diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index 24804073b797f11403e82fd1ed97be66a228c017..4cdb0978ae17b95da43919b17edb438d3a033ad0 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -188,7 +188,22 @@ Copy =rr_org/init.el= in your =~/.emacs.d/= directory. Alternatively, if you do not want to mess with your already existing emacs configuration, you may launch emacs with this specific configuration with the following command: =emacs -q -l rr_org/init.el=. -** Step 3: Check whether the installation is working or not +** Step 3: Adapt the configuration to your specific needs if required +There are two situations in which it might be necessary to modify +=init.el=: +1. Your network environment forces you to use a proxy for access + to Web sites (HTTP(S) protocol). +2. You have multiple installations of Python or R on your computer, + or they are in unusual places and not fully configured. + If you can run + - "python3" and "R" under Linux and macOS + - "Python" and "R" under Windows + in a terminal without getting an error message, then you should + not have to do anything. + +If you do have to modify =init.el=, check the comments at the +beginning of the file for instructions. +** Step 4: Check whether the installation is working or not Open a new instance of Emacs and open a =foo.org= file. Copy the following lines in this file: : #+begin_src shell :session foo :results output :exports both @@ -206,7 +221,7 @@ In the video, we already have demonstrated the main features and shortcuts of emacs/org-mode that will help you maintain a document and benefit from literate programming. The list of features and shortcuts is demonstrated in the [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][first entry of your labbook]]. -** Step 4: Open and play with your journal: +** Step 5: Open and play with your journal: In step 1, you were told to create an journal in =~org/journal.org=. First you probably want to make sure this file is backed up in a revision control system like git. We leave it up to you
