Commit aac09faf authored by Konrad Hinsen's avatar Konrad Hinsen
Add explanation for machine-specific configuration of Python and R
parent c53385ce
;; Machine-dependent configuration - adapt as required for your computer!
;; If a full path to the interpreter is used, be careful it if contains spaces
;; (which seems to be typical for Windows and not rare for macOS). The path
;; must then be surrounded by backslash-escaped quotation marks, as in
;; (setq org-babel-python-command "\"C:/Program Files/Python/Python37/python.exe\"")
(setq org-babel-python-command "python3")
;; For Unix-like systems, this can be normally left commented out. Under Windows,
;; insert the path to your R interpreter.
;; (setq inferior-R-program-name "C:/Program Files/R/R-3.5.1/bin/x64/Rterm.exe")
(require 'org) (require 'org)
(setq inhibit-splash-screen t) (setq inhibit-splash-screen t)
...@@ -154,8 +166,6 @@ Entered on %U ...@@ -154,8 +166,6 @@ Entered on %U
(setq org-src-preserve-indentation t) (setq org-src-preserve-indentation t)
(add-to-list 'org-structure-template-alist (add-to-list 'org-structure-template-alist
'("s" "#+begin_src ?\n\n#+end_src" "<src lang=\"?\">\n\n</src>")) '("s" "#+begin_src ?\n\n#+end_src" "<src lang=\"?\">\n\n</src>"))
...@@ -18,6 +18,29 @@ to work, you'll need: ...@@ -18,6 +18,29 @@ to work, you'll need:
Backup you own =.emacs= if you have one and replace it with [[file:init.el][the content Backup you own =.emacs= if you have one and replace it with [[file:init.el][the content
of this file]]. If you ever want to regenerate if from this org of this file]]. If you ever want to regenerate if from this org
document, simply =M-x org-babel-tangle=. document, simply =M-x org-babel-tangle=.
* Machine-dependent configuration
For Linux, macOS, and other Unix-like systems, the following settings will probably work fine. If you use Windows, or if running Python and/or R code from OrgMode fails with an error message, please replace "python3" by the full path to your Python interpreter.
#+begin_src emacs-lisp :tangle init.el
** Python
*** We use python3
** R
* Loading files: * Loading files:
** Loading babel: :ARNAUD: ** Loading babel: :ARNAUD:
#+begin_src emacs-lisp :tangle init.el #+begin_src emacs-lisp :tangle init.el
...@@ -280,11 +303,6 @@ Additional shortcuts for navigating through org-mode documents: ...@@ -280,11 +303,6 @@ Additional shortcuts for navigating through org-mode documents:
#+end_src #+end_src
** Python
*** We use python3
** Adding source code blocks: :LUKA: ** Adding source code blocks: :LUKA:
*** With capital letters: *** With capital letters:
To use this type <s and then TAB To use this type <s and then TAB
