diff --git a/module2/ressources/gitlab.org b/module2/ressources/gitlab.org index 9af90b0575dec685a6c120596c5c9cee49f4b6e8..47100e30a433ccc0db3a6f46eb8a3cc211d88b15 100644 --- a/module2/ressources/gitlab.org +++ b/module2/ressources/gitlab.org @@ -6,9 +6,9 @@ #+OPTIONS: num:nil toc:t #+PROPERTY: header-args :eval never-export -*This document is particularly important if you follow the Rstudio or -the Org-Mode course.* *If you follow the Jupyter course, it can be -ignored in a first step* *as we have closely integrated Jupyter and +*This document is particularly important if you follow the RStudio or +the Org-Mode path.* *If you follow the Jupyter path, it can be +ignored at first* *as we have closely integrated Jupyter and GitLab in the context of this MOOC.* So far, you only used git via the web interface from the GitLab we @@ -30,10 +30,10 @@ Please read all these instructions carefully, in particular the one on "Configuring your password on GitLab". * Installing Git -** Linux (debian, ubuntu) -We provide here only instructions for debian-based distributions. Feel +** Linux (Debian, Ubuntu) +We provide here only instructions for Debian-based distributions. Feel free to contribute to this document to provide up-to-date information -for other distributions (e.g., redhat, fedora). +for other distributions (e.g., RedHat, Fedora). Run (as root): #+begin_src sh :results output :exports both @@ -42,7 +42,7 @@ apt-get update ; apt-get install git ** Mac OSX and Windows - Download and install Git from the [[https://git-scm.com/downloads][Git website]]. - Optional Git clients (should not be needed if you work within - Rstudio): + RStudio): - [[https://www.sourcetreeapp.com/][SourceTree]] - [[https://desktop.github.com/][GitHub Desktop]] #+BEGIN_QUOTE @@ -50,7 +50,7 @@ apt-get update ; apt-get install git #+END_QUOTE * Configuring Git ** Telling Git who you are: Name and Email -1. Open Terminal. +1. Open terminal. 2. Set a Git username and email: #+begin_src shell :results output :exports both git config --global user.name "Mona Lisa" @@ -158,16 +158,16 @@ installing SSH, creating a pair or private/public keys, and uploading your SSH public key on GitLab. This section provides with information on how to do this. *** Installing SSH -**** Linux (debian, ubuntu) +**** Linux (Debian, Ubuntu) We provide here only instructions for debian-based distributions. Feel free to contribute to this document to provide up-to-date information -for other distributions (e.g., redhat, fedora). +for other distributions (e.g., RedHat, Fedora). Run (as root): #+begin_src sh :results output :exports both apt-get update ; apt-get install openssh-client #+end_src -**** Mac OSX +**** macOS You do not have anything to do as it is installed by default. **** Windows You should install the [[https://www.ssh.com/ssh/putty/windows/][Putty]] client. Once it is installed, look for @@ -182,9 +182,9 @@ video: * Using Git through the command line to synchronize your local files with Gitlab This section describes a generic (through the command line) way to synchronize your local files with Gitlab. You will not need this if -you follow the Jupyter course. If you follow the Rstudio course, all -these operations can be done through Rstudio and you may want to read -[[file:rstudio.org][the corresponding instructions]]. If you follow the Org-Mode course, all +you follow the Jupyter path. If you follow the RStudio path, all +these operations can be done through RStudio and you may want to read +[[file:rstudio.org][the corresponding instructions]]. If you follow the Org-Mode path, all these operations can be done through Magit and you may want to read [[file:emacs_orgmode.org][the corresponding instructions]].
