diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index 6617d5f17cec15ada7d844679e554771da4dd551..24804073b797f11403e82fd1ed97be66a228c017 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -55,26 +55,41 @@ emacs -batch --funcall "org-version" 2>&1 | grep version The version numbers you get will depend on the distribution you are running. _You really want to make sure you do not rely on org-mode 8_, which is now deprecated. -** Mac OS X +** macOS +*Note:* macOS comes with a prehistoric command-line-only version of Emacs located at /usr/bin/emacs. It's best to forget about it. + - *Option 1*: Install the =.dmg= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]: https://vigou3.github.io/emacs-modified-macos/. It ships with recent versions: - Emacs 26.1 - Org-mode 9.1.13 - ESS 17.11 - In that case you may have several versions of emacs installed on - your machine and launching emacs from a terminal may not run the one - you just installed. If anyone know how to get rid of this... -- *Option 2*: If you already use =brew=, simply do the following + + If you install this version of Emacs, or in fact any other version of + Emacs distributed as a clickable application in a =.dmg= file, + you must type the full path to the executable if you want to run + Emacs from a terminal. For example, if your clickable application + is at =/Applications/Emacs.app=, then the executable is at + =/Applications/Emacs.app/Contents/MacOS/Emacs= + +- *Option 2*: If you use [[https://docs.brew.sh/][Homebrew]], do the following: #+begin_src sh :results output :exports both brew update - brew install emacs [--with-cocoa] + brew install emacs --with-cocoa brew linkapps emacs - brew tap homebrew/science - brew install ess - brew install auctex # The name may be slightly more complicated here brew install wget + brew tap dunn/emacs + brew install auctex + brew tap brewsci/science + brew install ess + #+end_src + This provides an =emacs= command for use from the command line, plus a clickable application at =Cellar/emacs/26.1_1/Emacs.app= inside your Homebrew directory. If + you installed Homebrew at the default location =/usr/local=, then this is =/usr/local/Cellar/emacs/26.1_1/Emacs.app=. + If you installed Homebrew on an account with administrator privileges, you can add + #+begin_src sh :results output :exports both + brew linkapps emacs #+end_src + in order to make Emacs accessible directly from =/Applications=. ** Windows Install the =.exe= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]: https://vigou3.github.io/emacs-modified-windows/. It ships with recent
