diff --git a/module2/ressources/replicable_article/article.org b/module2/ressources/replicable_article/article.org index ce122bd2c6579dd5a33a0250900b082e9b53e722..7c793856c4a47ba0f0a797b3ab7c8a685c550f0a 100644 --- a/module2/ressources/replicable_article/article.org +++ b/module2/ressources/replicable_article/article.org @@ -97,37 +97,38 @@ echo 'file:measurements.txt' * Extracting traces from data files :noexport: -#+begin_src perl :results output raw :exports both :var input="measurements.txt" output="data.csv" -use strict; -open INPUT, $input; -open OUTPUT, "> $output"; - -my($line); -my($size); -my($seq,$par,$libc); - -print OUTPUT "Size, Seq, Par, Libc\n" ; -while($line=) { - chomp $line; - if($line =~/^Size: ([\d\.]*)$/) { - $size = $1; - next; - } - if($line =~/^Sequential quicksort.*: ([\d\.]*) sec.$/) { - $seq=$1; next; - } - if($line =~/^Parallel quicksort.*: ([\d\.]*) sec.$/) { - $par=$1; next; - } - if($line =~/^Built-in quicksort.*: ([\d\.]*) sec.$/) { - $libc=$1; - print OUTPUT "$size, $seq, $par, $libc\n"; - next; - } -} -print "file:$output" +#+begin_src python :results output raw :exports both :var input="measurements.txt" output="data.csv" +import re,sys + +INPUT = open(input, "r") +OUTPUT = open(output, "w") + +OUTPUT.writelines("Size, Seq, Par, Libc\n") + +for line in INPUT.readlines(): + m = re.match('^Size: ([\d\.]*)$',line) + if(m): + size = m.group(1) + continue + m = re.match('^Sequential quicksort.*: ([\d\.]*) sec.$',line) + if(m): + seq = m.group(1) + continue + m = re.match('^Parallel quicksort.*: ([\d\.]*) sec.$',line) + if(m): + par = m.group(1) + continue + m = re.match('^Built-in quicksort.*: ([\d\.]*) sec.$',line) + if(m): + libc = m.group(1) + OUTPUT.writelines(size+", "+seq+", "+par+", "+libc+"\n") + +print "[[file:"+output+"]]" #+end_src +#+RESULTS: +[[file:data.csv]] + * R functions :noexport: Initialization and reading of the data. #+begin_src R :results output :session *R* :exports both @@ -248,7 +249,7 @@ our own experimental testbed with support of our university. # Local Variables: # eval: (add-to-list 'load-path ".") # eval: (require 'org-install) -# eval: (org-babel-do-load-languages 'org-babel-load-languages '((shell . t) (R . t) (perl . t) (python . t) )) +# eval: (org-babel-do-load-languages 'org-babel-load-languages '((shell . t) (R . t) (python . t) )) # eval: (setq org-confirm-babel-evaluate nil) # eval: (unless (boundp 'org-latex-classes) (setq org-latex-classes nil)) # eval: (add-to-list 'org-latex-classes '("IEEEtran"
