diff --git a/module2/ressources/emacs_orgmode.org b/module2/ressources/emacs_orgmode.org index ea25453c5c3f3140a3744715bdd64640a6cc50d9..5a9a8d4b883d613f501d8a594e06ebce1f82c03d 100644 --- a/module2/ressources/emacs_orgmode.org +++ b/module2/ressources/emacs_orgmode.org @@ -6,8 +6,8 @@ #+OPTIONS: num:nil toc:t #+PROPERTY: header-args :eval never-export -*Disclaimer:* The two sections _A simple "/reproducible research/" emacs -configuration_ and _A stub of replicable article_ explain how to set up +*Disclaimer:* The two sections /A simple "reproducible research" emacs configuration/ +and /A stub of replicable article/ explain how to set up emacs/org-mode for this MOOC. These are very important sections in the context of this MOOC. *These sections are illustrated in two out of the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][three video tutorials of this sequence]], and* *which you @@ -59,7 +59,7 @@ which is now deprecated. *Note:* macOS comes with a prehistoric command-line-only version of Emacs located at =/usr/bin/emacs=. It's best to forget about it. - *Option 1*: Install the =.dmg= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]: - https://vigou3.gitlab.io/emacs-modified-macos/. It ships with recent + [[https://vigou3.gitlab.io/emacs-modified-macos/][https://vigou3.gitlab.io/emacs-modified-macos/]]. It ships with recent versions: - Emacs 26.1 - Org-mode 9.1.13 @@ -92,7 +92,7 @@ which is now deprecated. in order to make Emacs accessible directly from =/Applications=. ** Windows Install the =.exe= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]: -https://vigou3.gitlab.io/emacs-modified-windows/. It ships with recent +[[https://vigou3.gitlab.io/emacs-modified-windows/][https://vigou3.gitlab.io/emacs-modified-windows/]]. It ships with recent versions: - Emacs 26.1 - Org-mode 9.1.13 @@ -133,7 +133,7 @@ matplotlib.matplotlib_fname() [[file:emacs_orgmode_images/matplotlib.png]] Open the =matplotlibrc= file and modify the line starting with =backend= -to make it =backend : Agg=/ +to make it =backend : Agg=. ** All platforms: pretty code in HTML export To have code pretty printing when exporting to HTML, you should @@ -306,11 +306,11 @@ channel with many step by step emacs tutorials]]. [[http://company-mode.github.io/][Company-mode]] is a text completion framework for Emacs. It allows to have smart completion in emacs for the most common languages. If you feel this is needed, you should follow the instructions from the -official Web page: http://company-mode.github.io/ +official Web page: [[http://company-mode.github.io/][http://company-mode.github.io/]] *** Magit [[https://magit.vc/][Magit]] is an Emacs interface for Git. Its usage is briefly illustrated -in the context of this MOOC in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][video tutorial]] (/"Utilisation -Emacs/git"/ in French). +in the context of this MOOC in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][video tutorial]] +("/Utilisation Emacs/git/" in French). It is very powerful and we use it on a daily basis but you should definitely understand what git does behind the scenes beforehand. If
