From 53f7a2c40073331f24a07e2dea43196111a0095c Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Wed, 25 Jul 2018 19:00:45 +0200 Subject: [PATCH] Minor typos plus link to the MOOC videos (rather than youtube ones) --- module2/ressources/gitlab.html | 112 ++++++++++++++++----------------- module2/ressources/gitlab.org | 18 +++--- 2 files changed, 65 insertions(+), 65 deletions(-) diff --git a/module2/ressources/gitlab.html b/module2/ressources/gitlab.html index 4d05a98..a89d820 100644 --- a/module2/ressources/gitlab.html +++ b/module2/ressources/gitlab.html @@ -4,24 +4,24 @@
Table of Contents
Setting up SSH on Framagit
Setting up SSH on GitLab
Here are all the official explanations on how to set up your SSH key on GitLab. Alternatively, you may also want to have a look at this diff --git a/module2/ressources/gitlab.org b/module2/ressources/gitlab.org index da17909..a74f17e 100644 --- a/module2/ressources/gitlab.org +++ b/module2/ressources/gitlab.org @@ -19,9 +19,11 @@ is very convenient but in most cases, you will want to have your own local copy of the repository and you will have to synchronize your local copy with the remote GitLab one. To propagate your modifications, you will obviously have to authenticate yourself on -GitLab. This document describes the software you need to have -installed on your machine and how to handle authentification. Please -read these instructions carefully. +GitLab. How to do this is illustrated in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/f6580ad8e997400faeffe9af4fd37063/2][video tutorial]] (in French). + +This document describes the software you need to have +installed on your machine and how to handle authentication. Please +read these instructions carefully. * Installing Git ** Linux (debian, ubuntu) @@ -52,10 +54,8 @@ never asks me for any password anymore and I don't have to remember anything). ** Option 1: HTTPS *** Configuring your GitLab password -In this video, I explain how to change your password on our GitLab. -#+BEGIN_CENTER -Youtube Video -#+END_CENTER +In this [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/f6580ad8e997400faeffe9af4fd37063/2][video tutorial]] (in French), I explain how to change your +password on our GitLab. *** Making sure git remembers your password My GitLab id is =3211ac4f2fb71deaeff9252764c368e7=. Say I've configured my password to be =tototutu= (what a weak password...) and I want to @@ -83,7 +83,7 @@ git config --global credential.helper "cache --timeout=3600" # for one hour at m With this setup, you will be prompted for your password but it will be cached in memory and they will not be asked again before an hour. ** Option 2: SSH -My prefered (although more technical) solution is to install SSH, to +My preferred (although more technical) solution is to install SSH, to create a pair or private/public keys, and to upload your SSH public key on GitLab. This section provides with information on how to do this. @@ -102,7 +102,7 @@ You do not have anything to do as it is installed by default. **** Windows You should install the [[https://www.ssh.com/ssh/putty/windows/][Putty]] client. Once it is installed, look for the section on [[https://www.ssh.com/ssh/putty/windows/puttygen][generating an SSH key]]. -*** Setting up SSH on Framagit +*** Setting up SSH on GitLab Here are [[https://docs.gitlab.com/ee/ssh/][all the official explanations on how to set up your SSH key on GitLab]]. Alternatively, you may also want to have a look at this video: -- 2.18.1
