if you don't know which is best, try the 64-bit version and if it cannot be started, switch to 32-bit. Unzip the zip file preserving the directory structure. If this approach does not work, follow the instructions from the [[https://www.gnu.org/software/emacs/download.html#windows][official emacs website]]. If this still fails, do not hesitate to ask questions on the forum. Finally run =bin\runemacs.exe=. Alternatively, create a desktop shortcut to =bin\runemacs.exe=, and start Emacs by double-clicking on that shortcut's icon. See [[https://www.gnu.org/software/emacs/manual/html_node/emacs/Windows-Startup.html][here]] for an explanation of this and other methods for launching Emacs under Windows. You should be able to obtain a window that looks like this: #+BEGIN_CENTER
