diff --git a/module2/ressources/gitlab.org b/module2/ressources/gitlab.org index d5e1038c6468bda2027161ca65841f052d6e7286..56f9fc047e79222c2c61c7924827aa51160b23af 100644 --- a/module2/ressources/gitlab.org +++ b/module2/ressources/gitlab.org @@ -81,24 +81,32 @@ git config --global http.proxy http://proxyUsername:proxyPassword@proxy.server.c The proxyPassword will be stored unencrypted in your ~.gitconfig~ file, which you may not want. In that case, remove it from the URL and you will be prompted for it every time it is needed. -** Changing the default password on GitLab - +** Getting and changing the default password on GitLab *Warning (Jupyter users) :* changing your default Gitlab password will prevent you from commiting in Jupyter. You will have to do the extra step of changing your Jupyter =~/.git-credentials= -1. Get your default password using the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/7508aece244548349424dfd61ee3ba85][Gitlab credentials retrieval tool]]. -2. Access [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/xblock/block-v1:inria+41016+session01bis+type@lti+block@05a0ce425f1741e5bee5049040f70529/handler/preview_handler][GitLab]]. /Note: You have to access Gitlab from the FUN - platform otherwise you may get a 405 error/ /when trying to direcly - open https://app-learninglab.inria.fr/gitlab/users/sign_in/. +1. Get your default password using the [[https://app-learninglab.inria.fr/jupyterhub/services/password][Gitlab credentials retrieval + tool]] as described on the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/7508aece244548349424dfd61ee3ba85][corresponding resource]]. + + /Note: You have to access this webpage from the FUN platform + otherwise you may get a 405 error/ /when trying to direcly open + [[https://app-learninglab.inria.fr/jupyterhub/services/password]]./ #+BEGIN_CENTER [[file:gitlab_images/erreur405.png]] #+END_CENTER +2. Access [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/xblock/block-v1:inria+41016+session01bis+type@lti+block@05a0ce425f1741e5bee5049040f70529/handler/preview_handler][GitLab]]. + + /Note: Again, you have to access Gitlab from the FUN platform + otherwise you may get a 405 error/ /when trying to direcly open + https://app-learninglab.inria.fr/gitlab/users/sign_in/. 3. Click on =Sign in:= or using your default credentials #+BEGIN_CENTER [[file:gitlab_images/signin.png]] #+END_CENTER - The long and uggly character sequence, which is here replaced by =xxx= - is your GitLab login/id. You'll need to use it when trying to - propagate some modifications from your computer to GitLab. + The long and uggly character sequence, which is here replaced by + =xxx= is your GitLab login/id (it is the same as the one you obtained + from Gitlab credentials retrieval tool). You'll need to use it when + trying to propagate some modifications from your computer to + GitLab. 4. Go to =Account > Settings > Password= and define your password using your default password : #+BEGIN_CENTER [[file:gitlab_images/password.png]]
