From c2a72bebf732cf903bc88bbd6e66950a0a84bbb0 Mon Sep 17 00:00:00 2001 From: Konrad Hinsen Date: Fri, 24 Aug 2018 17:54:43 +0200 Subject: [PATCH] Always use a named session for shell commands under Windows --- module2/ressources/rr_org/init.el | 9 +++++++-- module2/ressources/rr_org/init.org | 9 +++++++-- 2 files changed, 14 insertions(+), 4 deletions(-) diff --git a/module2/ressources/rr_org/init.el b/module2/ressources/rr_org/init.el index 12a552d..01b7586 100644 --- a/module2/ressources/rr_org/init.el +++ b/module2/ressources/rr_org/init.el @@ -232,8 +232,13 @@ Entered on %U (add-to-list 'org-structure-template-alist '("PP" "#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file \"figure\" \".png\") :exports both\nimport matplotlib.pyplot as plt\n\nimport numpy\nx=numpy.linspace(-15,15)\nplt.figure(figsize=(10,5))\nplt.plot(x,numpy.cos(x)/x)\nplt.tight_layout()\n\nplt.savefig(matplot_lib_filename)\nmatplot_lib_filename\n#+end_src" "\n\n")) -(add-to-list 'org-structure-template-alist - '("b" "#+begin_src shell :results output :exports both\n\n#+end_src" "\n\n")) +(if (memq system-type '(windows-nt ms-dos)) + ;; Non-session shell execution does not seem to work under Windows, so we use + ;; a named session just like for B. + (add-to-list 'org-structure-template-alist + '("b" "#+begin_src shell :session session :results output :exports both\n\n#+end_src" "\n\n")) + (add-to-list 'org-structure-template-alist + '("b" "#+begin_src shell :results output :exports both\n\n#+end_src" "\n\n"))) (add-to-list 'org-structure-template-alist '("B" "#+begin_src shell :session *shell* :results output :exports both \n\n#+end_src" "\n\n")) diff --git a/module2/ressources/rr_org/init.org b/module2/ressources/rr_org/init.org index 3e94a68..60c3c6d 100644 --- a/module2/ressources/rr_org/init.org +++ b/module2/ressources/rr_org/init.org @@ -395,8 +395,13 @@ To use this type
\n\n")) +(if (memq system-type '(windows-nt ms-dos)) + ;; Non-session shell execution does not seem to work under Windows, so we use + ;; a named session just like for B. + (add-to-list 'org-structure-template-alist + '("b" "#+begin_src shell :session session :results output :exports both\n\n#+end_src" "\n\n")) + (add-to-list 'org-structure-template-alist + '("b" "#+begin_src shell :results output :exports both\n\n#+end_src" "\n\n"))) #+end_src To use this type
