diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index 3f7a04ee5f85ab4bc950134f4757a34946bc3f6b..3feae860bfed0b67d7c8c7ea55c7a681b4aa3503 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -4,6 +4,12 @@ #+DATE: June, 2018 #+STARTUP: overview indent #+OPTIONS: num:nil toc:t +#+PROPERTY: header-args :eval never-export + +*Disclaimer:* The two sections _A simple "/reproducible research/" +emacs configuration_ and _A stub of replicable article_ explain how to +set up org-mode for this MOOC. *You really should follow them +carefully or you may have trouble doing the exercices later on*. * Installing emacs, org-mode, ess, and auctex. ** OS-specific installation procedure @@ -71,7 +77,11 @@ versions: - Emacs 26.1 - Org-mode 9.1.13 - ESS 17.11 -** A simple "/reproducible research/" emacs configuration +** TODO A simple "/reproducible research/" emacs configuration +#+BEGIN_QUOTE +There will be a mini video illustrating these steps at some point +#+END_QUOTE + Emacs comes with very basic default configuration and it appears like everyone has its own taste. You will for example find [[https://www.emacswiki.org/emacs/StarterKits][here]] several default Emacs configurations that reflect the preferences of their @@ -144,7 +154,11 @@ In step 1, you were told to create an journal in backed up in a revision control system like git. We leave it up to set this up but if you have any trouble, feel free to ask on the FUN forums. -** A stub of replicable article +** TODO A stub of replicable article +#+BEGIN_QUOTE +There will be a mini video illustrating these steps at some point +#+END_QUOTE + Remember, you need a working LaTeX and R environment. If you can't open a terminal and run the commands =R=, =pdflatex=, and =python=, you will not be able to generate this document. When being compiled, the article downloads the
