diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index 07cdd33d8c6e4574bfd6306b6bf108fe551faa50..63d5189b46ed66bff51d89686b1459104be5c0e8 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -94,7 +94,7 @@ The Web site https://emacsformacosx.com/ proposes precompiled Emacs versions for If you like working in a terminal (the =Terminal.app= from macOS, or an enhanced one such as [[https://iterm2.com/][iTerm2]]), the standard macOS way of opening a file in Emacs is =open -a Emacs.app /path/to/my/file.txt=. This will launch Emacs, unless it is already running, and then ask Emacs to open the file. Note that this is different from the Unix/Linux way of running Emacs, which is what you see in the videos. Under Linux, you type =emacs /path/to/my/file.txt= in the terminal, which always starts a fresh copy of Emacs. *** Advanced topics - not required for following the MOOC -For advanced uses of Emacs, such as calling Emacs from a Makefile to automate document processing, you have to adopt the Unix way also under macOS, because this is the only way to provide parameters other than filenames. However, you have to enter the full path to the executable. Assuming that you have copied =Emacs.app= to =/path/to/emacs=, this is =/path/to/emacs/Emacs.app/Contents/MacOS/Emacs=. If you just type =emacs=, you will use the prehistoric command-line-only version at =/usr/bin/emacs= provided by Apple. You can of course make the Emacs executable more easily accessible using a shell alias, or by putting =/path/to/emacs/Emacs.app/Contents/MacOS/= on your =$PATH=. See the [[https://www.gnu.org/software/bash/manual/bashref.html][bash manual]] for details and explanation. +For advanced uses of Emacs, such as calling Emacs from a Makefile to automate document processing, you have to adopt the Unix way also under macOS, because this is the only way to provide parameters other than filenames. However, you have to enter the full path to the executable. Assuming that you have copied =Emacs.app= to =/path/to/emacs=, this is =/path/to/emacs/Emacs.app/Contents/MacOS/Emacs=. If you just type =emacs=, you will use the prehistoric command-line-only version at =/usr/bin/emacs= provided by Apple. You can of course make the Emacs executable more easily accessible using a shell alias, or by putting =/path/to/emacs/Emacs.app/Contents/MacOS/= on your =$PATH= in your =~/.bashrc= ou =~/.bash_profile=. See the [[https://www.gnu.org/software/bash/manual/bashref.html][bash manual]] for details and explanation. Be aware that running Emacs the Unix way implies some subtle differences compared to running Emacs the macOS way. In particular, Emacs will inherit the shell's environment variables when run the Unix way, but the user session's environment variables when run the macOS way. ** Windows @@ -148,7 +148,7 @@ to make it =backend : Agg=. * Python, R, and LaTeX Computational documents contain code, which in the case of our MOOC use the languages Python and R. So you must install Python and R in addition to Emacs, unless of course they are already installed on your computer. Since Python and R are also used in the other paths of our MOOC, we explain their installation in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/19c2b1de7766484bae73f3ab133463c6][separate resource]]. -That same resource also explains how to install LaTeX, which you must have if you want to produce PDF versions of org-mode documents. For example, if you want to work with the replicable article stub (shown in [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][this video]]), you must install LaTeX. However, it is a rather big piece of software (several GB), so you may prefer to skip its installation. It is not required to follow the MOOC. +That same resource also explains how to install LaTeX, which you must have if you want to produce PDF versions of org-mode documents. For example, if you want to work with the replicable article stub (shown in [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4#tuto3][the video "Write a replicable article with Emacs/Org-mode"]]), you must install LaTeX. However, it is a rather big piece of software (several GB), so you may prefer to skip its installation. It is not required to follow the MOOC. * A simple "reproducible research" emacs configuration This section is illustrated in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][video tutorial]] (/"Mise en place @@ -286,8 +286,7 @@ stored in a version control system like git. We leave it up to you to set this up but if you have any trouble, feel free to ask on the MOOC forum. * A stub of a replicable article -This section is illustrated in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][video tutorial]] (/"Écrire un article -réplicable avec Emacs/Orgmode"/ in French). Watching it before +This section is illustrated in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4#tuto3][video tutorial]] (/"Write a replicable article with Emacs/Org-mode"/). Watching it before following the instructions given in this section may help. To work with this article stub, you need working installations of LaTeX, R, and Python. If you can't open a terminal and run the commands =R=, =pdflatex=, and =python3=, you will not be able to generate this document. When being compiled, the article downloads the corresponding LaTeX packages, so you must have a working network connection. @@ -374,7 +373,7 @@ The following method has been tested with Windows and worked like a charm: NB: =M-= corresponds to the == key and =RET= corresponds to the == key. ** Other resources -- [[https://orgmode.org/orgguide.pdf][The compact Org-mode Guide]] +- The compact Org-mode Guide ([[https://orgmode.org/orgguide.pdf][pdf file]]) - A huge resource of emacs/org-mode magic is Bernt Hansen's «[[http://doc.norang.ca/org-mode.html][Organize your life in plain text]]», whose source is obviously itself an [[http://doc.norang.ca/org-mode.org][org-mode document]]. diff --git a/module2/ressources/emacs_orgmode_fr.org b/module2/ressources/emacs_orgmode_fr.org index 171406e46dd90456fc8d6dda7b171c94804dc01f..01963b59a99b908859d16c14bc19575ccd678d00 100644 --- a/module2/ressources/emacs_orgmode_fr.org +++ b/module2/ressources/emacs_orgmode_fr.org @@ -10,8 +10,8 @@ machine et recense un certain nombre d'autres références utiles sur cet environnement. *Attention:* Les sections [[#une-configuration-emacs-adaptée-à-la-recherche-reproductible][Une configuration Emacs adaptée à la -"recherche reproductible"]], et [[#un-mod%C3%A8le-darticle-r%C3%A9plicable][Un modèle d'article réplicable]] -expliquent comment configure Emacs/Org-Mode pour ce MOOC. Ce sont donc +"recherche reproductible"]] et [[#un-mod%C3%A8le-darticle-r%C3%A9plicable][Un modèle d'article réplicable]] +expliquent comment configurer Emacs/Org-Mode pour ce MOOC. Ce sont donc des sections très *importantes* qui sont *illustrées dans [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][deux des trois tutoriels vidéo de cette page]]*. *Nous vous encourageons vivement à suivre attentivement ces sections* *et ces vidéos avant de vous lancer @@ -57,11 +57,11 @@ distributions de type Debian (Ubuntu par exemple). N'hésitez pas à contribuer à ce document pour partager des informations à jour pour d'autres distributions (redhat, fedora, ...). -Voici les version d'Emacs fournies par différentes distributions: +Voici les versions d'Emacs fournies par différentes distributions: - Debian (stretch) fourni [[https://packages.debian.org/stretch/emacs25][emacs 25.1]] et [[https://packages.debian.org/stretch/org-mode][org-mode 9.0.3]] - Ubuntu (bionic 18.04) fourni [[https://packages.ubuntu.com/bionic/emacs25][emacs 25.2]] et [[https://packages.ubuntu.com/bionic/org-mode][org-mode 9.1.6]] - Ubuntu (artful 17.04) fourni [[https://packages.ubuntu.com/artful/emacs25][emacs 25.2]] et [[https://packages.ubuntu.com/artful/org-mode][org-mode 9.0.9]] -Si votre distribution est plus anciennes que celles-ci, et bien... c'est peut-être le bon moment pour faire une mise à jour. +Si votre distribution est plus ancienne que celles-ci, et bien... c'est peut-être le bon moment pour faire une mise à jour. En tant que root, tapez les commandes suivantes: #+begin_src sh :results output :exports both @@ -93,10 +93,10 @@ complètement obsolète. Le site Web https://emacsformacosx.com/ propose des versions pré-compilées d'Emacs pour macOS. Téléchargez la dernière version (celle dont le numéro apparaît en gros sur la page d'accueil) et installez le de la même façon que n'importe quelle autre application macOS, en copiant =Emacs.app= de la zone de téléchargement vers le répertoire de votre choix sur votre ordinateur. -Si vous aimez travailler avec un terminal (le =Terminal.app= de macOS ou bien une version plus évoluée comme [[https://iterm2.com/][iTerm2]]), la façon standard sous macOS d'ouvrir emacs dans un terminal consiste à taper la commande =open -a Emacs.app /path/to/my/file.txt=. Cela lancera Emacs, à moins qu'il ne soit déjà ouvert, et demandera à Emacs d'ouvrir le fichier =file.txt=. Avec cette approche, il n'y a qu'une seule instance d'Emacs en cours d'exécution. C'est donc légèrement différent de la méthode Unix/Linux qui est illustrée dans les vidéos et où on tape =emacs /path/to/my/file.txt= in the terminal, ce qui conduit à l'ouverture d'un nouvel emacs à chaque fois. +Si vous aimez travailler avec un terminal (le =Terminal.app= de macOS ou bien une version plus évoluée comme [[https://iterm2.com/][iTerm2]]), la façon standard sous macOS d'ouvrir emacs dans un terminal consiste à taper la commande =open -a Emacs.app /path/to/my/file.txt=. Cela lancera Emacs, à moins qu'il ne soit déjà ouvert, et demandera à Emacs d'ouvrir le fichier =file.txt=. Avec cette approche, il n'y a qu'une seule instance d'Emacs en cours d'exécution. C'est donc légèrement différent de la méthode Unix/Linux qui est illustrée dans les vidéos et où on tape =emacs /path/to/my/file.txt= dans le terminal, ce qui conduit à l'ouverture d'un nouvel emacs à chaque fois. *** Sujets avancés - non requis pour suivre le MOOC -Pour les utilisations avancées d'Emacs, comme appeler Emacs à partir d'un Makefile pour automatiser le traitement de documents, il vous faudra adopter l'approche Unix également sous macOS car c'est le seul moyen de fournir des paramètres autres que des noms de fichiers. Il vous faudra alors également spécifier le chemin complet de l'exécutable. En effet, si vous tapez simplement =emacs=, vous utiliserez la version préhistorique en ligne de commande uniquement de =/usr/bin/emacs= fournie par Apple. En supposant que vous avez copié =Emacs.app= vers =/path/to/emacs=, l'exécutable =Emacs= sera situé dans =/path/to/emacs/Emacs.app/Contents/MacOS/Emacs=. Vous pouvez bien sûr rendre l'exécutable Emacs plus facilement accessible en utilisant un =alias= shell, ou en mettant =/path/to/emacs/Emacs.app/Contents/MacOS/= dans votre =$PATH=, par exemple en écrivant =export PATH=/path/to/emacs/Emacs.app/Contents/MacOS/:$PATH= dans votre =~/.bashrc=. Voir le [[https://www.gnu.org/software/bash/manual/bashref.html][bash manual]] pour plus de détails et explications. +Pour les utilisations avancées d'Emacs, comme appeler Emacs à partir d'un Makefile pour automatiser le traitement de documents, il vous faudra adopter l'approche Unix également sous macOS car c'est le seul moyen de fournir des paramètres autres que des noms de fichiers. Il vous faudra alors également spécifier le chemin complet de l'exécutable. En effet, si vous tapez simplement =emacs=, vous utiliserez la version préhistorique en ligne de commande uniquement de =/usr/bin/emacs= fournie par Apple. En supposant que vous avez copié =Emacs.app= vers =/path/to/emacs=, l'exécutable =Emacs= sera situé dans =/path/to/emacs/Emacs.app/Contents/MacOS/Emacs=. Vous pouvez bien sûr rendre l'exécutable Emacs plus facilement accessible en utilisant un =alias= shell, ou en mettant =/path/to/emacs/Emacs.app/Contents/MacOS/= dans votre =$PATH=, par exemple en écrivant =export PATH=/path/to/emacs/Emacs.app/Contents/MacOS/:$PATH= dans votre =~/.bashrc= ou =~/.bash_profile=. Voir le [[https://www.gnu.org/software/bash/manual/bashref.html][bash manual]] pour plus de détails et explications. Notez bien que l'exécution d'Emacs à la mode Unix implique quelques différences subtiles par rapport à l'exécution d'Emacs à la mode MacOS. En particulier, Emacs héritera des variables d'environnement du shell lorsqu'il est lancé à la mode Unix, alors qu'il héritera des variables d'environnement de la session utilisateur lorsqu'il est lancé à la mode MacOS. @@ -120,7 +120,7 @@ cela signifie que nous faisons référence à =C:\Users\yourname\org= (respectiv *** Gestion des archives Plus loin dans ce document, il vous sera demandé de télécharger de petites archives contenant des fichiers ([[file:rr_org_archive.tgz][rr_org_archive.tgz]] et [[file:réplicable_article.tgz][réplicable_article.tgz]]). Pour décompresser ces archives sur votre ordinateur, vous pouvez utiliser le programme =7z=. Dans ce cas, vous devrez probablement décompresser chaque fichier deux fois.... La première fois, =archive.tgz= sera décompressé dans =archive.tar= et la deuxième fois =archive.tar= créera un répertoire =archive/= comprenant tous les fichiers de l'archive originale. *** Rendre R et Python disponible dans une console -Lors de l'exécution d'une commande, Windows recherchera l'exécutable dans les répertoires indiqués dans la variable d'environnement =PATH=. Si aucun des +Lors de l'exécution d'une commande, Windows recherchera l'exécutable dans les répertoires indiqués dans la variable d'environnement =PATH=. Si aucun de ces répertoires ne contient la commande, Windows s'arrêtera et indiquera que la commande n'existe pas. Pour s'assurer que R (qui peut être dans quelque chose comme =C:/Program Files/R/R-3.5.1/bin/x64/=) et Python (qui peut être dans quelque chose comme =C:/Program Files/Python/Python/Python37/=) puissent @@ -147,10 +147,10 @@ Ouvrez le fichier =matplotlibrc=, localisez la ligne commençant par =backend= e * Python, R et LaTeX Les documents computationnels contiennent du code, et en particulier dans le cas de notre MOOC du code utilisant les langages Python et R. Vous devrez donc installer Python et R en plus d'Emacs, sauf s'ils sont déjà installés sur votre ordinateur. Puisque Python et R sont aussi utilisés dans les autres parcours de notre MOOC, nous expliquons leur installation dans une [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/19c2b1de7766484bae73f3ab133463c6][ressource séparée]]. -Cette même ressource explique également comment installer LaTeX, dont vous devrez disposer si vous voulez produire des versions PDF de documents org-mode. Par exemple, si vous voulez travailler avec modèle d'article réplicable (montré dans [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][cette vidéo]]), il vous faudra installer LaTeX. Cependant, comme il s'agit d'un logiciel assez volumineux (plusieurs Go), vous pouvez préférer ne pas l'installer. Ce n'est pas indispensable. +Cette même ressource explique également comment installer LaTeX, dont vous devrez disposer si vous voulez produire des versions PDF de documents org-mode. Par exemple, si vous voulez travailler avec modèle d'article réplicable (montré dans [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4#tuto3][la vidéo "écrire un article réplicable avec Emacs/Org-mode"]]), il vous faudra installer LaTeX. Cependant, comme il s'agit d'un logiciel assez volumineux (plusieurs Go), vous pouvez préférer ne pas l'installer. Ce n'est pas indispensable. * Une configuration Emacs adaptée à la "recherche reproductible" -Cette section est illustrée dans un [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][une vidéo de démonstration]] (/Mise en place en place Emacs/Orgmode/). Nous vous suggérons de la regarder avant de suivre les instructions données dans cette section. +Cette section est illustrée dans une [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][vidéo de démonstration]] (/Mise en place en place Emacs/Orgmode/). Nous vous suggérons de la regarder avant de suivre les instructions données dans cette section. Emacs s'installe avec une configuration par défaut très basique que chacun va donc vouloir personnaliser. Compte tenu de la flexibilité @@ -158,8 +158,7 @@ d'Emacs, sa configuration peut vite devenir assez complexe et pourrait même faire l'objet d'un paquet à part entière. Dans le contexte de ce MOOC, nous vous proposons une configuration relativement minimaliste orientée "/recherche reproductible/" avec Org-Mode. Si vous êtes peu -familier d'Emacs, nous vous recommandons fortement de l'utiliser et de -ne la modifier qu'aussi peu que possible. Il vous suffira de suivre +familier d'Emacs, nous vous recommandons fortement de l'utiliser et de la modifier le moins possible. Il vous suffira de suivre les instructions données dans cette section. Si vous êtes un utilisateur Emacs plus expérimenté, vous pouvez vous contenter de regarder nos instructions et de ne récupérer que les parties qui vous @@ -213,7 +212,7 @@ Si vous avez des problèmes avec cette archive, [[file:rr_org/][les fichiers don aurez besoin sont également disponibles ici]]. Vous allez vite réaliser que la configuration (=init.el= en emacs lisp) est assez difficile à suivre. C'est pourquoi nous le gérons via un fichier =init.org=, qui -bien plus lisble. C'est une astuce que vous voudrez peut-être aussi +bien plus lisible. C'est une astuce que vous voudrez peut-être aussi adopter (pour cela, modifiez le =init.org= et régénérez le =init.el= en /tanglant/ le fichier avec =M-x org-babel-tangle= comme expliqué dans les instructions au début de =init.org=). @@ -255,7 +254,7 @@ prendre un peu de temps parce qu'Emacs va télécharger quelques paquets supplé échouer pour diverses raisons (surcharge des serveurs de paquets, connexion trop lente, ...). Ces situations durent rarement bien longtemps. C'est pourquoi si cela arrive, nous vous recommandons de vous contenter de quittez Emacs (=C-x C-c=, c'est-à-dire =Ctrl + x= suivi de =Ctrl + c=) et -redémarrez-le. Au pire, répétez cette opération jusqu'à ce que vous n'obteniez plus d'erreurs au +redémarrez-le. Au pire, répétez cette opération jusqu'à ce que vous n'obteniez plus d'erreur au démarrage. Ensuite, créez un fichier =foo.org=. Copiez les lignes suivantes dans ce fichier : @@ -283,7 +282,7 @@ un système de contrôle de version comme git. Nous vous laissons la responsabilité de mettre tout ceci en place mais si vous avez des problèmes, n'hésitez pas à poser des questions sur le forum du MOOC. * Un modèle d'article réplicable -Cette section est illustrée dans une [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2388d2317ec7b037b4][vidéo]] (/"Écrire un article +Cette section est illustrée dans une [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4#tuto3][vidéo]] (/"Écrire un article réplicable avec Emacs/Orgmode"/). Nous vous suggérons de la regarder avant de suivre les instructions données dans cette section. Pour travailler avec ce modèle d'article, vous aurez besoin d'installations fonctionnelles de LaTeX, R, et Python. Si vous ne pouvez pas ouvrir un terminal et exécuter les commandes =R=, =pdflatex=, et =python3=, vous ne pourrez pas générer ce document. @@ -299,7 +298,7 @@ tar zcf replicable_article.tgz $FILE_LIST #+RESULTS: -Téléchargez l'[[file:replicable_article.tgz][archive]] suivante et décompressez la. L'archive contient l'article compilé, vous pouvez donc commencer par le consulter. +Téléchargez l'[[file:replicable_article.tgz][archive]] suivante et décompressez-la. L'archive contient l'article compilé, vous pouvez donc commencer par le consulter. Pour reconstruire l'article, supprimez =article.pdf=, ou renommez-le en autre chose. Sinon, la procédure de reconstruction vous indiquera simplement que l'article est déjà à jour. Tapez ensuite =make= pour tout construire à partir de zéro. Ouvrez l'article fraîchement construit =article.pdf= pour voir s'il a l'air correct. @@ -311,9 +310,9 @@ Si vous supprimez le =#= au début de la ligne qui indique un commentaire, org-m * Emacs trucs et astuces -** Pense-bête +** Pense-bêtes L'apprentissage d'Emacs et d'Org-Mode peut être difficile car il y a quantité de raccourcis clavier assez inhumaine. -On trouve donc de nombreuses pense-bêtes dont voici une sélection à toute fin utile : +On trouve donc de nombreux pense-bêtes dont voici une sélection à toute fin utile : *** Emacs - [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org][Notre liste des raccourcis Emacs les plus utiles dans le contexte de notre configuration emacs /recherche reproductible/.]] - [[https://www.gnu.org/software/emacs/refcards/pdf/fr-refcard.pdf][Le pense-bête officiel de GNU emacs]] @@ -366,8 +365,8 @@ La méthode suivante a été testée avec Windows et a fonctionné sans encombre NB : =M-= (Meta) correspond à la touche == et =RET= correspond à la touche ==. ** Autres ressources -- [[https://orgmode.org/orgguide.pdf][The compact Org-mode Guide]] -- Une source inépuisable de magie emacs/org-mode: le site web de Bernt Hansen "[[http://doc.norang.ca/org-mode.html][Organisez votre vie en plain text]]", dont les sources sont évidemment eux-mêmes un [[http://doc.norang.ca/org-mode.org][document org-mode]]. +- The compact Org-mode Guide ([[https://orgmode.org/orgguide.pdf][lien vers le pdf]]) +- Une source inépuisable de magie emacs/org-mode: le site web de Bernt Hansen "[[http://doc.norang.ca/org-mode.html][Organisez votre vie en texte brute]]", dont les sources sont évidemment eux-mêmes un [[http://doc.norang.ca/org-mode.org][document org-mode]]. - [[https://github.com/dfeich/org-babel-examples][De nombreux exemples illustrant l'utilisation de différents langages]]. diff --git a/module2/ressources/rr_org/journal.org b/module2/ressources/rr_org/journal.org index 4104ff1918f1b1e1ed5a64f035301b7edfd818f9..86835b7c23b4c1c2ccdccfa1f832b8c1a1098d25 100644 --- a/module2/ressources/rr_org/journal.org +++ b/module2/ressources/rr_org/journal.org @@ -22,7 +22,7 @@ These informations were gathered and first demonstrated in my [[https://github.c webinar on reproducible research: litterate programming]]. ***** Emacs shortcuts Here are a few convenient emacs shortcuts for those that have never -used emacs. In all of the emacs shortcuts, =C=Ctrl=, =M=Alt/Esc= and +used emacs. In all of the emacs shortcuts, =C=Ctrl=, =M=Alt/Esc or Cmd with MacOs= and =S=Shift=. Note that you may want to use two hours to follow the emacs tutorial (=C-h t=). In the configuration file CUA keys have been activated and allow you to use classical copy/paste (=C-c/C-v=)
