Commit b91dd673 authored by Arnaud Legrand's avatar Arnaud Legrand
Regenerate HTML. Please propagate to FUN.
parent bf361766
...@@ -4,26 +4,27 @@ ...@@ -4,26 +4,27 @@
<h2>Table of Contents</h2> <h2>Table of Contents</h2>
<div id="text-table-of-contents"> <div id="text-table-of-contents">
<ul style="margin:0 0;"> <ul style="margin:0 0;">
<li style="margin-bottom:0;"><a href="#org0b4fddb">1. Jupyter tips and tricks</a> <li style="margin-bottom:0;"><a href="#orgd37ebcc">1. Jupyter tips and tricks</a>
<li style="margin-bottom:0;"><a href="#orgfa26619">Running R and Python in the same notebook</a></li> <li style="margin-bottom:0;"><a href="#orge426487">Creating or importing a notebook</a></li>
<li style="margin-bottom:0;"><a href="#org6905b1c">Other languages</a></li> <li style="margin-bottom:0;"><a href="#org6607533">Running R and Python in the same notebook</a></li>
<li style="margin-bottom:0;"><a href="#orgd909163">Other languages</a></li>
</ul> </ul>
</li> </li>
<li style="margin-bottom:0;"><a href="#org71d8232">2. Installing and configuring Jupyter on your computer</a> <li style="margin-bottom:0;"><a href="#org9176019">2. Installing and configuring Jupyter on your computer</a>
<li style="margin-bottom:0;"><a href="#org080a19d">2.1 Installing Jupyter</a></li> <li style="margin-bottom:0;"><a href="#org51b3378">2.1 Installing Jupyter</a></li>
<li style="margin-bottom:0;"><a href="#org74a2cde">2.2 Making sure Jupyter allows you to use R</a> <li style="margin-bottom:0;"><a href="#orgc0d2a71">2.2 Making sure Jupyter allows you to use R</a>
<li style="margin-bottom:0;"><a href="#orgb3f32d9">• Installing IRKernel (R package)</a></li> <li style="margin-bottom:0;"><a href="#org608c96e">• Installing IRKernel (R package)</a></li>
<li style="margin-bottom:0;"><a href="#org4157978">• Installing rpy2 (Python package)</a></li> <li style="margin-bottom:0;"><a href="#org076acd5">• Installing rpy2 (Python package)</a></li>
</ul> </ul>
</li> </li>
<li style="margin-bottom:0;"><a href="#org3c0a58e">2.3 Additional tips</a> <li style="margin-bottom:0;"><a href="#org524a8ac">2.3 Additional tips</a>
<li style="margin-bottom:0;"><a href="#org847c6d1">• Exporting a notebook</a></li> <li style="margin-bottom:0;"><a href="#org814c076">• Exporting a notebook</a></li>
<li style="margin-bottom:0;"><a href="#org581d99c">• Improving notebook readability</a></li> <li style="margin-bottom:0;"><a href="#orga5ae744">• Improving notebook readability</a></li>
<li style="margin-bottom:0;"><a href="#org3ec1745">• Interacting with GitLab and GitHub</a></li> <li style="margin-bottom:0;"><a href="#orgab0846a">• Interacting with GitLab and GitHub</a></li>
</ul> </ul>
</li> </li>
</ul> </ul>
...@@ -32,9 +33,9 @@ ...@@ -32,9 +33,9 @@
</div> </div>
</div> </div>
<div id="outline-container-org0b4fddb" class="outline-2"> <div id="outline-container-orgd37ebcc" class="outline-2">
<h2 id="org0b4fddb">1. Jupyter tips and tricks</h2> <h2 id="orgd37ebcc">1. Jupyter tips and tricks</h2>
<div class="outline-text-2" id="text-org0b4fddb"> <div class="outline-text-2" id="text-orgd37ebcc">
<p> <p>
The following <a href="https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/">webpage</a> lists several Jupyter tricks (in particular, it The following <a href="https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/">webpage</a> lists several Jupyter tricks (in particular, it
illustrates many <code>IPython magic</code> commands) that should improve your illustrates many <code>IPython magic</code> commands) that should improve your
...@@ -43,9 +44,57 @@ the tricks may have been integrated in the default behavior of Jupyter ...@@ -43,9 +44,57 @@ the tricks may have been integrated in the default behavior of Jupyter
now). now).
</p> </p>
</div> </div>
<div id="outline-container-orgfa26619" class="outline-3"> <div id="outline-container-orge426487" class="outline-3">
<h3 id="orgfa26619">Running R and Python in the same notebook</h3> <h3 id="orge426487">Creating or importing a notebook</h3>
<div class="outline-text-3" id="text-orgfa26619"> <div class="outline-text-3" id="text-orge426487">
<p>
Using the Jupyter environment we deployed for this MOOC will allow to
easily access any file from your default GitLab project. There are
situations however where you may want to play with other notebooks.
</p>
<dl class="org-dl">
<dt>Adding a brand new notebook in a given directory</dt><dd>Simply follow
the following steps:
<ol class="org-ol">
<li style="margin-bottom:0;">From the menu: <code>File -&gt; Open</code>. You're now in the Jupyter file manager.</li>
<li style="margin-bottom:0;">Navigate to the directory where you want your notebook to be created.</li>
<li style="margin-bottom:0;">Then from the top right button: <code>New -&gt; Notebook: Python 3</code>.</li>
<li style="margin-bottom:0;"><p>
Give your notebook a name from the menu: <code>File -&gt; Rename</code>.
</p>
<p>
N.B.: If you create a file by doing <code>File -&gt; New Notebook -&gt;
Python 3</code>, the new notebook will be created in the current
directory. Moving it afterward is possible but a bit cumbersome
(you'll have to go through the Jupyter file manager by following
the menu <code>File -&gt; Open</code>, then select it, <code>Shut</code> it <code>down</code>, and <code>Move</code>
and/or <code>Rename</code>).
</p></li>
</ol></dd>
<dt>Importing an already existing notebook</dt><dd>If your notebook is
already in your GitLab project, then simply synchronize by using
the <code>Git pull</code> button and use the <code>File -&gt; Open</code> menu. Otherwise,
imagine, you want to import the <a href="https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/blob/master/src/Python3/challenger.ipynb">following notebook</a> from someone
else's repository to re-execute it.
<ol class="org-ol">
<li style="margin-bottom:0;">Download the file on your computer. E.g., for this <a href="https://app-learninglab.inria.fr/gitlab/moocrr-session1/moocrr-reproducibility-study/blob/master/src/Python3/challenger.ipynb">GitLab hosted
notebook</a>, click on <code>Open raw</code> (a small <code>&lt;/&gt;</code> within a document icon)
and save (<code>Ctrl-S</code> on most browsers) the content (a long Json text
file).</li>
<li style="margin-bottom:0;">Open the Jupyter file manager from the menu <code>File -&gt; Open</code> and
navigate to the directory where you want to upload your notebook.</li>
<li style="margin-bottom:0;">Then from the top right button, <code>Upload</code> the previously downloaded
notebook and confirm the upload.</li>
<li style="margin-bottom:0;">Open the freshly uploaded notebook through the Jupyter file
manager.</li>
</ol></dd>
</dl>
</div>
</div>
<div id="outline-container-org6607533" class="outline-3">
<h3 id="org6607533">Running R and Python in the same notebook</h3>
<div class="outline-text-3" id="text-org6607533">
<p> <p>
<code>rpy2</code> package allows to use both languages in the same notebook by: <code>rpy2</code> package allows to use both languages in the same notebook by:
</p> </p>
...@@ -82,9 +131,9 @@ python cell. ...@@ -82,9 +131,9 @@ python cell.
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-org6905b1c" class="outline-3"> <div id="outline-container-orgd909163" class="outline-3">
<h3 id="org6905b1c">Other languages</h3> <h3 id="orgd909163">Other languages</h3>
<div class="outline-text-3" id="text-org6905b1c"> <div class="outline-text-3" id="text-orgd909163">
<p> <p>
Jupyter is not limited to Pytyhon and R. Many other languages are available: Jupyter is not limited to Pytyhon and R. Many other languages are available:
<a href="https://github.com/jupyter/jupyter/wiki/Jupyter-kernels">https://github.com/jupyter/jupyter/wiki/Jupyter-kernels</a>, including <a href="https://github.com/jupyter/jupyter/wiki/Jupyter-kernels">https://github.com/jupyter/jupyter/wiki/Jupyter-kernels</a>, including
...@@ -114,9 +163,9 @@ and environment control will certainly help anyway. ...@@ -114,9 +163,9 @@ and environment control will certainly help anyway.
</div> </div>
</div> </div>
<div id="outline-container-org71d8232" class="outline-2"> <div id="outline-container-org9176019" class="outline-2">
<h2 id="org71d8232">2. Installing and configuring Jupyter on your computer</h2> <h2 id="org9176019">2. Installing and configuring Jupyter on your computer</h2>
<div class="outline-text-2" id="text-org71d8232"> <div class="outline-text-2" id="text-org9176019">
<p> <p>
In this section, we explain how to set up a Jupyter environment on In this section, we explain how to set up a Jupyter environment on
your own computer similar to the one deployed for this MOOC. your own computer similar to the one deployed for this MOOC.
...@@ -131,9 +180,9 @@ benefit from JupyterLab which was still under active development. You may, howev ...@@ -131,9 +180,9 @@ benefit from JupyterLab which was still under active development. You may, howev
</p> </p>
</div> </div>
<div id="outline-container-org080a19d" class="outline-3"> <div id="outline-container-org51b3378" class="outline-3">
<h3 id="org080a19d">2.1 Installing Jupyter</h3> <h3 id="org51b3378">2.1 Installing Jupyter</h3>
<div class="outline-text-3" id="text-org080a19d"> <div class="outline-text-3" id="text-org51b3378">
<p> <p>
Follow these instructions if you wish to have a Jupyter environment on Follow these instructions if you wish to have a Jupyter environment on
your own computer similar to the one we set up for this MOOC. your own computer similar to the one we set up for this MOOC.
...@@ -166,18 +215,18 @@ jupyter notebook ...@@ -166,18 +215,18 @@ jupyter notebook
</div> </div>
</div> </div>
</div> </div>
<div id="outline-container-org74a2cde" class="outline-3"> <div id="outline-container-orgc0d2a71" class="outline-3">
<h3 id="org74a2cde">2.2 Making sure Jupyter allows you to use R</h3> <h3 id="orgc0d2a71">2.2 Making sure Jupyter allows you to use R</h3>
<div class="outline-text-3" id="text-org74a2cde"> <div class="outline-text-3" id="text-orgc0d2a71">
<p> <p>
The environment described in the last section should include R, but if The environment described in the last section should include R, but if
you proceeded otherwise and only have Python available in Jupyter, you you proceeded otherwise and only have Python available in Jupyter, you
may want to read the following section. may want to read the following section.
</p> </p>
</div> </div>
<div id="outline-container-orgb3f32d9" class="outline-4"> <div id="outline-container-org608c96e" class="outline-4">
<h4 id="orgb3f32d9">• Installing <a href="https://github.com/IRkernel/IRkernel">IRKernel</a> (R package)</h4> <h4 id="org608c96e">• Installing <a href="https://github.com/IRkernel/IRkernel">IRKernel</a> (R package)</h4>
<div class="outline-text-4" id="text-orgb3f32d9"> <div class="outline-text-4" id="text-org608c96e">
<p> <p>
Do the following in R console: Do the following in R console:
</p> </p>
...@@ -213,9 +262,9 @@ IRkernel::installspec() <span style="font-weight: bold; font-style: italic;"># ...@@ -213,9 +262,9 @@ IRkernel::installspec() <span style="font-weight: bold; font-style: italic;">#
</div> </div>
</div> </div>
<div id="outline-container-org4157978" class="outline-4"> <div id="outline-container-org076acd5" class="outline-4">
<h4 id="org4157978">• Installing rpy2 (Python package)</h4> <h4 id="org076acd5">• Installing rpy2 (Python package)</h4>
<div class="outline-text-4" id="text-org4157978"> <div class="outline-text-4" id="text-org076acd5">
<p> <p>
On Linux, the rpy2 package is available in standard distributions On Linux, the rpy2 package is available in standard distributions
</p> </p>
...@@ -258,13 +307,13 @@ Install also <code>tzlocal</code>: ...@@ -258,13 +307,13 @@ Install also <code>tzlocal</code>:
</div> </div>
</div> </div>
</div> </div>
<div id="outline-container-org3c0a58e" class="outline-3"> <div id="outline-container-org524a8ac" class="outline-3">
<h3 id="org3c0a58e">2.3 Additional tips</h3> <h3 id="org524a8ac">2.3 Additional tips</h3>
<div class="outline-text-3" id="text-org3c0a58e"> <div class="outline-text-3" id="text-org524a8ac">
</div> </div>
<div id="outline-container-org847c6d1" class="outline-4"> <div id="outline-container-org814c076" class="outline-4">
<h4 id="org847c6d1">• Exporting a notebook</h4> <h4 id="org814c076">• Exporting a notebook</h4>
<div class="outline-text-4" id="text-org847c6d1"> <div class="outline-text-4" id="text-org814c076">
<p> <p>
Here is what we had to install on a recent Debian computer to make sure Here is what we had to install on a recent Debian computer to make sure
the notebook export via LaTeX works: the notebook export via LaTeX works:
...@@ -309,9 +358,9 @@ packages when exporting to pdf. ...@@ -309,9 +358,9 @@ packages when exporting to pdf.
</div> </div>
</div> </div>
<div id="outline-container-org581d99c" class="outline-4"> <div id="outline-container-orga5ae744" class="outline-4">
<h4 id="org581d99c">• Improving notebook readability</h4> <h4 id="orga5ae744">• Improving notebook readability</h4>
<div class="outline-text-4" id="text-org581d99c"> <div class="outline-text-4" id="text-orga5ae744">
<p> <p>
Here are a few extensions that can ease your life: Here are a few extensions that can ease your life:
</p> </p>
...@@ -338,9 +387,9 @@ jupyter-serverextension enable --py hide_code ...@@ -338,9 +387,9 @@ jupyter-serverextension enable --py hide_code
</div> </div>
</div> </div>
<div id="outline-container-org3ec1745" class="outline-4"> <div id="outline-container-orgab0846a" class="outline-4">
<h4 id="org3ec1745">• Interacting with GitLab and GitHub</h4> <h4 id="orgab0846a">• Interacting with GitLab and GitHub</h4>
<div class="outline-text-4" id="text-org3ec1745"> <div class="outline-text-4" id="text-orgab0846a">
<p> <p>
To ease your experience, we added pull/push buttons that allow To ease your experience, we added pull/push buttons that allow
you to commit and sync with GitLab. This development was specific to you to commit and sync with GitLab. This development was specific to
