From 7adc434e3ec6eb0d774979921adefdeb1107452c Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Wed, 25 Jul 2018 19:22:48 +0200 Subject: [PATCH] Final (?) reorganization and link to FUN video tutorials --- module2/ressources/emacs_orgmode.html | 170 +++++++++++++------------- module2/ressources/emacs_orgmode.org | 10 +- 2 files changed, 90 insertions(+), 90 deletions(-) diff --git a/module2/ressources/emacs_orgmode.html b/module2/ressources/emacs_orgmode.html index 191370c..38185c3 100644 --- a/module2/ressources/emacs_orgmode.html +++ b/module2/ressources/emacs_orgmode.html @@ -4,39 +4,39 @@
Table of Contents
@@ -45,24 +45,24 @@
Disclaimer: The two sections A simple "reproducible research" emacs configuration and A stub of replicable article explain how to set up -org-mode for this MOOC. These sections are illustrated in two out of -the three video tutorials of this sequence, and which you really -should follow carefully. Otherwise, you may have trouble doing the -exercises later on. Likewise, I strongly encourage you to watch the -"emacs and git" video tutorial available at the same place. +emacs/org-mode for this MOOC. These sections are illustrated in two +out of the three video tutorials of this sequence, and which you +really should follow carefully. Otherwise, you may have trouble doing +the exercises later on. Likewise, I strongly encourage you to watch +the "emacs and git" video tutorial available at the same place.
The next section provides information on how to install emacs.
Installing emacs, org-mode, ess, and auctex.
Linux (Debian, Ubuntu)
We provide here only instructions for debian-based distributions. Feel free to contribute to this document to provide up-to-date information @@ -124,9 +124,9 @@ which is now deprecated.
Mac OS X
Mac OS X
  • Option 1: Install the .dmg file from Vincent Goulet: @@ -159,9 +159,9 @@ brew install wget
Windows
Windows
Install the .exe file from Vincent Goulet: https://vigou3.github.io/emacs-modified-windows/. It ships with recent @@ -175,9 +175,9 @@ versions:
This section is illustrated in a video tutorial (in French). Watching it before following the instructions given in this section may help. @@ -195,9 +195,9 @@ adding a few org-mode specific configurations.
Step 0: Backup and download our configuration
The procedure we propose will wipe your already existing custom emacs configuration if you already have one. You should thus beforehand make @@ -218,9 +218,9 @@ rr_org/journal.org
Step 1: Prepare your journal
Create an org/ directory in the top of your home:
@@ -237,9 +237,9 @@ should give a try.
Step 2: Set up Emacs configuration
Copy rr_org/init.el in your ~/.emacs.d/ directory.
@@ -251,9 +251,9 @@ configuration with the following command: emacs -q -l rr_org/init.el
Step 3: Check whether the installation is working or not
Open a new instance of Emacs and open a foo.org file. Copy the following lines in this file: @@ -284,9 +284,9 @@ is demonstrated in the -
Step 4: Open and play with your journal:
In step 1, you were told to create an journal in ~org/journal.org. First you probably want to make sure this file is @@ -297,9 +297,9 @@ forums.
This section is illustrated in a video tutorial (in French). Watching it before following the instructions given in this section may help. @@ -362,22 +362,22 @@ chunk of code when exporting.
Emacs Tips and tricks
Cheat-sheets
Cheat-sheets
Learning emacs and org-mode can be difficult as there is an inordinate amount of shortcuts. Many people have thus come up with cheat-sheats. Here is a selection in case it helps:
Emacs
Emacs
Org-mode
Org-mode
Video tutorials
Video tutorials
For those of you who prefer video explanations, here is a Youtube channel with many step by step emacs tutorials.
Additional useful emacs packages
Company-mode
Company-mode
Company-mode is a text completion framework for Emacs. It allows to have smart completion in emacs for the most common languages. If you @@ -421,9 +421,9 @@ official Web page: http://company-mode.
Magit
Magit
Magit is an emacs interface for Git. Its usage is briefly illustrated in the context of this MOOC in a video tutorial (in French). @@ -440,9 +440,9 @@ invoke magit by using C-x g.
Other resources
Other resources
  • The compact Org-mode Guide
  • Many examples illustrating the use of different languages in org-mode
  • diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index db2beb3..9cb55ad 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -8,11 +8,11 @@ *Disclaimer:* The two sections _A simple "/reproducible research/" emacs configuration_ and _A stub of replicable article_ explain how to set up -org-mode for this MOOC. *These sections are illustrated in two out of -the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3][three video tutorials of this sequence]], and* *which you really -should follow carefully*. *Otherwise, you may have trouble doing the -exercises later on*. Likewise, I strongly encourage you to watch the -[[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3]["emacs and git" video tutorial available at the same place]]. +emacs/org-mode for this MOOC. *These sections are illustrated in two +out of the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3][three video tutorials of this sequence]], and* *which you +really should follow carefully*. *Otherwise, you may have trouble doing +the exercises later on*. Likewise, I strongly encourage you to watch +the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3]["emacs and git" video tutorial available at the same place]]. The next section provides information on how to install emacs. -- 2.18.1
