diff --git a/module2/ressources/jupyter.org b/module2/ressources/jupyter.org index 65886f7cb5c3b9a0d85eb8199ede2136582b85d7..9e4432190f6911df8f4ae16f227a2ece84f4f19f 100644 --- a/module2/ressources/jupyter.org +++ b/module2/ressources/jupyter.org @@ -19,8 +19,8 @@ installed the =python3-rpy2= debian package with =apt-get install=. E.g., #+begin_src shell :results output :exports both sudo apt-get install python3-rpy2 python3-tzlocal #+end_src -An other (not really recommanded) alternative consists in going -through the python package manager with +An other (not really recommended if the first one is available) +alternative consists in going through the python package manager with #+begin_src python :results output :exports both pip3 install rpy2 #+end_src @@ -31,7 +31,7 @@ Then you'll be able to use both languages in the same notebook by: #+end_src 2. Using the =%R= Ipython magic: #+begin_src python :results output :exports both - %R + %%R summary(cars) #+end_src Python objects can then even be passed to R as follows (assuming =df= @@ -40,6 +40,9 @@ Then you'll be able to use both languages in the same notebook by: %%R -i df plot(df) #+end_src +Note that this =%%R= notation allows you to use R for the whole cell but +an other possibility is to use =%R= to have a single line of R within a +python cell. ** Exporting a notebook Obviously, you can convert to html or pdf using the using the =File > Download as > HTML= (or =PDF=) menu option. This can also be done from @@ -49,12 +52,12 @@ the command line with the following command: ipython3 nbconvert --to pdf Untitled.ipynb #+end_src -If you want to use a specific style, then the nbconvert exporter -should be customised. This is discussed and demoed [[http://markus-beuckelmann.de/blog/customizing-nbconvert-pdf.html][here]]. We encourage +If you want to use a specific style, then the =nbconvert= exporter +should be customized. This is discussed and demoed [[http://markus-beuckelmann.de/blog/customizing-nbconvert-pdf.html][here]]. We encourage you to simply read the [[https://nbconvert.readthedocs.io/en/latest/][doc of nbconvert]]. Instead of going directly through LaTeX and playing too much with the -nbconvert exporter, an other option consists in exporting to Markdown +=nbconvert= exporter, an other option consists in exporting to Markdown and playing with [[https://pandoc.org/][pandoc]]. Both approaches work, it's rather a matter of taste. * Installing Jupyter on your own machine @@ -122,12 +125,12 @@ This being said, you may have noticed that Jupyter keeps a perfect track of the sequence in which cells have been run by updating the "output index". This is a very good property from the reproducibility point of view but depending on your usage, you may find it a bit -painful when commiting. Some people have thus developped [[https://gist.github.com/pbugnion/ea2797393033b54674af][specific git -hooks]] to ignore these numbers when comitting Jupyter notebooks. There +painful when committing. Some people have thus developed [[https://gist.github.com/pbugnion/ea2797393033b54674af][specific git +hooks]] to ignore these numbers when committing Jupyter notebooks. There is a long an interesting discussion about various options on [[https://stackoverflow.com/questions/18734739/using-ipython-notebooks-under-version-control][StackOverflow]]. -Last but not least, remembter that Jupyter notebooks are only a small +Last but not least, remember that Jupyter notebooks are only a small part of the picture and that Jupyter is now part of a bigger project: [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows you to mix various components (including notebooks) in your browser. A specific [[https://github.com/jupyterlab/jupyterlab-git][JupyterLab git plugin]] has been
