From cbf72ffbf2cf173da9196d93d2048da4b9aea303 Mon Sep 17 00:00:00 2001 From: FARHI Laurence Date: Thu, 28 Mar 2019 09:06:14 +0100 Subject: [PATCH] Liens dans la TOC --- module1/ressources/sequence3.org | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-) diff --git a/module1/ressources/sequence3.org b/module1/ressources/sequence3.org index 763a0fc..94754ab 100644 --- a/module1/ressources/sequence3.org +++ b/module1/ressources/sequence3.org @@ -13,9 +13,9 @@ #+STARTUP: indent * Table of contents :TOC: -- [[Text files and text editors]] -- [[The case of the =PDF= file opened with a text editor]] -- [[On TinyTex]] +- [[#text-files-and-text-editors][Text files and text editors]] +- [[#the-case-of-the-pdf-file-opened-with-a-text-editor][The case of the =PDF= file opened with a text editor]] +- [[#on-tinyTex][On TinyTex]] * Text files and text editors A more technical as well as less circular (!) definition of a text file can be found on the dedicated [[https://en.wikipedia.org/wiki/Text_file][Wikipedia article]]. For more details on text editors you can also check the [[https://en.wikipedia.org/wiki/Text_editor][corresponding Wikipedia page]]. -- 2.18.1
