diff --git a/module4/ressources/resources.html b/module4/ressources/resources.html index 9d397a651e98aa7d6b3228d6ac674494e8db9816..6e510c4f089ac8734880d52a30254b4d79ff2a71 100644 --- a/module4/ressources/resources.html +++ b/module4/ressources/resources.html @@ -3,25 +3,114 @@
Table of Contents
Getting information about Python(3) libraries
Getting information about your Git repository
+When taking notes, it may be difficult to remember which version of +the code or of a file was used. This is what version control is useful +for. Here are a few useful commands that we typically insert at the +top of our notebooks in shell cells +
git log -1
+commit 741b0088af5b40588493c23c46d6bab5d0adeb33
+Author: Arnaud Legrand <arnaud.legrand@imag.fr>
+Date:   Tue Sep 4 12:45:43 2018 +0200
+    Fix a few typos and provide information on jupyter-git plugins.
git status
+On branch master
+Your branch is ahead of 'origin/master' by 4 commits.
+  (use "git push" to publish your local commits)
+Changes not staged for commit:
+  (use "git add <file>..." to update what will be committed)
+  (use "git checkout -- <file>..." to discard changes in working directory)
+	modified:   resources.org
+Untracked files:
+  (use "git add <file>..." to include in what will be committed)
+	../../module2/ressources/replicable_article/IEEEtran.bst
+	../../module2/ressources/replicable_article/IEEEtran.cls
+	../../module2/ressources/replicable_article/article.bbl
+	../../module2/ressources/replicable_article/article.tex
+	../../module2/ressources/replicable_article/data.csv
+	../../module2/ressources/replicable_article/figure.pdf
+	../../module2/ressources/replicable_article/logo.png
+	.#resources.org
+no changes added to commit (use "git add" and/or "git commit -a")
+Then, I often include commands at the end of my notebook indicating +how to commit the results (adding the new files, committing with a +clear message and pushing). E.g., +
git add resources.org;
+git commit -m "Completing the section on getting Git information"
+git push
+[master 514fe2c1 ] Completing the section on getting Git information
+ 1 file changed, 61 insertions(+)
+Counting objects: 25, done.
+Delta compression using up to 4 threads.
+Compressing objects: 100% (20/20), done.
+Writing objects: 100% (25/25), 7.31 KiB | 499.00 KiB/s, done.
+Total 25 (delta 11), reused 0 (delta 0)
+To ssh://app-learninglab.inria.fr:9418/learning-lab/mooc-rr-ressources.git
+   6359f8c..1f8a567  master -> master
+Obviously, in this case you need to save the notebook before running +this cell, hence the output of this final command (with the new git +hash) will not be stored in the cell. This is not really a problem and +is the price to pay for running git from within the notebook itself. +
Getting the list of installed packages and their version
How to list imported modules?
Inspiring from StackOverflow, here is a simple function that lists loaded package (that have a __version__ attribute, which is @@ -147,9 +236,9 @@ zlib 1.0
Setting up an environment with pip
The easiest way to go is as follows:
@@ -167,9 +256,9 @@ dynamic libraries that are wrapped by Python.
Getting information about R libraries
The best way seems to be to rely on the devtools package.
