diff --git a/module2/ressources/jupyter.org b/module2/ressources/jupyter.org index 6bad690227e5e10ccbb520a9f1a4ef958684f014..65886f7cb5c3b9a0d85eb8199ede2136582b85d7 100644 --- a/module2/ressources/jupyter.org +++ b/module2/ressources/jupyter.org @@ -11,7 +11,7 @@ The following [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][webpage]] lists several Jupyter tricks (in particular, it illustrates many =Ipython magic= commands) that should improve your efficiency (note that this blog post is about two years old so some of -the tricks may have been integrated in the default behavior of jupyter +the tricks may have been integrated in the default behavior of Jupyter now). ** Running R and Python in the same notebook The best solution to this is to install rpy2. On my machine, I have @@ -58,13 +58,16 @@ nbconvert exporter, an other option consists in exporting to Markdown and playing with [[https://pandoc.org/][pandoc]]. Both approaches work, it's rather a matter of taste. * Installing Jupyter on your own machine -** Installing jupyter -Follow these instructions if you wish to have a similar Jupyter environment on you own machine. +** Installing Jupyter +Follow these instructions if you wish to have a Jupyter environment on +your own machine similar to the one we set up for this MOOC. -First, download and install [[https://conda.io/miniconda.html][Miniconda latest version]]. We use Miniconda version =4.5.4= and Python version =3.6= on our server .\\ -Miniconda is a light version of Anaconda which includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science. +First, download and install the [[https://conda.io/miniconda.html][latest version of Miniconda]]. We use +Miniconda version =4.5.4= and Python version =3.6= on our server. -Then download the [[https://gist.github.com/brospars/4671d9013f0d99e1c961482dab533c57][mooc_rr environment file]] and create it using conda: +Miniconda is a light version of Anaconda, which includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science. + +Then download the [[https://gist.github.com/brospars/4671d9013f0d99e1c961482dab533c57][mooc_rr environment file]] and create the environment using conda: #+begin_src shell :results output :exports both conda env create -f environment.yml @@ -76,26 +79,56 @@ source activate mooc_rr jupyter notebook #+end_src - +** Side note about Jupyter, JupyterLab, JupyterHub, ... +Note that Jupyter notebooks are only a small part of the picture and +that Jupyter is now part of a bigger project: [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows +you to mix various components (including notebooks) in your +browser. In the context of this MOOC, our time frame was too short to +benefit from JupyterLab which was still under active development but +this is probably the best option now if you want to benefit from +cutting-edge Jupyter notebooks. ** Exporting your notebooks with latex -Here is what I had to install on my recent debian machine to make sure +Here is what we had to install on our recent debian machine to make sure the notebook export via latex works: #+begin_src shell :results output :exports both -sudo apt-get install wkhtmltopdf -sudo apt-get install texlive-xetex +sudo apt-get install texlive-xetex wkhtmltopdf #+end_src -** Interesting extensions to improve notebook readability -Here are two interesting extensions that can improve readability: -- [[https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook][Code folding]] +** Jupyter extensions/plugins +*** Improving notebook readability +Here are a few extensions that can ease your life: +- [[https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook][Code folding]] to improve readability when browsing the notebook. #+begin_src shell :results output :exports both pip3 install jupyter_contrib_nbextensions # jupyter contrib nbextension install --user # not done yet #+end_src -- [[https://github.com/kirbs-/hide_code][Hiding code]] +- [[https://github.com/kirbs-/hide_code][Hiding code]] to improve readability when exporting. #+begin_src sh :results output :exports both sudo pip3 install hide_code sudo jupyter-nbextension install --py hide_code jupyter-nbextension enable --py hide_code jupyter-serverextension enable --py hide_code #+end_src +*** Interacting with GitLab and GitHub +To ease your experience, we added some pull/push buttons that allow +you to commit and sync with GitLab. This development was specific to +the MOOC but inspired from a previous [[https://github.com/Lab41/sunny-side-up][proof of concept]]. We have +recently discovered that someone else developed about at the same time +a [[https://github.com/sat28/githubcommit][rather generic version of this Jupyter plugin]]. Otherwise, remember +that it is very easy to insert a shell cell in Jupyter in which you +can easily issue git commands. This is how we work most of the time. + +This being said, you may have noticed that Jupyter keeps a perfect +track of the sequence in which cells have been run by updating the +"output index". This is a very good property from the reproducibility +point of view but depending on your usage, you may find it a bit +painful when commiting. Some people have thus developped [[https://gist.github.com/pbugnion/ea2797393033b54674af][specific git +hooks]] to ignore these numbers when comitting Jupyter notebooks. There +is a long an interesting discussion about various options on +[[https://stackoverflow.com/questions/18734739/using-ipython-notebooks-under-version-control][StackOverflow]]. + +Last but not least, remembter that Jupyter notebooks are only a small +part of the picture and that Jupyter is now part of a bigger project: +[[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows you to mix various components (including +notebooks) in your browser. A specific [[https://github.com/jupyterlab/jupyterlab-git][JupyterLab git plugin]] has been +developed to offer a nice version control experience.
