diff --git a/module2/ressources/gitlab.org b/module2/ressources/gitlab.org index 47100e30a433ccc0db3a6f46eb8a3cc211d88b15..9206597784c00ab13e8f61e4b4dacafa744c36e2 100644 --- a/module2/ressources/gitlab.org +++ b/module2/ressources/gitlab.org @@ -82,7 +82,10 @@ The =proxyPassword= will be stored in plain text (unencrypted) in your ~.gitconf which you may not want. In that case, remove it from the URL and you will be prompted for it every time it is needed. ** Getting your default password on GitLab (and possibly changing it) -*Warning (Jupyter users) :* changing your default Gitlab password will prevent you from committing in Jupyter. You will have to do the extra step of changing your Jupyter =~/.git-credentials= +*Warning (Jupyter users) :* changing your default Gitlab password will +prevent you from committing in Jupyter. You will have to do the extra +step of changing your =~/.git-credentials= in the Jupyter environment +(possibly several times). 1. Get your default password using the [[https://app-learninglab.inria.fr/jupyterhub/services/password][Gitlab credentials retrieval tool]] as described on the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/7508aece244548349424dfd61ee3ba85][corresponding resource]]. @@ -114,13 +117,13 @@ will be prompted for it every time it is needed. #+BEGIN_CENTER [[file:gitlab_images/signin.png]] #+END_CENTER -4. If you wish to modify your password, you shoul go to =Account > Settings > Password= +4. If you wish to modify your password, you should go to =Account > Settings > Password= and define your password using the default password you just retrieved. Again, if you use the Jupyter notebooks we have deployed for the MOOC, remember that changing your default Gitlab password will prevent you from committing in Jupyter. You will have to do the extra step of changing your - Jupyter =~/.git-credentials= through a jupyter console (see next + Jupyter =~/.git-credentials= through a Jupyter console (see next section). #+BEGIN_CENTER [[file:gitlab_images/password.png]]
