From 6ad9bce761f4403dd3727b394f398d845265cd80 Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Thu, 19 Jul 2018 18:17:33 +0200 Subject: [PATCH] =?UTF-8?q?Introduction=20=C3=A0=20Markdown!!?= MIME-Version: 1.0 Content-Type: text/plain; charset=UTF-8 Content-Transfer-Encoding: 8bit --- .../ressources/introduction_to_markdown.html | 407 +++++++++++++++--- .../ressources/introduction_to_markdown.org | 89 +++- 2 files changed, 406 insertions(+), 90 deletions(-) diff --git a/module1/ressources/introduction_to_markdown.html b/module1/ressources/introduction_to_markdown.html index 8fb8eba..3a369b8 100644 --- a/module1/ressources/introduction_to_markdown.html +++ b/module1/ressources/introduction_to_markdown.html @@ -4,26 +4,30 @@
Table of Contents
@@ -31,16 +35,15 @@
Voici un aperçu rapide de la syntaxe Markdown repris d'une -présentation de Github ainsi que de celles d'Archer Reilly et de James -H. Steiger. +présentation de Github ainsi que de celles d'Archer Reilly.
Syntaxe
Syntaxe
Headers
Headers
 # This is an <h1> tag
 ## This is an <h2> tag
@@ -49,9 +52,9 @@ H. Steiger.
Emphasis
Emphasis
 *This text will be italic*
 _This will also be italic_
@@ -64,13 +67,13 @@ _You **can** combine them_
Lists
Lists
Unordered
Unordered
 * Item 1
 * Item 2
@@ -79,9 +82,9 @@ _You **can** combine them_
Ordered
Ordered
 1. Item 1
 1. Item 2
@@ -92,27 +95,27 @@ _You **can** combine them_
Images
Images
 ![GitHub Logo](/images/logo.png)
 Format: ![Alt Text](url)
Links
Links
 http://github.com - automatic!
 [GitHub](http://github.com)
Blockquotes
Blockquotes
 As Kanye West said:
@@ -121,9 +124,9 @@ As Kanye West said:
Inline code
Inline code
 I think you should use an
 `<addr>` element here instead.
@@ -131,55 +134,62 @@ I think you should use an
Écrire des Maths
Écrire des Maths
-Equations can be formatted inline or as displayed formulas. In the -latter case, they are centered and set off from the main text. In the -former case, the mathematical material occurs smoothly in the line of -text. +Il est possible d'écrire des formules en Markdown, soit en mode inline +soit en mode displayed formulas. Dans le premier cas, les formules +sont inclues directement à l'intérieur du paragraphe courant alors +que dans le second, elles apparaissent centrées et mises en exergue.
-In order to fit neatly in a line, summation expressions (and similar -constructs) are formatted slightly differently in their inline and -display versions. +Le formatage de la formule est légèrement différent dans les deux cas +car pour qu'une formule s'affiche joliment sur une seule ligne, il +faut la "tasser" un peu plus que lorsqu'elle est mise en valeur.
-Inline mathematical material is set off by the use of single -dollar-sign characters. Consequently, if you wish to use a dollar sign -(for example, to indicate currency), you need to preface it with a -back-slash. The following examples, followed by their typeset -versions, should make this clear +Pour écrire une formule en mode inline, il faut la délimiter par un $ +(du coup, pour écrire le symbole dollar, il faut le préfixer par un +backslash, comme ceci: \$) alors que pour écrire en mode displayed, il +faut la délimiter par un $$. Un petit exemple valant mieux qu'un long +discours, voici concrètement comment cela fonctionne:
-This summation expression $\sum_{i=1}^n X_i$ appears inline.
+Cette expression $\sum_{i=1}^n X_i$ est inlinée.
-This summation expression \(\sum_{i=1}^n X_i\) appears inline. +Cette expression \(\sum_{i=1}^n X_i\) est inlinée.
-This summation expression is in display form.
+Cette expression est mise en valeur:
 $$\sum_{i=1}^n X_i$$
-This summation expression is in display form. +Cette expression est mise en valeur:
\[\sum_{i=1}^n X_i\]
Lettres grecques
+Nous vous présentons par la suite une sélection de symboles et de +commandes courantes. En fait, à peu près tout ce qui est classique +dans le langage LaTeX peut être utilisé pourvu que vous délimitiez +bien avec un $. Pour d'autres exemples plus complets jetez un coup +d'œil à ces exemples de James H. Steiger. +
Lettres grecques
@@ -223,8 +233,265 @@ This summation expression is in display form.
Operators
Fonctions et opérateurs
SymboleCommande
\(\cos\)$\cos$
\(\sin\)$\sin$
\(\lim\)$\lim$
\(\exp\)$\exp$
\(\to\)$\to$
\(\in\)$\in$
\(\forall\)$\forall$
\(\exists\)$\exists$
\(\equiv\)$\equiv$
\(\sim\)$\sim$
\(\approx\)$\approx$
\(\times\)$\times$
\(\le\)$\le$
\(\ge\)$\ge$
Exposants et indices
SymboleCommande
\(k_{n+1}\)$k_{n+1}$
\(n^2\)$n^2$
\(k_n^2\)$k_n^2$
Fractions, coefficients binomiaux, racines, …
SymboleCommande
\(\frac{4z^3}{16}\)$\frac{4z^3}{16}$
\(\frac{n!}{k!(n-k)!}\)$\frac{n!}{k!(n-k)!}$
\(\binom{n}{k}\)$\binom{n}{k}$
\(\frac{\frac{x}{1}}{x - y}\)$\frac{\frac{x}{1}}{x - y}$
\(^3/_7\)$^3/_7$
\(\sqrt{k}\)$\sqrt{k}$
\(\sqrt[n]{k}\)$\sqrt[n]{k}$
Sommes et intégrales
SymboleCommande
\(\sum_{i=1}^{10} t_i\)$\sum_{i=1}^{10} t_i$
\(\int_0^\infty \mathrm{e}^{-x}\,\mathrm{d}x\)$\int_0^\infty \mathrm{e}^{-x}\,\mathrm{d}x$
Déguisements
SymboleCommande
\(\hat{a}\)$\hat{a}$
\(\bar{a}\)$\bar{a}$
\(\dot{a}\)$\dot{a}$
\(\ddot{a}\)$\ddot{a}$
\(\overrightarrow{AB}\)$\overrightarrow{AB}$
diff --git a/module1/ressources/introduction_to_markdown.org b/module1/ressources/introduction_to_markdown.org index 3cbb121..ee8b2c4 100644 --- a/module1/ressources/introduction_to_markdown.org +++ b/module1/ressources/introduction_to_markdown.org @@ -8,8 +8,7 @@ Voici un aperçu rapide de la syntaxe Markdown repris d'une -[[https://guides.github.com/features/mastering-markdown/][présentation de Github]] ainsi que de celles d'[[http://csrgxtu.github.io/2015/03/20/Writing-Mathematic-Fomulars-in-Markdown/][Archer Reilly]] et de [[http://www.statpower.net/Content/310/R%2520Stuff/SampleMarkdown.html][James -H. Steiger]]. +[[https://guides.github.com/features/mastering-markdown/][présentation de Github]] ainsi que de celles d'[[http://csrgxtu.github.io/2015/03/20/Writing-Mathematic-Fomulars-in-Markdown/][Archer Reilly]]. * Syntaxe ** Headers #+BEGIN_EXAMPLE @@ -68,37 +67,41 @@ H. Steiger]]. `` element here instead. #+END_EXAMPLE * Écrire des Maths +Il est possible d'écrire des formules en Markdown, soit en mode *inline* +soit en mode *displayed formulas*. Dans le premier cas, les formules +sont inclues directement à l'intérieur du paragraphe courant alors +que dans le second, elles apparaissent centrées et mises en exergue. -Equations can be formatted *inline* or as *displayed formulas*. In the -latter case, they are centered and set off from the main text. In the -former case, the mathematical material occurs smoothly in the line of -text. +Le formatage de la formule est légèrement différent dans les deux cas +car pour qu'une formule s'affiche joliment sur une seule ligne, il +faut la "tasser" un peu plus que lorsqu'elle est mise en valeur. -In order to fit neatly in a line, summation expressions (and similar -constructs) are formatted slightly differently in their inline and -display versions. - -Inline mathematical material is set off by the use of single -dollar-sign characters. Consequently, if you wish to use a dollar sign -(for example, to indicate currency), you need to preface it with a -back-slash. The following examples, followed by their typeset -versions, should make this clear +Pour écrire une formule en mode *inline*, il faut la délimiter par un =$= +(du coup, pour écrire le symbole dollar, il faut le préfixer par un +backslash, comme ceci: =\$=) alors que pour écrire en mode *displayed*, il +faut la délimiter par un =$$=. Un petit exemple valant mieux qu'un long +discours, voici concrètement comment cela fonctionne: #+BEGIN_EXAMPLE -This summation expression $\sum_{i=1}^n X_i$ appears inline. +Cette expression $\sum_{i=1}^n X_i$ est inlinée. #+END_EXAMPLE -This summation expression $\sum_{i=1}^n X_i$ appears inline. +Cette expression $\sum_{i=1}^n X_i$ est inlinée. #+BEGIN_EXAMPLE -This summation expression is in display form. +Cette expression est mise en valeur: $$\sum_{i=1}^n X_i$$ #+END_EXAMPLE -This summation expression is in display form. +Cette expression est mise en valeur: $$\sum_{i=1}^n X_i$$ +Nous vous présentons par la suite une sélection de symboles et de +commandes courantes. En fait, à peu près tout ce qui est classique +dans le langage LaTeX peut être utilisé pourvu que vous délimitiez +bien avec un =$=. Pour d'autres exemples plus complets jetez un coup +d'œil à ces [[http://www.statpower.net/Content/310/R%2520Stuff/SampleMarkdown.html][exemples de James H. Steiger]]. ** Lettres grecques | Symbole | Commande | |---------+----------| @@ -107,4 +110,50 @@ $$\sum_{i=1}^n X_i$$ | $\gamma$ | =$\gamma$= | | $\Gamma$ | =$\Gamma$= | | $\pi$ | =$\pi$= | -** Operators +** Fonctions et opérateurs + | Symbole | Commande | + |---------+----------| + | $\cos$ | =$\cos$= | + | $\sin$ | =$\sin$= | + | $\lim$ | =$\lim$= | + | $\exp$ | =$\exp$= | + | $\to$ | =$\to$= | + | $\in$ | =$\in$= | + | $\forall$ | =$\forall$= | + | $\exists$ | =$\exists$= | + | $\equiv$ | =$\equiv$= | + | $\sim$ | =$\sim$= | + | $\approx$ | =$\approx$= | + | $\times$ | =$\times$= | + | $\le$ | =$\le$= | + | $\ge$ | =$\ge$= | +** Exposants et indices + | Symbole | Commande | + |---------+-----------| + | $k_{n+1}$ | =$k_{n+1}$= | + | $n^2$ | =$n^2$= | + | $k_n^2$ | =$k_n^2$= | +** Fractions, coefficients binomiaux, racines, ... + | Symbole | Commande | + |-----------------------------+-----------------------------| + | $\frac{4z^3}{16}$ | =$\frac{4z^3}{16}$= | + | $\frac{n!}{k!(n-k)!}$ | =$\frac{n!}{k!(n-k)!}$= | + | $\binom{n}{k}$ | =$\binom{n}{k}$= | + | $\frac{\frac{x}{1}}{x - y}$ | =$\frac{\frac{x}{1}}{x - y}$= | + | $^3/_7$ | =$^3/_7$= | + | $\sqrt{k}$ | =$\sqrt{k}$= | + | $\sqrt[n]{k}$ | =$\sqrt[n]{k}$= | +** Sommes et intégrales + | Symbole | Commande | + |---------------------------------+--------------------------------------| + | $\sum_{i=1}^{10} t_i$ | =$\sum_{i=1}^{10} t_i$= | + | $\int_0^\infty \mathrm{e}^{-x}\,\mathrm{d}x$ | =$\int_0^\infty \mathrm{e}^{-x}\,\mathrm{d}x$= | +** Déguisements + | Symbole | Commande | + |-----------------------+-----------------------| + | $\hat{a}$ | =$\hat{a}$= | + | $\bar{a}$ | =$\bar{a}$= | + | $\dot{a}$ | =$\dot{a}$= | + | $\ddot{a}$ | =$\ddot{a}$= | + | $\overrightarrow{AB}$ | =$\overrightarrow{AB}$= | + -- 2.18.1
