diff --git a/module1/ressources/sequence4.org b/module1/ressources/sequence4.org new file mode 100644 index 0000000000000000000000000000000000000000..912b2d7380f04ff3371c722d11f003c65c2d0a8c --- /dev/null +++ b/module1/ressources/sequence4.org @@ -0,0 +1,58 @@ +#+OPTIONS: ':nil *:t -:t ::t <:t H:3 \n:nil ^:t arch:headline +#+OPTIONS: author:t broken-links:nil c:nil creator:nil +#+OPTIONS: d:(not "LOGBOOK") date:t e:t email:nil f:t inline:t num:t +#+OPTIONS: p:nil pri:nil prop:nil stat:t tags:t tasks:t tex:t +#+OPTIONS: timestamp:t title:t toc:t todo:t |:t +#+TITLE: Notes (and codes) that are archived but can evolve with version control systems +#+AUTHOR: Christophe Pouzat +#+EMAIL: christophe.pouzat@parisdescartes.fr +#+LANGUAGE: en +#+SELECT_TAGS: export +#+EXCLUDE_TAGS: noexport +#+CREATOR: Emacs 26.1 (Org mode 9.1.9) +#+STARTUP: indent + +* Table of contents :TOC: +- [[Version control with GitLab and Git]] +- [[Version control with =LibreOffice= or DokuWiki]] + +* Version control with GitLab and Git +We have created a GitLab server especially for this MOOC so that you can smoothly learn how to implement version control. +This section describes the successive steps involved. The following [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/5571950188c946e790f06d4bc90fb5f6][video]] shows how to use GitLab. We strongly recommend that you watch it if you've never used GitLab before. + +- Go to [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/5571950188c946e790f06d4bc90fb5f6][GitLab]] from the FUN platform (click on *Accédez à + Gitlab / Access to Gitlab*) +- You reach the following form : + #+BEGIN_CENTER + [[file:gitlab_images/sign_in.png]] + #+END_CENTER + - NB : You must reach GitLab from the FUN platform. You are likely to get a "405 error" if you are using the following address: https://app-learninglab.inria.fr/gitlab/users/sign_in. + #+BEGIN_CENTER + [[file:gitlab_images/erreur405.png]] + #+END_CENTER +- Click on **Sign in**. Authentication is automatic at that stage. + #+BEGIN_CENTER + [[file:gitlab_images/projects.png]] + #+END_CENTER + + The long string replaced here by =xxx= is the login you will have to use in Git to synchronize with GitLab. + +- To recover a predefined password you must use [[https://app-learninglab.inria.fr/jupyterhub/services/password][Gitlab + credentials retrieval tool]]. One gets then the login and password. + #+BEGIN_CENTER + [[file:gitlab_images/password_retrieval.png]] + #+END_CENTER + +- You can change this password in `Account / + Paramètres / Mot de passe`. We do not recommend doing it since that will block you from using the Jupyter notebooks of this MOOC. + #+BEGIN_CENTER + [[file:gitlab_images/password.png]] + #+END_CENTER + +If you want to go further, few tutorial videos are gathered in [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/7508aece244548349424dfd61ee3ba85][sequence "7. Installations, configurations, references" of module 2]] +of this MOOC. + +* Version control with =LibreOffice= or DokuWiki +Modification tracking in files generated and managed by =LibreOffice= is briefly described on the [[https://help.libreoffice.org/Common/Recording_Changes][wiki page]] of this software. A [[https://help.libreoffice.org/Common/Navigating_Changes][table of contents]] of the pages dedicated to this subject is available. + +For DoKuWiki, the best is to check the [[https://www.dokuwiki.org/start?id=dokuwiki][wiki]].
