Learning Lab
61d32194
61d32194
Use python3 by default and fix babel chunks
6c7dc12e
2
2 changed files
11 additions
4 deletions
+11
-4
init.el
module2/ressources/rr_org/init.el
+4
-2
init.org
module2/ressources/rr_org/init.org
+7
-2
61d32194
@@ -155,6 +155,8 @@ Entered on %U
setq
org-src-preserve-indentation
t
setq
t
setq
org-babel-python-command
"python3"
add-to-list
'org-structure-template-alist
add-to-list
"s"
"#+begin_src ?\n\n#+end_src"
"<src lang=\"?\">\n\n</src>"
"s"
@@ -174,10 +176,10 @@ Entered on %U
"p"
"#+begin_src python :results output :exports both\n\n#+end_src"
"<src lang=\"python\">\n\n</src>"
"p"
add-to-list
add-to-list
"P"
"#+begin_src python :results output :session
*python*
"P"
"#+begin_src python :results output :session :exports both\n\n#+end_src"
add-to-list
add-to-list
"PP"
file :var matplot_lib_filename=(org-babel-temp-file \"figure\" \".png\") :exports both \nimport matplotlib.pyplot as plt\n\nimport numpy\nx=numpy.linspace(-15,15)\nplt.figure(figsize=(10,5))\nplt.plot(x,numpy.cos(x)/x)\nplt.tight_layout()\n\nplt.savefig(matplot_lib_filename)\nreturn
(matplot_lib_filename)\n#+end_src"
"PP"
output file :session :var matplot_lib_filename=(org-babel-temp-file \"figure\" \".png\") :exports both\nimport matplotlib.pyplot as plt\n\nimport numpy\nx=numpy.linspace(-15,15)\nplt.figure(figsize=(10,5))\nplt.plot(x,numpy.cos(x)/x)\nplt.tight_layout()\n\nplt.savefig(matplot_lib_filename)\nprint
add-to-list
add-to-list
"b"
"#+begin_src shell :results output :exports both\n\n#+end_src"
"<src lang=\"sh\">\n\n</src>"
"b"
61d32194
@@ -281,6 +281,11 @@ Additional shortcuts for navigating through org-mode documents:
(setq org-src-preserve-indentation t)
** Python
*** We use python3
#+begin_src emacs-lisp :tangle init.el
(setq org-babel-python-command "python3")
** Adding source code blocks: :LUKA:
*** With capital letters:
To use this type <s and then TAB
@@ -325,12 +330,12 @@ To use this type <p and then TAB
(add-to-list 'org-structure-template-alist
'("P" "#+begin_src python :results output :session
*python*
:exports both\n\n#+end_src" "<src lang=\"python\">\n\n</src>"))
'("P" "#+begin_src python :results output :session :exports both\n\n#+end_src" "<src lang=\"python\">\n\n</src>"))
'("PP" "#+begin_src python :results
(matplot_lib_filename)\n#+end_src" "<src lang=\"python\">\n\n</src>"))
*** Bash "sh" code:
*** Bash "sh" code:
To use this type <b and then TAB
