diff --git a/module2/ressources/jupyter.org b/module2/ressources/jupyter.org index d2ffb23a7f4f81c953165cebe0592c66de4c1017..d164c547bfca87ee4b75df445a262f40c45ffbf0 100644 --- a/module2/ressources/jupyter.org +++ b/module2/ressources/jupyter.org @@ -43,6 +43,20 @@ Then you'll be able to use both languages in the same notebook by: Note that this =%%R= notation allows you to use R for the whole cell but an other possibility is to use =%R= to have a single line of R within a python cell. + +*** Windows +Download =rpy2= [[https://www.lfd.uci.edu/~gohlke/pythonlibs/#rpy2][binary file]] by choosing the right operating system. + +Open a DOS console and type the following command: +#+begin_src shell :results output :exports both +python -m pip install rpy2‑2.9.4‑cp37‑cp37m‑win_amd64.whl # adapt filename +#+end_src + +Install also =tzlocal=: +#+begin_src shell :results output :exports both +python -m pip install tzlocal +#+end_src + ** Exporting a notebook Obviously, you can convert to html or pdf using the using the =File > Download as > HTML= (or =PDF=) menu option. This can also be done from the command line with the following command: @@ -81,7 +95,7 @@ source activate mooc_rr jupyter notebook #+end_src -** Side note about Jupyter, JupyterLab, JupyterHub, ... +** Side note about Jupyter, JupyterLab, JupyterHub... Note that Jupyter notebooks are only a small part of the picture and that Jupyter is now part of a bigger project: [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows you to mix various components (including notebooks) in your @@ -96,6 +110,11 @@ the notebook export via latex works: sudo apt-get install texlive-xetex wkhtmltopdf #+end_src +*** Windows +Download and install MiKTeX from the [[https://miktex.org/download][MiKTeX webpage]] +by choosing the right operating system. You will be prompted to install some specific +packages when exporting to pdf. + ** Jupyter extensions/plugins *** Improving notebook readability Here are a few extensions that can ease your life:
