Commit d01c3be2 authored by Arnaud Legrand's avatar Arnaud Legrand
This author command was broken anyway
Indeed, with this document class, the author command should be in the
preembule. So nervemind...
parent 22bc5b7c
...@@ -8,7 +8,7 @@ ...@@ -8,7 +8,7 @@
#+LANGUAGE: en #+LANGUAGE: en
#+OPTIONS: num:nil toc:t \n:nil @:t ::t |:t ^:nil -:t f:t *:t <:t #+OPTIONS: num:nil toc:t \n:nil @:t ::t |:t ^:nil -:t f:t *:t <:t
#+OPTIONS: TeX:t LaTeX:t skip:nil d:nil todo:t pri:nil tags:not-in-toc #+OPTIONS: TeX:t LaTeX:t skip:nil d:nil todo:t pri:nil tags:not-in-toc
#+OPTIONS: author:nil email:nil creator:nil timestamp:t #+OPTIONS: email:nil creator:nil timestamp:t
#+TAGS: noexport(n) deprecated(d) #+TAGS: noexport(n) deprecated(d)
#+EXPORT_SELECT_TAGS: export #+EXPORT_SELECT_TAGS: export
#+EXPORT_EXCLUDE_TAGS: noexport #+EXPORT_EXCLUDE_TAGS: noexport
...@@ -45,27 +45,6 @@ ...@@ -45,27 +45,6 @@
\sloppy \sloppy
#+END_EXPORT #+END_EXPORT
#+BEGIN_EXPORT latex
\title{Org Mode Template for an IEEE Conference Article}
%\subtitle{}
\author{%
\IEEEauthorblockN{%
John Doe\IEEEauthorrefmark{1},
John Smith\IEEEauthorrefmark{2},
Jane Doe\IEEEauthorrefmark{1},
}\smallskip
\IEEEauthorblockA{
\IEEEauthorrefmark{1}University of Middle-of-Nowhere; \url{firstname.lastname@mon.edu}}
\IEEEauthorblockA{
\IEEEauthorrefmark{2}Institute of Whatever; \url{firstname.lastname@smith.org}}
\maketitle
#+END_EXPORT
#+BEGIN_abstract #+BEGIN_abstract
Reproducible research has become increasingly important, just like Reproducible research has become increasingly important, just like
parallel architectures so we propose a novel experimental study of a parallel architectures so we propose a novel experimental study of a
