From 7fd3cd0687a6c6dee40226d753ff3c5700ecf02a Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Fri, 29 Mar 2019 22:04:00 +0100 Subject: [PATCH] Cosmetics --- module2/ressources/emacs_newbie.org | 23 ++++++++++++----------- 1 file changed, 12 insertions(+), 11 deletions(-) diff --git a/module2/ressources/emacs_newbie.org b/module2/ressources/emacs_newbie.org index 4181599..40bdda1 100644 --- a/module2/ressources/emacs_newbie.org +++ b/module2/ressources/emacs_newbie.org @@ -11,7 +11,7 @@ the screenshots in this demo are done under the Windows operating system but similar results should be obtained on any OS. * First steps with Emacs as a computationnal environment -** Run Emacs +** A first org-mode document - Launch emacs #+BEGIN_CENTER [[file:emacs_orgmode_images/emacs.png]] @@ -59,13 +59,13 @@ system but similar results should be obtained on any OS. If you do not like this behavior, you can edit the =init.el= file and replace =(org-babel-temp-file \"figure\" \".png\")= by =\"D:/temp/figure.png\"= or whichever location/name you prefer (both - for =
