From d7d9a6ddb9f32c2e77f2b5cac18f6b3f44db474e Mon Sep 17 00:00:00 2001 From: Arnaud Legrand Date: Tue, 4 Sep 2018 12:58:36 +0200 Subject: [PATCH] Add minor comments --- module4/ressources/resources.org | 11 +++++++++++ 1 file changed, 11 insertions(+) diff --git a/module4/ressources/resources.org b/module4/ressources/resources.org index 602c81e..6139e4f 100644 --- a/module4/ressources/resources.org +++ b/module4/ressources/resources.org @@ -68,8 +68,19 @@ git push #+BEGIN_EXAMPLE [master 514fe2c1 ] Completing the section on getting Git information 1 file changed, 61 insertions(+) +Counting objects: 25, done. +Delta compression using up to 4 threads. +Compressing objects: 100% (20/20), done. +Writing objects: 100% (25/25), 7.31 KiB | 499.00 KiB/s, done. +Total 25 (delta 11), reused 0 (delta 0) +To ssh://app-learninglab.inria.fr:9418/learning-lab/mooc-rr-ressources.git + 6359f8c..1f8a567 master -> master #+END_EXAMPLE +Obviously, in this case you need to save the notebook before running +this cell, hence the output of this final command (with the new git +hash) will not be stored in the cell. This is not really a problem and +is the price to pay for running git from within the notebook itself. * Getting information about Python(3) libraries ** Getting the list of installed packages and their version https://stackoverflow.com/questions/20180543/how-to-check-version-of-python-modules -- 2.18.1
