diff --git a/module2/ressources/emacs_orgmode.html b/module2/ressources/emacs_orgmode.html index d7886858c1d5cb25edce30a674083f25099a04b5..de60757be0d26a2fb53c62c2757173b62c9b5e48 100644 --- a/module2/ressources/emacs_orgmode.html +++ b/module2/ressources/emacs_orgmode.html @@ -4,71 +4,66 @@
-Disclaimer: The two sections A simple "reproducible research" -emacs configuration and A stub of replicable article explain how to -set up org-mode for this MOOC. You really should follow them -carefully or you may have trouble doing the exercices later on. +Disclaimer: The two sections A simple "reproducible research" emacs +configuration and A stub of replicable article explain how to set up +org-mode for this MOOC. I have prepared two video tutorials (here and +here) for each, which you really should follow carefully. Otherwise, +you may have trouble doing the exercises later on. Likewise, I +strongly encourage you to watch the "emacs and git" video tutorial.
The next sections provide information on how to install emacs. Before -proceeding, make sure you have read the "Git and GitLab" instructions. +proceeding, make sure you have read the "Git and GitLab" instructions +(tutorial and resources from the 4th sequence of the 2nd module).
-We provide here only instructions for debian-based distributions. Feel free to contribute to this document to provide up-to-date information @@ -130,9 +125,9 @@ which is now deprecated.
Option 1: Install the .dmg file from Vincent Goulet:
@@ -165,9 +160,9 @@ brew install wget
Install the .exe file from Vincent Goulet:
https://vigou3.github.io/emacs-modified-windows/. It ships with recent
@@ -181,14 +176,13 @@ versions:
++A simple "reproducible research" emacs configuration
+--There will be a mini video illustrating these steps at some point +This section is illustrated in a video tutorial (in French). Watching +it before following the instructions given in this section may help.
-Emacs comes with very basic default configuration and it appears like @@ -197,14 +191,14 @@ default Emacs configurations that reflect the preferences of their creators. Likewise the configuration of Org-Mode is incredibly flexible (see for example the org-mode website for more references). In the context of this MOOC, we propose you a relatively -minimalistic one that is rather "reproducible research" oriented by +minimalist one that is rather "reproducible research" oriented by adding a few org-mode specific configurations.
-Step 0: Backup and download our configuration
-++-Step 0: Backup and download our configuration
+The procedure we propose will wipe your already existing custom emacs configuration if you already have one. You should thus beforehand make @@ -225,9 +219,9 @@ rr_org/journal.org
-Step 1: Prepare your journal
-++-Step 1: Prepare your journal
+Create an
@@ -244,9 +238,9 @@ should give a try.org/directory in the top of your home:-Step 2: Set up Emacs configuration
-++-Step 2: Set up Emacs configuration
+Copy
@@ -258,9 +252,9 @@ configuration with the following command:rr_org/init.elin your~/.emacs.d/directory.emacs -q -l rr_org/init.el-Step 3: Check whether the installation is working or not
-++Step 3: Check whether the installation is working or not
+Open a new instance of Emacs and open a
foo.orgfile. Copy the following lines in this file: @@ -291,9 +285,9 @@ is demonstrated in the -Step 4: Open and play with your journal:
-+-+Step 4: Open and play with your journal:
+In step 1, you were told to create an journal in
~org/journal.org. First you probably want to make sure this file is @@ -304,14 +298,13 @@ forums.-TODO A stub of replicable article
---++-A stub of replicable article
+-There will be a mini video illustrating these steps at some point +This section is illustrated in a video tutorial (in French). Watching +it before following the instructions given in this section may help.
-Remember, you need a working LaTeX and R environment. If you can't @@ -323,7 +316,7 @@ source (archive, untar it and simply
@@ -356,7 +349,7 @@ command line to load your personal emacs configuration.maketo generate the +Download the following archive, uncompress it and simplymaketo generate the article. You should then be able to open the resulting article. This is summarized in the following command:-Finally, when you'll be tired of always reexecuting all the source +Finally, when you'll be tired of always re-executing all the source code when exporting, just look for the following line in article.org:
@@ -369,24 +362,23 @@ chunk of code when exporting.-Emacs Tips and tricks
-++Emacs Tips and tricks
+--Cheat-sheets
-++Cheat-sheets
+-Learning emacs and org-mode can be difficult as there is an inordinate amount of shortcuts. Many people have thus come up with cheat-sheats. Here is a selection in case it helps:
-Emacs
-++-Emacs
- Common and step-by-step emacs shortcuts for our reproducible research configuration
- The official GNU emacs refcard
@@ -395,9 +387,9 @@ cheat-sheats. Here is a selection in case it helps:-Org-mode
-+-+Org-mode
- Common and step-by-step org-mode shortcuts for our reproducible research configuration
- The official org-mode refcard
@@ -406,35 +398,40 @@ cheat-sheats. Here is a selection in case it helps:-Video tutorials
-++-Video tutorials
+For those of you who prefer video explanations, here is a Youtube channel with many step by step emacs tutorials.
-Additional useful emacs packages
-++Additional useful emacs packages
+--Company-mode
-++-Company-mode
+Company-mode is a text completion framework for Emacs. It allows to have smart completion in emacs for the most common languages. If you feel this is needed, you should follow the instructions from the -official webpage: http://company-mode.github.io/ +official Web page: http://company-mode.github.io/
-Magit
-+-+Magit
+++Magit]] is an emacs interface for Git. It is briefly illustrated in a +video tutorial. +
+-Magit is an emacs interface for Git. It is very powerfull and we use +It is very powerful and we use it on a daily basis but you should definitely understand what git does behind the scene beforehand. If you feel this would be useful for you, you should follow the instructions from here: @@ -445,9 +442,9 @@ magit by using
C-x g.-Other resources
-++Other resources
- The compact Org-mode Guide
- Many examples illustrating the use of different languages in org-mode
diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index 5bf598da8c4a6bd8dccdf701723e1f3650a2aa20..a16223744eb9cc9d0db1e40bd49c761299b468ba 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -6,17 +6,19 @@ #+OPTIONS: num:nil toc:t #+PROPERTY: header-args :eval never-export -*Disclaimer:* The two sections _A simple "/reproducible research/" -emacs configuration_ and _A stub of replicable article_ explain how to -set up org-mode for this MOOC. *You really should follow them -carefully or you may have trouble doing the exercices later on*. +*Disclaimer:* The two sections _A simple "/reproducible research/" emacs +configuration_ and _A stub of replicable article_ explain how to set up +org-mode for this MOOC. *I have prepared two video tutorials (here and +here) for each, which you really should follow carefully*. *Otherwise, +you may have trouble doing the exercises later on*. Likewise, I +strongly encourage you to watch the "emacs and git" video tutorial. The next sections provide information on how to install emacs. Before -proceeding, make sure you have read the "Git and GitLab" instructions. +proceeding, make sure you have read the "Git and GitLab" instructions +(tutorial and resources from the 4th sequence of the 2nd module). * Installing emacs, org-mode, ess, and auctex. -** OS-specific installation procedure -*** Linux (Debian, Ubuntu) +** Linux (Debian, Ubuntu) We provide here only instructions for debian-based distributions. Feel free to contribute to this document to provide up-to-date information for other distributions (e.g.n redhat, fedora). @@ -53,7 +55,7 @@ emacs -batch --funcall "org-version" 2>&1 | grep version The version numbers you get will depend on the distribution you are running. _You really want to make sure you do not rely on org-mode 8_, which is now deprecated. -*** Mac OS X +** Mac OS X - *Option 1*: Install the =.dmg= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]: https://vigou3.github.io/emacs-modified-macos/. It ships with recent versions: @@ -73,17 +75,16 @@ which is now deprecated. brew install auctex # The name may be slightly more complicated here brew install wget #+end_src -*** Windows +** Windows Install the =.exe= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]: https://vigou3.github.io/emacs-modified-windows/. It ships with recent versions: - Emacs 26.1 - Org-mode 9.1.13 - ESS 17.11 -** TODO A simple "/reproducible research/" emacs configuration -#+BEGIN_QUOTE -There will be a mini video illustrating these steps at some point -#+END_QUOTE +* A simple "/reproducible research/" emacs configuration +This section is illustrated in a video tutorial (in French). Watching +it before following the instructions given in this section may help. Emacs comes with very basic default configuration and it appears like everyone has its own taste. You will for example find [[https://www.emacswiki.org/emacs/StarterKits][here]] several @@ -91,10 +92,10 @@ default Emacs configurations that reflect the preferences of their creators. Likewise the configuration of Org-Mode is incredibly flexible (see for example [[https://orgmode.org/worg/org-configs/index.html][the org-mode website]] for more references). In the context of this MOOC, we propose you a relatively -minimalistic one that is rather "/reproducible research/" oriented by +minimalist one that is rather "/reproducible research/" oriented by adding a few org-mode specific configurations. -*** Step 0: Backup and download our configuration +** Step 0: Backup and download our configuration The procedure we propose will wipe your already existing custom emacs configuration if you already have one. *You should thus beforehand make a backup of =~/.emacs= and of =~/.emacs.d/init.el=* (if these file @@ -117,7 +118,7 @@ tar tzf rr_org_archive.tgz : rr_org/init.el : rr_org/journal.org -*** Step 1: Prepare your journal +** Step 1: Prepare your journal Create an =org/= directory in the top of your home: #+begin_src sh :results output :exports both mkdir -p ~/org/ @@ -127,13 +128,13 @@ file will be your laboratory notebook and all the notes you will capture with =C-c c= will go automatically go in this file. The first entry of this notebook is populated with [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][many emacs shortcuts]] that you should give a try. -*** Step 2: Set up Emacs configuration +** Step 2: Set up Emacs configuration Copy =rr_org/init.el= in your =~/.emacs.d/= directory. Alternatively, if you do not want to mess with your already existing emacs configuration, you may launch emacs with this specific configuration with the following command: =emacs -q -l rr_org/init.el=. -*** Step 3: Check whether the installation is working or not +** Step 3: Check whether the installation is working or not Open a new instance of Emacs and open a =foo.org= file. Copy the following lines in this file: : #+begin_src shell :session foo :results output :exports both @@ -151,16 +152,15 @@ In the video, we already have demonstrated the main features and shortcuts of emacs/org-mode that will help you maintain a document and benefit from literate programming. The list of features and shortcuts is demonstrated in the [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][first entry of your labbook]]. -*** Step 4: Open and play with your journal: +** Step 4: Open and play with your journal: In step 1, you were told to create an journal in =~org/journal.org=. First you probably want to make sure this file is backed up in a revision control system like git. We leave it up to set this up but if you have any trouble, feel free to ask on the FUN forums. -** TODO A stub of replicable article -#+BEGIN_QUOTE -There will be a mini video illustrating these steps at some point -#+END_QUOTE +* A stub of replicable article +This section is illustrated in a video tutorial (in French). Watching +it before following the instructions given in this section may help. Remember, you need a working LaTeX and R environment. If you can't open a terminal and run the commands =R=, =pdflatex=, and =python=, you will not be @@ -175,7 +175,7 @@ make -C replicable_article/ all replicable_article.tgz #+RESULTS: -Download the following [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/raw/master/module2/ressources/replicable_article/replicable_article.tgz][archive]], untar it and simply =make= to generate the +Download the following [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/raw/master/module2/ressources/replicable_article/replicable_article.tgz][archive]], uncompress it and simply =make= to generate the article. You should then be able to open the [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.pdf][resulting article]]. This is summarized in the following command: #+begin_src sh :results output :exports both @@ -196,7 +196,7 @@ tar zxf replicable.tgz; cd replicable; make ; evince article.pdf system-wide. In that case, try to remove the =-q= in the previous command line to load your personal emacs configuration. -Finally, when you'll be tired of always reexecuting all the source +Finally, when you'll be tired of always re-executing all the source code when exporting, just look for the following line in [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org][article.org]]: #+BEGIN_EXAMPLE # #+PROPERTY: header-args :eval never-export @@ -227,9 +227,12 @@ channel with many step by step emacs tutorials]]. [[http://company-mode.github.io/][Company-mode]] is a text completion framework for Emacs. It allows to have smart completion in emacs for the most common languages. If you feel this is needed, you should follow the instructions from the -official webpage: http://company-mode.github.io/ +official Web page: http://company-mode.github.io/ *** Magit -[[https://magit.vc/][Magit]] is an emacs interface for Git. It is very powerfull and we use +Magit]] is an emacs interface for Git. It is briefly illustrated in a +video tutorial. + +It is very powerful and we use it on a daily basis but you should definitely understand what git does behind the scene beforehand. If you feel this would be useful for you, you should follow the instructions from here:
