diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index 7ecb19e2471372090c5e31998c1d4f5ef5382f54..857287ac9e31d2cf68b6176e60a4dc97e88cf212 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -52,7 +52,7 @@ for upgrading... Simply run (as root): #+begin_src sh :results output :exports both -apt-get update ; apt-get install emacs25 org-mode ess r-base auctex +apt-get update ; apt-get install emacs25 org-mode #+end_src Then make sure you have a sufficiently recent version of emacs. @@ -73,7 +73,9 @@ emacs -batch --funcall "org-version" 2>&1 | grep version The version numbers you get will depend on the distribution you are running. _You really want to make sure you do not rely on org-mode 8_, -which is now deprecated. +which is now deprecated. + +The packages [[https://ess.r-project.org/][ESS]] (for working with the R language) and [[https://www.gnu.org/software/auctex/][AUCTeX]] (for editing LaTeX) will be installed automatically the first time you start Emacs if you use the configuration described under [[#a-simple-reproducible-research-emacs-configuration][A simple "reproducible research" emacs configuration]]. ** macOS *Note:* macOS comes with a prehistoric command-line-only version of Emacs located at =/usr/bin/emacs=. It's best to forget about it.
