@@ -34,13 +34,13 @@ Voici un aperçu rapide de la syntaxe Markdown repris d'une
<ahref="https://guides.github.com/features/mastering-markdown/">présentation de Github</a> ainsi que de celles d'<ahref="http://csrgxtu.github.io/2015/03/20/Writing-Mathematic-Fomulars-in-Markdown/">Archer Reilly</a> et de <ahref="http://www.statpower.net/Content/310/R%20Stuff/SampleMarkdown.html">James
<listyle="margin-bottom:0;"><ahref="org/journal.html#MissingReference">Common and step-by-step emacs shortcuts for our <i>reproducible research</i> configuration</a></li>
<listyle="margin-bottom:0;"><ahref="https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf">The official GNU emacs refcard</a></li>
@@ -316,9 +316,9 @@ cheat-sheats. Here is a selection in case it helps:
<listyle="margin-bottom:0;"><ahref="org/journal.html#MissingReference">Common and step-by-step org-mode shortcuts for our <i>reproducible research</i> configuration</a></li>
<listyle="margin-bottom:0;"><ahref="https://orgmode.org/worg/orgcard.html">The official org-mode refcard</a></li>
@@ -327,22 +327,22 @@ cheat-sheats. Here is a selection in case it helps:
<listyle="margin-bottom:0;"><ahref="https://github.com/dfeich/org-babel-examples">Many examples illustrating the use of different languages in org-mode</a></li>
@@ -374,13 +374,13 @@ you should follow the instructions from here:
The following <ahref="https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/">webpage</a> lists several Jupyter tricks (in particular, it
illustrates many <code>Ipython magic</code> commands) that should improve your
