diff --git a/module1/ressources/gitlab_interface.org b/module1/ressources/gitlab_interface.org index 457945b905f6dfdc8795770e4ac98dc84a66e8be..cd6b75140def938441081121e5b7ae3a4e438cec 100644 --- a/module1/ressources/gitlab_interface.org +++ b/module1/ressources/gitlab_interface.org @@ -30,9 +30,9 @@ button "*Accéder à Gitlab / Access to Gitlab*". [[file:gitlab_images/projects.png]] #+END_CENTER - The long string replaced here by =xxx= is the login you will have to use in Git to synchronize with GitLab. - - *NB* : You must reach GitLab from the FUN platform. You are likely to get a "405 error" if you are using the following address: https://app-learninglab.inria.fr/gitlab/users/sign_in. + The long string replaced here by =xxx= is the login you will have to + use in Git to synchronize with GitLab. +- *NB* : You must reach GitLab from the FUN platform. You are likely to get a "405 error" if you are using the following address: https://app-learninglab.inria.fr/gitlab/users/sign_in. #+BEGIN_CENTER [[file:gitlab_images/erreur405.png]] @@ -56,3 +56,11 @@ To recover a predefined password you must use [[https://app-learninglab.inria.fr ** To go learn more about git/Gitlab If you want to go further, few tutorial videos are gathered in [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+self-paced/jump_to_id/7508aece244548349424dfd61ee3ba85][sequence "7. Installations, configurations, references" of module 2]] of this MOOC. +** In case of problems with Gitlab +In case of problem, contact us via the forum. In order to help you +solve any problems, please give us your LTI identifier (external +identifier automatically assigned for GitLab and Jupyter) +that you can find on your GitLab account (see capture below). +#+BEGIN_CENTER + [[File:gitlab_images/gitlab_id_lti.jpg]] +#+END_CENTER diff --git a/module1/ressources/gitlab_interface_fr.org b/module1/ressources/gitlab_interface_fr.org index 021d2e0a5e5a01a7f1462cac710efc9d6f1c3c17..c0dead43f70d092b0efc1177f573bc3d96705ce7 100644 --- a/module1/ressources/gitlab_interface_fr.org +++ b/module1/ressources/gitlab_interface_fr.org @@ -30,8 +30,7 @@ plateforme FUN après avoir cliqué sur le bouton "*Accéder à Gitlab / Access La grande chaîne de caractères remplacée ici par =xxx= est le login qu'il faudra utiliser dans Git pour accéder à Gitlab. - -*NB* : Il faut accéder à Gitlab depuis la plateforme FUN. Vous risquez +- *NB* : Il faut accéder à Gitlab depuis la plateforme FUN. Vous risquez d'obtenir une erreur 405 en accédant directement à la page https://app-learninglab.inria.fr/gitlab/users/sign_in. #+BEGIN_CENTER [[file:gitlab_images/erreur405.png]] @@ -41,9 +40,10 @@ plateforme FUN après avoir cliqué sur le bouton "*Accéder à Gitlab / Access Pour récupérer le mot de passe prédéfini, il faut utiliser le [[https://app-learninglab.inria.fr/jupyterhub/services/password][Gitlab credentials retrieval tool]]. On retrouve alors le login et le mot de passe. - #+BEGIN_CENTER - [[file:gitlab_images/password_retrieval.png]] - #+END_CENTER + +#+BEGIN_CENTER +[[file:gitlab_images/password_retrieval.png]] +#+END_CENTER ** Modifier son mot de passe Il est possible de modifier ce mot de passe dans "Account / Paramètres / Mot de passe". Mais nous vous déconseillons de le faire @@ -58,3 +58,13 @@ sur l'outil de gestion de version git sur lequel s'appuie GitLab, quelques vidéos de démonstration sur git et Gitlab sont proposées dans la [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+self-paced/jump_to_id/7508aece244548349424dfd61ee3ba85][séquence "7. Installations, configurations, references" du module 2] de ce Mooc ainsi que des ressources pour apprivoiser git en ligne de commandes. + +** Que faire en cas de problème +En cas de problème, contactez-nous via le forum. Afin de pouvoir vous +aider à résoudre vos problèmes éventuels, +merci de nous communiquer votre identifiant LTI (identifiant externe +attribué automatiquement pour GitLab et Jupyter) que vous pouvez +retrouvez sur votre compte GitLab (cf capture ci-dessous). +#+BEGIN_CENTER + [[File:gitlab_images/gitlab_id_lti.jpg]] +#+END_CENTER
