diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index ddfd7c55700fd4f5ce5b35a49ce964fcd7cf0713..a244b4b771d0c554ba4f42b077af08ccefd51319 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -144,39 +144,6 @@ In step 1, you were told to create an journal in backed up in a revision control system like git. We leave it up to set this up but if you have any trouble, feel free to ask on the FUN forums. -* Emacs Tips and tricks -** Cheat-sheets -Learning emacs and org-mode can be difficult as there is an inordinate -amount of shortcuts. Many people have thus come up with -cheat-sheats. Here is a selection in case it helps: -*** Emacs -- [[file:org/journal.org::*Emacs%20shortcuts][Common and step-by-step emacs shortcuts for our /reproducible research/ configuration]] -- [[https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf][The official GNU emacs refcard]] -- Two graphical cheat-sheats by Sacha Hua on [[http://sachachua.com/blog/wp-content/uploads/2013/05/How-to-Learn-Emacs-v2-Large.png][how to learn emacs]] and on - [[http://sachachua.com/blog/wp-content/uploads/2013/08/20130830-Emacs-Newbie-How-to-Learn-Emacs-Keyboard-Shortcuts.png][how to learn emacs shortcuts]]. -*** Org-mode -- [[file:org/journal.org::*Org-mode][Common and step-by-step org-mode shortcuts for our /reproducible research/ configuration]] -- [[https://orgmode.org/worg/orgcard.html][The official org-mode refcard]] -- [[https://orgmode.org/worg/dev/org-syntax.html][The official description of the org-mode syntax]] and a [[https://gist.github.com/hoeltgman/3825415][relatively concise description of the org-mode syntax]]. -** Video tutorials -For those of you who prefer video explanations, here is a [[https://www.youtube.com/playlist?list=PL9KxKa8NpFxIcNQa9js7dQQIHc81b0-Xg][Youtube -channel with many step by step emacs tutorials]]. -** Additional useful emacs packages -*** Company-mode -[[http://company-mode.github.io/][Company-mode]] is a text completion framework for Emacs. It allows to -have smart completion in emacs for the most common languages. If you -feel this is needed, you should follow the instructions from the -official webpage: http://company-mode.github.io/ -*** Magit -[[https://magit.vc/][Magit]] is an emacs interface for Git. It is very powerfull and we use -it on a daily basis but you should definitely understand what git does -behind the scene beforehand. If you feel this would be useful for you, -you should follow the instructions from here: -https://www.emacswiki.org/emacs/Magit -** Other resources -- [[https://orgmode.org/orgguide.pdf][The compact Org-mode Guide]] -- [[https://github.com/dfeich/org-babel-examples][Many examples illustrating the use of different languages in org-mode]] -* A replicable article ** A stub of replicable article Remember, you need a working LaTeX and R environment. If you can't open a terminal and run the commands =R= and =pdflatex=, you will not be @@ -223,3 +190,36 @@ code when exporting, just look for the following line in [[file:replicable_artic If you remove the =# = in the beginning of the line, it will not be a comment anymore and will indicate org-mode to stop evaluating every chunk of code when exporting. + +* Emacs Tips and tricks +** Cheat-sheets +Learning emacs and org-mode can be difficult as there is an inordinate +amount of shortcuts. Many people have thus come up with +cheat-sheats. Here is a selection in case it helps: +*** Emacs +- [[file:org/journal.org::*Emacs%20shortcuts][Common and step-by-step emacs shortcuts for our /reproducible research/ configuration]] +- [[https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf][The official GNU emacs refcard]] +- Two graphical cheat-sheats by Sacha Hua on [[http://sachachua.com/blog/wp-content/uploads/2013/05/How-to-Learn-Emacs-v2-Large.png][how to learn emacs]] and on + [[http://sachachua.com/blog/wp-content/uploads/2013/08/20130830-Emacs-Newbie-How-to-Learn-Emacs-Keyboard-Shortcuts.png][how to learn emacs shortcuts]]. +*** Org-mode +- [[file:org/journal.org::*Org-mode][Common and step-by-step org-mode shortcuts for our /reproducible research/ configuration]] +- [[https://orgmode.org/worg/orgcard.html][The official org-mode refcard]] +- [[https://orgmode.org/worg/dev/org-syntax.html][The official description of the org-mode syntax]] and a [[https://gist.github.com/hoeltgman/3825415][relatively concise description of the org-mode syntax]]. +** Video tutorials +For those of you who prefer video explanations, here is a [[https://www.youtube.com/playlist?list=PL9KxKa8NpFxIcNQa9js7dQQIHc81b0-Xg][Youtube +channel with many step by step emacs tutorials]]. +** Additional useful emacs packages +*** Company-mode +[[http://company-mode.github.io/][Company-mode]] is a text completion framework for Emacs. It allows to +have smart completion in emacs for the most common languages. If you +feel this is needed, you should follow the instructions from the +official webpage: http://company-mode.github.io/ +*** Magit +[[https://magit.vc/][Magit]] is an emacs interface for Git. It is very powerfull and we use +it on a daily basis but you should definitely understand what git does +behind the scene beforehand. If you feel this would be useful for you, +you should follow the instructions from here: +https://www.emacswiki.org/emacs/Magit +** Other resources +- [[https://orgmode.org/orgguide.pdf][The compact Org-mode Guide]] +- [[https://github.com/dfeich/org-babel-examples][Many examples illustrating the use of different languages in org-mode]]
