diff --git a/module2/ressources/gitlab.org b/module2/ressources/gitlab.org index b473db6f31eb3f24e66920ef2ab7338e651fe231..87bab681bc645df4d1c36c1fa074d80816ff61ee 100644 --- a/module2/ressources/gitlab.org +++ b/module2/ressources/gitlab.org @@ -200,7 +200,9 @@ Here are other ways to learn Git through the command line: Now, let's start! 1. Obtain the repository URL + #+BEGIN_CENTER [[file:rstudio_images/adresse_depot.png]] + #+END_CENTER 2. Cloning the repository #+begin_src shell :results output :exports both cd /the/directory/where/you/want/to/clone/your/repository @@ -226,47 +228,57 @@ Now, let's start! GitLab. The =git status= will indicate you whether files are tracked/modified/committed/... - Let's assume you just created a `fichier.txt` file on the top of + Let's assume you just created a =fichier.txt= file on the top of the =mooc-rr= directory. #+begin_src shell :results output :exports both git status #+end_src + #+BEGIN_CENTER [[file:gitlab_images/status1.png]] - + #+END_CENTER + #+begin_src shell :results output :exports both git add fichier.txt git status #+end_src + #+BEGIN_CENTER [[file:gitlab_images/status2.png]] - + #+END_CENTER + #+begin_src shell :results output :exports both git commit -m "message commit" #+end_src + #+BEGIN_CENTER [[file:gitlab_images/commit_git.png]] - + #+END_CENTER + #+begin_src shell :results output :exports both git status #+end_src + #+BEGIN_CENTER [[file:gitlab_images/status3.png]] - + #+END_CENTER + The file can then be transfered to GitLab: #+begin_src shell :results output :exports both git push #+end_src - At this point, git will as you about your login/password unless + At this point, git will ask you about your login/password unless you followed the previous /Remembering your password locally/ instructions. N.B.: you will not be allowed to propagate your modifications to GitLab if other modifications (e.g., from someone else) have been propagated in between + #+BEGIN_CENTER [[file:gitlab_images/rejected.png]] + #+END_CENTER 5. Synchronizing from Gitlab: to avoid the previous problem, you need to fetch the remote GitLab modifications first and apply them locally.
