diff --git a/module2/ressources/replicable_article/article.org b/module2/ressources/replicable_article/article.org index 608cc3a72667aa06ccbee8aee1ef22699ea3f212..2d9cfcc24db73b1432f4ddaf4c890894df147935 100644 --- a/module2/ressources/replicable_article/article.org +++ b/module2/ressources/replicable_article/article.org @@ -52,28 +52,27 @@ reproducible research technology. #+END_abstract * Getting the LaTeX packages :noexport: -#+begin_src shell :results output :exports both -set -e -if which wget; then - wget --no-check-certificate -O IEEEtran.cls http://mirror.ibcp.fr/pub/CTAN/macros/latex/contrib/IEEEtran/IEEEtran.cls - wget --no-check-certificate -O IEEEtran.bst http://mirrors.ctan.org/macros/latex/contrib/IEEEtran/bibtex/IEEEtran.bst -else - if which curl; then - curl -o IEEEtran.cls http://mirror.ibcp.fr/pub/CTAN/macros/latex/contrib/IEEEtran/IEEEtran.cls - curl -o IEEEtran.bst http://mirrors.ctan.org/macros/latex/contrib/IEEEtran/bibtex/IEEEtran.bst - else - echo "Neither wget nor curl was found!!! Get a real OS!" 1>&2 - exit 1 - fi -fi +#+begin_src python :session python :results output :exports both +import urllib.request +import os.path + +def download_urls(url_list): + for url,filename in url_list: + if(not(os.path.isfile(filename))): + urllib.request.urlretrieve(url, filename) + +download_urls([("http://mirrors.ctan.org/macros/latex/contrib/IEEEtran/IEEEtran.cls","IEEEtran.cls"), + ("http://mirrors.ctan.org/macros/latex/contrib/IEEEtran/bibtex/IEEEtran.bst","IEEEtran.bst")]) #+end_src +#+RESULTS: + * Getting the data :noexport: -#+begin_src shell :results output raw :exports both -wget --no-check-certificate -O measurements.txt https://raw.githubusercontent.com/alegrand/M2R-ParallelQuicksort/master/data/sama_2014-10-13/measurements_03%3A47.txt -echo 'file:measurements.txt' +#+begin_src python :session python :results output :exports both +download_urls([("https://raw.githubusercontent.com/alegrand/M2R-ParallelQuicksort/master/data/sama_2014-10-13/measurements_03%3A47.txt","measurements.txt")]) #+end_src +#+RESULTS: * Extracting traces from data files :noexport: #+begin_src python :results output raw :exports both :var input="measurements.txt" output="data.csv"
