From 7e0ec26682c7c0c215a9ccc49cc7b98f367443f5 Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Wed, 5 Sep 2018 14:20:34 +0200 Subject: [PATCH] Many additional information on how to deploy a specific R or python package. --- module4/ressources/resources.org | 159 +++++++++++++++++++++++++++++-- 1 file changed, 153 insertions(+), 6 deletions(-) diff --git a/module4/ressources/resources.org b/module4/ressources/resources.org index be9a530..eac7583 100644 --- a/module4/ressources/resources.org +++ b/module4/ressources/resources.org @@ -90,7 +90,9 @@ This topic is discussed on [[https://stackoverflow.com/questions/20180543/how-to package installer) within a shell command, it is easy to query the version of all installed packages (note that on your system, you may have to use either =pip= or =pip3= depending on how it is named and which -versions of Python are available on your machine. +versions of Python are available on your machine + +Here for example how I get these information on my machine: #+begin_src shell :results output :exports both pip3 freeze #+end_src @@ -116,14 +118,45 @@ wcwidth==0.1.7 webencodings==0.5 #+end_example +In a Jupyter notebook, this can easily be done by using the =%%sh= +magic. Here is for example what you could do and get on the Jupyter +notebooks we deployed for the MOOC (note that here, you should simply +use the =pip= command): +#+begin_src python :results output :exports both +%%sh +pip freeze +#+end_src + +#+results: +#+begin_example +alembic==0.9.9 +asn1crypto==0.24.0 +attrs==18.1.0 +Automat==0.0.0 +... +numpy==1.13.3 +olefile==0.45.1 +packaging==17.1 +pamela==0.3.0 +pandas==0.22.0 +... +webencodings==0.5 +widgetsnbextension==3.2.1 +xlrd==1.1.0 +zope.interface==4.5.0 +#+end_example + +In the rest of this document, I will assume the correct command is =pip= +and I will not systematically insert the =%%sh= magic. + Once you know which packages are installed, you can easily get additional information about a given package and in particular check whether it was installed "locally" through pip or whether it is installed system-wide. Again, in a shell command: #+begin_src shell :results output :exports both -pip3 show pandas +pip show pandas echo " " -pip3 show statsmodels +pip show statsmodels #+end_src #+RESULTS: @@ -148,7 +181,6 @@ License: BSD License Location: /home/alegrand/.local/lib/python3.6/site-packages Requires: patsy, pandas #+end_example - ** How to list imported modules? Without resorting to pip (that will list all available packages), you may want to know which modules are loaded in a Python session as well @@ -216,8 +248,63 @@ pip3 install -r requirements.txt # to install the previous list of packages, pos If you want to have several installed Python environments, you may want to use [[https://docs.pipenv.org/][Pipenv]]. I doubt it allows to track correctly FORTRAN or C dynamic libraries that are wrapped by Python though. +** Installing a new package or a specific version +The Jupyter environment we deployed on our servers for the MOOC is +based on the version 4.5.4 of Miniconda and Python 3.6. In this +environment you should simply use the =pip= command (remember on your +machine, you may have to use =pip3=). + +If I query the current version of =statsmodels= in a shell command, +here is what I will get. +#+begin_src shell :results output :exports both +pip show statsmodels +#+end_src + +#+RESULTS: +#+BEGIN_EXAMPLE +Name: statsmodels +Version: 0.8.0 +Summary: Statistical computations and models for Python +Home-page: http://www.statsmodels.org/ +Author: Skipper Seabold, Josef Perktold +Author-email: pystatsmodels@googlegroups.com +License: BSD License +Location: /opt/conda/lib/python3.6/site-packages +Requires: scipy, patsy, pandas +#+END_EXAMPLE + +I can then easily upgrade =statsmodels=: +#+begin_src shell :results output :exports both +pip install --upgrade statsmodels +#+end_src + +Then the new version should then be: +#+begin_src shell :results output :exports both +pip show statsmodels +#+end_src + +#+RESULTS: +#+BEGIN_EXAMPLE +Name: statsmodels +Version: 0.9.0 +Summary: Statistical computations and models for Python +Home-page: http://www.statsmodels.org/ +Author: Skipper Seabold, Josef Perktold +Author-email: pystatsmodels@googlegroups.com +License: BSD License +Location: /opt/conda/lib/python3.6/site-packages +Requires: scipy, patsy, pandas +#+END_EXAMPLE + +It is even possible to install a specific (possibly much older) version, e.g.,: +#+begin_src shell :results output :exports both +pip install statsmodels==0.6.1 +#+end_src * Getting information about R libraries -The best way seems to be to rely on the =devtools= package. +** Getting the list imported modules and their version +The best way seems to be to rely on the =devtools= package (if this +package is not installed, you should install it first by running in =R= +the command =install.packages("devtools")=). #+begin_src R :results output :session *R* :exports both sessionInfo() @@ -276,7 +363,7 @@ Packages ---------------------------------------------------------------------- Some actually advocate that [[https://github.com/ropensci/rrrpkg][writing a reproducible research compendium can be done by writing an R package]]. Those of you willing to have a clean R dependency management should thus have a look at [[https://rstudio.github.io/packrat/][Packrat]]. - +** Getting the list of installed packages and their version Finally, it is good to know that there is a built-in R command (=installed.packages=) allowing to retrieve and list the details of all packages installed. @@ -296,3 +383,63 @@ head(installed.packages()) | Matrix | /home/alegrand/R/x86_64-pc-linux-gnu-library/3.5 | 1.2-14 | recommended | R (>= 3.2.0) | methods, graphics, grid, stats, utils, lattice | nil | expm, MASS | MatrixModels, graph, SparseM, sfsmisc | GPL (>= 2) | file LICENCE | nil | nil | nil | nil | yes | 3.5.1 | | StanHeaders | /home/alegrand/R/x86_64-pc-linux-gnu-library/3.5 | 2.17.2 | nil | nil | nil | nil | RcppEigen, BH | nil | BSD_3_clause + file LICENSE | nil | nil | nil | nil | yes | 3.5.1 | | | acepack | /home/alegrand/R/x86_64-pc-linux-gnu-library/3.5 | 1.4.1 | nil | nil | nil | nil | testthat | nil | MIT + file LICENSE | nil | nil | nil | nil | yes | 3.5.1 | | + +** Installing a new package or a specific version +This section is mostly a cut and paste from the [[https://support.rstudio.com/hc/en-us/articles/219949047-Installing-older-versions-of-packages][recent post by Ian +Pylvainen]] on this topic. It comprises a very clear explanation on how +to proceed. + +*** Installing a pre-compiled version +If you're on a Debian or a Ubuntu system, it may be difficult to +access a specific version without breaking your system. So unless you +are moving to the latest version available in your Linux distribution, +*we strongly recommend you to build from source*. In this case, you'll +need to make sure you have the necessary toolchain to build packages +from source (e.g., gcc, FORTRAN, etc.). On Windows, this may require +you to install [[https://cran.r-project.org/bin/windows/Rtools/][Rtools]]. + +If you're on Windows or OS X and looking for a package for an *older +version of R* (R 2.1 or below), you can check the [[https://cran-archive.r-project.org/bin/][CRAN binary +archive]]. Once you have the URL, you can install it using a command +similar to the example below: +#+begin_src R :results output :session *R* :exports both +packageurl <- "https://cran-archive.r-project.org/bin/windows/contrib/2.13/BBmisc_1.0-58.zip" +install.packages(packageurl, repos=NULL, type="binary") +#+end_src +*** Using devtools +The simplest method to install the version you need is to use the +=install_version()= function of the =devtools= package (obviously, you +need to install =devtools= first, which can be done by running in =R= the +command =install.packages("devtools")=). For instance: + +#+begin_src R :results output :session *R* :exports both +require(devtools) +install_version("ggplot2", version = "0.9.1", repos = "http://cran.us.r-project.org") +#+end_src +*** Alternatively, you may want to install an older package from source +If you devtools fails or if you do not want to depend on it, you can +install it from source via =install.packages()= directed to the right +URL. This URL can be obtained by browsing the [[https://cran.r-project.org/src/contrib/Archive][CRAN Package Archive]]. + +Once you have the URL, you can install it using a command similar to +the example below: +#+begin_src R :results output :session *R* :exports both +packageurl <- "http://cran.r-project.org/src/contrib/Archive/ggplot2/ggplot2_0.9.1.tar.gz" +install.packages(packageurl, repos=NULL, type="source") +#+end_src + +If you know the URL, you can also install from source via the command +line outside of R. For instance (in bash): +#+begin_src shell :results output :exports both +wget http://cran.r-project.org/src/contrib/Archive/ggplot2/ggplot2_0.9.1.tar.gz +R CMD INSTALL ggplot2_0.9.1.tar.gz +#+end_src +*** Potential issues +There are a few potential issues that may arise with installing older +versions of packages: +- You may be losing functionality or bug fixes that are only present + in the newer versions of the packages. +- The older package version needed may not be compatible with the + version of R you have installed. In this case, you will either need + to downgrade R to a compatible version or update your R code to work + with a newer version of the package. -- 2.18.1
