Commit dcb86d05 authored by Konrad Hinsen's avatar Konrad Hinsen
Documentation plus complète pour configurer Emacs pour Anaconda
parent af506038
......@@ -244,12 +244,23 @@ There are two situations in which it might be necessary to modify
1. Your network environment forces you to use a proxy for access
to Web sites (HTTP(S) protocol).
2. You have multiple installations of Python or R on your computer,
or they are in unusual places and not fully configured.
If you can run
or they are in unusual places and not fully configured. *Note that this will be
the case if you followed our recommendation to use the Anaconda distribution.*
For diagnosing your installation, do the following:
1. Open a new terminal, and try to run the following commands:
- =python3= and =R= under Linux and macOS
- =Python= and =R= under Windows
in a terminal without getting an error message, then you should
not have to do anything.
If you get no error message, all is gine. You should
not have to do anything to access Python and R from Emacs.
2. If you got an error message, you will have to track down where exactly
you installed Python and/or R. What you have to insert into =init.el= is the
complete path to each executable. For example, if you have installed Anaconda
under =/opt=, and if you have installed Python and/or R in Anaconda's default
environment, then the paths are =/opt/anaconda3/bin/python3= and
=/opt/anaconda3/bin/R=. If they are installed in an environment called
=mooc_rr=, the paths are =/opt/anaconda3/envs/mooc_rr/bin/python3= and
=/opt/anaconda3/envs/mooc_rr/bin/R=.
If you do have to modify =init.el=, check the comments at the
beginning of the file for instructions.
......@@ -241,12 +241,14 @@ Créez le répertoire =~/.emacs.d/= et copiez =rr_org/init.el= dedans.
Il y a deux situations dans lesquelles il peut être nécessaire de modifier
=init.el= :
1. Votre environnement réseau vous oblige à utiliser un proxy accéder à internet (protocole HTTP(S)).
2. Vous avez plusieurs installations de Python ou R sur votre ordinateur, ou bien elles se trouvent dans des endroits inhabituels ou ne sont pas entièrement configurées.
Si vous pouvez exécuter dans un terminal
2. Vous avez plusieurs installations de Python ou R sur votre ordinateur, ou bien elles se trouvent dans des endroits inhabituels ou ne sont pas entièrement configurées. *Ceci est notamment le cas si vous avez utilisé Anaconda pour installer Python et/ou R, comme nous le recommandons.*
Voici comment évaluer votre installation :
1. Ouvrez un nouveau terminal, et essayez d'exécuter les commandes suivantes:
- =python3= et =R= sous Linux et macOS
- =Python= et =R= sous Windows
sans obtenir un message d'erreur, alors vous ne devriez pas avoir à
faire quoi que ce soit.
Si vous n'obtenez pas de message d'erreur, tout va bien et vous ne devriez pas avoir à faire quoi que ce soit pour accéder à Python et R sous Emacs.
2. Si vous avez eu un message d'erreur, il va falloir trouver où vous avez installé Python et/où R. Notez le chemin complet à chaque exécutable - c'est ce qu'il faut insérer dans votre =init.el=. Par exemple, si vous avez installé Anaconda sous =/opt=, et si par la suite vous avez mis Python et R dans l'environnment par défaut, vos exécutables sont à =/opt/anaconda3/bin/python3= et =/opt/anaconda3/bin/R=. S'ils sont dans un environnment qui s'appelle =mooc_rr=, les chemins sont =/opt/anaconda3/envs/mooc_rr/bin/python3= et =/opt/anaconda3/envs/mooc_rr/bin/R=.
Si vous devez modifier =init.el=, regardez bien les commentaires dans le fichier =init.org= pour comprendre comment ça marche.
** Etape 5 : Vérifier si l'installation fonctionne ou non
