diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index 491044aa692db5f7c7320967727e4912d6f34c9e..d905a9e0a483dc471cdad0655c69d5c45d20904b 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -17,18 +17,18 @@ the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id The next section provides information on how to install emacs. * Table of Contents :TOC: -- [[#installing-emacs-org-mode-ess-and-auctex][Installing emacs, org-mode, ess, and auctex.]] +- [[#installing-emacs][Installing Emacs]] - [[#linux-debian-ubuntu][Linux (Debian, Ubuntu)]] - [[#macos][macOS]] - [[#windows][Windows]] - - [[#all-platforms-pretty-code-in-html-export][All platforms: pretty code in HTML export]] - [[#a-simple-reproducible-research-emacs-configuration][A simple "reproducible research" emacs configuration]] - - [[#step-0-backup-and-download-our-configuration][Step 0: Backup and download our configuration]] - - [[#step-1-prepare-your-journal][Step 1: Prepare your journal]] - - [[#step-2-set-up-emacs-configuration][Step 2: Set up Emacs configuration]] - - [[#step-3-adapt-the-configuration-to-your-specific-needs-if-required][Step 3: Adapt the configuration to your specific needs if required]] - - [[#step-4-check-whether-the-installation-is-working-or-not][Step 4: Check whether the installation is working or not]] - - [[#step-5-open-and-play-with-your-journal][Step 5: Open and play with your journal:]] + - [[#step-0-backup-and-remove-your-previous-configuration][Step 0: Backup and remove your previous configuration]] + - [[#step-1-download-our-configuration][Step 1: Download our configuration]] + - [[#step-2-prepare-your-journal][Step 2: Prepare your journal]] + - [[#step-3-put-the-emacs-configuration-file-in-the-right-place][Step 3: Put the Emacs configuration file in the right place]] + - [[#step-4-adapt-the-configuration-to-your-specific-needs-if-required][Step 4: Adapt the configuration to your specific needs if required]] + - [[#step-5-check-whether-the-installation-is-working-or-not][Step 5: Check whether the installation is working or not]] + - [[#step-6-open-and-play-with-your-journal][Step 6: Open and play with your journal:]] - [[#a-stub-of-a-replicable-article][A stub of a replicable article]] - [[#emacs-tips-and-tricks][Emacs tips and tricks]] - [[#cheat-sheets][Cheat-sheets]]
