- [[https://gitlab.com/c_pouzat/etudes-de-cas-m1/blob/master/TriDesPA][Enregistrements extracellulaires et le tri des potentiel d'action : supports de cours et les codes associés]], Christophe Pouzat (github @c_pouzat). [[https://gitlab.com/c_pouzat/etudes-de-cas-m1/blob/master/TriDesPA/Pouzat_TriDesPA_20190128.pdf][Pdf]]
- [[https://gitlab.com/c_pouzat/etudes-de-cas-m1/blob/master/FluoCalcium][Mesures de concentrations calciques au moyen de sondes fluorescentes : supports de cours et les codes associés]], Christophe Pouzat (gitlab @c_pouzat)[[https://gitlab.com/c_pouzat/etudes-de-cas-m1/blob/master/FluoCalcium/Pouzat_FluoCalcium_20180309.pdf][Pdf]]
supports de cours et les codes associés]] ([[https://gitlab.com/c_pouzat/etudes-de-cas-m1/blob/master/TriDesPA/Pouzat_TriDesPA_20190128.pdf][Pdf]]), Christophe Pouzat (github @c_pouzat)
- [[https://github.com/christophe-pouzat/YRLS2017][YRLS2017: R for statistics and reproducible research in the life sciences]], Christophe Pouzat (github @christophe-pouzat). [[http://htmlpreview.github.io/?https://github.com/christophe-pouzat/YRLS2017/blob/master/Pouzat_YRLS_RR_20170516.html][Html]]
fluorescentes : supports de cours et les codes associés]] ([[https://gitlab.com/c_pouzat/etudes-de-cas-m1/blob/master/FluoCalcium/Pouzat_FluoCalcium_20180309.pdf][Pdf]]), Christophe
- [[https://gitlab.com/c_pouzat/etudes-de-cas-m1/blob/master/TriDesPA/Pouzat_TriDesPA_20190128.org][Enregistrements extracellulaires et le tri des potentiel d'action : supports de cours et les codes associés]], Christophe Pouzat (github @c_pouzat). [[https://gitlab.com/c_pouzat/etudes-de-cas-m1/blob/master/TriDesPA/Pouzat_TriDesPA_20190128.pdf][Pdf]]
- [[https://gitlab.com/c_pouzat/etudes-de-cas-m1/blob/master/FluoCalcium/Pouzat_FluoCalcium_20180309.org][Mesures de concentrations calciques au moyen de sondes fluorescentes : supports de cours et les codes associés]], Christophe Pouzat (gitlab @c_pouzat)[[https://gitlab.com/c_pouzat/etudes-de-cas-m1/blob/master/FluoCalcium/Pouzat_FluoCalcium_20180309.pdf][Pdf]]
- [[https://github.com/jkitchin/dft-book][Un livre de chimie théorique écrit en Org-Mode]], John Kitchin (github @jkitchin). [[https://github.com/jkitchin/dft-book/raw/master/dft.pdf][Pdf version of the book]]
- [[https://plmlab.math.cnrs.fr/xtof/interacting_neurons_with_stp/blob/master/interacting_neurons_with_stp.org][A system of interacting neurons with short term plasticity]], (org avec du C, gnuplot, shell) Christophe Pouzat. [[https://plmlab.math.cnrs.fr/xtof/interacting_neurons_with_stp/blob/master/interacting_neurons_with_stp.Pdf][Pdf]]
- [[https://github.com/jkitchin/dft-book][Un livre de chimie théorique écrit en Org-Mode]] ([[https://github.com/jkitchin/dft-book/raw/master/dft.pdf][Pdf version of the book]]), John Kitchin (github @jkitchin).
avec du C, gnuplot, shell) ([[https://plmlab.math.cnrs.fr/xtof/interacting_neurons_with_stp/blob/master/interacting_neurons_with_stp.Pdf][Pdf]]), Christophe Pouzat
- [[https://hal.archives-ouvertes.fr/hal-01224765][Supplementary Material for: Homogeneity and identity tests for unidimensional Poisson processes with an application to neurophysiological peri-stimulus time histograms--R version]], (org
avec R) Christophe Pouzat. [[https://hal.archives-ouvertes.fr/hal-01224765/document][Pdf]]
avec R), ([[https://hal.archives-ouvertes.fr/hal-01224765/document][Pdf]]), Christophe Pouzat
- [[https://hal.archives-ouvertes.fr/hal-01224764][Supplementary Material for: Homogeneity and identity tests for unidimensional Poisson processes with an application to neurophysiological peri-stimulus time histograms--Python version]],
(org avec Python, mais les mêmes calculs que le précédent),
(org avec Python, mais les mêmes calculs que le précédent),([[https://hal.archives-ouvertes.fr/hal-01224764/document][Pdf]]), Christophe Pouzat
- [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/tree/master/module2/ressources/sequence6_examples][Les documents montrés en exemple dans les vidéos du MOOC]]
