diff --git a/module2/ressources/gitlab.org b/module2/ressources/gitlab.org index 9206597784c00ab13e8f61e4b4dacafa744c36e2..b473db6f31eb3f24e66920ef2ab7338e651fe231 100644 --- a/module2/ressources/gitlab.org +++ b/module2/ressources/gitlab.org @@ -187,9 +187,9 @@ This section describes a generic (through the command line) way to synchronize your local files with Gitlab. You will not need this if you follow the Jupyter path. If you follow the RStudio path, all these operations can be done through RStudio and you may want to read -[[file:rstudio.org][the corresponding instructions]]. If you follow the Org-Mode path, all +[[/jump_to_id/1a4f58a1efed437c93a9f5c5f15df428][the corresponding instructions]]. If you follow the Org-Mode path, all these operations can be done through Magit and you may want to read -[[file:emacs_orgmode.org][the corresponding instructions]]. +[[/jump_to_id/508299f7373449a3939faa5b11462bc4][the corresponding instructions]]. Here are other ways to learn Git through the command line: - The [[http://swcarpentry.github.io/git-novice/][Software Carpentry git tutorial]]
