diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index b0b421b3c8b4c2e8fdba6ac2091bd079e245eacc..67bb8a6e9b5ce8222e5352b5661b01e347fe9d84 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -293,48 +293,27 @@ This section is illustrated in a [[https://www.fun-mooc.fr/courses/course-v1:inr réplicable avec Emacs/Orgmode"/ in French). Watching it before following the instructions given in this section may help. -Remember, you need a working LaTeX and R environment. If you can't -open a terminal and run the commands =R=, =pdflatex=, and =python=, you will not be -able to generate this document. When being compiled, the article downloads the -corresponding LaTeX packages so you also need to have a working =wget= -command (alternatively, it uses =curl=). Once downloaded, you may still read the -source ([[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org]]) and understand how it works though. +To work with this article stub, you need working installations of LaTeX, R, and Python. If you can't open a terminal and run the commands =R=, =pdflatex=, and =python3=, you will not be able to generate this document. When being compiled, the article downloads the corresponding LaTeX packages, so you must have a working network connection. + +Note for macOS users: Since the article is compiled using =make=, you need to put the Emacs executable on your shell's search path, as explained above under [[*Advanced topics - not required for following the MOOC][advanced topics]]. #+begin_src shell :results output :exports none -make -C replicable_article/ all ../replicable_article.tgz +export FILE_LIST="replicable_article/Makefile replicable_article/article.org replicable_article/biblio.bib replicable_article/article.pdf" +make -C replicable_article/ article.pdf +tar zcf replicable_article.tgz $FILE_LIST #+end_src #+RESULTS: -Download the following [[file:replicable_article.tgz][archive]], uncompress it and simply =make= to generate the -article. You should then be able to open the [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.pdf][resulting article]]. This -is summarized in the following command: -#+begin_src sh :results output :exports both -wget --no-check-certificate -O replicable_article.tgz https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/replicable_article.tgz -tar zxf replicable_article.tgz; cd replicable_article; make ; evince article.pdf -#+end_src +Download the following [[file:replicable_article.tgz][archive]] and uncompress it. The archive contains the compiled article, so you can start by looking at it. + +To rebuild the article, delete =article.pdf=, or rename it to something else. Otherwise the rebuild procedure will simply tell you that the article is already up to date. Then type =make= to build everything from scratch. Open the freshly built =article.pdf= to see if it looks OK. -*Possible issues*: -- If the =make= command fails (especially on Mac), it may be because - Emacs or something else is not correctly installed. In that case, - open the article directly with the following command: - #+begin_src sh :results output :exports both - emacs -q --eval "(setq enable-local-eval t)" --eval "(setq enable-local-variables t)" article.org - #+end_src - and export it to pdf with the following shortcut: =C-c C-e l o= -- If it still doesn't work and emacs complains about not finding ESS, - it may be because you installed ESS in your home instead of - system-wide. In that case, try to remove the =-q= in the previous - command line to load your personal emacs configuration. - -Finally, when you'll be tired of always re-executing all the source -code when exporting, just look for the following line in [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org][article.org]]: +If you get tired of always re-executing all the source code when exporting, look for the following line in [[file:replicable_article/article.org][article.org]]: #+BEGIN_EXAMPLE # #+PROPERTY: header-args :eval never-export #+END_EXAMPLE -If you remove the =# = in the beginning of the line, it will not be a -comment anymore and will indicate org-mode to stop evaluating every -chunk of code when exporting. +If you remove the =# = in the beginning of the line, it will not be a comment anymore and will indicate org-mode to stop evaluating every chunk of code when exporting. * Emacs tips and tricks ** Cheat-sheets diff --git a/module2/ressources/replicable_article.tgz b/module2/ressources/replicable_article.tgz index dc54bc9708e62fd4ceef163f7b35decdc07caa09..5fbaab10a100198b2b8f7899ea926ddc4537223f 100644 Binary files a/module2/ressources/replicable_article.tgz and b/module2/ressources/replicable_article.tgz differ diff --git a/module2/ressources/replicable_article/article.pdf b/module2/ressources/replicable_article/article.pdf index 8e8320500de233fdb7971296a0fcb2f8c362cf68..adb0c5b64a6713727eb3fafd7f0be7c745304f7e 100644 Binary files a/module2/ressources/replicable_article/article.pdf and b/module2/ressources/replicable_article/article.pdf differ
