diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index a244b4b771d0c554ba4f42b077af08ccefd51319..28ebe3bfc30e4ccf146e8e43f36cdb3f86f3818e 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -146,22 +146,20 @@ this up but if you have any trouble, feel free to ask on the FUN forums. ** A stub of replicable article Remember, you need a working LaTeX and R environment. If you can't -open a terminal and run the commands =R= and =pdflatex=, you will not be -able to generate this document. The article downloads the +open a terminal and run the commands =R=, =pdflatex=, and =python=, you will not be +able to generate this document. When being compiled, the article downloads the corresponding LaTeX packages so you also need to have a working =wget= -command (alternatively, you can use =curl=). You may still read the +command (alternatively, it uses =curl=). Once downloaded, you may still read the source ([[file:replicable_article/article.org][article.org]]) and understand how it works though. #+begin_src shell :results output :exports none -make -C replicable_article/ replicable_article.tgz +make -C replicable_article/ all replicable_article.tgz #+end_src #+RESULTS: -: make : on entre dans le répertoire « /home/alegrand/Work/Documents/Enseignements/RR_MOOC/references/module2/replicable_article » -: tar --xform "s|^|replicable_article/|" -zcf replicable_article.tgz article.org biblio.bib Makefile -: make : on quitte le répertoire « /home/alegrand/Work/Documents/Enseignements/RR_MOOC/references/module2/replicable_article » +Download the following [[file:replicable_article/replicable_article.tgz][archive]] and untar it. -Download the [[file:replicable_article/replicable_article.tgz][archive]], untar it and simply make to generate the + and simply =make= to generate the article. You should then be able to open the [[file:replicable_article/article.pdf][resulting article]]. This is summarized in the following command: #+begin_src sh :results output :exports both
