diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org new file mode 100644 index 0000000000000000000000000000000000000000..596be1f73ece9afb114accfd3b56ef6a052f04ba --- /dev/null +++ b/module2/ressources/emacs_orgmode.org @@ -0,0 +1,236 @@ +# -*- mode: org -*- +#+TITLE: Emacs/org-mode +#+AUTHOR: Arnaud Legrand +#+DATE: June, 2018 +#+STARTUP: overview indent + +* Table of Contents :TOC: + - [[#installing-emacs-org-mode-ess-and-auctex][Installing emacs, org-mode, ess, and auctex.]] + - [[#os-specific-installation-procedure][OS-specific installation procedure]] + - [[#a-simple-reproducible-research-emacs-configuration-][A simple "/reproducible research/" emacs configuration ]] + - [[#emacs-tips-and-tricks][Emacs Tips and tricks]] + - [[#cheat-sheets][Cheat-sheets]] + - [[#video-tutorials][Video tutorials]] + - [[#additional-useful-emacs-packages][Additional useful emacs packages]] + - [[#other-resources][Other resources]] + - [[#a-replicable-article][A replicable article]] + - [[#a-stub-of-replicable-article][A stub of replicable article]] + +* Installing emacs, org-mode, ess, and auctex. +** OS-specific installation procedure +*** Linux (Debian, Ubuntu) +We provide here only instructions for debian-based distributions. Feel +free to contribute to this document to provide up-to-date information +for other distributions (e.g.n redhat, fedora). + +Today, the stable versions of the most common distributions provide +recent enough versions of emacs and org-mode: +- Debian (stretch) ships with [[https://packages.debian.org/stretch/emacs25][emacs 25.1]] and [[https://packages.debian.org/stretch/org-mode][org-mode 9.0.3]] +- Ubuntu (bionic 18.04) ships with [[https://packages.ubuntu.com/bionic/emacs25][emacs 25.2]] and [[https://packages.ubuntu.com/bionic/org-mode][org-mode 9.1.6]] +- Ubuntu (artful 17.04) ships with [[https://packages.ubuntu.com/artful/emacs25][emacs 25.2]] and [[https://packages.ubuntu.com/artful/org-mode][org-mode 9.0.9]] +If your distribution is older than this, well, it may be a good time +for upgrading... + +Simply run (as root): +#+begin_src sh :results output :exports both +apt-get update ; apt-get install emacs25 org-mode ess r-base auctex +#+end_src + +Then make sure you have a sufficiently recent version of emacs. +#+begin_src sh :results output :exports both +emacs --version 2>&1 | head -n 1 +#+end_src + +#+RESULTS: +: GNU Emacs 25.2.2 + +Likewise, you'll want to check you have a recent version of org-mode: +#+begin_src sh :results output :exports both +emacs -batch --funcall "org-version" 2>&1 | grep version +#+end_src + +#+RESULTS: +: Org mode version 9.1.11 (9.1.11-dist @ /usr/share/emacs/25.2/site-lisp/elpa/org-9.1.11/) + +The version numbers you get will depend on the distribution you are +running. _You really want to make sure you do not rely on org-mode 8_, +which is now deprecated. +*** Mac OS X +- *Option 1*: Install the =.dmg= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]: + https://vigou3.github.io/emacs-modified-macos/. It ships with recent + versions: + - Emacs 26.1 + - Org-mode 9.1.13 + - ESS 17.11 + In that case you may have several versions of emacs installed on + your machine and launching emacs from a terminal may not run the one + you just installed. If anyone know how to get rid of this... +- *Option 2*: If you already use =brew=, simply do the following + #+begin_src sh :results output :exports both + brew update + brew install emacs [--with-cocoa] + brew linkapps emacs + brew tap homebrew/science + brew install ess + brew install auctex # The name may be slightly more complicated here + brew install wget + #+end_src +*** Windows +Install the =.exe= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]: +https://vigou3.github.io/emacs-modified-windows/. It ships with recent +versions: +- Emacs 26.1 +- Org-mode 9.1.13 +- ESS 17.11 +** A simple "/reproducible research/" emacs configuration +Emacs comes with very basic default configuration and it appears like +everyone has its own taste. You will for example find [[https://www.emacswiki.org/emacs/StarterKits][here]] several +default Emacs configurations that reflect the preferences of their +creators. Likewise the configuration of Org-Mode is incredibly +flexible (see for example [[https://orgmode.org/worg/org-configs/index.html][the org-mode website]] for more +references). In the context of this MOOC, we propose you a relatively +minimalistic one that is rather "/reproducible research/" oriented by +adding a few org-mode specific configurations. + +*** Step 0: Backup and download our configuration +The procedure we propose will wipe your already existing custom emacs +configuration if you already have one. *You should thus beforehand make +a backup of =~/.emacs= and of =~/.emacs.d/init.el=* (if these file +exists). + +#+begin_src shell :results output :exports none +export FILE_LIST="rr_org/init.el rr_org/journal.org" +tar zcf rr_org_archive.tgz $FILE_LIST +#+end_src + +#+RESULTS: +Then download [[file:rr_org_archive.tgz][this archive]] and uncompress it. It contains the +following files and we will refer to them in the following: + +#+begin_src shell :results output :exports results +tar tzf rr_org_archive.tgz +#+end_src + +#+RESULTS: +: rr_org/init.el +: rr_org/journal.org + +*** Step 1: Prepare your journal +Create an =org/= directory in the top of your home: +#+begin_src sh :results output :exports both +mkdir -p ~/org/ +#+end_src +Then copy =rr_org/journal.org= file in your =~/org/= directory. This +file will be your laboratory notebook and all the notes you will +capture with =C-c c= will go automatically go in this file. The first +entry of this notebook is populated with [[file:rr_org/journal.org::*Org-mode][many emacs shortcuts]] that you +should give a try. +*** Step 2: Set up Emacs configuration +Copy =rr_org/init.el= in your =~/.emacs.d/= directory. + +Alternatively, if you do not want to mess with your already existing +emacs configuration, you may launch emacs with this specific +configuration with the following command: =emacs -q -l rr_org/init.el=. +*** Step 3: Check whether the installation is working or not +Open a new instance of Emacs and open a =foo.org= file. Copy the +following lines in this file: + : #+begin_src shell :session foo :results output :exports both + : ls -la + : #+end_src + +Put your cursor inside this code block and execute it with the +following command: =C-c C-c= (If you are not familiar with Emacs +commands, this one means '=Ctrl + C=' twice) + +A =#+RESULTS:= block with the result of the command should appear if it +worked. + +In the video, we already have demonstrated the main features and +shortcuts of emacs/org-mode that will help you maintain a document and +benefit from literate programming. The list of features and shortcuts +is demonstrated in the [[file:rr_org/journal.org::*Emacs%20shortcuts][first entry of your labbook]]. +*** Step 4: Open and play with your journal: +In step 1, you were told to create an journal in +=~org/journal.org=. First you probably want to make sure this file is +backed up in a revision control system like git. We leave it up to set +this up but if you have any trouble, feel free to ask on the FUN +forums. +* Emacs Tips and tricks +** Cheat-sheets +Learning emacs and org-mode can be difficult as there is an inordinate +amount of shortcuts. Many people have thus come up with +cheat-sheats. Here is a selection in case it helps: +*** Emacs +- [[file:org/journal.org::*Emacs%20shortcuts][Common and step-by-step emacs shortcuts for our /reproducible research/ configuration]] +- [[https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf][The official GNU emacs refcard]] +- Two graphical cheat-sheats by Sacha Hua on [[http://sachachua.com/blog/wp-content/uploads/2013/05/How-to-Learn-Emacs-v2-Large.png][how to learn emacs]] and on + [[http://sachachua.com/blog/wp-content/uploads/2013/08/20130830-Emacs-Newbie-How-to-Learn-Emacs-Keyboard-Shortcuts.png][how to learn emacs shortcuts]]. +*** Org-mode +- [[file:org/journal.org::*Org-mode][Common and step-by-step org-mode shortcuts for our /reproducible research/ configuration]] +- [[https://orgmode.org/worg/orgcard.html][The official org-mode refcard]] +- [[https://orgmode.org/worg/dev/org-syntax.html][The official description of the org-mode syntax]] and a [[https://gist.github.com/hoeltgman/3825415][relatively concise description of the org-mode syntax]]. +** Video tutorials +For those of you who prefer video explanations, here is a [[https://www.youtube.com/playlist?list=PL9KxKa8NpFxIcNQa9js7dQQIHc81b0-Xg][Youtube +channel with many step by step emacs tutorials]]. +** Additional useful emacs packages +*** Company-mode +[[http://company-mode.github.io/][Company-mode]] is a text completion framework for Emacs. It allows to +have smart completion in emacs for the most common languages. If you +feel this is needed, you should follow the instructions from the +official webpage: http://company-mode.github.io/ +*** Magit +[[https://magit.vc/][Magit]] is an emacs interface for Git. It is very powerfull and we use +it on a daily basis but you should definitely understand what git does +behind the scene beforehand. If you feel this would be useful for you, +you should follow the instructions from here: +https://www.emacswiki.org/emacs/Magit +** Other resources +- [[https://orgmode.org/orgguide.pdf][The compact Org-mode Guide]] +- [[https://github.com/dfeich/org-babel-examples][Many examples illustrating the use of different languages in org-mode]] +* A replicable article +** A stub of replicable article +Remember, you need a working LaTeX and R environment. If you can't +open a terminal and run the commands =R= and =pdflatex=, you will not be +able to generate this document. The article downloads the +corresponding LaTeX packages so you also need to have a working =wget= +command (alternatively, you can use =curl=). You may still read the +source ([[file:replicable_article/article.org][article.org]]) and understand how it works though. + +#+begin_src shell :results output :exports none +make -C replicable_article/ replicable_article.tgz +#+end_src + +#+RESULTS: +: make : on entre dans le répertoire « /home/alegrand/Work/Documents/Enseignements/RR_MOOC/references/module2/replicable_article » +: tar --xform "s|^|replicable_article/|" -zcf replicable_article.tgz article.org biblio.bib Makefile +: make : on quitte le répertoire « /home/alegrand/Work/Documents/Enseignements/RR_MOOC/references/module2/replicable_article » + +Download the [[file:replicable_article/replicable_article.tgz][archive]], untar it and simply make to generate the +article. You should then be able to open the [[file:replicable_article/article.pdf][resulting article]]. This +is summarized in the following command: +#+begin_src sh :results output :exports both +wget --no-check-certificate -O replicable.tgz https://github.com/alegrand/RR_webinars/raw/master/1_replicable_article_laboratory_notebook/replicable/replicable.tgz ### Fix the broken URL +tar zxf replicable.tgz; cd replicable; make ; evince article.pdf +#+end_src + +If the =make= command fails (especially on Mac), it may be because emacs +or something else is not correctly installed. In that case, open the +article directly with the following command: +#+begin_src sh :results output :exports both +emacs -q --eval "(setq enable-local-eval t)" --eval "(setq enable-local-variables t)" article.org +#+end_src +and export it to pdf with the following shortcut: =C-c C-e l o= + +If it still doesn't work and emacs complains about not finding ESS, it +may be because you installed ESS in your home instead of +system-wide. In that case, try to remove the =-q= in the previous +command line to load your personal emacs configuration. + +Finally, when you'll be tired of always reexecuting all the source +code when exporting, just look for the following line in [[file:replicable_article/article.org][article.org]]: +#+BEGIN_EXAMPLE +# #+PROPERTY: header-args :eval never-export +#+END_EXAMPLE +If you remove the =# = in the beginning of the line, it will not be a +comment anymore and will indicate org-mode to stop evaluating every +chunk of code when exporting. diff --git a/module2/ressources/jupyter.org b/module2/ressources/jupyter.org new file mode 100644 index 0000000000000000000000000000000000000000..ccad9b6a4631177c77ae341f8706ff7202ac7b4b --- /dev/null +++ b/module2/ressources/jupyter.org @@ -0,0 +1,138 @@ +# -*- mode: org -*- +#+TITLE: Rstudio +#+AUTHOR: Arnaud Legrand +#+DATE: June, 2018 +#+STARTUP: overview indent + +* Table of Contents :TOC: + - [[#interacting-with-gitlab][Interacting with gitlab]] + - [[#additional-jupyter-resources-or-tricks][Additional Jupyter resources or tricks]] + - [[#tips-and-tricks][Tips and tricks]] + - [[#running-r-and-python-in-the-same-notebook][Running R and Python in the same notebook]] + - [[#exporting-a-notebook][Exporting a notebook]] + - [[#installing-jupyter-or-jupyter-hub-on-your-own-machine][Installing jupyter or jupyter hub on your own machine]] + - [[#installing-jupyter][Installing jupyter]] + - [[#using-r][Using R]] + - [[#exporting-your-notebooks-with-latex][Exporting your notebooks with latex]] + - [[#interacting-with-gitlab][Interacting with gitlab]] + - [[#interesting-extensions][Interesting extensions]] + - [[#installing-jupyterhub][Installing jupyterhub]] + +* Interacting with gitlab +#+BEGIN_QUOTE +This section needs some love. +#+END_QUOTE + +As you may have seen from the videos, we provide two buttons to sync +with gitlab. Indeed, even if you recover your files when you log back +into fun, the jupyter runs on a different machine than the gitlab +server and you need to commit your notebook every time you have made a +significant step. This is also the only way to really make it public +and to share your notebook with others. +* Additional Jupyter resources or tricks +** Tips and tricks +The following [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][webpage]] lists several Jupyter tricks (in particular, it +illustrates many =Ipython magic= commands) that should improve your +efficiency (note that this blog post is about two years old so some of +the tricks may have been integrated in the default behavior of jupyter +now). +** Running R and Python in the same notebook +The best solution to this is to install rpy2. On my machine, I have +installed the =python3-rpy2= debian package with =apt-get install=. An +other alternative consists in going through the python package manager +with +#+begin_src python :results output :exports both +pip install rpy2 +#+end_src +Then you'll be able to use both languages in the same notebook by: +1. Loading =rpy2=: + #+begin_src python :results output :exports both + %load_ext rpy2.ipython + #+end_src +2. Using the =%R= Ipython magic: + #+begin_src python :results output :exports both + %R + summary(cars) + #+end_src + Python objects can then even be passed to R as follows (assuming df + is a pandas dataframe: + #+begin_src python :results output :exports both + %%R -i df + plot((df) + #+end_src +** Exporting a notebook +Obviously, you can convert to html or pdf using the using the =File > +Download as > HTML= (or =PDF=) menu option. This can also be done from +the command line with the following command: + +#+begin_src sh :results output :exports both +ipython3 nbconvert --to pdf Untitled.ipynb +#+end_src + +If you want to use a specific style, then the nbconvert exporter +should be customised. This is discussed and demoed [[http://markus-beuckelmann.de/blog/customizing-nbconvert-pdf.html][here]]. We encourage +you to simply read the [[https://nbconvert.readthedocs.io/en/latest/][doc of nbconvert]]. + +Instead of going directly through LaTeX and playing too much with the +nbconvert exporter, an other option consists in exporting to Markdown +and playing with [[https://pandoc.org/][pandoc]]. Both approaches work, it's rather a matter of +taste. +* Installing jupyter or jupyter hub on your own machine +** Installing jupyter +Here is what you should install: +#+begin_src shell :results output :exports both +sudo apt-get install jupyter-notebook python3-pip python3-matplotlib python3-numpy +#+end_src + +On my machine, I got the version 5.4.1: +#+begin_src shell :results output :exports both +jupyter-notebook --version +#+end_src + +#+RESULTS: +: 5.4.1 + +The ipython notebook can then be run with the following command: +#+begin_src shell :results output :exports both +jupyter-notebook +#+end_src +** Using R +If you also want to have the R kernel in jupyter, follow [[https://github.com/IRkernel/IRkernel#installation][these +instructions]]. + +Alternatively, you can install =rpy2= (see the [[*Running R and Python in the same notebook][Running R and Python in +the same notebook]] section). +#+begin_src shell :results output :exports both +sudo apt-get python3-rpy2 +#+end_src +** Exporting your notebooks with latex +Here is what I had to install to make sure the notebook export via +latex works: +#+begin_src shell :results output :exports both +sudo apt-get install wkhtmltopdf +sudo apt-get install texlive-xetex +#+end_src +** Interacting with gitlab +Here is our [[https://github.com/brospars/nb-git][jupyter extension that allows to git push/pull from the +notebooks]]: +#+begin_src shell :results output :exports both +jupyter nbextension install https://raw.githubusercontent.com/brospars/nb-git/master/nb-git.js +jupyter nbextension enable nb-git +#+end_src +** Interesting extensions +- [[https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook][Code folding]] + #+begin_src shell :results output :exports both + pip3 install jupyter_contrib_nbextensions + # jupyter contrib nbextension install --user # not done yet + #+end_src +- [[https://github.com/kirbs-/hide_code][Hiding code]] + #+begin_src sh :results output :exports both + sudo pip3 install hide_code + sudo jupyter-nbextension install --py hide_code + jupyter-nbextension enable --py hide_code + jupyter-serverextension enable --py hide_code + #+end_src +** Installing jupyterhub +#+BEGIN_QUOTE +Benoit may give a few hints on this. +#+END_QUOTE diff --git a/module2/ressources/replicable_article/Makefile b/module2/ressources/replicable_article/Makefile new file mode 100644 index 0000000000000000000000000000000000000000..c75898131d90dae94ffcd7056eafdddf12d0de71 --- /dev/null +++ b/module2/ressources/replicable_article/Makefile @@ -0,0 +1,25 @@ +ARCHIVE=replicable_article +# ARCHIVE_FILES=$(shell git ls-tree -r master --name-only | grep -v -e 'article.pdf') +ARCHIVE_FILES=article.org biblio.bib Makefile +all: article.pdf + +%.tex: %.org + emacs -q -batch --eval "(setq enable-local-eval t)" --eval "(setq enable-local-variables t)" $^ --funcall org-latex-export-to-latex + +%.pdf: %.tex + pdflatex $^ + bibtex `basename $^ .tex` + pdflatex $^ + pdflatex $^ + +%.html: %.org + emacs -q -batch --eval "(setq enable-local-eval t)" --eval "(setq enable-local-variables t)" $^ --funcall org-html-export-to-html + +$(ARCHIVE).tgz: $(ARCHIVE_FILES) + tar --xform "s|^|$(ARCHIVE)/|" -zcf $@ $^ + +clean: + rm -f article.aux article.bbl article.blg article.log article.out *~ + +distclean: clean + rm -f article.html article.tex article.pdf figure.pdf data.csv measurements.txt IEEEtran.bst IEEEtran.cls \#article.org\# diff --git a/module2/ressources/replicable_article/article.org b/module2/ressources/replicable_article/article.org new file mode 100644 index 0000000000000000000000000000000000000000..64a9d3b2712bb332b3a562acbebab5b0dc96def9 --- /dev/null +++ b/module2/ressources/replicable_article/article.org @@ -0,0 +1,263 @@ +# -*- coding: utf-8 -*- +# -*- mode: org -*- + +#+TITLE: Org Mode Template for an IEEE Conference Article +#+AUTHOR: John Doe, John Smith, and Jane Doe + +#+STARTUP: overview indent inlineimages logdrawer +#+LANGUAGE: en +#+OPTIONS: num:nil toc:t \n:nil @:t ::t |:t ^:nil -:t f:t *:t <:t +#+OPTIONS: TeX:t LaTeX:t skip:nil d:nil todo:t pri:nil tags:not-in-toc +#+OPTIONS: author:nil email:nil creator:nil timestamp:t +#+TAGS: noexport(n) deprecated(d) +#+EXPORT_SELECT_TAGS: export +#+EXPORT_EXCLUDE_TAGS: noexport + +# # Default org-mode HTML style +# #+HTML_HEAD: +# # Shiny readthedocs HTML style +#+HTML_HEAD: +#+HTML_HEAD: +#+HTML_HEAD: +#+HTML_HEAD: +#+HTML_HEAD: +#+HTML_HEAD: + + +# ### By default, all code chunks are being run when exporting. To +# ### avoid this, simply remove the "# " of the next line. +# #+PROPERTY: header-args :eval never-export + +#+LATEX_CLASS: IEEEtran +#+LATEX_HEADER: \usepackage[T1]{fontenc} +#+LATEX_HEADER: \usepackage[utf8]{inputenc} +#+LATEX_HEADER: \usepackage{graphicx} +#+LATEX_HEADER: \usepackage{xspace,ifthen} +#+LATEX_HEADER: \usepackage{amsmath,amssymb} +#+LATEX_HEADER: \usepackage[american]{babel} +#+LATEX_HEADER: \usepackage{url} \urlstyle{sf} + +#+BEGIN_EXPORT latex +\let\oldcite=\cite +\renewcommand\cite[2][]{~\ifthenelse{\equal{#1}{}}{\oldcite{#2}}{\oldcite[#1]{#2}}\xspace} +\let\oldref=\ref +\def\ref#1{~\oldref{#1}\xspace} +\sloppy +#+END_EXPORT + +#+BEGIN_EXPORT latex + \title{Org Mode Template for an IEEE Conference Article} + %\subtitle{} + + \author{% + \IEEEauthorblockN{% + John Doe\IEEEauthorrefmark{1}, + John Smith\IEEEauthorrefmark{2}, + Jane Doe\IEEEauthorrefmark{1}, + }\smallskip +% \\ + \IEEEauthorblockA{ + \IEEEauthorrefmark{1}University of Middle-of-Nowhere; \url{firstname.lastname@mon.edu}} + \IEEEauthorblockA{ + \IEEEauthorrefmark{2}Institute of Whatever; \url{firstname.lastname@smith.org}} + } + + \maketitle + +#+END_EXPORT + +#+BEGIN_abstract + Reproducible research has become increasingly important, just like + parallel architectures so we propose a novel experimental study of a + parallel implementation of the quicksort algorithm that builds on + reproducible research technology. +#+END_abstract +* Getting the LaTeX packages :noexport: +#+begin_src shell :results output :exports both +set -e +if which wget; then + wget --no-check-certificate -O IEEEtran.cls http://mirror.ibcp.fr/pub/CTAN/macros/latex/contrib/IEEEtran/IEEEtran.cls + wget --no-check-certificate -O IEEEtran.bst http://mirrors.ctan.org/macros/latex/contrib/IEEEtran/bibtex/IEEEtran.bst +else + if which curs; then + curl -o IEEEtran.cls http://mirror.ibcp.fr/pub/CTAN/macros/latex/contrib/IEEEtran/IEEEtran.cls + curl -o IEEEtran.bst http://mirrors.ctan.org/macros/latex/contrib/IEEEtran/bibtex/IEEEtran.bst + else + echo "Neither wget nor curl was found!!! Get a real OS!" 1>&2 + exit 1 + fi +fi +#+end_src + +* Getting the data :noexport: +#+begin_src shell :results output raw :exports both +wget --no-check-certificate -O measurements.txt https://raw.githubusercontent.com/alegrand/M2R-ParallelQuicksort/master/data/sama_2014-10-13/measurements_03%3A47.txt +echo 'file:measurements.txt' +#+end_src + +* Extracting traces from data files :noexport: + +#+begin_src perl :results output raw :exports both :var input="measurements.txt" output="data.csv" +use strict; +open INPUT, $input; +open OUTPUT, "> $output"; + +my($line); +my($size); +my($seq,$par,$libc); + +print OUTPUT "Size, Seq, Par, Libc\n" ; +while($line=) { + chomp $line; + if($line =~/^Size: ([\d\.]*)$/) { + $size = $1; + next; + } + if($line =~/^Sequential quicksort.*: ([\d\.]*) sec.$/) { + $seq=$1; next; + } + if($line =~/^Parallel quicksort.*: ([\d\.]*) sec.$/) { + $par=$1; next; + } + if($line =~/^Built-in quicksort.*: ([\d\.]*) sec.$/) { + $libc=$1; + print OUTPUT "$size, $seq, $par, $libc\n"; + next; + } +} +print "file:$output" +#+end_src + +* R functions :noexport: +Initialization and reading of the data. +#+begin_src R :results output :session *R* :exports both +df=read.csv("data.csv",strip.white=T,header=T) +#+end_src + +#+RESULTS: + +Let's compute some (crappy) statistics. +#+begin_src R :results output :session *R* :exports both +sdf = data.frame() +for(size in unique(df$Size)) { + seq = mean(df[df$Size == size,]$Seq) + par = mean(df[df$Size == size,]$Par) + libc = mean(df[df$Size == size,]$Libc) + sdf = rbind(sdf,data.frame(Size=size,Seq=seq,Par=par,Libc=libc)) +} +#+end_src + +#+RESULTS: + +* Introduction + With the advent of parallel architecture, it is tempting to propose + parallel implementations of classical operations. In this wonderful + article, we report the performance gain of the well known quicksort + algorithm, whose parallelization seems natural. +* Context + Quicksort (sometimes called partition-exchange sort) is an efficient + sorting algorithm, serving as a systematic method for placing the + elements of an array in order. Developed by Tony Hoare in 1959 with + his work published in 1961\cite{qsort}, it is still a commonly used + algorithm for sorting. Quicksort is a divide and conquer + algorithm. Quicksort first divides a large array into two smaller + sub-arrays: the low elements and the high elements. Quicksort can + then recursively sort the sub-arrays. We propose to sort the + sub-arrays in parallel on two threads and to bound the recursion + level. +* Related Work + Well, this is such a brilliant and novel idea that none has worked + on this cutting-edge topic. Parallel architecture barely existed in + 1959, when Hoare proposed the sequential version of this + algorithm\cite{qsort}. Some colleagues mentioned some obscure + parallelization of the partitioning phase but it is too complex to + implement and certainly too costly to provide any performance gain. +* Methodology + We used a Dell Latitude 6430u with 16Gb of RAM running a Debian with + Linux 3.14.15. The CPU is an Intel(R) Core(TM) i7-3687U CPU @ + 2.10GHz comprising two physical cores and hyperthreading. The + =performance= frequency governor was used. We used FCC 5.3.1 with the + following compilation flags: =-g -Wall -O2 -pthread -lrt=. Since we + care a lot about reproducibility of our research, all the sources + and detailed information regarding our experiments are provided on + [[https://github.com/alegrand/M2R-ParallelQuicksort/blob/master/journal.org][Github]] + #+LaTeX:\footnote{Or figshare, or zenodo, or whatever platform you prefer!}. + + We used the wonderful Org-mode + format\cite{schulte11:_activ_docum_org_mode} to both document our + experiments and create a replicable article that can be obtained on + [[https://github.com/alegrand/RR_webinars/blob/master/1_replicable_article_laboratory_notebook/replicable/article.org][Github]] as well. We could have used the Ipython + approach\cite{PER-GRA:2007} but we dishonestly ruled it out because + we wanted to be in full control of our C experimental setup and did + not know how to properly use it to write a replicable article. + + Finally, it is important to explain that each measurement was + repeated five times and the set of experiments was absolutely not + randomized, which may compromise the validity of our observations + and conclusions. +* Experimental results + #+begin_src R :results graphics :file "figure.pdf" :exports none :width 6 :height 4 :session *R* + # This code will not appear. It is just here to generate a nice figure to include later on. + linetype <- c(1:3) + plotchar <- c(1:3) + + plot(sdf$Size,sdf$Seq,log="x", type="b", lty=linetype[1], pch=plotchar[1]) + legend( x="topleft", + legend=c("Sequential execution","Parallel execution", "Default Libc execution"), + lwd=1, lty=linetype, pch=plotchar) + lines(sdf$Size,sdf$Par, type="b", lty=linetype[2], pch=plotchar[2]) + lines(sdf$Size,sdf$Libc, type="b", lty=linetype[3], pch=plotchar[3]) + #+end_src + + #+RESULTS: + [[file:figure.pdf]] + + As we can see in Figure\ref{fig.comparison}, to benefit from the parallel + version of our quicksort implementation, significantly large arrays + (over a million entry) are required. Of course, it is difficult to + conclude from so few measurements and a better experiment design + would be useful. + #+LaTeX: \vspace{-1cm} + + #+CAPTION: Comparing performances of several implementation of the quicksort algorithm\label{fig.comparison} + #+ATTR_LaTeX: :width .8\linewidth + file:figure.pdf + #+LaTeX: \vspace{-.3cm} + +* Conclusion +Exploiting parallel machine can be quite difficult and tedious. From +our experience, such architecture are useful only when processing +sufficiently large data sets. As a future work, we intend to +consolidate our study with more experiments. + +#+Latex:\section*{Acknowledgments} +This work is partially supported by the FOO and BAR +projects. Experiments presented in this paper were carried out using +our own experimental testbed with support of our university. + +#+LaTeX: \nocite{*} +#+LaTeX: \def\raggedright{} +#+LaTeX: \bibliographystyle{IEEEtran} +#+LaTeX: \bibliography{biblio} +* Emacs Setup :noexport: + This document has local variables in its postembule, which should + allow Org-mode to work seamlessly without any setup. If you're + uncomfortable using such variables, you can safely ignore them at + startup. Exporting may require that you copy them in your .emacs. + +# Local Variables: +# eval: (add-to-list 'load-path ".") +# eval: (require 'org-install) +# eval: (org-babel-do-load-languages 'org-babel-load-languages '((shell . t) (R . t) (perl . t) (python . t) )) +# eval: (setq org-confirm-babel-evaluate nil) +# eval: (unless (boundp 'org-latex-classes) (setq org-latex-classes nil)) +# eval: (add-to-list 'org-latex-classes '("IEEEtran" +# "\\documentclass[conference, 10pt, compsocconf]{IEEEtran}\n \[NO-DEFAULT-PACKAGES]\n \[EXTRA]\n \\usepackage{graphicx}\n \\usepackage{hyperref}" ("\\section{%s}" . "\\section*{%s}") ("\\subsection{%s}" . "\\subsection*{%s}") ("\\subsubsection{%s}" . "\\subsubsection*{%s}") ("\\paragraph{%s}" . "\\paragraph*{%s}") ("\\subparagraph{%s}" . "\\subparagraph*{%s}"))) +# eval: (setq org-alphabetical-lists t) +# eval: (setq org-src-fontify-natively t) +# eval: (setq ess-ask-for-ess-directory nil) +# eval: (setq ispell-local-dictionary "american") +# eval: (eval (flyspell-mode t)) +# End: + + diff --git a/module2/ressources/replicable_article/article.pdf b/module2/ressources/replicable_article/article.pdf new file mode 100644 index 0000000000000000000000000000000000000000..7e7a0fec06bd135c8710fa6a505b77548e8e3931 Binary files /dev/null and b/module2/ressources/replicable_article/article.pdf differ diff --git a/module2/ressources/replicable_article/biblio.bib b/module2/ressources/replicable_article/biblio.bib new file mode 100644 index 0000000000000000000000000000000000000000..9cdf02114c91c2039e6f5fc9d298172515696783 --- /dev/null +++ b/module2/ressources/replicable_article/biblio.bib @@ -0,0 +1,46 @@ +@article{schulte11:_activ_docum_org_mode, +author ={Eric Schulte and Dan Davison}, +title ={Active Document with Org-Mode}, +journal ={Computing in Science \& Engineering}, +year =2011, +volume =13, +number =3, +pages ={66--73}, +month ={May/June} +} + +@Article{PER-GRA:2007, + Author = {P\'erez, Fernando and Granger, Brian E.}, + Title = {{IP}ython: a System for Interactive Scientific Computing}, + Journal = {Computing in Science and Engineering}, + Volume = {9}, + Number = {3}, + Pages = {21--29}, + month = may, + year = 2007, + url = "http://ipython.org", + ISSN = "1521-9615", + doi = {10.1109/MCSE.2007.53}, + publisher = {IEEE Computer Society}, +} + + + +@article{qsort, + author = {Hoare, C. A. R.}, + title = {Algorithm 64: Quicksort}, + journal = {Commun. ACM}, + issue_date = {July 1961}, + volume = {4}, + number = {7}, + month = jul, + year = {1961}, + issn = {0001-0782}, + pages = {321--}, + url = {http://doi.acm.org/10.1145/366622.366644}, + doi = {10.1145/366622.366644}, + acmid = {366644}, + publisher = {ACM}, + address = {New York, NY, USA}, +} + diff --git a/module2/ressources/replicable_article/measurements.txt b/module2/ressources/replicable_article/measurements.txt new file mode 100644 index 0000000000000000000000000000000000000000..b0f16ba727e6d8f4f47b47bed3e992b01d84b652 --- /dev/null +++ b/module2/ressources/replicable_article/measurements.txt @@ -0,0 +1,100 @@ +Size: 100 +Sequential quicksort took: 0.000010 sec. +Parallel quicksort took: 0.004024 sec. +Built-in quicksort took: 0.000013 sec. +Size: 100 +Sequential quicksort took: 0.000010 sec. +Parallel quicksort took: 0.004448 sec. +Built-in quicksort took: 0.000014 sec. +Size: 100 +Sequential quicksort took: 0.000009 sec. +Parallel quicksort took: 0.003384 sec. +Built-in quicksort took: 0.000013 sec. +Size: 100 +Sequential quicksort took: 0.000010 sec. +Parallel quicksort took: 0.003738 sec. +Built-in quicksort took: 0.000012 sec. +Size: 100 +Sequential quicksort took: 0.000010 sec. +Parallel quicksort took: 0.003133 sec. +Built-in quicksort took: 0.000011 sec. +Size: 1000 +Sequential quicksort took: 0.000128 sec. +Parallel quicksort took: 0.020407 sec. +Built-in quicksort took: 0.000209 sec. +Size: 1000 +Sequential quicksort took: 0.000126 sec. +Parallel quicksort took: 0.022003 sec. +Built-in quicksort took: 0.000201 sec. +Size: 1000 +Sequential quicksort took: 0.000128 sec. +Parallel quicksort took: 0.016149 sec. +Built-in quicksort took: 0.000210 sec. +Size: 1000 +Sequential quicksort took: 0.000128 sec. +Parallel quicksort took: 0.014594 sec. +Built-in quicksort took: 0.000209 sec. +Size: 1000 +Sequential quicksort took: 0.000129 sec. +Parallel quicksort took: 0.014905 sec. +Built-in quicksort took: 0.000210 sec. +Size: 10000 +Sequential quicksort took: 0.001774 sec. +Parallel quicksort took: 0.018943 sec. +Built-in quicksort took: 0.001720 sec. +Size: 10000 +Sequential quicksort took: 0.001698 sec. +Parallel quicksort took: 0.016226 sec. +Built-in quicksort took: 0.001733 sec. +Size: 10000 +Sequential quicksort took: 0.001652 sec. +Parallel quicksort took: 0.017348 sec. +Built-in quicksort took: 0.001702 sec. +Size: 10000 +Sequential quicksort took: 0.001680 sec. +Parallel quicksort took: 0.017302 sec. +Built-in quicksort took: 0.001726 sec. +Size: 10000 +Sequential quicksort took: 0.001675 sec. +Parallel quicksort took: 0.017386 sec. +Built-in quicksort took: 0.001716 sec. +Size: 100000 +Sequential quicksort took: 0.020040 sec. +Parallel quicksort took: 0.050548 sec. +Built-in quicksort took: 0.020300 sec. +Size: 100000 +Sequential quicksort took: 0.020004 sec. +Parallel quicksort took: 0.043119 sec. +Built-in quicksort took: 0.020504 sec. +Size: 100000 +Sequential quicksort took: 0.019763 sec. +Parallel quicksort took: 0.050735 sec. +Built-in quicksort took: 0.020439 sec. +Size: 100000 +Sequential quicksort took: 0.019913 sec. +Parallel quicksort took: 0.049806 sec. +Built-in quicksort took: 0.020541 sec. +Size: 100000 +Sequential quicksort took: 0.019726 sec. +Parallel quicksort took: 0.044636 sec. +Built-in quicksort took: 0.020252 sec. +Size: 1000000 +Sequential quicksort took: 0.230648 sec. +Parallel quicksort took: 0.162221 sec. +Built-in quicksort took: 0.242869 sec. +Size: 1000000 +Sequential quicksort took: 0.235778 sec. +Parallel quicksort took: 0.162137 sec. +Built-in quicksort took: 0.241607 sec. +Size: 1000000 +Sequential quicksort took: 0.238383 sec. +Parallel quicksort took: 0.163279 sec. +Built-in quicksort took: 0.242786 sec. +Size: 1000000 +Sequential quicksort took: 0.232921 sec. +Parallel quicksort took: 0.170237 sec. +Built-in quicksort took: 0.241583 sec. +Size: 1000000 +Sequential quicksort took: 0.230096 sec. +Parallel quicksort took: 0.153896 sec. +Built-in quicksort took: 0.242492 sec. diff --git a/module2/ressources/rr_org/init.el b/module2/ressources/rr_org/init.el new file mode 100644 index 0000000000000000000000000000000000000000..619e502523fc45b17d439ce76ced2932414a6323 --- /dev/null +++ b/module2/ressources/rr_org/init.el @@ -0,0 +1,212 @@ +(require 'org-install) +(require 'org) + +(setq inhibit-splash-screen t) + +(setq frame-title-format + '("Emacs - " (buffer-file-name "%f" + (dired-directory dired-directory "%b")))) + + (global-font-lock-mode t) + (custom-set-faces + '(flyspell-incorrect ((t (:inverse-video t))))) + +(line-number-mode 1) +(column-number-mode 1) + +(load-library "paren") +(show-paren-mode 1) +(transient-mark-mode t) +(require 'paren) + +(defalias 'yes-or-no-p 'y-or-n-p) + +(set-terminal-coding-system 'utf-8) +(set-keyboard-coding-system 'utf-8) +(prefer-coding-system 'utf-8) + + (setq + ns-command-modifier 'meta ; Apple/Command key is Meta + ns-alternate-modifier nil ; Option is the Mac Option key + ns-use-mac-modifier-symbols nil ; display standard Emacs (and not standard Mac) modifier symbols + ) + +(cua-mode t) + +(defun jump-mark () + (interactive) + (set-mark-command (point))) +(defun beginning-of-defun-and-mark () + (interactive) + (push-mark (point)) + (beginning-of-defun)) +(defun end-of-defun-and-mark () + (interactive) + (push-mark (point)) + (end-of-defun)) + +(global-set-key "\^c\^b" 'beginning-of-defun-and-mark) +(global-set-key "\^c\^e" 'end-of-defun-and-mark) +(global-set-key "\^c\^j" 'jump-mark) +(global-set-key [S-f6] 'jump-mark) ;; jump from mark to mark + +(global-set-key "\M-g" 'goto-line) + +(global-set-key (kbd "C-+") 'text-scale-increase) +(global-set-key (kbd "C--") 'text-scale-decrease) +;; C-x C-0 restores the default font size + +;; Inspired from http://tex.stackexchange.com/questions/166681/changing-language-of-flyspell-emacs-with-a-shortcut +;; (defun spell (choice) +;; "Switch between language dictionaries." +;; (interactive "cChoose: (a) American | (f) Francais") +;; (cond ((eq choice ?1) +;; (setq flyspell-default-dictionary "american") +;; (setq ispell-dictionary "american") +;; (ispell-kill-ispell)) +;; ((eq choice ?2) +;; (setq flyspell-default-dictionary "francais") +;; (setq ispell-dictionary "francais") +;; (ispell-kill-ispell)) +;; (t (message "No changes have been made."))) ) + +(define-key global-map (kbd "C-c s a") (lambda () (interactive) (ispell-change-dictionary "american"))) +(define-key global-map (kbd "C-c s f") (lambda () (interactive) (ispell-change-dictionary "francais"))) +(define-key global-map (kbd "C-c s r") 'flyspell-region) +(define-key global-map (kbd "C-c s b") 'flyspell-buffer) +(define-key global-map (kbd "C-c s s") 'flyspell-mode) + +(global-set-key [f5] '(lambda () (interactive) (revert-buffer nil t nil))) + +(defun auto-fill-mode-on () (TeX-PDF-mode 1)) +(add-hook 'tex-mode-hook 'TeX-PDF-mode-on) +(add-hook 'latex-mode-hook 'TeX-PDF-mode-on) +(setq TeX-PDF-mode t) + +(defun auto-fill-mode-on () (auto-fill-mode 1)) +(add-hook 'text-mode-hook 'auto-fill-mode-on) +(add-hook 'emacs-lisp-mode 'auto-fill-mode-on) +(add-hook 'tex-mode-hook 'auto-fill-mode-on) +(add-hook 'latex-mode-hook 'auto-fill-mode-on) + +(setq org-directory "~/org/") + +(setq org-hide-leading-stars t) +(setq org-alphabetical-lists t) +(setq org-src-fontify-natively t) ;; you want this to activate coloring in blocks +(setq org-src-tab-acts-natively t) ;; you want this to have completion in blocks +(setq org-hide-emphasis-markers t) ;; to hide the *,=, or / markers +(setq org-pretty-entities t) ;; to have \alpha, \to and others display as utf8 http://orgmode.org/manual/Special-symbols.html + +(global-set-key "\C-cl" 'org-store-link) +(global-set-key "\C-cc" 'org-capture) +(global-set-key (kbd "C-c a") 'org-agenda) +(define-key global-map "\C-cl" 'org-store-link) +(define-key global-map (kbd "C-c a") 'org-agenda) +(global-set-key "\C-cb" 'org-iswitchb) +(setq org-default-notes-file "~/org/notes.org") + (define-key global-map "\C-cd" 'org-capture) +(setq org-capture-templates (quote (("t" "Todo" entry (file+headline "~/org/liste.org" "Tasks") "* TODO %? + %i + %a" :prepend t) ("j" "Journal" entry (file+datetree "~/org/journal.org") "* %? +Entered on %U + %i + %a")))) + +(setq org-agenda-include-all-todo t) +(setq org-agenda-include-diary t) + +(global-set-key (kbd "C-c d") 'insert-date) +(defun insert-date (prefix) + "Insert the current date. With prefix-argument, use ISO format. With + two prefix arguments, write out the day and month name." + (interactive "P") + (let ((format (cond + ((not prefix) "** %Y-%m-%d") + ((equal prefix '(4)) "[%Y-%m-%d]")))) + (insert (format-time-string format)))) + +(global-set-key (kbd "C-c t") 'insert-time-date) +(defun insert-time-date (prefix) + "Insert the current date. With prefix-argument, use ISO format. With + two prefix arguments, write out the day and month name." + (interactive "P") + (let ((format (cond + ((not prefix) "[%H:%M:%S; %d.%m.%Y]") + ((equal prefix '(4)) "[%H:%M:%S; %Y-%m-%d]")))) + (insert (format-time-string format)))) + +(global-set-key (kbd "C-c l") 'org-store-link) + +(global-set-key (kbd "C-c ") 'outline-up-heading) +(global-set-key (kbd "C-c ") 'outline-previous-visible-heading) +(global-set-key (kbd "C-c ") 'outline-next-visible-heading) + +;; In org-mode 9 you need to have #+PROPERTY: header-args :eval never-export +;; in the beginning or your document to tell org-mode not to evaluate every +;; code block every time you export. +(setq org-confirm-babel-evaluate nil) ;; Do not ask for confirmation all the time!! + + (org-babel-do-load-languages + 'org-babel-load-languages + '( + (shell . t) + (python . t) + (R . t) + (ruby . t) + (ocaml . t) + (ditaa . t) + (dot . t) + (octave . t) + (sqlite . t) + (perl . t) + (screen . t) + (plantuml . t) + (lilypond . t) + (org . t) + (makefile . t) + )) + (setq org-src-preserve-indentation t) + +(add-to-list 'org-structure-template-alist + '("s" "#+begin_src ?\n\n#+end_src" "\n\n")) + +(add-to-list 'org-structure-template-alist + '("m" "#+begin_src emacs-lisp :tangle init.el\n\n#+end_src" "\n\n")) + +(add-to-list 'org-structure-template-alist + '("r" "#+begin_src R :results output :session *R* :exports both\n\n#+end_src" "\n\n")) + +(add-to-list 'org-structure-template-alist + '("R" "#+begin_src R :results output graphics :file (org-babel-temp-file \"figure\" \".png\") :exports both :width 600 :height 400 :session *R* \n\n#+end_src" "\n\n")) + +(add-to-list 'org-structure-template-alist + '("RR" "#+begin_src R :results output graphics :file (org-babel-temp-file (concat (file-name-directory (or load-file-name buffer-file-name)) \"figure-\") \".png\") :exports both :width 600 :height 400 :session *R* \n\n#+end_src" "\n\n")) + +(add-to-list 'org-structure-template-alist + '("p" "#+begin_src python :results output :exports both\n\n#+end_src" "\n\n")) + +(add-to-list 'org-structure-template-alist + '("P" "#+begin_src python :results output :session *python* :exports both\n\n#+end_src" "\n\n")) + +(add-to-list 'org-structure-template-alist + '("PP" "#+begin_src python :results file :var matplot_lib_filename=(org-babel-temp-file \"figure\" \".png\") :exports both \nimport matplotlib.pyplot as plt\n\nimport numpy\nx=numpy.linspace(-15,15)\nplt.figure(figsize=(10,5))\nplt.plot(x,numpy.cos(x)/x)\nplt.tight_layout()\n\nplt.savefig(matplot_lib_filename)\nreturn(matplot_lib_filename)\n#+end_src" "\n\n")) + +(add-to-list 'org-structure-template-alist + '("b" "#+begin_src shell :results output :exports both\n\n#+end_src" "\n\n")) + +(add-to-list 'org-structure-template-alist + '("B" "#+begin_src shell :session *shell* :results output :exports both \n\n#+end_src" "\n\n")) + +(add-to-list 'org-structure-template-alist + '("g" "#+begin_src dot :results output graphics :file \"/tmp/graph.pdf\" :exports both + digraph G { + node [color=black,fillcolor=white,shape=rectangle,style=filled,fontname=\"Helvetica\"]; + A[label=\"A\"] + B[label=\"B\"] + A->B + }\n#+end_src" "\n\n")) + +(add-hook 'org-babel-after-execute-hook 'org-display-inline-images) +(add-hook 'org-mode-hook 'org-display-inline-images) +(add-hook 'org-mode-hook 'org-babel-result-hide-all) diff --git a/module2/ressources/rr_org/init.org b/module2/ressources/rr_org/init.org new file mode 100644 index 0000000000000000000000000000000000000000..9e264375863c982dc058f01dcf7d9bc68c65c3ee --- /dev/null +++ b/module2/ressources/rr_org/init.org @@ -0,0 +1,360 @@ +# -*- mode: org -*- +#+TITLE: Emacs init file written in org-mode +#+AUTHOR: Arnaud Legrand +#+EMAIL: arnaud.legrand@imag.fr +#+STARTUP: indent +#+LANGUAGE: en + +This is a "minimal" =.emacs= configuration file. For this configuration +to work, you'll need: +- emacs25 (>25.2) (this way installing through elpa will save you some + time) and emacs-goodies (e.g., for color themes) +- org-mode > 9.0 (there has been several major compatibility breakage + so need to stay away from old versions) +- ess and R +- texlive and auctex + +* Installation Instructions +Backup you own =.emacs= if you have one and replace it with [[file:init.el][the content +of this file]]. If you ever want to regenerate if from this org +document, simply =M-x org-babel-tangle=. +* Loading files: +** Loading babel: :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(require 'org-install) +(require 'org) +#+end_src +* Emacs aesthetics: +** Remove splash screen: :WEB: +#+begin_src emacs-lisp :tangle init.el +(setq inhibit-splash-screen t) +#+end_src +** Change frame name of emacs: :LUKA:WEB: +#+begin_src emacs-lisp :tangle init.el +(setq frame-title-format + '("Emacs - " (buffer-file-name "%f" + (dired-directory dired-directory "%b")))) +#+end_src +** Text coloring :ARNAUD: +#+begin_src emacs-lisp :tangle init.el + (global-font-lock-mode t) + (custom-set-faces + '(flyspell-incorrect ((t (:inverse-video t))))) +#+end_src +** Line and column numbering :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(line-number-mode 1) +(column-number-mode 1) +#+end_src +** Parenthesis :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(load-library "paren") +(show-paren-mode 1) +(transient-mark-mode t) +(require 'paren) +#+end_src +** Asking for confirmation concisely: :WEB: +Link: http://org.ryuslash.org/dotfiles/emacs/init.html#sec-7-1 Being +asked to type in yes explicitly all the time gets very tedious. I +understand that it is safer since y is much easier to type in +accidentally than yes and so the potential to say yes to things you +don't want is there, but I haven't had any such problems yet. + +#+begin_src emacs-lisp :tangle init.el +(defalias 'yes-or-no-p 'y-or-n-p) +#+end_src +* Shortcuts: +** UTF 8 by default :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(set-terminal-coding-system 'utf-8) +(set-keyboard-coding-system 'utf-8) +(prefer-coding-system 'utf-8) +#+end_src +** Keyboard fix for Mac OS X users... :ADRIEN: +Thanks to Adrien Lebre for providing me with this +=ns-use-mac-modifier-symbols= thing. Unfortunately, this is broken at +the moment (I tried to wrap the command around the cond but it should +fail on mac). +#+begin_src emacs-lisp :tangle init.el + (setq + ns-command-modifier 'meta ; Apple/Command key is Meta + ns-alternate-modifier nil ; Option is the Mac Option key + ns-use-mac-modifier-symbols nil ; display standard Emacs (and not standard Mac) modifier symbols + ) +#+end_src +** CUA mode a.k.a =C-x, C-c, C-v= +Yuck! Many people like this but I hate it as it conflicts with some of +my other shortcuts (e.g., the ones for spelling a region). +#+begin_src emacs-lisp :tangle init.el +(cua-mode t) +#+end_src +** Navigate back in text :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(defun jump-mark () + (interactive) + (set-mark-command (point))) +(defun beginning-of-defun-and-mark () + (interactive) + (push-mark (point)) + (beginning-of-defun)) +(defun end-of-defun-and-mark () + (interactive) + (push-mark (point)) + (end-of-defun)) + +(global-set-key "\^c\^b" 'beginning-of-defun-and-mark) +(global-set-key "\^c\^e" 'end-of-defun-and-mark) +(global-set-key "\^c\^j" 'jump-mark) +(global-set-key [S-f6] 'jump-mark) ;; jump from mark to mark +#+end_src +** Goto line :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(global-set-key "\M-g" 'goto-line) +#+end_src +** Increase/decrease text size in emacs :WEB: +#+begin_src emacs-lisp :tangle init.el +(global-set-key (kbd "C-+") 'text-scale-increase) +(global-set-key (kbd "C--") 'text-scale-decrease) +;; C-x C-0 restores the default font size +#+end_src +[11:26:47; 18.04.2014] +** Add spell checker to the file :WEB: +#+begin_src emacs-lisp :tangle init.el +;; Inspired from http://tex.stackexchange.com/questions/166681/changing-language-of-flyspell-emacs-with-a-shortcut +;; (defun spell (choice) +;; "Switch between language dictionaries." +;; (interactive "cChoose: (a) American | (f) Francais") +;; (cond ((eq choice ?1) +;; (setq flyspell-default-dictionary "american") +;; (setq ispell-dictionary "american") +;; (ispell-kill-ispell)) +;; ((eq choice ?2) +;; (setq flyspell-default-dictionary "francais") +;; (setq ispell-dictionary "francais") +;; (ispell-kill-ispell)) +;; (t (message "No changes have been made."))) ) + +(define-key global-map (kbd "C-c s a") (lambda () (interactive) (ispell-change-dictionary "american"))) +(define-key global-map (kbd "C-c s f") (lambda () (interactive) (ispell-change-dictionary "francais"))) +(define-key global-map (kbd "C-c s r") 'flyspell-region) +(define-key global-map (kbd "C-c s b") 'flyspell-buffer) +(define-key global-map (kbd "C-c s s") 'flyspell-mode) +#+end_src +** Reload buffer :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(global-set-key [f5] '(lambda () (interactive) (revert-buffer nil t nil))) +#+end_src +* Small fixes for LaTeX: +** PDF with LaTeX by default :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(defun auto-fill-mode-on () (TeX-PDF-mode 1)) +(add-hook 'tex-mode-hook 'TeX-PDF-mode-on) +(add-hook 'latex-mode-hook 'TeX-PDF-mode-on) +(setq TeX-PDF-mode t) +#+end_src +** Auto-fill-mode +#+begin_src emacs-lisp :tangle init.el +(defun auto-fill-mode-on () (auto-fill-mode 1)) +(add-hook 'text-mode-hook 'auto-fill-mode-on) +(add-hook 'emacs-lisp-mode 'auto-fill-mode-on) +(add-hook 'tex-mode-hook 'auto-fill-mode-on) +(add-hook 'latex-mode-hook 'auto-fill-mode-on) +#+end_src +* Org-mode convenient configuration +** Default directory +#+begin_src emacs-lisp :tangle init.el +(setq org-directory "~/org/") +#+end_src +** Cosmetics +#+begin_src emacs-lisp :tangle init.el +(setq org-hide-leading-stars t) +(setq org-alphabetical-lists t) +(setq org-src-fontify-natively t) ;; you want this to activate coloring in blocks +(setq org-src-tab-acts-natively t) ;; you want this to have completion in blocks +(setq org-hide-emphasis-markers t) ;; to hide the *,=, or / markers +(setq org-pretty-entities t) ;; to have \alpha, \to and others display as utf8 http://orgmode.org/manual/Special-symbols.html +#+end_src +** Agenda +*** Add short cut keys for the org-agenda :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(global-set-key "\C-cl" 'org-store-link) +(global-set-key "\C-cc" 'org-capture) +(global-set-key (kbd "C-c a") 'org-agenda) +(define-key global-map "\C-cl" 'org-store-link) +(define-key global-map (kbd "C-c a") 'org-agenda) +(global-set-key "\C-cb" 'org-iswitchb) +(setq org-default-notes-file "~/org/notes.org") + (define-key global-map "\C-cd" 'org-capture) +(setq org-capture-templates (quote (("t" "Todo" entry (file+headline "~/org/liste.org" "Tasks") "* TODO %? + %i + %a" :prepend t) ("j" "Journal" entry (file+datetree "~/org/journal.org") "* %? +Entered on %U + %i + %a")))) +#+end_src + +#+RESULTS: +| t | Todo | entry | (file+headline ~/org/liste.org Tasks) | * TODO %?\n %i\n %a | :prepend | t | +| j | Journal | entry | (file+datetree ~/org/journal.org) | * %?\nEntered on %U\n %i\n %a | | | + +*** Agenda config :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(setq org-agenda-include-all-todo t) +(setq org-agenda-include-diary t) +#+end_src +* Org-mode shortcuts +** Adding date with brackets with command "C-c d": :LUKA: +#+begin_src emacs-lisp :tangle init.el +(global-set-key (kbd "C-c d") 'insert-date) +(defun insert-date (prefix) + "Insert the current date. With prefix-argument, use ISO format. With + two prefix arguments, write out the day and month name." + (interactive "P") + (let ((format (cond + ((not prefix) "** %Y-%m-%d") + ((equal prefix '(4)) "[%Y-%m-%d]")))) + (insert (format-time-string format)))) +#+end_src +[16:34:01; 24.04.2013] + +** Adding date with command "C-c t": :LUKA: +#+begin_src emacs-lisp :tangle init.el +(global-set-key (kbd "C-c t") 'insert-time-date) +(defun insert-time-date (prefix) + "Insert the current date. With prefix-argument, use ISO format. With + two prefix arguments, write out the day and month name." + (interactive "P") + (let ((format (cond + ((not prefix) "[%H:%M:%S; %d.%m.%Y]") + ((equal prefix '(4)) "[%H:%M:%S; %Y-%m-%d]")))) + (insert (format-time-string format)))) +#+end_src +[16:34:15; 24.04.2013] +** Org-store-link: :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(global-set-key (kbd "C-c l") 'org-store-link) +#+end_src +** Navigating through org-mode: +Additional shortcuts for navigating through org-mode documents: +#+begin_src emacs-lisp :tangle init.el +(global-set-key (kbd "C-c ") 'outline-up-heading) +(global-set-key (kbd "C-c ") 'outline-previous-visible-heading) +(global-set-key (kbd "C-c ") 'outline-next-visible-heading) +#+end_src +* Org-mode + babel: +** Seamless use of babel (no confirmation, lazy export) :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +;; In org-mode 9 you need to have #+PROPERTY: header-args :eval never-export +;; in the beginning or your document to tell org-mode not to evaluate every +;; code block every time you export. +(setq org-confirm-babel-evaluate nil) ;; Do not ask for confirmation all the time!! +#+end_src +** Some initial languages we want org-babel to support: :ARNAUD: +#+begin_src emacs-lisp :tangle init.el + (org-babel-do-load-languages + 'org-babel-load-languages + '( + (shell . t) + (python . t) + (R . t) + (ruby . t) + (ocaml . t) + (ditaa . t) + (dot . t) + (octave . t) + (sqlite . t) + (perl . t) + (screen . t) + (plantuml . t) + (lilypond . t) + (org . t) + (makefile . t) + )) + (setq org-src-preserve-indentation t) +#+end_src + +** Adding source code blocks: :LUKA: +*** With capital letters: +To use this type \n\n")) +#+end_src +*** Emacs-elisp code: +To use this type \n\n")) +#+end_src + +*** R code: +To use this type \n\n")) +#+end_src + +To use this type \n\n")) +#+end_src + +To use this type \n\n")) +#+end_src +*** Python code +To use this type
\n\n")) +#+end_src + +#+begin_src emacs-lisp :tangle init.el +(add-to-list 'org-structure-template-alist + '("P" "#+begin_src python :results output :session *python* :exports both\n\n#+end_src" "\n\n")) +#+end_src + +#+begin_src emacs-lisp :tangle init.el +(add-to-list 'org-structure-template-alist + '("PP" "#+begin_src python :results file :var matplot_lib_filename=(org-babel-temp-file \"figure\" \".png\") :exports both \nimport matplotlib.pyplot as plt\n\nimport numpy\nx=numpy.linspace(-15,15)\nplt.figure(figsize=(10,5))\nplt.plot(x,numpy.cos(x)/x)\nplt.tight_layout()\n\nplt.savefig(matplot_lib_filename)\nreturn(matplot_lib_filename)\n#+end_src" "\n\n")) +#+end_src +*** Bash "sh" code: +To use this type \n\n")) +#+end_src + +To use this type \n\n")) +#+end_src +*** Graphviz +#+begin_src emacs-lisp :tangle init.el +(add-to-list 'org-structure-template-alist + '("g" "#+begin_src dot :results output graphics :file \"/tmp/graph.pdf\" :exports both + digraph G { + node [color=black,fillcolor=white,shape=rectangle,style=filled,fontname=\"Helvetica\"]; + A[label=\"A\"] + B[label=\"B\"] + A->B + }\n#+end_src" "\n\n")) +#+end_src +** Evaluating whole subtree: :LUKA: +#+begin_src emacs-lisp +(global-set-key (kbd "C-c S-t") 'org-babel-execute-subtree) +#+end_src +** Display images :ARNAUD: +#+begin_src emacs-lisp :tangle init.el +(add-hook 'org-babel-after-execute-hook 'org-display-inline-images) +(add-hook 'org-mode-hook 'org-display-inline-images) +(add-hook 'org-mode-hook 'org-babel-result-hide-all) +#+end_src diff --git a/module2/ressources/rr_org/journal.org b/module2/ressources/rr_org/journal.org new file mode 100644 index 0000000000000000000000000000000000000000..64d48252f0cf02ccae4966db4ef7e9702345f4d2 --- /dev/null +++ b/module2/ressources/rr_org/journal.org @@ -0,0 +1,96 @@ +# -*- mode: org -*- +# -*- coding: utf-8 -*- +#+STARTUP: overview indent inlineimages logdrawer +#+TITLE: Journal +#+AUTHOR: Put your name here +#+LANGUAGE: en +#+TAGS: LIG(L) HOME(H) Europe(E) Blog(B) noexport(n) Stats(S) +#+TAGS: Epistemology(E) Vulgarization(V) Teaching(T) R(R) OrgMode(O) Python(P) +#+EXPORT_SELECT_TAGS: Blog +#+OPTIONS: H:3 num:t toc:t \n:nil @:t ::t |:t ^:t -:t f:t *:t <:t +#+OPTIONS: TeX:t LaTeX:nil skip:nil d:nil todo:t pri:nil tags:not-in-toc +#+EXPORT_SELECT_TAGS: export +#+EXPORT_EXCLUDE_TAGS: noexport +#+COLUMNS: %25ITEM %TODO %3PRIORITY %TAGS +#+SEQ_TODO: TODO(t!) STARTED(s!) WAITING(w@) APPT(a!) | DONE(d!) CANCELLED(c!) DEFERRED(f!) + +* 2018 +** 2018-02 March +*** 2018-02-12 Monday +**** Demonstrating Emacs/Orgmode shortcuts +These informations were gathered and first demonstrated in my [[https://github.com/alegrand/RR_webinars/blob/master/1_replicable_article_laboratory_notebook/index.org][First +webinar on reproducible research: litterate programming]]. +***** Emacs shortcuts +Here are a few convenient emacs shortcuts for those that have never +used emacs. In all of the emacs shortcuts, =C=Ctrl=, =M=Alt/Esc= and +=S=Shift=. Note that you may want to use two hours to follow the emacs +tutorial (=C-h t=). In the configuration file CUA keys have been +activated and allow you to use classical copy/paste (=C-c/C-v=) +shortcuts. This can be changed from the Options menu. + - =C-x C-c= exit + - =C-x C-s= save buffer + - =C-g= panic mode ;) type this whenever you want to exit an awful + series of shortcuts + - =C-Space= start selection marker although selection with shift and + arrows should work as well + - =C-l= reposition the screen + - =C-_= (or =C-z= if CUA keys have been activated) + - =C-s= search + - =M-%= replace + - =C-x C-h= get the list of emacs shortcuts + - =C-c C-h= get the list of emacs shortcuts considering the mode you are + currently using (e.g., C, Lisp, org, ...) + There are a bunch of cheatsheets also available out there (e.g., + [[http://www.shortcutworld.com/en/linux/Emacs_23.2.1.html][this one for emacs]] and [[http://orgmode.org/orgcard.txt][this one for org-mode]] or this [[http://sachachua.com/blog/wp-content/uploads/2013/05/How-to-Learn-Emacs-v2-Large.png][graphical one]]). +***** Org-mode + Many emacs shortcuts start by =C-x=. Org-mode's shortcuts generaly + start with =C-c=. + - =Tab= fold/unfold + - =C-c c= capture (finish capturing with =C-c C-c=, this is explained on + the top of the buffer that just opened) + - =C-c C-c= do something useful here (tag, execute, ...) + - =C-c C-o= open link + - =C-c C-t= switch todo + - =C-c C-e= export + - =M-Enter= new item/section + - =C-c a= agenda (try the =L= option) + - =C-c C-a= attach files + - =C-c C-d= set a deadl1ine (use =S-arrows= to navigate in the dates) + - =A-arrows= move subtree (add shift for the whole subtree) +***** Org-mode Babel (for literate programming) + - =
