diff --git a/module2/exo5/exo5_python-en.org b/module2/exo5/exo5_python-en.org index 69bbe07c4f8ee03b8d2a33a7f15cf68bed7e6994..8c4c66a12d63e37a92945e5f12bc90e611c724cb 100644 --- a/module2/exo5/exo5_python-en.org +++ b/module2/exo5/exo5_python-en.org @@ -15,24 +15,24 @@ # #+PROPERTY: header-args :session :exports both On January 27, 1986, the day before the takeoff of the shuttle /Challenger/, had -held a three-hour teleconference between the -Morton Thiokol (manufacturer of one of the engines) and NASA. The +a three-hour teleconference was held between +Morton Thiokol (the manufacturer of one of the engines) and NASA. The discussion focused on the consequences of the temperature at take-off of 31°F (just below -0°C) on the success of the flight and in particular on the performance of the -O-rings used in motors. Indeed, no test +0°C) for the success of the flight and in particular on the performance of the +O-rings used in the engines. Indeed, no test had been performed at this temperature. -The following study therefore takes up some of the analyses carried out in this study -night and whose objective was to assess the potential influence of -the temperature and pressure to which the seals are subjected -O-rings on their probability of malfunction. To do this, we -have the results of the experiments carried out by the engineers -of NASA during the 6 years preceding the launch of the shuttle +The following study takes up some of the analyses carried out that +night with the objective of assessing the potential influence of +the temperature and pressure to which the O-rings are subjected +on their probability of malfunction. Our starting point is +the results of the experiments carried out by NASA engineers +during the six years preceding the launch of the shuttle Challenger. -* Data loading -So we start by loading this data: +* Loading the data +We start by loading this data: #+begin_src python :results value :session *python* :exports both import numpy as np import pandas as pd @@ -68,16 +68,15 @@ data 22 1/12/86 6 58 200 1 #+end_example -The data set shows us the date of the test, the number of joints +The data set shows us the date of each test, the number of O-rings (there are 6 on the main launcher), the temperature (in Fahrenheit) and pressure (in psi), and finally the -number of identified dysfunctions. +number of identified malfunctions. -* Graphical data inspection -Flights where no incidents are found that do not provide any information -on the influence of temperature or pressure on the -dysfunctions, we focus on experiences where in the -at least one seal was defective. +* Graphical inspection +Flights without incidents do not provide any information +on the influence of temperature or pressure on malfunction. +We thus focus on the experiments in which at least one O-ring was defective. #+begin_src python :results value :session *python* :exports both data = data[data.Malfunction>0] @@ -94,7 +93,7 @@ data : 20 10/30/85 6 75 200 2 : 22 1/12/86 6 58 200 1 -All right, we have a high temperature variability but +We have a high temperature variability but the pressure is almost always 200, which should simplify the analysis. @@ -114,17 +113,16 @@ print(matplot_lib_filename) #+RESULTS: [[file:freq_temp_python.png]] -At first sight, it's not obvious but good, let's try it anyway -to estimate the impact of temperature $t$ on the probability of -malfunctions of a seal. +At first glance, the dependence does not look very important, but let's try to +estimate the impact of temperature $t$ on the probability of O-ring malfunction. * Estimation of the temperature influence -Suppose that each of the 6 toroidal seals is damaged with the same -probability and independently of the others and that this probability does not -depends only on the temperature. If we note $p(t)$ this probability, the -number of joints $D$ malfunctioning when the flight is performed at -temperature $t$ follows a binomial law of parameter $n=6$ and +Suppose that each of the six O-rings is damaged with the same +probability and independently of the others and that this probability +depends only on the temperature. If $p(t)$ is this probability, the +number $D$ of malfunctioning O-rings during a flight at +temperature $t$ follows a binomial law with parameters $n=6$ and $p=p(t)$. To link $p(t)$ to $t$, we will therefore perform a logistic regression. @@ -166,9 +164,9 @@ and the standard error of this estimator is 0.122, in other words we cannot distinguish any particular impact and we must take our estimates with caution. -* Estimation of the probability of malfunctioning O-rings -The expected temperature on take-off day is 31°F. Let's try to -estimate the probability of malfunctioning O-rings at +* Estimation of the probability of O-ring malfunction +The expected temperature on the take-off day is 31°F. Let's try to +estimate the probability of O-ring malfunction at this temperature from the model we just built: #+begin_src python :results output file :var matplot_lib_filename="proba_estimate_python.png" :exports both :session *python* @@ -190,9 +188,7 @@ print(matplot_lib_filename) As expected from the initial data, the temperature has no significant impact on the probability of failure of the O-rings. It will be about 0.2, as in the tests -where we had a failure of at least one joint. Let's get back to the subject -to the set of initial data to estimate the probability of -failure of a seal: +where we had a failure of at least one joint. Let's get back to the initial dataset to estimate the probability of failure: #+begin_src python :results output :session *python* :exports both data = pd.read_csv("shuttle.csv") @@ -202,21 +198,20 @@ print(np.sum(data.Malfunction)/np.sum(data.Count)) #+RESULTS: : 0.06521739130434782 -This probability is therefore about $p=0.065$, knowing that there is -a primary seal a secondary seal on each of the three parts of the -launcher, the probability of failure of the two joints of a launcher -is $p^2 \approx 0.00425$. The probability of failure of one of the -so the thrower is $1-(1-p^2)^3 \approximately 1.2%$. It would really be -no luck.... Everything is under control, so the takeoff can have +This probability is thus about $p=0.065$. Knowing that there is +a primary and a secondary O-ring on each of the three parts of the +launcher, the probability of failure of both joints of a launcher +is $p^2 \approx 0.00425$. The probability of failure of any one of the +launchers is $1-(1-p^2)^3 \approximately 1.2%$. That would really be +bad luck.... Everything is under control, so the takeoff can happen tomorrow as planned. -Only the next day, the Challenger shuttle will explode and take away -with her seven crew members. Public opinion is -affected and in the subsequent investigation, the reliability of the -O-rings will be directly implicated. Beyond the problems -of internal communication at NASA, which have a lot to do with this -fiasco, the previous analysis includes (at least) a small -problem.... Can you find it? You are free to modify this -analysis and to look at this dataset from all angles in order to -to explain what's wrong. +But the next day, the Challenger shuttle exploded and took away +with her the seven crew members. The public was shocked and in +the subsequent investigation, the reliability of the +O-rings was questioned. Beyond the internal communication problems +of NASA, which have a lot to do with this fiasco, the previous analysis +includes (at least) a small problem.... Can you find it? +You are free to modify this analysis and to look at this dataset +from all angles in order to to explain what's wrong.
